QEP driver patch example programs and output
James Fitzsimons
james.fitzsimons at gmail.com
Fri Aug 21 10:09:19 UTC 2020
Hi all,
Further to the patch I have just submitted I thought it would be useful for
any reviewers to have the following example programs and output as a
reference when reviewing the patch.
Thanks in advance for your review and feedback.
Regards,
James Fitzsimons
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200821/4b616ac7/attachment.html>
U-Boot SPL 2019.04-00002-g07d5700e21 (Mar 06 2020 - 11:24:55 -0600)
Trying to boot from MMC2
Loading Environment from EXT4...
** Unable to use mmc 0:1 for loading the env **
U-Boot 2019.04-00002-g07d5700e21 (Mar 06 2020 - 11:24:55 -0600), Build: jenkins-github_Bootloader-Builder-137
CPU : AM335X-GP rev 2.1
I2C: ready
DRAM: 512 MiB
No match for driver 'omap_hsmmc'
Some drivers were not found
Reset Source: Power-on reset has occurred.
RTC 32KCLK Source: External.
MMC: OMAP SD/MMC: 0, OMAP SD/MMC: 1
Board: BeagleBone Black
<ethaddr> not set. Validating first E-fuse MAC
BeagleBone Black:
Model: BeagleBoard.org BeagleBone Black Wireless:
BeagleBone: cape eeprom: i2c_probe: 0x54:
BeagleBone: cape eeprom: i2c_probe: 0x55:
BeagleBone: cape eeprom: i2c_probe: 0x56:
BeagleBone: cape eeprom: i2c_probe: 0x57:
Net: eth0: MII MODE
Could not get PHY for cpsw: addr 0
cpsw, usb_ether
Press SPACE to abort autoboot in 0 seconds
board_name=[BBBW] ...
switch to partitions #0, OK
mmc0 is current device
SD/MMC found on device 0
Scanning mmc 0:1...
53130 bytes read in 6 ms (8.4 MiB/s)
gpio: pin 56 (gpio 56) value is 0
gpio: pin 55 (gpio 55) value is 0
gpio: pin 54 (gpio 54) value is 0
gpio: pin 53 (gpio 53) value is 1
gpio: pin 54 (gpio 54) value is 1
Checking for: /uEnv.txt ...
282 bytes read in 2 ms (137.7 KiB/s)
gpio: pin 55 (gpio 55) value is 1
Loaded environment from /uEnv.txt
Importing environment from mmc ...
Checking if uenvcmd is set ...
gpio: pin 56 (gpio 56) value is 1
Running uenvcmd ...
86538 bytes read in 8 ms (10.3 MiB/s)
373 bytes read in 2 ms (181.6 KiB/s)
## Booting kernel from Legacy Image at 80800000 ...
Image Name: RTEMS
Created: 2020-08-21 9:28:55 UTC
Image Type: ARM Linux Kernel Image (gzip compressed)
Data Size: 86474 Bytes = 84.4 KiB
Load Address: 80000000
Entry Point: 80000000
Verifying Checksum ... OK
## Flattened Device Tree blob at 88000000
Booting using the fdt blob at 0x88000000
Uncompressing Kernel Image ... OK
Loading Device Tree to 8ffef000, end 8fffffff ... OK
Starting kernel ...
RTEMS Beagleboard: am335x-based
ARM Debug: 0x4b141000
Initialising QEP
Setting Quadrature mode to relative
Setting unit timer to 1s
Completed initialising QEP
clock is running true
Enabling PWM output....
Value of qep position is -4936
Value of qep position is -5382
Value of qep position is -5400
Value of qep position is -5403
Value of qep position is -5406
Value of qep position is -5413
Value of qep position is -5418
Value of qep position is -5421
Value of qep position is -5422
Value of qep position is -5431
Value of qep position is -5435
Value of qep position is -5434
Value of qep position is -5438
Value of qep position is -5437
Value of qep position is -5440
Value of qep position is -5444
PWM disabled. Test finished.
*** FATAL ***
fatal source: 0 (INTERNAL_ERROR_CORE)
fatal code: 5 (INTERNAL_ERROR_THREAD_EXITTED)
Type: text/x-csrc
Desc: not available
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200821/4b616ac7/attachment.bin>
Type: text/x-csrc
Desc: not available
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200821/4b616ac7/attachment-0001.bin>
I2C: ready
DRAM: 512 MiB
BeagleBone Black:
Net: eth0: MII MODE
cpsw, usb_ether
Scanning mmc 0:1...
Running uenvcmd ...
86422 bytes read in 8 ms (10.3 MiB/s)
Image Name: RTEMS
Created: 2020-08-21 9:33:18 UTC
Data Size: 86358 Bytes = 84.3 KiB
Starting kernel ...
Initialising QEP
Value of qep position is 0
Value of qep position is -5093
Value of qep position is -10552
Value of qep position is -16016
Value of qep position is -21485
Value of qep position is -26950
Value of qep position is -32418
Value of qep position is -37890
Value of qep position is -43361
Value of qep position is -48830
Value of qep position is -54300
Value of qep position is -59765
Value of qep position is -65238
Value of qep position is -70711
Value of qep position is -76146
Value of qep position is -81597
Value of qep position is -87052
Value of qep position is -92517
Value of qep position is -97988
*** FATAL ***
RTEMS version: 5.0.0.5284e812e2c82466b3f3a21e494310d8cb69c7cd-modified
RTEMS tools: 7.5.0 20191114 (RTEMS 5, RSB 5 (f2f0fdf13587 modified), Newlib 7947581)
