[PATCH 2/7] score: Add <rtems/score/freechainimpl.h>
Sebastian Huber
Fri Aug 21 11:50:58 UTC 2020
Hide implementation details.
Update #3959.
cpukit/headers.am | 1 +
cpukit/include/rtems/posix/keyimpl.h | 2 +-
cpukit/include/rtems/score/freechain.h | 124 +---------------
cpukit/include/rtems/score/freechainimpl.h | 161 +++++++++++++++++++++
cpukit/score/src/freechain.c | 2 +-
cpukit/score/src/thread.c | 1 +
cpukit/score/src/threadallocateunlimited.c | 1 +
cpukit/score/src/threadinitialize.c | 1 +
cpukit/score/src/threadrestart.c | 1 +
testsuites/sptests/spfreechain01/init.c | 2 +-
10 files changed, 170 insertions(+), 126 deletions(-)
create mode 100644 cpukit/include/rtems/score/freechainimpl.h
diff --git a/cpukit/headers.am b/cpukit/headers.am
index e1d450a99d..77df5ecb4c 100644
--- a/cpukit/headers.am
+++ b/cpukit/headers.am
@@ -343,6 +343,7 @@ include_rtems_score_HEADERS += include/rtems/score/coresem.h
include_rtems_score_HEADERS += include/rtems/score/coresemimpl.h
include_rtems_score_HEADERS += include/rtems/score/cpustdatomic.h
include_rtems_score_HEADERS += include/rtems/score/freechain.h
+include_rtems_score_HEADERS += include/rtems/score/freechainimpl.h
include_rtems_score_HEADERS += include/rtems/score/heap.h
include_rtems_score_HEADERS += include/rtems/score/heapimpl.h
include_rtems_score_HEADERS += include/rtems/score/heapinfo.h
diff --git a/cpukit/include/rtems/posix/keyimpl.h b/cpukit/include/rtems/posix/keyimpl.h
index d27244fe81..eed5d3fed2 100644
--- a/cpukit/include/rtems/posix/keyimpl.h
+++ b/cpukit/include/rtems/posix/keyimpl.h
@@ -19,7 +19,7 @@
#include <rtems/posix/key.h>
-#include <rtems/score/freechain.h>
+#include <rtems/score/freechainimpl.h>
diff --git a/cpukit/include/rtems/score/freechain.h b/cpukit/include/rtems/score/freechain.h
index ab1e8150da..7db1101cff 100644
--- a/cpukit/include/rtems/score/freechain.h
+++ b/cpukit/include/rtems/score/freechain.h
@@ -16,8 +16,7 @@
#ifndef _RTEMS_SCORE_FREECHAIN_H
#define _RTEMS_SCORE_FREECHAIN_H
-#include <rtems/score/basedefs.h>
-#include <rtems/score/chainimpl.h>
+#include <rtems/score/chain.h>
#ifdef __cplusplus
extern "C" {
@@ -37,11 +36,6 @@ extern "C" {
- * @brief Allocator function.
-typedef void *( *Freechain_Allocator )( size_t size );
* @brief The freechain control.
@@ -52,122 +46,6 @@ typedef struct {
Chain_Control Free;
} Freechain_Control;
- * @brief Initializes a freechain.
- * This routine initializes the freechain control structure to manage a chain
- * of nodes. In the case the freechain is empty the extend handler is called to
- * get more nodes.
- * @param[out] freechain The freechain control to initialize.
- * @param[out] initial_nodes Array with the initial nodes.
- * @param number_nodes The initial number of nodes.
- * @param node_size The node size.
-RTEMS_INLINE_ROUTINE void _Freechain_Initialize(
- Freechain_Control *freechain,
- void *initial_nodes,
- size_t number_nodes,
- size_t node_size
- _Chain_Initialize(
- &freechain->Free,
- initial_nodes,
- number_nodes,
- node_size
- * @brief Return true if the freechain is empty, otherwise false
- * @param freechain The freechain control.
-RTEMS_INLINE_ROUTINE bool _Freechain_Is_empty(
- const Freechain_Control *freechain
- return _Chain_Is_empty( &freechain->Free );
- * @brief Pops a node from the freechain.
- * The freechain shall not be empty.
-RTEMS_INLINE_ROUTINE void *_Freechain_Pop( Freechain_Control *freechain )
- return _Chain_Get_first_unprotected( &freechain->Free );
- * @brief Pushes a node back to the freechain.
- * @param node The node to push back. The node shall not be @c NULL.
-void RTEMS_INLINE_ROUTINE _Freechain_Push(
- void *node
- _Chain_Initialize_node( node );
- _Chain_Prepend_unprotected( &freechain->Free, node );
- * @brief Extend the freechain with new nodes.
- * @param allocator The allocator function.
- * @param number_nodes_to_extend The number of nodes to extend.
- * @retval NULL The extend operation failed.
- * @retval nodes Pointer to the new nodes.
-void *_Freechain_Extend(
- Freechain_Allocator allocator,
- size_t number_nodes_to_extend,
- size_t node_size
- * @brief Gets a node from the freechain.
