[PATCH] build: Use Python tarfile instead of pax
Wed Aug 19 16:33:44 UTC 2020
On 19/08/2020 16:12, Joel Sherrill wrote:
> On Wed, Aug 19, 2020 at 8:38 AM Sebastian Huber
> <sebastian.huber at embedded-brains.de
> <mailto:sebastian.huber at embedded-brains.de>> wrote:
>     On 19/08/2020 14:44, Joel Sherrill wrote:
>     > On Tue, Aug 18, 2020 at 5:52 PM Chris Johns <chrisj at rtems.org
>     <mailto:chrisj at rtems.org>
>     > <mailto:chrisj at rtems.org <mailto:chrisj at rtems.org>>> wrote:
>     >     On 18/8/20 9:16 pm, Sebastian Huber wrote:
>     >     > This patch is for the new build system.
>     >     <stand><clap><clap><clap>
>     >     Looking forward to this change.
>     > Me too.
>     > We determined that the Python tar defaulted to " POSIX.1-2001 (pax)
>     > format"
>     > which is newer than the "IEEE Std 1003.2 (“POSIX.2”)" from the
>     pax man
>     > page as ustar as best I can tell.
>     I was not really sure which format we need. The
>     +            tar = tarfile.TarFile(
>     +                task.outputs[0].abspath(), "w",
>     format=tarfile.USTAR_FORMAT
>     seems to work.
> And that is my concern. If you switched to Python tar but didn't change
> the format from the 1988 USTAR to the 2001 PAX tar, then we didn't
> fix the bug. I think the RTEMS side has to be updated to understand
> the 2001 header also.
I didn't want to fix a bug with this patch. My aim was to get rid of a
tool which is not installed by default on Linux distributions (and also
Windows). My goal is to build RTEMS only using Python (hopefully 3 in
the near future) and tools installed by RSB.
