[PATCH 06/16] c-user: Split up interrupt manager
Thu Aug 20 10:18:55 UTC 2020
This makes it easier to automatically generate parts of the manager
documentation in the future.
Update #3993.
 c-user/index.rst                              |   2 +-
 c-user/intr/background.rst                    | 106 ++++++++
 .../directives.rst}                           | 251 ------------------
 c-user/intr/index.rst                         |  15 ++
 c-user/intr/introduction.rst                  |  37 +++
 c-user/intr/operations.rst                    | 112 ++++++++
 6 files changed, 271 insertions(+), 252 deletions(-)
 create mode 100644 c-user/intr/background.rst
 rename c-user/{interrupt_manager.rst => intr/directives.rst} (61%)
 create mode 100644 c-user/intr/index.rst
 create mode 100644 c-user/intr/introduction.rst
 create mode 100644 c-user/intr/operations.rst
diff --git a/c-user/index.rst b/c-user/index.rst
index 50d0b5b..c9822a1 100644
--- a/c-user/index.rst
+++ b/c-user/index.rst
@@ -31,7 +31,7 @@ RTEMS Classic API Guide (|version|).
 	scheduling_concepts
 	initialization
 	task_manager
-	interrupt_manager
+	intr/index
 	clock/index
 	timer_manager
 	rate_monotonic_manager
diff --git a/c-user/intr/background.rst b/c-user/intr/background.rst
new file mode 100644
index 0000000..b626640
--- /dev/null
+++ b/c-user/intr/background.rst
@@ -0,0 +1,106 @@
+.. SPDX-License-Identifier: CC-BY-SA-4.0
+.. Copyright (C) 1988, 2008 On-Line Applications Research Corporation (OAR)
+Background
+.. index:: interrupt processing
+Processing an Interrupt
+The interrupt manager allows the application to connect a function to a
+hardware interrupt vector.  When an interrupt occurs, the processor will
+automatically vector to RTEMS.  RTEMS saves and restores all registers which
+are not preserved by the normal C calling convention for the target processor
+and invokes the user's ISR.  The user's ISR is responsible for processing the
+interrupt, clearing the interrupt if necessary, and device specific
+manipulation.
+.. index:: rtems_vector_number
+The ``rtems_interrupt_catch`` directive connects a procedure to an interrupt
+vector.  The vector number is managed using the ``rtems_vector_number`` data
+type.
+The interrupt service routine is assumed to abide by these conventions and have
+a prototype similar to the following:
+.. index:: rtems_isr
+.. code-block:: c
+    rtems_isr user_isr(
+      rtems_vector_number vector
+The vector number argument is provided by RTEMS to allow the application to
+identify the interrupt source.  This could be used to allow a single routine to
+service interrupts from multiple instances of the same device.  For example, a
+single routine could service interrupts from multiple serial ports and use the
+vector number to identify which port requires servicing.
+To minimize the masking of lower or equal priority level interrupts, the ISR
+should perform the minimum actions required to service the interrupt.  Other
+non-essential actions should be handled by application tasks.  Once the user's
+ISR has completed, it returns control to the RTEMS interrupt manager which will
+perform task dispatching and restore the registers saved before the ISR was
+invoked.
+The RTEMS interrupt manager guarantees that proper task scheduling and
+dispatching are performed at the conclusion of an ISR.  A system call made by
+the ISR may have readied a task of higher priority than the interrupted task.
+Therefore, when the ISR completes, the postponed dispatch processing must be
+performed.  No dispatch processing is performed as part of directives which
+have been invoked by an ISR.
+Applications must adhere to the following rule if proper task scheduling and
+dispatching is to be performed:
+.. note::
+  The interrupt manager must be used for all ISRs which may be interrupted by
+  the highest priority ISR which invokes an RTEMS directive.
