[PATCH v2] Confstr Patches
Eshan dhawan eshandhawan51 at gmail.com
Thu Aug 20 17:05:18 UTC 2020
Adds Confstr file To RTEMS with test
Signed-off-by: Eshan dhawan <eshandhawan51 at gmail.com>
 cpukit/Makefile.am                            |   1 +
 cpukit/posix/src/confstr.c                    | 105 ++++++++++++++
 testsuites/psxtests/Makefile.am               |   9 ++
 testsuites/psxtests/configure.ac              |   1 +
 testsuites/psxtests/psxconfstr/init.c         | 130 ++++++++++++++++++
 testsuites/psxtests/psxconfstr/psxconfstr.doc |  17 +++
 testsuites/psxtests/psxconfstr/psxconfstr.scn |   4 +
 7 files changed, 267 insertions(+)
 create mode 100644 cpukit/posix/src/confstr.c
 create mode 100644 testsuites/psxtests/psxconfstr/init.c
 create mode 100644 testsuites/psxtests/psxconfstr/psxconfstr.doc
 create mode 100644 testsuites/psxtests/psxconfstr/psxconfstr.scn
diff --git a/cpukit/Makefile.am b/cpukit/Makefile.am
index aa1fe5fc16..8edee5d82b 100644
--- a/cpukit/Makefile.am
+++ b/cpukit/Makefile.am
@@ -508,6 +508,7 @@ librtemscpu_a_SOURCES += posix/src/condsignalsupp.c
 librtemscpu_a_SOURCES += posix/src/condtimedwait.c
 librtemscpu_a_SOURCES += posix/src/condwait.c
 librtemscpu_a_SOURCES += posix/src/condwaitsupp.c
+librtemscpu_a_SOURCES += posix/src/confstr.c
 librtemscpu_a_SOURCES += posix/src/_execve.c
 librtemscpu_a_SOURCES += posix/src/fork.c
 librtemscpu_a_SOURCES += posix/src/key.c
diff --git a/cpukit/posix/src/confstr.c b/cpukit/posix/src/confstr.c
new file mode 100644
index 0000000000..71041db462
--- /dev/null
+++ b/cpukit/posix/src/confstr.c
@@ -0,0 +1,105 @@
+ * SPDX-License-Identifier: BSD-3-Clause
+ * Copyright (c) 1993
+ *	The Regents of the University of California.  All rights reserved.
+ * are met:
+ * 3. Neither the name of the University nor the names of its contributors
+ *    may be used to endorse or promote products derived from this software
+ *    without specific prior written permission.
+ * THIS SOFTWARE IS PROVIDED BY THE REGENTS AND CONTRIBUTORS ``AS IS'' AND
+ * ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
+ * ARE DISCLAIMED.  IN NO EVENT SHALL THE REGENTS OR CONTRIBUTORS BE LIABLE
+ * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
+ * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS
+ * OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
+ * HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT
+ * LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY
+ * OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
+ * SUCH DAMAGE.
+#include <sys/cdefs.h>
+__SCCSID("@(#)confstr.c	8.1 (Berkeley) 6/4/93");
+__FBSDID("$FreeBSD$");
+#include <sys/param.h>
+#include <errno.h>
+#include <limits.h>
+#include <paths.h>
+#include <string.h>
+#include <unistd.h>
+size_t
+confstr(int name, char *buf, size_t len)
+	const char *p;
+	const char UPE[] = "unsupported programming environment";
+	switch (name) {
+#ifndef __rtems__
+	case _CS_PATH:
+		p = _PATH_STDPATH;
+		goto docopy;
+#endif
+		 * POSIX/SUS ``Programming Environments'' stuff
+		 * We don't support more than one programming environment
+		 * on any platform (yet), so we just return the empty
+		 * string for the environment we are compiled for,
+		 * and the string "unsupported programming environment"
+		 * for anything else.  (The Standard says that if these
+		 * values are used on a system which does not support
+		 * this environment -- determined via sysconf() -- then
+		 * the value we return is unspecified.  So, we return
+		 * something which will cause obvious breakage.)
