[PATCH 02/16] c-user: Split up event manager
Sebastian Huber
Thu Aug 20 10:18:51 UTC 2020
This makes it easier to automatically generate parts of the manager
documentation in the future.
Update #3993.
c-user/event/background.rst | 96 +++++++++++
c-user/event/directives.rst | 142 ++++++++++++++++
c-user/event/index.rst | 15 ++
c-user/event/introduction.rst | 13 ++
c-user/event/operations.rst | 63 +++++++
c-user/event_manager.rst | 309 ----------------------------------
c-user/index.rst | 2 +-
7 files changed, 330 insertions(+), 310 deletions(-)
create mode 100644 c-user/event/background.rst
create mode 100644 c-user/event/directives.rst
create mode 100644 c-user/event/index.rst
create mode 100644 c-user/event/introduction.rst
create mode 100644 c-user/event/operations.rst
delete mode 100644 c-user/event_manager.rst
diff --git a/c-user/event/background.rst b/c-user/event/background.rst
new file mode 100644
index 0000000..f14e55f
--- /dev/null
+++ b/c-user/event/background.rst
@@ -0,0 +1,96 @@
+.. SPDX-License-Identifier: CC-BY-SA-4.0
+.. Copyright (C) 1988, 2008 On-Line Applications Research Corporation (OAR)
+Background
+.. index:: event flag, definition
+.. index:: event set, definition
+.. index:: rtems_event_set
+Event Sets
+An event flag is used by a task (or ISR) to inform another task of the
+occurrence of a significant situation. Thirty-two event flags are associated
+with each task. A collection of one or more event flags is referred to as an
+event set. The data type ``rtems_event_set`` is used to manage event sets.
+The application developer should remember the following key characteristics of
+event operations when utilizing the event manager:
+- Events provide a simple synchronization facility.
+- Events are aimed at tasks.
+- Tasks can wait on more than one event simultaneously.
+- Events are independent of one another.
+- Events do not hold or transport data.
+- Events are not queued. In other words, if an event is sent more than once to
+ a task before being received, the second and subsequent send operations to
+ that same task have no effect.
+An event set is posted when it is directed (or sent) to a task. A pending
+event is an event that has been posted but not received. An event condition is
+used to specify the event set which the task desires to receive and the
+algorithm which will be used to determine when the request is satisfied. An
+event condition is satisfied based upon one of two algorithms which are
+selected by the user. The ``RTEMS_EVENT_ANY`` algorithm states that an event
+condition is satisfied when at least a single requested event is posted. The
+``RTEMS_EVENT_ALL`` algorithm states that an event condition is satisfied when
+every requested event is posted.
+.. index:: event condition, building
+.. index:: event set, building
+Building an Event Set or Condition
+An event set or condition is built by a bitwise OR of the desired events. The
+set of valid events is ``RTEMS_EVENT_0`` through ``RTEMS_EVENT_31``. If an
+event is not explicitly specified in the set or condition, then it is not
+present. Events are specifically designed to be mutually exclusive, therefore
+bitwise OR and addition operations are equivalent as long as each event appears
+exactly once in the event set list.
+For example, when sending the event set consisting of ``RTEMS_EVENT_6``,
+``RTEMS_EVENT_15``, and ``RTEMS_EVENT_31``, the event parameter to the
+``rtems_event_send`` directive should be ``RTEMS_EVENT_6 | RTEMS_EVENT_15 |
+RTEMS_EVENT_31``.
+Building an EVENT_RECEIVE Option Set
+In general, an option is built by a bitwise OR of the desired option
+components. The set of valid options for the ``rtems_event_receive`` directive
+are listed in the following table:
+.. list-table::
+ :class: rtems-table
+ * - ``RTEMS_WAIT``
+ - task will wait for event (default)
+ * - ``RTEMS_NO_WAIT``
+ - task should not wait
+ * - ``RTEMS_EVENT_ALL``
+ - return after all events (default)
+ * - ``RTEMS_EVENT_ANY``
+ - return after any events
+Option values are specifically designed to be mutually exclusive, therefore
+bitwise OR and addition operations are equivalent as long as each option
+appears exactly once in the component list. An option listed as a default is
+not required to appear in the option list, although it is a good programming
+practice to specify default options. If all defaults are desired, the option
+``RTEMS_DEFAULT_OPTIONS`` should be specified on this call.