+Consider a processor which allows a numerically low interrupt level to
+interrupt a numerically greater interrupt level.  In this example, if an RTEMS
+directive is used in a level 4 ISR, then all ISRs which execute at levels 0
+through 4 must use the interrupt manager.
+Interrupts are nested whenever an interrupt occurs during the execution of
+another ISR.  RTEMS supports efficient interrupt nesting by allowing the nested
+ISRs to terminate without performing any dispatch processing.  Only when the
+outermost ISR terminates will the postponed dispatching occur.
+.. index:: interrupt levels
+RTEMS Interrupt Levels
+Many processors support multiple interrupt levels or priorities.  The exact
+number of interrupt levels is processor dependent.  RTEMS internally supports
+256 interrupt levels which are mapped to the processor's interrupt levels.  For
+specific information on the mapping between RTEMS and the target processor's
+interrupt levels, refer to the Interrupt Processing chapter of the Applications
+Supplement document for a specific target processor.
+.. index:: disabling interrupts
+Disabling of Interrupts by RTEMS
+During the execution of directive calls, critical sections of code may be
+executed.  When these sections are encountered, RTEMS disables all maskable
+interrupts before the execution of the section and restores them to the
+previous level upon completion of the section.  RTEMS has been optimized to
+ensure that interrupts are disabled for a minimum length of time.  The maximum
+length of time interrupts are disabled by RTEMS is processor dependent and is
+detailed in the Timing Specification chapter of the Applications Supplement
+document for a specific target processor.
+Non-maskable interrupts (NMI) cannot be disabled, and ISRs which execute at
+this level MUST NEVER issue RTEMS system calls.  If a directive is invoked,
+unpredictable results may occur due to the inability of RTEMS to protect its
+critical sections.  However, ISRs that make no system calls may safely execute
+as non-maskable interrupts.
diff --git a/c-user/interrupt_manager.rst b/c-user/intr/directives.rst
similarity index 61%
rename from c-user/interrupt_manager.rst
rename to c-user/intr/directives.rst
index 5eb7270..95181db 100644
--- a/c-user/interrupt_manager.rst
+++ b/c-user/intr/directives.rst
@@ -2,257 +2,6 @@
-.. index:: interrupts
-Interrupt Manager
-Introduction
-Any real-time executive must provide a mechanism for quick response to
-externally generated interrupts to satisfy the critical time constraints of the
-application.  The interrupt manager provides this mechanism for RTEMS.  This
-manager permits quick interrupt response times by providing the critical
-ability to alter task execution which allows a task to be preempted upon exit
-from an ISR.  The interrupt manager includes the following directive:
-- rtems_interrupt_catch_ - Establish an ISR
-- rtems_interrupt_disable_ - Disable Interrupts
-- rtems_interrupt_enable_ - Restore Interrupt Level
-- rtems_interrupt_flash_ - Flash Interrupt
-- rtems_interrupt_local_disable_ - Disable Interrupts on Current Processor
-- rtems_interrupt_local_enable_ - Restore Interrupt Level on Current Processor
-- rtems_interrupt_lock_initialize_ - Initialize an ISR Lock
-- rtems_interrupt_lock_acquire_ - Acquire an ISR Lock
-- rtems_interrupt_lock_release_ - Release an ISR Lock
-- rtems_interrupt_lock_acquire_isr_ - Acquire an ISR Lock from ISR
-- rtems_interrupt_lock_release_isr_ - Release an ISR Lock from ISR
-- rtems_interrupt_is_in_progress_ - Is an ISR in Progress
-Background
-.. index:: interrupt processing
-Processing an Interrupt
-The interrupt manager allows the application to connect a function to a
-hardware interrupt vector.  When an interrupt occurs, the processor will
-automatically vector to RTEMS.  RTEMS saves and restores all registers which
-are not preserved by the normal C calling convention for the target processor
-and invokes the user's ISR.  The user's ISR is responsible for processing the
-interrupt, clearing the interrupt if necessary, and device specific
-manipulation.
