[PATCH v1 0/6] [libbsd] Fix e1000 driver for i386 in master and 5
Joel Sherrill
joel at rtems.org
Fri Aug 14 22:31:45 UTC 2020
On Fri, Aug 14, 2020 at 4:42 PM Chris Johns <chrisj at rtems.org> wrote:
> On 15/8/20 5:57 am, Jan Sommer wrote:
> > Hello,
> > I finally got around to port the e1000 driver fixes which are already
> > present in the 5-freebsd-12 branch of rtems-libbsd also for the master
> > (and 5) branch.
> Thanks. I will push these soon.
> I am not sure if the 5 branch in the rtems-libbsd.git repo is right and if
> it
> should be made from the 5-freebsd-12 branch? I feel it is currently
> confusing
> but either way it has issues.
If I remember correctly, Sebastian told me 5 was FreeBSD master on RTEMS 5.
If that's right, it would have been better with the longer name
5-freebsd-master since
we use 5 as the name for other repos to indicate trusted "5".
--joel
> Chris
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200814/a61a0302/attachment.html>
