[PATCH 1/1] confdefs: Fix cyclic dependency
Sebastian Huber
Fri Aug 21 06:59:10 UTC 2020
Close #4060.
cpukit/include/rtems/confdefs/mpci.h | 13 ++-----------
cpukit/include/rtems/confdefs/threads.h | 7 ++++++-
2 files changed, 8 insertions(+), 12 deletions(-)
diff --git a/cpukit/include/rtems/confdefs/mpci.h b/cpukit/include/rtems/confdefs/mpci.h
index e4d9737b31..0a9be4a2ea 100644
--- a/cpukit/include/rtems/confdefs/mpci.h
+++ b/cpukit/include/rtems/confdefs/mpci.h
@@ -6,9 +6,6 @@
* @ingroup RTEMSApplicationConfiguration
* @brief Evaluate MPCI Configuration Options
- * This header file defines _CONFIGURE_MPCI_RECEIVE_SERVER_COUNT for use by
- * other configuration header files.
@@ -49,6 +46,8 @@
#ifdef CONFIGURE_MP_APPLICATION
+#include <rtems/confdefs/threads.h>
#ifndef CONFIGURE_EXTRA_MPCI_RECEIVE_SERVER_STACK
#define CONFIGURE_EXTRA_MPCI_RECEIVE_SERVER_STACK 0
#endif
@@ -83,8 +82,6 @@
#error "CONFIGURE_MP_NODE_NUMBER must be less than or equal to CONFIGURE_MP_MAXIMUM_NODES"
#endif
-#define _CONFIGURE_MPCI_RECEIVE_SERVER_COUNT 1
#ifdef __cplusplus
extern "C" {
#endif
@@ -126,10 +123,6 @@ RTEMS_SECTION( ".rtemsstack.mpci" );
#endif
-#else /* CONFIGURE_MP_APPLICATION */
-#define _CONFIGURE_MPCI_RECEIVE_SERVER_COUNT 0
#endif /* CONFIGURE_MP_APPLICATION */
#else /* RTEMS_MULTIPROCESSING */
@@ -138,8 +131,6 @@ RTEMS_SECTION( ".rtemsstack.mpci" );
#error "CONFIGURE_MP_APPLICATION must not be defined if multiprocessing is disabled"
#endif
#endif /* RTEMS_MULTIPROCESSING */
#endif /* CONFIGURE_INIT */
diff --git a/cpukit/include/rtems/confdefs/threads.h b/cpukit/include/rtems/confdefs/threads.h
index 7288243ead..12726487ba 100644
--- a/cpukit/include/rtems/confdefs/threads.h
+++ b/cpukit/include/rtems/confdefs/threads.h
@@ -44,7 +44,6 @@
#include <rtems/confdefs/bdbuf.h>
#include <rtems/confdefs/extensions.h>
-#include <rtems/confdefs/mpci.h>
#include <rtems/confdefs/percpu.h>
#include <rtems/confdefs/scheduler.h>
#include <rtems/confdefs/unlimited.h>
@@ -197,6 +196,12 @@ const size_t _Thread_Initial_thread_count =
rtems_resource_maximum_per_allocation( _CONFIGURE_TASKS ) +
rtems_resource_maximum_per_allocation( CONFIGURE_MAXIMUM_POSIX_THREADS );
+#if defined(RTEMS_MULTIPROCESSING) && defined(CONFIGURE_MP_APPLICATION)
+ #define _CONFIGURE_MPCI_RECEIVE_SERVER_COUNT 1
+#else
+ #define _CONFIGURE_MPCI_RECEIVE_SERVER_COUNT 0
+#endif
THREAD_INFORMATION_DEFINE(
_Thread,
OBJECTS_INTERNAL_API,
2.26.2
