[PATCH 3/5] eng: Add test header to test case
Sebastian Huber
Wed Aug 19 09:14:21 UTC 2020
Update #3715.
eng/req/items.rst | 159 ++++++++++++++++++++++++----------------------
1 file changed, 82 insertions(+), 77 deletions(-)
diff --git a/eng/req/items.rst b/eng/req/items.rst
index 030f47f..878c47e 100644
--- a/eng/req/items.rst
+++ b/eng/req/items.rst
@@ -1735,7 +1735,7 @@ test-description
then it shall be the test case description.
test-header
- The attribute value shall be an :ref:`SpecTypeActionRequirementTestHeader`.
+ The attribute value shall be a :ref:`SpecTypeTestHeader`.
test-includes
The attribute value shall be a list of strings. It shall be a list of
@@ -2088,6 +2088,9 @@ target
The attribute value shall be a string. It shall be the path to the
generated target test case source file.
+test-header
.. _SpecTypeTestPlatformItemType:
Test Platform Item Type
@@ -2344,80 +2347,6 @@ This type is used by the following types:
* :ref:`SpecTypeActionRequirementItemType`
-.. _SpecTypeActionRequirementTestHeader:
-Action Requirement Test Header
-A value of this type shall be of one of the following variants:
-* The value may be a set of attributes. This set of attributes specifies an
- action requirement test header. In case a test header is specified, then
- instead of a test case a test run function will be generated. The test run
- function will be declared in the test header target file and defined in the
- test source target file. The test run function can be used to compose test
- cases. The test header file is not automatically included in the test source
- file. It should be added to the includes or local includes of the test. All
- explicit attributes shall be specified. The explicit attributes for this type
- are:
- code
- The attribute value shall be an optional string. If the value is present,
- then it shall be the test case header code. The header code is placed at
- file scope after the test enum declarations and before the test run
- function declaration.
- includes
- The attribute value shall be a list of strings. It shall be a list of
- header files included by the header file via ``#include <...>``.
- local-includes
- header files included by the header file via ``#include "..."``.
- run-params
- The attribute value shall be a list. Each list element shall be an
- :ref:`SpecTypeActionRequirementTestRunParameter`.
- target
- The attribute value shall be a string. It shall be the path to the
- generated test header file.
-* There may by be no value (null).
-This type is used by the following types:
-* :ref:`SpecTypeActionRequirementItemType`
-.. _SpecTypeActionRequirementTestRunParameter:
-Action Requirement Test Run Parameter
-This set of attributes specifies a parameter for the test run function. The
-parameter is also added as a member to the test context, see
-:ref:`SpecTypeActionRequirementTestContextMember`. All explicit attributes
-shall be specified. The explicit attributes for this type are:
-description
- The attribute value shall be a string. It shall be the description of the
- parameter.
-dir
- The attribute value shall be an :ref:`SpecTypeInterfaceParameterDirection`.
-name
- The attribute value shall be a string. It shall be the parameter name.
-specifier
- The attribute value shall be a string. It shall be the complete function
- parameter specifier. Use ``${.:name}`` for the parameter name, for example
- ``"int ${.:name}"``.
-* :ref:`SpecTypeActionRequirementTestHeader`
.. _SpecTypeActionRequirementTransition:
Action Requirement Transition
@@ -3903,10 +3832,10 @@ A value of this type shall be of one of the following variants:
-* :ref:`SpecTypeActionRequirementTestRunParameter`
* :ref:`SpecTypeInterfaceParameter`
+* :ref:`SpecTypeTestRunParameter`
.. _SpecTypeInterfacePlacementLinkRole:
Interface Placement Link Role
@@ -4956,6 +4885,82 @@ This type is used by the following types:
* :ref:`SpecTypeTestCaseAction`
+.. _SpecTypeTestHeader:
+Test Header
+A value of this type shall be of one of the following variants:
+* The value may be a set of attributes. This set of attributes specifies a test
+ header. In case a test header is specified, then instead of a test case a
+ test run function will be generated. The test run function will be declared
+ in the test header target file and defined in the test source target file.
+ The test run function can be used to compose test cases. The test header
+ file is not automatically included in the test source file. It should be
+ added to the includes or local includes of the test. All explicit attributes
+ shall be specified. The explicit attributes for this type are:
+ code
+ The attribute value shall be an optional string. If the value is present,
+ then it shall be the test header code. The header code is placed at file
+ scope after the general test declarations and before the test run
+ function declaration.
+ includes
+ The attribute value shall be a list of strings. It shall be a list of
+ header files included by the header file via ``#include <...>``.
+ local-includes
+ header files included by the header file via ``#include "..."``.
+ run-params
+ The attribute value shall be a list. Each list element shall be a
+ :ref:`SpecTypeTestRunParameter`.
+ target
+ The attribute value shall be a string. It shall be the path to the
+ generated test header file.
+* There may by be no value (null).
+This type is used by the following types:
+* :ref:`SpecTypeActionRequirementItemType`
+* :ref:`SpecTypeTestCaseItemType`
+.. _SpecTypeTestRunParameter:
+Test Run Parameter
+This set of attributes specifies a parameter for the test run function. In case
+this parameter is used in an :ref:`SpecTypeActionRequirementItemType` item,
+then the parameter is also added as a member to the test context, see
+:ref:`SpecTypeActionRequirementTestContextMember`. All explicit attributes
+shall be specified. The explicit attributes for this type are:
+description
+ The attribute value shall be a string. It shall be the description of the
+ parameter.
+dir
+ The attribute value shall be an :ref:`SpecTypeInterfaceParameterDirection`.
+name
+ The attribute value shall be a string. It shall be the parameter name.
+specifier
+ The attribute value shall be a string. It shall be the complete function
+ parameter specifier. Use ``${.:name}`` for the parameter name, for example
+ ``"int ${.:name}"``.
+* :ref:`SpecTypeTestHeader`
.. _SpecTypeUID:
UID
2.26.2
