[PATCH 4/7] score: Add _Stack_Allocator_do_initialize()
Sebastian Huber
Fri Aug 21 11:51:00 UTC 2020
Do the stack allocator initialization and sanity check only if a
user-provided stack allocator was configured. This avoids a dependency
of _Thread_Handler_initialization() on the stack allocator.
Update #3959.
cpukit/Makefile.am | 1 +
cpukit/include/rtems/confdefs/wkspace.h | 6 +++
cpukit/include/rtems/score/stack.h | 7 +++
cpukit/include/rtems/sysinit.h | 1 +
cpukit/score/src/stackallocator.c | 2 -
cpukit/score/src/stackallocatorinit.c | 60 +++++++++++++++++++++++++
cpukit/score/src/thread.c | 22 ++-------
7 files changed, 78 insertions(+), 21 deletions(-)
create mode 100644 cpukit/score/src/stackallocatorinit.c
diff --git a/cpukit/Makefile.am b/cpukit/Makefile.am
index 1ea3def4ef..a936045ad8 100644
--- a/cpukit/Makefile.am
+++ b/cpukit/Makefile.am
@@ -931,6 +931,7 @@ librtemscpu_a_SOURCES += score/src/schedulercbssetparameters.c
librtemscpu_a_SOURCES += score/src/schedulercbsreleasejob.c
librtemscpu_a_SOURCES += score/src/schedulercbsunblock.c
librtemscpu_a_SOURCES += score/src/stackallocator.c
+librtemscpu_a_SOURCES += score/src/stackallocatorinit.c
librtemscpu_a_SOURCES += score/src/pheapallocate.c
librtemscpu_a_SOURCES += score/src/pheapextend.c
librtemscpu_a_SOURCES += score/src/pheapfree.c
diff --git a/cpukit/include/rtems/confdefs/wkspace.h b/cpukit/include/rtems/confdefs/wkspace.h
index 484dde20ea..de476dbf82 100644
--- a/cpukit/include/rtems/confdefs/wkspace.h
+++ b/cpukit/include/rtems/confdefs/wkspace.h
@@ -150,6 +150,12 @@ const uintptr_t _Stack_Space_size = _CONFIGURE_STACK_SPACE_SIZE;
const Stack_Allocator_free _Stack_Allocator_free =
CONFIGURE_TASK_STACK_DEALLOCATOR;
+ RTEMS_SYSINIT_ITEM(
+ _Stack_Allocator_do_initialize,
+ RTEMS_SYSINIT_DIRTY_MEMORY,
+ RTEMS_SYSINIT_ORDER_MIDDLE
#elif defined(CONFIGURE_TASK_STACK_ALLOCATOR) \
|| defined(CONFIGURE_TASK_STACK_DEALLOCATOR)
#error "CONFIGURE_TASK_STACK_ALLOCATOR and CONFIGURE_TASK_STACK_DEALLOCATOR must be both defined or both undefined"
diff --git a/cpukit/include/rtems/score/stack.h b/cpukit/include/rtems/score/stack.h
index df1df74867..e869a04db5 100644
--- a/cpukit/include/rtems/score/stack.h
+++ b/cpukit/include/rtems/score/stack.h
@@ -123,6 +123,13 @@ extern const Stack_Allocator_allocate _Stack_Allocator_allocate;
extern const Stack_Allocator_free _Stack_Allocator_free;
+ * @brief Do the stack allocator initialization during system initialize.
+ * This function is used to initialize application provided stack allocators.