-.. index:: rtems_vector_number
-The ``rtems_interrupt_catch`` directive connects a procedure to an interrupt
-vector.  The vector number is managed using the ``rtems_vector_number`` data
-type.
-The interrupt service routine is assumed to abide by these conventions and have
-a prototype similar to the following:
-.. index:: rtems_isr
-.. code-block:: c
-    rtems_isr user_isr(
-      rtems_vector_number vector
-The vector number argument is provided by RTEMS to allow the application to
-identify the interrupt source.  This could be used to allow a single routine to
-service interrupts from multiple instances of the same device.  For example, a
-single routine could service interrupts from multiple serial ports and use the
-vector number to identify which port requires servicing.
-To minimize the masking of lower or equal priority level interrupts, the ISR
-should perform the minimum actions required to service the interrupt.  Other
-non-essential actions should be handled by application tasks.  Once the user's
-ISR has completed, it returns control to the RTEMS interrupt manager which will
-perform task dispatching and restore the registers saved before the ISR was
-invoked.
-The RTEMS interrupt manager guarantees that proper task scheduling and
-dispatching are performed at the conclusion of an ISR.  A system call made by
-the ISR may have readied a task of higher priority than the interrupted task.
-Therefore, when the ISR completes, the postponed dispatch processing must be
-performed.  No dispatch processing is performed as part of directives which
-have been invoked by an ISR.
-Applications must adhere to the following rule if proper task scheduling and
-dispatching is to be performed:
-.. note::
-  The interrupt manager must be used for all ISRs which may be interrupted by
-  the highest priority ISR which invokes an RTEMS directive.
-Consider a processor which allows a numerically low interrupt level to
-interrupt a numerically greater interrupt level.  In this example, if an RTEMS
-directive is used in a level 4 ISR, then all ISRs which execute at levels 0
-through 4 must use the interrupt manager.
-Interrupts are nested whenever an interrupt occurs during the execution of
-another ISR.  RTEMS supports efficient interrupt nesting by allowing the nested
-ISRs to terminate without performing any dispatch processing.  Only when the
-outermost ISR terminates will the postponed dispatching occur.
-.. index:: interrupt levels
-RTEMS Interrupt Levels
-Many processors support multiple interrupt levels or priorities.  The exact
-number of interrupt levels is processor dependent.  RTEMS internally supports
-256 interrupt levels which are mapped to the processor's interrupt levels.  For
-specific information on the mapping between RTEMS and the target processor's
-interrupt levels, refer to the Interrupt Processing chapter of the Applications
-Supplement document for a specific target processor.
-.. index:: disabling interrupts
-Disabling of Interrupts by RTEMS
-During the execution of directive calls, critical sections of code may be
-executed.  When these sections are encountered, RTEMS disables all maskable
-interrupts before the execution of the section and restores them to the
-previous level upon completion of the section.  RTEMS has been optimized to
-ensure that interrupts are disabled for a minimum length of time.  The maximum
-length of time interrupts are disabled by RTEMS is processor dependent and is
-detailed in the Timing Specification chapter of the Applications Supplement
-document for a specific target processor.
-Non-maskable interrupts (NMI) cannot be disabled, and ISRs which execute at
-this level MUST NEVER issue RTEMS system calls.  If a directive is invoked,
-unpredictable results may occur due to the inability of RTEMS to protect its
-critical sections.  However, ISRs that make no system calls may safely execute
-as non-maskable interrupts.
-Operations
-Establishing an ISR
-The ``rtems_interrupt_catch`` directive establishes an ISR for the system.  The
-address of the ISR and its associated CPU vector number are specified to this
-directive.  This directive installs the RTEMS interrupt wrapper in the
-processor's Interrupt Vector Table and the address of the user's ISR in the
-RTEMS' Vector Table.  This directive returns the previous contents of the
-specified vector in the RTEMS' Vector Table.
