[PATCH] ada: Add missing attributes
Wed Aug 19 17:20:39 UTC 2020
Looks good. I forgot about these with the barrier change... I guess
there has been some bitrot in here. I wonder if there is an easier way
to remember to keep this updated.
On Tue, Aug 18, 2020 at 10:49 PM Sebastian Huber
>  cpukit/include/adainclude/rtems.ads | 9 +++++++++
>  1 file changed, 9 insertions(+)
> diff --git a/cpukit/include/adainclude/rtems.ads b/cpukit/include/adainclude/rtems.ads
> index 5069c36011..0b4b3e7e5f 100644
> --- a/cpukit/include/adainclude/rtems.ads
> +++ b/cpukit/include/adainclude/rtems.ads
> @@ -201,6 +201,15 @@ pragma Elaborate_Body (RTEMS);
>     Inherit_Priority        : constant RTEMS.Attribute := 16#00000040#;
>     No_Priority_Ceiling     : constant RTEMS.Attribute := 16#00000000#;
>     Priority_Ceiling        : constant RTEMS.Attribute := 16#00000080#;
> +   No_Multiprocessor_Resource_Sharing
> +                           : constant RTEMS.Attribute := 16#00000000#;
> +   Multiprocessor_Resource_Sharing
> +                           : constant RTEMS.Attribute := 16#00000100#;
> +   Barrier_Manual_Release  : constant RTEMS.Attribute := 16#00000000#;
> +   Barrier_Automatic_Release
> +                           : constant RTEMS.Attribute := 16#00000200#;
> +   Application_Task        : constant RTEMS.Attribute := 16#00000000#;
> +   System_Task             : constant RTEMS.Attribute := 16#00008000#;
>     function Interrupt_Level (
>        Level : in     RTEMS.Unsigned32
> 2.26.2
> devel mailing list
> devel at rtems.org