+void _Stack_Allocator_do_initialize( void );
#ifdef __cplusplus
diff --git a/cpukit/include/rtems/sysinit.h b/cpukit/include/rtems/sysinit.h
index 245da74f2c..a28e44817a 100644
--- a/cpukit/include/rtems/sysinit.h
+++ b/cpukit/include/rtems/sysinit.h
@@ -41,6 +41,7 @@ extern "C" {
#define RTEMS_SYSINIT_INITIAL_EXTENSIONS 000500
#define RTEMS_SYSINIT_MP_EARLY 000600
#define RTEMS_SYSINIT_DATA_STRUCTURES 000700
+#define RTEMS_SYSINIT_STACK_ALLOCATOR 000780
#define RTEMS_SYSINIT_MP 000800
#define RTEMS_SYSINIT_USER_EXTENSIONS 000900
#define RTEMS_SYSINIT_CLASSIC_TASKS 000a00
diff --git a/cpukit/score/src/stackallocator.c b/cpukit/score/src/stackallocator.c
index 404b98fa1c..64a1337fe5 100644
--- a/cpukit/score/src/stackallocator.c
+++ b/cpukit/score/src/stackallocator.c
@@ -34,8 +34,6 @@
const bool _Stack_Allocator_avoids_workspace = false;
-const Stack_Allocator_initialize _Stack_Allocator_initialize = NULL;
const Stack_Allocator_allocate _Stack_Allocator_allocate = _Workspace_Allocate;
const Stack_Allocator_free _Stack_Allocator_free = _Workspace_Free;
diff --git a/cpukit/score/src/stackallocatorinit.c b/cpukit/score/src/stackallocatorinit.c
new file mode 100644
index 0000000000..60d243631f
--- /dev/null
+++ b/cpukit/score/src/stackallocatorinit.c
@@ -0,0 +1,60 @@
+ * @file
+ * @ingroup RTEMSScoreStack
+ * @brief Stack Allocator Initialization
+ * Copyright (C) 2020 embedded brains GmbH (http://www.embedded-brains.de)
+ * are met:
+ * notice, this list of conditions and the following disclaimer.
+ * notice, this list of conditions and the following disclaimer in the
+ * documentation and/or other materials provided with the distribution.
+#ifdef HAVE_CONFIG_H
+#include "config.h"
+#endif
+#include <rtems/score/stack.h>
+#include <rtems/score/interr.h>
+#include <rtems/config.h>
+ rtems_stack_allocate_init_hook init_hook;
+ if (
+ rtems_configuration_get_stack_allocate_hook() == NULL
+ || rtems_configuration_get_stack_free_hook() == NULL
+ _Internal_error( INTERNAL_ERROR_BAD_STACK_HOOK );
+ init_hook = rtems_configuration_get_stack_allocate_init_hook();
+ if ( init_hook != NULL ) {
+ (*init_hook )( rtems_configuration_get_stack_space_size() );
diff --git a/cpukit/score/src/thread.c b/cpukit/score/src/thread.c
index a491753836..3dde437e72 100644
--- a/cpukit/score/src/thread.c
+++ b/cpukit/score/src/thread.c
@@ -20,10 +20,8 @@
#include <rtems/score/freechainimpl.h>
-#include <rtems/score/interr.h>
-#include <rtems/score/wkspace.h>
#define THREAD_OFFSET_ASSERT( field ) \
RTEMS_STATIC_ASSERT( \
@@ -59,23 +57,9 @@ void _Thread_Initialize_information( Thread_Information *information )
void _Thread_Handler_initialization(void)
- rtems_stack_allocate_init_hook stack_allocate_init_hook =
- rtems_configuration_get_stack_allocate_init_hook();
- #if defined(RTEMS_MULTIPROCESSING)
- uint32_t maximum_proxies =
- _MPCI_Configuration.maximum_proxies;
- #endif
- if ( rtems_configuration_get_stack_allocate_hook() == NULL ||
- rtems_configuration_get_stack_free_hook() == NULL)
- _Internal_error( INTERNAL_ERROR_BAD_STACK_HOOK );
- if ( stack_allocate_init_hook != NULL )
- (*stack_allocate_init_hook)( rtems_configuration_get_stack_space_size() );
- _Thread_MP_Handler_initialization( maximum_proxies );
- #endif
+#if defined(RTEMS_MULTIPROCESSING)
+ _Thread_MP_Handler_initialization( _MPCI_Configuration.maximum_proxies );
+#endif
* Initialize the internal class of threads. We need an IDLE thread
2.26.2
