[PATCH 00/16] c-user: Split up chapter files
Thu Aug 20 10:18:49 UTC 2020
This patch set is a preparation to automatically generate parts of the
documentation (introduction.rst and directives.rst) in the future from
specification items.
Sebastian Huber (16):
  c-user: Split up semaphore manager
  c-user: Split up event manager
  c-user: Split up barrier manager
  c-user: Split up clock manager
  c-user: Split up dual-ported memory manager
  c-user: Split up interrupt manager
  c-user: Split up IO manager
  c-user: Split up message manager
  c-user: Split up partition manager
  c-user: Split up rate-monotonic manager
  c-user: Split up region manager
  c-user: Split up signal manager
  c-user: Split up task manager
  c-user: Split up timer manager
  c-user: Split up user extensions manager
  c-user: Split up scheduling concepts
 c-user/barrier/background.rst                 |   68 +
 .../directives.rst}                           |  169 +--
 c-user/barrier/index.rst                      |   14 +
 c-user/barrier/introduction.rst               |   20 +
 c-user/barrier/operations.rst                 |   60 +
 c-user/clock/background.rst                   |   96 ++
 .../directives.rst}                           |  238 +---
 c-user/clock/index.rst                        |   15 +
 c-user/clock/introduction.rst                 |   36 +
 c-user/clock/operations.rst                   |   78 ++
 c-user/dpmem/background.rst                   |   23 +
 .../directives.rst}                           |   84 --
 c-user/dpmem/index.rst                        |   16 +
 c-user/dpmem/introduction.rst                 |   20 +
 c-user/dpmem/operations.rst                   |   44 +
 c-user/event/background.rst                   |   96 ++
 c-user/event/directives.rst                   |  142 +++
 c-user/event/index.rst                        |   15 +
 c-user/event/introduction.rst                 |   13 +
 c-user/event/operations.rst                   |   63 +
 c-user/event_manager.rst                      |  309 -----
 c-user/index.rst                              |   32 +-
 c-user/intr/background.rst                    |  106 ++
 .../directives.rst}                           |  251 ----
 c-user/intr/index.rst                         |   15 +
 c-user/intr/introduction.rst                  |   37 +
 c-user/intr/operations.rst                    |  112 ++
 c-user/io/background.rst                      |  162 +++
 c-user/{io_manager.rst => io/directives.rst}  |  215 ----
 c-user/io/index.rst                           |   16 +
 c-user/io/introduction.rst                    |   30 +
 c-user/io/operations.rst                      |   26 +
 c-user/message/background.rst                 |   91 ++
 .../directives.rst}                           |  205 ----
 c-user/message/index.rst                      |   16 +
 c-user/message/introduction.rst               |   28 +
 c-user/message/operations.rst                 |   89 ++
 c-user/part/background.rst                    |   50 +
 .../directives.rst}                           |  120 --
 c-user/part/index.rst                         |   15 +
 c-user/part/introduction.rst                  |   19 +
 c-user/part/operations.rst                    |   55 +
 c-user/rate_monotonic_manager.rst             | 1091 -----------------
 c-user/ratemon/background.rst                 |  390 ++++++
 c-user/ratemon/directives.rst                 |  474 +++++++
 c-user/ratemon/index.rst                      |   16 +
 c-user/ratemon/introduction.rst               |   33 +
 c-user/ratemon/operations.rst                 |  200 +++
 c-user/region/background.rst                  |   87 ++
 .../directives.rst}                           |  213 ----
 c-user/region/index.rst                       |   15 +
 c-user/region/introduction.rst                |   29 +
 c-user/region/operations.rst                  |  101 ++
 c-user/sched/background.rst                   |  327 +++++
 c-user/sched/directives.rst                   |  424 +++++++
 c-user/sched/index.rst                        |   19 +
 c-user/sched/introduction.rst                 |   42 +
 c-user/sched/smp-schedulers.rst               |   69 ++
 c-user/sched/uniprocessor-schedulers.rst      |  113 ++
 c-user/scheduling_concepts.rst                |  968 ---------------
 c-user/sem/background.rst                     |  180 +++
 .../directives.rst}                           |  309 -----
 c-user/sem/index.rst                          |   18 +
 c-user/sem/introduction.rst                   |   25 +
 c-user/sem/operations.rst                     |  105 ++
 c-user/signal/background.rst                  |  112 ++
 c-user/signal/directives.rst                  |  126 ++
 c-user/signal/index.rst                       |   15 +
 c-user/signal/introduction.rst                |   13 +
 c-user/signal/operations.rst                  |   75 ++
 c-user/signal_manager.rst                     |  322 -----
 c-user/tasks/background.rst                   |  390 ++++++
 .../directives.rst}                           |  625 ----------