-Directives Allowed from an ISR
-Using the interrupt manager ensures that RTEMS knows when a directive is being
-called from an ISR.  The ISR may then use system calls to synchronize itself
-with an application task.  The synchronization may involve messages, events or
-signals being passed by the ISR to the desired task.  Directives invoked by an
-ISR must operate only on objects which reside on the local node.  The following
-is a list of RTEMS system calls that may be made from an ISR:
-- Task Management
-  Although it is acceptable to operate on the RTEMS_SELF task (e.g.  the
-  currently executing task), while in an ISR, this will refer to the
-  interrupted task.  Most of the time, it is an application implementation
-  error to use RTEMS_SELF from an ISR.
-  - rtems_task_suspend
-  - rtems_task_resume
-- Interrupt Management
-  - rtems_interrupt_enable
-  - rtems_interrupt_disable
-  - rtems_interrupt_flash
-  - rtems_interrupt_lock_acquire
-  - rtems_interrupt_lock_release
-  - rtems_interrupt_lock_acquire_isr
-  - rtems_interrupt_lock_release_isr
-  - rtems_interrupt_is_in_progress
-  - rtems_interrupt_catch
-- Clock Management
-  - rtems_clock_set
-  - rtems_clock_get_tod
-  - rtems_clock_get_tod_timeval
-  - rtems_clock_get_seconds_since_epoch
-  - rtems_clock_get_ticks_per_second
-  - rtems_clock_get_ticks_since_boot
-  - rtems_clock_get_uptime
-- Timer Management
-  - rtems_timer_cancel
-  - rtems_timer_reset
-  - rtems_timer_fire_after
-  - rtems_timer_fire_when
-  - rtems_timer_server_fire_after
-  - rtems_timer_server_fire_when
-- Event Management
-  - rtems_event_send
-  - rtems_event_system_send
-  - rtems_event_transient_send
-- Semaphore Management
-  - rtems_semaphore_release
-- Message Management
-  - rtems_message_queue_broadcast
-  - rtems_message_queue_send
-  - rtems_message_queue_urgent
-- Signal Management
-  - rtems_signal_send
-- Dual-Ported Memory Management
-  - rtems_port_external_to_internal
-  - rtems_port_internal_to_external
-- IO Management
-  The following services are safe to call from an ISR if and only if
-  the device driver service invoked is also safe.  The IO Manager itself
-  is safe but the invoked driver entry point may or may not be.
-  - rtems_io_initialize
-  - rtems_io_open
-  - rtems_io_close
-  - rtems_io_read
-  - rtems_io_write
-  - rtems_io_control
-- Fatal Error Management
-  - rtems_fatal
-  - rtems_fatal_error_occurred
-- Multiprocessing
-  - rtems_multiprocessing_announce
 Directives
diff --git a/c-user/intr/index.rst b/c-user/intr/index.rst
index 0000000..e1c529e
--- /dev/null
+++ b/c-user/intr/index.rst
@@ -0,0 +1,15 @@
+.. Copyright (C) 2020 embedded brains GmbH (http://www.embedded-brains.de)
+.. index:: interrupts
+Interrupt Manager
+.. toctree::
+    introduction
+    background
+    operations
+    directives
diff --git a/c-user/intr/introduction.rst b/c-user/intr/introduction.rst
index 0000000..272eba2
--- /dev/null
+++ b/c-user/intr/introduction.rst
@@ -0,0 +1,37 @@
+Introduction
+Any real-time executive must provide a mechanism for quick response to
+externally generated interrupts to satisfy the critical time constraints of the
+application.  The interrupt manager provides this mechanism for RTEMS.  This
+manager permits quick interrupt response times by providing the critical
+ability to alter task execution which allows a task to be preempted upon exit
+from an ISR.  The interrupt manager includes the following directive:
+- :ref:`rtems_interrupt_catch`
+- :ref:`rtems_interrupt_disable`
+- :ref:`rtems_interrupt_enable`
+- :ref:`rtems_interrupt_flash`
+- :ref:`rtems_interrupt_local_disable`
+- :ref:`rtems_interrupt_local_enable`
+- :ref:`rtems_interrupt_lock_initialize`
+- :ref:`rtems_interrupt_lock_acquire`
+- :ref:`rtems_interrupt_lock_release`
+- :ref:`rtems_interrupt_lock_acquire_isr`
+- :ref:`rtems_interrupt_lock_release_isr`
+- :ref:`rtems_interrupt_is_in_progress`
diff --git a/c-user/intr/operations.rst b/c-user/intr/operations.rst
index 0000000..67988c3
--- /dev/null
+++ b/c-user/intr/operations.rst
@@ -0,0 +1,112 @@
+Operations
+Establishing an ISR
+The ``rtems_interrupt_catch`` directive establishes an ISR for the system.  The
+address of the ISR and its associated CPU vector number are specified to this
+directive.  This directive installs the RTEMS interrupt wrapper in the
+processor's Interrupt Vector Table and the address of the user's ISR in the
+RTEMS' Vector Table.  This directive returns the previous contents of the
+specified vector in the RTEMS' Vector Table.