+This example demonstrates the option parameter needed to poll for all events in
+a particular event condition to arrive. The option parameter passed to the
+``rtems_event_receive`` directive should be either ``RTEMS_EVENT_ALL |
+RTEMS_NO_WAIT`` or ``RTEMS_NO_WAIT``. The option parameter can be set to
+``RTEMS_NO_WAIT`` because ``RTEMS_EVENT_ALL`` is the default condition for
+``rtems_event_receive``.
diff --git a/c-user/event/directives.rst b/c-user/event/directives.rst
index 0000000..ef94115
--- /dev/null
+++ b/c-user/event/directives.rst
@@ -0,0 +1,142 @@
+Directives
+This section details the event manager's directives. A subsection is dedicated
+to each of this manager's directives and describes the calling sequence,
+related constants, usage, and status codes.
+.. raw:: latex
+ \clearpage
+.. index:: send event set to a task
+.. index:: rtems_event_send
+.. _rtems_event_send:
+EVENT_SEND - Send event set to a task
+CALLING SEQUENCE:
+ .. code-block:: c
+ rtems_status_code rtems_event_send (
+ rtems_id id,
+ rtems_event_set event_in
+DIRECTIVE STATUS CODES:
+ .. list-table::
+ * - ``RTEMS_SUCCESSFUL``
+ - event set sent successfully
+ * - ``RTEMS_INVALID_ID``
+ - invalid task id
+DESCRIPTION:
+ This directive sends an event set, event_in, to the task specified by id.
+ If a blocked task's input event condition is satisfied by this directive,
+ then it will be made ready. If its input event condition is not satisfied,
+ then the events satisfied are updated and the events not satisfied are left
+ pending. If the task specified by id is not blocked waiting for events,
+ then the events sent are left pending.
+NOTES:
+ Specifying ``RTEMS_SELF`` for id results in the event set being sent to the
+ calling task.
+ Identical events sent to a task are not queued. In other words, the
+ second, and subsequent, posting of an event to a task before it can perform
+ an ``rtems_event_receive`` has no effect.
+ The calling task will be preempted if it has preemption enabled and a
+ higher priority task is unblocked as the result of this directive.
+ Sending an event set to a global task which does not reside on the local
+ node will generate a request telling the remote node to send the event set
+ to the appropriate task.
+.. raw:: latex
+ \clearpage
+.. index:: receive event condition
+.. index:: rtems_event_receive
+.. _rtems_event_receive:
+EVENT_RECEIVE - Receive event condition
+CALLING SEQUENCE:
+ .. code-block:: c
+ rtems_status_code rtems_event_receive (
+ rtems_event_set event_in,
+ rtems_option option_set,
+ rtems_interval ticks,
+ rtems_event_set *event_out
+ .. list-table::
+ - event received successfully
+ * - ``RTEMS_UNSATISFIED``
+ - input event not satisfied (``RTEMS_NO_WAIT``)
+ * - ``RTEMS_INVALID_ADDRESS``
+ - ``event_out`` is NULL
+ * - ``RTEMS_TIMEOUT``
+ - timed out waiting for event
+DESCRIPTION:
+ This directive attempts to receive the event condition specified in
+ event_in. If event_in is set to ``RTEMS_PENDING_EVENTS``, then the current
+ pending events are returned in event_out and left pending. The
+ ``RTEMS_WAIT`` and ``RTEMS_NO_WAIT`` options in the option_set parameter
+ are used to specify whether or not the task is willing to wait for the
+ event condition to be satisfied. ``RTEMS_EVENT_ANY`` and
+ ``RTEMS_EVENT_ALL`` are used in the option_set parameter are used to
+ specify whether a single event or the complete event set is necessary to
+ satisfy the event condition. The event_out parameter is returned to the
+ calling task with the value that corresponds to the events in event_in that
+ were satisfied.
+ If pending events satisfy the event condition, then event_out is set to the
+ satisfied events and the pending events in the event condition are cleared.
+ If the event condition is not satisfied and ``RTEMS_NO_WAIT`` is specified,
+ then event_out is set to the currently satisfied events. If the calling
+ task chooses to wait, then it will block waiting for the event condition.
+ If the calling task must wait for the event condition to be satisfied, then
+ the timeout parameter is used to specify the maximum interval to wait. If
+ it is set to ``RTEMS_NO_TIMEOUT``, then the calling task will wait forever.
+NOTES:
+ This directive only affects the events specified in event_in. Any pending
+ events that do not correspond to any of the events specified in event_in
+ will be left pending.