 c-user/tasks/index.rst                        |   15 +
 c-user/tasks/introduction.rst                 |   50 +
 c-user/tasks/operations.rst                   |  192 +++
 c-user/timer/background.rst                   |   71 ++
 .../directives.rst}                           |  180 ---
 c-user/timer/index.rst                        |   15 +
 c-user/timer/introduction.rst                 |   29 +
 c-user/timer/operations.rst                   |   84 ++
 .../background.rst}                           |  161 ---
 c-user/userext/directives.rst                 |  143 +++
 c-user/userext/index.rst                      |   16 +
 c-user/userext/introduction.rst               |   17 +
 85 files changed, 5759 insertions(+), 5449 deletions(-)
 create mode 100644 c-user/barrier/background.rst
 rename c-user/{barrier_manager.rst => barrier/directives.rst} (55%)
 create mode 100644 c-user/barrier/index.rst
 create mode 100644 c-user/barrier/introduction.rst
 create mode 100644 c-user/barrier/operations.rst
 create mode 100644 c-user/clock/background.rst
 rename c-user/{clock_manager.rst => clock/directives.rst} (65%)
 create mode 100644 c-user/clock/index.rst
 create mode 100644 c-user/clock/introduction.rst
 create mode 100644 c-user/clock/operations.rst
 create mode 100644 c-user/dpmem/background.rst
 rename c-user/{dual_ports_memory_manager.rst => dpmem/directives.rst} (64%)
 create mode 100644 c-user/dpmem/index.rst
 create mode 100644 c-user/dpmem/introduction.rst
 create mode 100644 c-user/dpmem/operations.rst
 create mode 100644 c-user/event/background.rst
 create mode 100644 c-user/event/directives.rst
 create mode 100644 c-user/event/index.rst
 create mode 100644 c-user/event/introduction.rst
 create mode 100644 c-user/event/operations.rst
 delete mode 100644 c-user/event_manager.rst
 create mode 100644 c-user/intr/background.rst
 rename c-user/{interrupt_manager.rst => intr/directives.rst} (61%)
 create mode 100644 c-user/intr/index.rst
 create mode 100644 c-user/intr/introduction.rst
 create mode 100644 c-user/intr/operations.rst
 create mode 100644 c-user/io/background.rst
 rename c-user/{io_manager.rst => io/directives.rst} (61%)
 create mode 100644 c-user/io/index.rst
 create mode 100644 c-user/io/introduction.rst
 create mode 100644 c-user/io/operations.rst
 create mode 100644 c-user/message/background.rst
 rename c-user/{message_manager.rst => message/directives.rst} (69%)
 create mode 100644 c-user/message/index.rst
 create mode 100644 c-user/message/introduction.rst
 create mode 100644 c-user/message/operations.rst
 create mode 100644 c-user/part/background.rst
 rename c-user/{partition_manager.rst => part/directives.rst} (70%)
 create mode 100644 c-user/part/index.rst
 create mode 100644 c-user/part/introduction.rst
 create mode 100644 c-user/part/operations.rst
 delete mode 100644 c-user/rate_monotonic_manager.rst
 create mode 100644 c-user/ratemon/background.rst
 create mode 100644 c-user/ratemon/directives.rst
 create mode 100644 c-user/ratemon/index.rst
 create mode 100644 c-user/ratemon/introduction.rst
 create mode 100644 c-user/ratemon/operations.rst
 create mode 100644 c-user/region/background.rst
 rename c-user/{region_manager.rst => region/directives.rst} (66%)
 create mode 100644 c-user/region/index.rst
 create mode 100644 c-user/region/introduction.rst
 create mode 100644 c-user/region/operations.rst
 create mode 100644 c-user/sched/background.rst
 create mode 100644 c-user/sched/directives.rst
 create mode 100644 c-user/sched/index.rst
 create mode 100644 c-user/sched/introduction.rst
 create mode 100644 c-user/sched/smp-schedulers.rst
 create mode 100644 c-user/sched/uniprocessor-schedulers.rst
 delete mode 100644 c-user/scheduling_concepts.rst
 create mode 100644 c-user/sem/background.rst
 rename c-user/{semaphore_manager.rst => sem/directives.rst} (64%)
 create mode 100644 c-user/sem/index.rst
 create mode 100644 c-user/sem/introduction.rst
 create mode 100644 c-user/sem/operations.rst
 create mode 100644 c-user/signal/background.rst
 create mode 100644 c-user/signal/directives.rst
 create mode 100644 c-user/signal/index.rst
 create mode 100644 c-user/signal/introduction.rst
 create mode 100644 c-user/signal/operations.rst
 delete mode 100644 c-user/signal_manager.rst
 create mode 100644 c-user/tasks/background.rst
 rename c-user/{task_manager.rst => tasks/directives.rst} (63%)
 create mode 100644 c-user/tasks/index.rst
 create mode 100644 c-user/tasks/introduction.rst
 create mode 100644 c-user/tasks/operations.rst
 create mode 100644 c-user/timer/background.rst
 rename c-user/{timer_manager.rst => timer/directives.rst} (64%)
 create mode 100644 c-user/timer/index.rst
 create mode 100644 c-user/timer/introduction.rst
 create mode 100644 c-user/timer/operations.rst
 rename c-user/{user_extensions.rst => userext/background.rst} (77%)
 create mode 100644 c-user/userext/directives.rst
 create mode 100644 c-user/userext/index.rst
 create mode 100644 c-user/userext/introduction.rst
2.26.2
