[PATCH] Add Strong APA test
Richi Dubey
richidubey at gmail.com
Wed Aug 19 15:47:54 UTC 2020
testsuites/smptests/smpstrongapa01/init.c | 85 +++++++++++++----------
1 file changed, 49 insertions(+), 36 deletions(-)
diff --git a/testsuites/smptests/smpstrongapa01/init.c b/testsuites/smptests/smpstrongapa01/init.c
index bf8bc05231..89cc6404b9 100644
--- a/testsuites/smptests/smpstrongapa01/init.c
+++ b/testsuites/smptests/smpstrongapa01/init.c
@@ -1,38 +1,40 @@
- * Copyright (c) 2016, 2017 embedded brains GmbH. All rights reserved.
+ * Copyright (c) 2020 Richi Dubey
+ * All rights reserved.
- * embedded brains GmbH
- * Dornierstr. 4
- * 82178 Puchheim
- * Germany
- * <rtems at embedded-brains.de>
+ * richidubey at gmail.com
* The license and distribution terms for this file may be
* found in the file LICENSE in this distribution or at
* http://www.rtems.org/license/LICENSE.
#ifdef HAVE_CONFIG_H
#include "config.h"
#endif
-#include "tmacros.h"
+#include <tmacros.h>
const char rtems_test_name[] = "SMPSTRONGAPA 1";
-#define CPU_COUNT 4
+#define CPU_COUNT 3
-#define TASK_COUNT (3 * CPU_COUNT)
+#define TASK_COUNT 4
#define P(i) (UINT32_C(2) + i)
#define ALL ((UINT32_C(1) << CPU_COUNT) - 1)
-#define IDLE UINT8_C(255)
+#define A(cpu0, cpu1, cpu2) ((cpu2 << 2) | (cpu1 << 1) | cpu0)
-#define NAME rtems_build_name('S', 'A', 'P', 'A')
+typedef enum {
+ T0,
+ T1,
+ T2,
+ T3,
+ IDLE
+} task_index;
typedef struct {
enum {
@@ -43,7 +45,7 @@ typedef struct {
KIND_UNBLOCK
} kind;
- size_t index;
+ task_index index;
struct {
rtems_task_priority priority;
@@ -65,54 +67,62 @@ typedef struct {
KIND_RESET, \
0, \
{ 0 }, \
- { IDLE, IDLE, IDLE, IDLE } \
+ { IDLE, IDLE, IDLE} \
-#define SET_PRIORITY(index, prio, cpu0, cpu1, cpu2, cpu3) \
+#define SET_PRIORITY(index, prio, cpu0, cpu1, cpu2) \
KIND_SET_PRIORITY, \
index, \
{ .priority = prio }, \
- { cpu0, cpu1, cpu2, cpu3 } \
+ { cpu0, cpu1, cpu2 } \
-#define SET_AFFINITY(index, aff, cpu0, cpu1, cpu2, cpu3) \
+#define SET_AFFINITY(index, aff, cpu0, cpu1, cpu2) \
KIND_SET_AFFINITY, \
index, \
{ .cpu_set = aff }, \
-#define BLOCK(index, cpu0, cpu1, cpu2, cpu3) \
+#define BLOCK(index, cpu0, cpu1, cpu2) \
KIND_BLOCK, \
index, \
{ 0 }, \
-#define UNBLOCK(index, cpu0, cpu1, cpu2, cpu3) \
+#define UNBLOCK(index, cpu0, cpu1, cpu2) \
KIND_UNBLOCK, \
index, \
{ 0 }, \
static const test_action test_actions[] = {
RESET,
- UNBLOCK( 0, 0, IDLE, IDLE, IDLE),
- UNBLOCK( 1, 0, 1, IDLE, IDLE),
- UNBLOCK( 2, 0, 1, 2, IDLE),
- UNBLOCK( 3, 0, 1, 2, 3),
- UNBLOCK( 5, 0, 1, 2, 3),
- SET_PRIORITY( 3, P(4), 0, 1, 2, 3),
- SET_PRIORITY( 5, P(3), 0, 1, 2, 5),
- BLOCK( 5, 0, 1, 2, 3),
- SET_AFFINITY( 5, ALL, 0, 1, 2, 3),
- RESET,
+ UNBLOCK( T0, T0, IDLE, IDLE),
+ UNBLOCK( T1, T0, T1, IDLE),
+ UNBLOCK( T2, T0, T1, T2),
+ UNBLOCK( T3, T0, T1, T2),
+ SET_PRIORITY( T0, P(0), T0, T1, T2),
+ SET_PRIORITY( T1, P(1), T0, T1, T2),
+ SET_PRIORITY( T3, P(3), T0, T1, T2),
+ * Introduce Task 2 intially with lowest priority to imitate late arrival
+ SET_PRIORITY( T2, P(4), T0, T1, T3),
+ SET_AFFINITY( T0, ALL, T0, T1, T3),
+ SET_AFFINITY( T1, A(0, 1, 1), T0, T1, T3),
+ SET_AFFINITY( T2, A(1, 0, 0), T0, T1, T3),
+ SET_AFFINITY( T3, A(0, 1, 1), T0, T1, T3),
+ * Show that higher priority task gets dislodged from its processor
+ SET_PRIORITY( T2, P(2), T2, T1, T0),
RESET
@@ -182,7 +192,7 @@ static void check_cpu_allocations(test_context *ctx, const test_action *action)
size_t i;
for (i = 0; i < CPU_COUNT; ++i) {
- size_t e;
+ task_index e;
const Per_CPU_Control *c;
const Thread_Control *h;
@@ -279,7 +289,7 @@ static void test(void)
for (i = 0; i < TASK_COUNT; ++i) {
sc = rtems_task_create(
- NAME,
+ rtems_build_name(' ', ' ', 'T', '0' + i),
P(i),
RTEMS_MINIMUM_STACK_SIZE,
RTEMS_DEFAULT_MODES,
@@ -292,7 +302,10 @@ static void test(void)
rtems_test_assert(sc == RTEMS_SUCCESSFUL);
- sc = rtems_timer_create(NAME, &ctx->timer_id);
+ sc = rtems_timer_create(
+ rtems_build_name('A', 'C', 'T', 'N'),
+ &ctx->timer_id
sc = rtems_timer_fire_after(ctx->timer_id, 1, timer, ctx);
2.17.1