+Directives Allowed from an ISR
+Using the interrupt manager ensures that RTEMS knows when a directive is being
+called from an ISR.  The ISR may then use system calls to synchronize itself
+with an application task.  The synchronization may involve messages, events or
+signals being passed by the ISR to the desired task.  Directives invoked by an
+ISR must operate only on objects which reside on the local node.  The following
+is a list of RTEMS system calls that may be made from an ISR:
+- Task Management
+  Although it is acceptable to operate on the RTEMS_SELF task (e.g.  the
+  currently executing task), while in an ISR, this will refer to the
+  interrupted task.  Most of the time, it is an application implementation
+  error to use RTEMS_SELF from an ISR.
+  - rtems_task_suspend
+  - rtems_task_resume
+- Interrupt Management
+  - rtems_interrupt_enable
+  - rtems_interrupt_disable
+  - rtems_interrupt_flash
+  - rtems_interrupt_lock_acquire
+  - rtems_interrupt_lock_release
+  - rtems_interrupt_lock_acquire_isr
+  - rtems_interrupt_lock_release_isr
+  - rtems_interrupt_is_in_progress
+  - rtems_interrupt_catch
+- Clock Management
+  - rtems_clock_set
+  - rtems_clock_get_tod
+  - rtems_clock_get_tod_timeval
+  - rtems_clock_get_seconds_since_epoch
+  - rtems_clock_get_ticks_per_second
+  - rtems_clock_get_ticks_since_boot
+  - rtems_clock_get_uptime
+- Timer Management
+  - rtems_timer_cancel
+  - rtems_timer_reset
+  - rtems_timer_fire_after
+  - rtems_timer_fire_when
+  - rtems_timer_server_fire_after
+  - rtems_timer_server_fire_when
+- Event Management
+  - rtems_event_send
+  - rtems_event_system_send
+  - rtems_event_transient_send
+- Semaphore Management
+  - rtems_semaphore_release
+- Message Management
+  - rtems_message_queue_broadcast
+  - rtems_message_queue_send
+  - rtems_message_queue_urgent
+- Signal Management
+  - rtems_signal_send
+- Dual-Ported Memory Management
+  - rtems_port_external_to_internal
+  - rtems_port_internal_to_external
+- IO Management
+  The following services are safe to call from an ISR if and only if
+  the device driver service invoked is also safe.  The IO Manager itself
+  is safe but the invoked driver entry point may or may not be.
+  - rtems_io_initialize
+  - rtems_io_open
+  - rtems_io_close
+  - rtems_io_read
+  - rtems_io_write
+  - rtems_io_control
+- Fatal Error Management
+  - rtems_fatal
+  - rtems_fatal_error_occurred
+- Multiprocessing
+  - rtems_multiprocessing_announce
2.26.2
