Context switching through an ISR in RTEMS
Utkarsh Rai
utkarsh.rai60 at gmail.com
Sun Aug 16 03:02:53 UTC 2020
On Sun, Aug 16, 2020 at 6:12 AM Utkarsh Rai <utkarsh.rai60 at gmail.com> wrote:
> On Sat, Aug 15, 2020 at 7:26 PM Gedare Bloom <gedare at rtems.org> wrote:
>> On Sat, Aug 15, 2020 at 6:26 AM Utkarsh Rai <utkarsh.rai60 at gmail.com>
>> wrote:
>> > On Thu, Aug 13, 2020 at 5:10 AM Utkarsh Rai <utkarsh.rai60 at gmail.com>
>> wrote:
>> >> Thanks, I'll check them out.
>> >> On Thu, Aug 13, 2020 at 12:56 AM Gedare Bloom <gedare at rtems.org>
>> wrote:
>> >>> On Wed, Aug 12, 2020 at 11:33 AM Utkarsh Rai <utkarsh.rai60 at gmail.com>
>> wrote:
>> >>> > Hello,
>> >>> > I have been testing my code for thread stack isolation against
>> various tests( Some written by me, and remaining already present). One of
>> the limitations that I have found is that I encounter fatal errors whenever
>> a context switch takes place through an ISR. Can you please explain how the
>> context switching procedure works when an interrupt occurs. When I use gdb
>> for stepping through the code it asynchronously moves to context switching
>> code from the executing thread( for example psx16 test).
>> >>> > For thread stack protection, the part that deals with context
>> switching simply 'sets 'the memory entries of the heir stack and 'unsets'
>> that of the executing stack.
>> >>> There are two issues to start: interrupt stacks and dispatching from
>> an ISR.
>> >>> I think you can start by reading some of the documentation:
>> https://docs.rtems.org/branches/master/c-user/interrupt_manager.html#processing-an-interrupt
>> https://docs.rtems.org/branches/master/c-user/scheduling_concepts.html#dispatching-tasks
>> https://docs.rtems.org/branches/master/c-user/config/general.html#configure-interrupt-stack-size
>> https://docs.rtems.org/branches/master/cpu-supplement/port.html#interrupt-processing
>> >>> You can also find some material in rtems-docs.git/porting -- I don't
>> >>> know where that gets generated.
>> >>> Continue to ask questions, and writing blog posts.
>> > So after going through the materials, I was able to understand how an
>> ISR is registered, ISR stack initialization. What is still not clear to me
>> is what are the differences between dispatching a task in ISR different
>> and a normal context-switch?
>> > For example the psxsignal06 test, we wait for a signal here, on
>> setting the breakpoint at the context switch code (cpu_asm.S), after this
>> line, I find that the heir context stack is the ISR stack. The next thread
>> is dispatched from this ISR but as soon as I unset the memory attributes of
>> the ISR stack I get a fatal error. One possible reason is that the ISR
>> stack is not page aligned and unsettling its attributes unsets nearby
>> memory regions. Is there something else that I am missing?
>> what else is on the same page as the ISR stack?
> The idle thread stack is between 0x202e40 to 0x203e40 and the ISR stack is
> between 0x203e40 to 0x204e40. So when we unset the memory for the ISR it
> unsets between 0x203000 to 0x205000, I think this may be the problem.
>> Not quite related, you'll need to also make sure to map the ISR stack
>> back in during ISR Handling, before using it.
> When the ISR gets called for the first time, it already has R/W permission
> and for subsequent context switches it's memory entry is accordingly
> set/unset.
The idle thread stack and the ISR stack are placed at these addresses with
the BSP specific linker script as "rtemsstack.idle" and
"rtemsstack.interrupt". So to make them page-aligned we may have to make
changes in the lnker script.
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200816/4d30596e/attachment.html>