+ The following event receive option constants are defined by RTEMS:
+ .. list-table::
+ A clock tick is required to support the functionality of this directive.
diff --git a/c-user/event/index.rst b/c-user/event/index.rst
index 0000000..6503c35
--- /dev/null
+++ b/c-user/event/index.rst
@@ -0,0 +1,15 @@
+.. Copyright (C) 2020 embedded brains GmbH (http://www.embedded-brains.de)
+.. index:: events
+Event Manager
+.. toctree::
+ introduction
+ background
+ operations
+ directives
diff --git a/c-user/event/introduction.rst b/c-user/event/introduction.rst
index 0000000..fb63e42
--- /dev/null
+++ b/c-user/event/introduction.rst
@@ -0,0 +1,13 @@
+Introduction
+The event manager provides a high performance method of intertask communication
+and synchronization. The directives provided by the event manager are:
+- :ref:`rtems_event_send`
+- :ref:`rtems_event_receive`
diff --git a/c-user/event/operations.rst b/c-user/event/operations.rst
index 0000000..e01b6dc
--- /dev/null
+++ b/c-user/event/operations.rst
@@ -0,0 +1,63 @@
+Operations
+Sending an Event Set
+The ``rtems_event_send`` directive allows a task (or an ISR) to direct an event
+set to a target task. Based upon the state of the target task, one of the
+following situations applies:
+- Target Task is Blocked Waiting for Events
+ - If the waiting task's input event condition is satisfied, then the task is
+ made ready for execution.
+ - If the waiting task's input event condition is not satisfied, then the
+ event set is posted but left pending and the task remains blocked.
+- Target Task is Not Waiting for Events
+ - The event set is posted and left pending.
+Receiving an Event Set
+The ``rtems_event_receive`` directive is used by tasks to accept a specific
+input event condition. The task also specifies whether the request is
+satisfied when all requested events are available or any single requested event
+is available. If the requested event condition is satisfied by pending events,
+then a successful return code and the satisfying event set are returned
+immediately. If the condition is not satisfied, then one of the following
+situations applies:
+- By default, the calling task will wait forever for the event condition to be
+ satisfied.
+- Specifying the ``RTEMS_NO_WAIT`` option forces an immediate return with an
+ error status code.
+- Specifying a timeout limits the period the task will wait before returning
+ with an error status code.
+Determining the Pending Event Set
+A task can determine the pending event set by calling the
+``rtems_event_receive`` directive with a value of ``RTEMS_PENDING_EVENTS`` for
+the input event condition. The pending events are returned to the calling task
+but the event set is left unaltered.
+Receiving all Pending Events
+A task can receive all of the currently pending events by calling the
+``rtems_event_receive`` directive with a value of ``RTEMS_ALL_EVENTS`` for the
+input event condition and ``RTEMS_NO_WAIT | RTEMS_EVENT_ANY`` for the option
+set. The pending events are returned to the calling task and the event set is
+cleared. If no events are pending then the ``RTEMS_UNSATISFIED`` status code
+will be returned.
diff --git a/c-user/event_manager.rst b/c-user/event_manager.rst
deleted file mode 100644
index f7593e5..0000000
--- a/c-user/event_manager.rst
+++ /dev/null
@@ -1,309 +0,0 @@
-.. SPDX-License-Identifier: CC-BY-SA-4.0
-.. Copyright (C) 1988, 2008 On-Line Applications Research Corporation (OAR)
-.. index:: events
-Event Manager
-Introduction
-The event manager provides a high performance method of intertask communication
-and synchronization. The directives provided by the event manager are:
-- rtems_event_send_ - Send event set to a task
-- rtems_event_receive_ - Receive event condition
-Background
-.. index:: event flag, definition
-.. index:: event set, definition
-.. index:: rtems_event_set
-Event Sets
-An event flag is used by a task (or ISR) to inform another task of the
-occurrence of a significant situation. Thirty-two event flags are associated
-with each task. A collection of one or more event flags is referred to as an
-event set. The data type ``rtems_event_set`` is used to manage event sets.
-The application developer should remember the following key characteristics of
-event operations when utilizing the event manager:
-- Events provide a simple synchronization facility.
-- Events are aimed at tasks.
-- Tasks can wait on more than one event simultaneously.
-- Events are independent of one another.
-- Events do not hold or transport data.