+	case _CS_POSIX_V6_ILP32_OFF32_CFLAGS:
+	case _CS_POSIX_V6_ILP32_OFF32_LDFLAGS:
+	case _CS_POSIX_V6_ILP32_OFF32_LIBS:
+	case _CS_POSIX_V6_LPBIG_OFFBIG_CFLAGS:
+	case _CS_POSIX_V6_LPBIG_OFFBIG_LDFLAGS:
+	case _CS_POSIX_V6_LPBIG_OFFBIG_LIBS:
+		p = UPE;
+		goto docopy;
+	case _CS_POSIX_V6_ILP32_OFFBIG_CFLAGS:
+	case _CS_POSIX_V6_ILP32_OFFBIG_LDFLAGS:
+	case _CS_POSIX_V6_ILP32_OFFBIG_LIBS:
+			p = UPE;
+		goto docopy;
+	case _CS_POSIX_V6_LP64_OFF64_CFLAGS:
+	case _CS_POSIX_V6_LP64_OFF64_LDFLAGS:
+	case _CS_POSIX_V6_LP64_OFF64_LIBS:
+			p = UPE;
+		goto docopy;
+docopy:
+		if (len != 0 && buf != NULL)
+			strlcpy(buf, p, len);
+		return (strlen(p) + 1);
+	default:
+		errno = EINVAL;
+		return (0);
+	/* NOTREACHED */
diff --git a/testsuites/psxtests/Makefile.am b/testsuites/psxtests/Makefile.am
index aae5fe764a..f0910330a9 100755
--- a/testsuites/psxtests/Makefile.am
+++ b/testsuites/psxtests/Makefile.am
@@ -358,6 +358,15 @@ psxconfig01_CPPFLAGS = $(AM_CPPFLAGS) $(TEST_FLAGS_psxconfig01) \
 	$(support_includes) -I$(top_srcdir)/include
 endif
+if TEST_psxgetcpuclockid01
+psx_tests += psxconfstr
+psx_screens += psxconfstr/psxconfstr.scn
+psx_docs += psxconfstr/psxconfstr.doc
+psxconfstr_SOURCES = psxconfstr/init.c
+psxconfstr_CPPFLAGS = $(AM_CPPFLAGS) $(TEST_FLAGS_psxgetcpuclockid01) \
+	$(support_includes)
+endif
 if TEST_psxdevctl01
 psx_tests += psxdevctl01
 psx_screens += psxdevctl01/psxdevctl01.scn
diff --git a/testsuites/psxtests/configure.ac b/testsuites/psxtests/configure.ac
index c509086abc..96c937cb4d 100644
--- a/testsuites/psxtests/configure.ac
+++ b/testsuites/psxtests/configure.ac
@@ -80,6 +80,7 @@ RTEMS_TEST_CHECK([psxconcurrency01])
 RTEMS_TEST_CHECK([psxcond01])
 RTEMS_TEST_CHECK([psxcond02])
 RTEMS_TEST_CHECK([psxconfig01])
+RTEMS_TEST_CHECK([psxconfstr])
 RTEMS_TEST_CHECK([psxdevctl01])
 RTEMS_TEST_CHECK([psxeintr_join])
 RTEMS_TEST_CHECK([psxenosys])
diff --git a/testsuites/psxtests/psxconfstr/init.c b/testsuites/psxtests/psxconfstr/init.c
index 0000000000..8916ee266d
--- /dev/null
+++ b/testsuites/psxtests/psxconfstr/init.c
@@ -0,0 +1,130 @@
+ *  @file
+ *  @brief Test suite for confstr method
+ * SPDX-License-Identifier: BSD-2-Clause
+ * Copyright (C) 2020 embedded brains GmbH, Eshan Dhawan
+ * are met:
+#ifdef HAVE_CONFIG_H
+#include "config.h"
+#endif
+#include <errno.h>
+#include <stdio.h>
+#include <rtems.h>
+#include <rtems/test.h>
+#include <rtems/bspIo.h>
+#include "tmacros.h"
+#include "test_support.h"
+const char rtems_test_name[] = "PSXCONFSTR";
+/* Forward declaration to avoid warnings */
+rtems_task Init( rtems_task_argument ignored );
+static char buffer[512];
+static const T_action actions[] = {
+  T_report_hash_sha256,
+  T_check_task_context,
+  T_check_file_descriptors,
+  T_check_rtems_barriers,
+  T_check_rtems_extensions,
+  T_check_rtems_message_queues,
+  T_check_rtems_partitions,
+  T_check_rtems_periods,
+  T_check_rtems_regions,
+  T_check_rtems_semaphores,
+  T_check_rtems_tasks,
+  T_check_rtems_timers,
+  T_check_posix_keys
+static const T_config config = {
+  .name = "psxconfstr",
+  .buf = buffer,
+  .putchar = rtems_put_char,
+  .buf_size = sizeof(buffer),
+  .verbosity = T_VERBOSE,
+  .now = T_now_clock,
+  .action_count = T_ARRAY_SIZE(actions),
+  .actions = actions
+/* init test function begins */
+T_TEST_CASE(confstr)
+int r;
+  char * buf ;
+  size_t len1;
+  len1 = strlen(UPE) + 1;
+  r = confstr(_CS_PATH, buf, sizeof(buf));
+  if (r != 0){
+    printf("This Function is not supported");
+  T_quiet_psx_success(r);
+  r = confstr(_CS_POSIX_V6_ILP32_OFFBIG_CFLAGS, buf, sizeof(buf));
+  if ( r != len1 ){
+    printf("lenght not matched");
+  rtems_test_assert(r == len1);
+rtems_task Init(rtems_task_argument ignored)
+  int exit_code;
+  TEST_BEGIN();
+  T_register();
+  exit_code = T_main(&config);
+  if (exit_code == 0) {
+    TEST_END();
+ rtems_test_exit(exit_code);
+#define CONFIGURE_APPLICATION_DOES_NOT_NEED_CLOCK_DRIVER
+#define CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER
+#define CONFIGURE_MAXIMUM_TASKS 1
+#define CONFIGURE_INITIAL_EXTENSIONS RTEMS_TEST_INITIAL_EXTENSION
+#define CONFIGURE_RTEMS_INIT_TASKS_TABLE
+#include <rtems/confdefs.h>
+/* end of file */
diff --git a/testsuites/psxtests/psxconfstr/psxconfstr.doc b/testsuites/psxtests/psxconfstr/psxconfstr.doc
index 0000000000..e353f74ae7
--- /dev/null
+++ b/testsuites/psxtests/psxconfstr/psxconfstr.doc
@@ -0,0 +1,17 @@
+#  COPYRIGHT (c) 2020
+#  On-Line Applications Research Corporation (OAR).
+# SPDX-License-Identifier: BSD-2-Clause
+This file describes the directives and concepts tested by this test set.
+test set name:  psxconfstr
+Directives:
+  Pthread_getcpuclockid()
+Concepts:
++ This test exercises the confstr method
diff --git a/testsuites/psxtests/psxconfstr/psxconfstr.scn b/testsuites/psxtests/psxconfstr/psxconfstr.scn
index 0000000000..705a08d51b
--- /dev/null
+++ b/testsuites/psxtests/psxconfstr/psxconfstr.scn
@@ -0,0 +1,4 @@
+*** BEGIN OF TEST PSXCONFSTR ***
+*** END OF TEST PSXCONFSTR ***
2.17.1
