[PATCH 1/5] eng: Add test case attributes
Sebastian Huber
Wed Aug 19 09:14:19 UTC 2020
Update #3715.
eng/req/items.rst | 18 ++++++++++++++++++
1 file changed, 18 insertions(+)
diff --git a/eng/req/items.rst b/eng/req/items.rst
index cba6cc6..d2b2860 100644
--- a/eng/req/items.rst
+++ b/eng/req/items.rst
@@ -1716,10 +1716,20 @@ test-brief
The attribute value shall be an optional string. If the value is present,
then it shall be the test case brief description.
+test-cleanup
+ The attribute value shall be an optional string. If the value is present,
+ then it shall be the test cleanup code. The code is placed in the test
+ action loop body after the test post-condition checks.
test-context
The attribute value shall be a list. Each list element shall be an
:ref:`SpecTypeActionRequirementTestContextMember`.
+test-context-support
+ then it shall be the test context support code. The context support code
+ is placed at file scope before the test context definition.
test-description
then it shall be the test case description.
@@ -1738,6 +1748,11 @@ test-local-includes
test-name
The attribute value shall be a :ref:`SpecTypeTestName`.
+test-prepare
+ then it shall be the early test preparation code. The code is placed in
+ the test action loop body before the test pre-condition preparations.
test-setup
:ref:`SpecTypeActionRequirementTestFixtureMethod`.
@@ -1841,6 +1856,7 @@ Please have a look at the following example:
test-action: |
/* Call the function of the action */
test-brief: null
+ test-cleanup: null
test-context:
- brief: null
description: null
@@ -1848,11 +1864,13 @@ Please have a look at the following example:
- brief: null
description: null
member: option_type option
+ test-context-support: null
test-description: null
test-header: null
test-includes: []
test-local-includes: []
test-name: RedGreenData
+ test-prepare: null
test-setup: null
test-stop: null
test-support: null
2.26.2