-- Events are not queued. In other words, if an event is sent more than once to
- a task before being received, the second and subsequent send operations to
- that same task have no effect.
-An event set is posted when it is directed (or sent) to a task. A pending
-event is an event that has been posted but not received. An event condition is
-used to specify the event set which the task desires to receive and the
-algorithm which will be used to determine when the request is satisfied. An
-event condition is satisfied based upon one of two algorithms which are
-selected by the user. The ``RTEMS_EVENT_ANY`` algorithm states that an event
-condition is satisfied when at least a single requested event is posted. The
-``RTEMS_EVENT_ALL`` algorithm states that an event condition is satisfied when
-every requested event is posted.
-.. index:: event condition, building
-.. index:: event set, building
-Building an Event Set or Condition
-An event set or condition is built by a bitwise OR of the desired events. The
-set of valid events is ``RTEMS_EVENT_0`` through ``RTEMS_EVENT_31``. If an
-event is not explicitly specified in the set or condition, then it is not
-present. Events are specifically designed to be mutually exclusive, therefore
-bitwise OR and addition operations are equivalent as long as each event appears
-exactly once in the event set list.
-For example, when sending the event set consisting of ``RTEMS_EVENT_6``,
-``RTEMS_EVENT_15``, and ``RTEMS_EVENT_31``, the event parameter to the
-``rtems_event_send`` directive should be ``RTEMS_EVENT_6 | RTEMS_EVENT_15 |
-RTEMS_EVENT_31``.
-Building an EVENT_RECEIVE Option Set
-In general, an option is built by a bitwise OR of the desired option
-components. The set of valid options for the ``rtems_event_receive`` directive
-are listed in the following table:
-.. list-table::
- :class: rtems-table
- * - ``RTEMS_WAIT``
- - task will wait for event (default)
- * - ``RTEMS_NO_WAIT``
- - task should not wait
- * - ``RTEMS_EVENT_ALL``
- - return after all events (default)
- * - ``RTEMS_EVENT_ANY``
- - return after any events
-Option values are specifically designed to be mutually exclusive, therefore
-bitwise OR and addition operations are equivalent as long as each option
-appears exactly once in the component list. An option listed as a default is
-not required to appear in the option list, although it is a good programming
-practice to specify default options. If all defaults are desired, the option
-``RTEMS_DEFAULT_OPTIONS`` should be specified on this call.
-This example demonstrates the option parameter needed to poll for all events in
-a particular event condition to arrive. The option parameter passed to the
-``rtems_event_receive`` directive should be either ``RTEMS_EVENT_ALL |
-RTEMS_NO_WAIT`` or ``RTEMS_NO_WAIT``. The option parameter can be set to
-``RTEMS_NO_WAIT`` because ``RTEMS_EVENT_ALL`` is the default condition for
-``rtems_event_receive``.
-Operations
-Sending an Event Set
-The ``rtems_event_send`` directive allows a task (or an ISR) to direct an event
-set to a target task. Based upon the state of the target task, one of the
-following situations applies:
-- Target Task is Blocked Waiting for Events
- - If the waiting task's input event condition is satisfied, then the task is
- made ready for execution.
- - If the waiting task's input event condition is not satisfied, then the
- event set is posted but left pending and the task remains blocked.
-- Target Task is Not Waiting for Events
- - The event set is posted and left pending.
-Receiving an Event Set
-The ``rtems_event_receive`` directive is used by tasks to accept a specific
-input event condition. The task also specifies whether the request is
-satisfied when all requested events are available or any single requested event
-is available. If the requested event condition is satisfied by pending events,
-then a successful return code and the satisfying event set are returned
-immediately. If the condition is not satisfied, then one of the following
-situations applies:
-- By default, the calling task will wait forever for the event condition to be
- satisfied.
-- Specifying the ``RTEMS_NO_WAIT`` option forces an immediate return with an
- error status code.
-- Specifying a timeout limits the period the task will wait before returning
- with an error status code.
-Determining the Pending Event Set
-A task can determine the pending event set by calling the
-``rtems_event_receive`` directive with a value of ``RTEMS_PENDING_EVENTS`` for
-the input event condition. The pending events are returned to the calling task
-but the event set is left unaltered.
-Receiving all Pending Events
-A task can receive all of the currently pending events by calling the
-``rtems_event_receive`` directive with a value of ``RTEMS_ALL_EVENTS`` for the
-input event condition and ``RTEMS_NO_WAIT | RTEMS_EVENT_ANY`` for the option
-set. The pending events are returned to the calling task and the event set is
-cleared. If no events are pending then the ``RTEMS_UNSATISFIED`` status code
-will be returned.
-Directives
-This section details the event manager's directives. A subsection is dedicated
-to each of this manager's directives and describes the calling sequence,
-related constants, usage, and status codes.
-.. raw:: latex
- \clearpage
-.. index:: send event set to a task
-.. index:: rtems_event_send
-.. _rtems_event_send:
-EVENT_SEND - Send event set to a task
-CALLING SEQUENCE:
- .. code-block:: c
- rtems_status_code rtems_event_send (
- rtems_id id,
- rtems_event_set event_in
-DIRECTIVE STATUS CODES:
- .. list-table::
- * - ``RTEMS_SUCCESSFUL``
- - event set sent successfully
- * - ``RTEMS_INVALID_ID``
- - invalid task id
-DESCRIPTION:
- This directive sends an event set, event_in, to the task specified by id.
- If a blocked task's input event condition is satisfied by this directive,
- then it will be made ready. If its input event condition is not satisfied,
- then the events satisfied are updated and the events not satisfied are left
- pending. If the task specified by id is not blocked waiting for events,
- then the events sent are left pending.
-NOTES:
- Specifying ``RTEMS_SELF`` for id results in the event set being sent to the
- calling task.
- Identical events sent to a task are not queued. In other words, the
- second, and subsequent, posting of an event to a task before it can perform
- an ``rtems_event_receive`` has no effect.
- The calling task will be preempted if it has preemption enabled and a
- higher priority task is unblocked as the result of this directive.
- Sending an event set to a global task which does not reside on the local
- node will generate a request telling the remote node to send the event set
- to the appropriate task.
-.. raw:: latex
- \clearpage
-.. index:: receive event condition
-.. index:: rtems_event_receive
-.. _rtems_event_receive:
-EVENT_RECEIVE - Receive event condition
-CALLING SEQUENCE:
- .. code-block:: c
- rtems_status_code rtems_event_receive (
- rtems_event_set event_in,
- rtems_option option_set,
- rtems_interval ticks,
- rtems_event_set *event_out
- .. list-table::
- - event received successfully
- * - ``RTEMS_UNSATISFIED``
- - input event not satisfied (``RTEMS_NO_WAIT``)
- * - ``RTEMS_INVALID_ADDRESS``
- - ``event_out`` is NULL
- * - ``RTEMS_TIMEOUT``
- - timed out waiting for event
-DESCRIPTION:
- This directive attempts to receive the event condition specified in
- event_in. If event_in is set to ``RTEMS_PENDING_EVENTS``, then the current
- pending events are returned in event_out and left pending. The
- ``RTEMS_WAIT`` and ``RTEMS_NO_WAIT`` options in the option_set parameter
- are used to specify whether or not the task is willing to wait for the
- event condition to be satisfied. ``RTEMS_EVENT_ANY`` and
- ``RTEMS_EVENT_ALL`` are used in the option_set parameter are used to
- specify whether a single event or the complete event set is necessary to
- satisfy the event condition. The event_out parameter is returned to the
- calling task with the value that corresponds to the events in event_in that
- were satisfied.
- If pending events satisfy the event condition, then event_out is set to the
- satisfied events and the pending events in the event condition are cleared.
- If the event condition is not satisfied and ``RTEMS_NO_WAIT`` is specified,
- then event_out is set to the currently satisfied events. If the calling
- task chooses to wait, then it will block waiting for the event condition.
- If the calling task must wait for the event condition to be satisfied, then
- the timeout parameter is used to specify the maximum interval to wait. If
- it is set to ``RTEMS_NO_TIMEOUT``, then the calling task will wait forever.
-NOTES:
- This directive only affects the events specified in event_in. Any pending
- events that do not correspond to any of the events specified in event_in
- will be left pending.
- The following event receive option constants are defined by RTEMS:
- .. list-table::
- A clock tick is required to support the functionality of this directive.
diff --git a/c-user/index.rst b/c-user/index.rst
index 64eac08..412fadc 100644
--- a/c-user/index.rst
+++ b/c-user/index.rst
@@ -38,7 +38,7 @@ RTEMS Classic API Guide (|version|).
sem/index
barrier_manager
message_manager
- event_manager
+ event/index
signal_manager
partition_manager
region_manager
2.26.2