- * @param[in, out] freechain The freechain control.
- * @param number_nodes_to_extend The number of nodes in the case an extend is
- * necessary due to an empty freechain.
- * @param[in] node_size The node size.
- * @retval NULL The freechain is empty and the extend operation failed.
- * @retval pointer Pointer to a node. The node ownership passes to the
- * caller.
-void *_Freechain_Get(
- size_t node_size
- * @brief Puts a node back onto the freechain.
- * @param[out] node The node to put back. The node may be @c NULL, in this case
- * the function does nothing.
-void _Freechain_Put(
- void *node
#ifdef __cplusplus
diff --git a/cpukit/include/rtems/score/freechainimpl.h b/cpukit/include/rtems/score/freechainimpl.h
new file mode 100644
index 0000000000..25660003ff
--- /dev/null
+++ b/cpukit/include/rtems/score/freechainimpl.h
@@ -0,0 +1,161 @@
+ * @file
+ * @ingroup RTEMSScoreFreechain
+ * @brief Freechain Handler API
+ * Copyright (c) 2013 Gedare Bloom.
+#ifndef _RTEMS_SCORE_FREECHAINIMPL_H
+#define _RTEMS_SCORE_FREECHAINIMPL_H
+#include <rtems/score/freechain.h>
+#include <rtems/score/basedefs.h>
+#include <rtems/score/chainimpl.h>
+#ifdef __cplusplus
+extern "C" {
+#endif
+ * @addtogroup RTEMSScoreFreechain
+ * @brief Allocator function.
+typedef void *( *Freechain_Allocator )( size_t size );
+ * @brief Initializes a freechain.
+ * This routine initializes the freechain control structure to manage a chain
+ * of nodes. In the case the freechain is empty the extend handler is called to
+ * get more nodes.
+ * @param[out] freechain The freechain control to initialize.
+ * @param[out] initial_nodes Array with the initial nodes.
+ * @param number_nodes The initial number of nodes.
+ * @param node_size The node size.
+RTEMS_INLINE_ROUTINE void _Freechain_Initialize(
+ Freechain_Control *freechain,
+ void *initial_nodes,
+ size_t number_nodes,
+ size_t node_size
+ _Chain_Initialize(
+ &freechain->Free,
+ initial_nodes,
+ number_nodes,
+ node_size
+ * @brief Return true if the freechain is empty, otherwise false
+ * @param freechain The freechain control.
+RTEMS_INLINE_ROUTINE bool _Freechain_Is_empty(
+ const Freechain_Control *freechain
+ return _Chain_Is_empty( &freechain->Free );
+ * @brief Pops a node from the freechain.
+ * The freechain shall not be empty.
+RTEMS_INLINE_ROUTINE void *_Freechain_Pop( Freechain_Control *freechain )
+ return _Chain_Get_first_unprotected( &freechain->Free );
+ * @brief Pushes a node back to the freechain.
+ * @param node The node to push back. The node shall not be @c NULL.
+void RTEMS_INLINE_ROUTINE _Freechain_Push(
+ void *node
+ _Chain_Initialize_node( node );
+ _Chain_Prepend_unprotected( &freechain->Free, node );
+ * @brief Extend the freechain with new nodes.
+ * @param allocator The allocator function.
+ * @param number_nodes_to_extend The number of nodes to extend.
+ * @retval NULL The extend operation failed.
+ * @retval nodes Pointer to the new nodes.
+void *_Freechain_Extend(
+ Freechain_Allocator allocator,
+ size_t number_nodes_to_extend,
+ size_t node_size
+ * @brief Gets a node from the freechain.
+ * @param[in, out] freechain The freechain control.
+ * @param number_nodes_to_extend The number of nodes in the case an extend is
+ * necessary due to an empty freechain.
+ * @param[in] node_size The node size.
+ * @retval NULL The freechain is empty and the extend operation failed.
+ * @retval pointer Pointer to a node. The node ownership passes to the
+ * caller.
+void *_Freechain_Get(
+ size_t node_size
+ * @brief Puts a node back onto the freechain.
+ * @param[out] node The node to put back. The node may be @c NULL, in this case
+ * the function does nothing.
+void _Freechain_Put(
+ void *node
+#ifdef __cplusplus
+#endif
+#endif
+/* end of include file */
diff --git a/cpukit/score/src/freechain.c b/cpukit/score/src/freechain.c
index 209a2b780d..e5b1f84a63 100644
--- a/cpukit/score/src/freechain.c
+++ b/cpukit/score/src/freechain.c
@@ -18,7 +18,7 @@
#include "config.h"
#endif
diff --git a/cpukit/score/src/thread.c b/cpukit/score/src/thread.c
index 69bfcf66e7..a491753836 100644
--- a/cpukit/score/src/thread.c
+++ b/cpukit/score/src/thread.c
@@ -19,6 +19,7 @@
#endif
#include <rtems/score/interr.h>
diff --git a/cpukit/score/src/threadallocateunlimited.c b/cpukit/score/src/threadallocateunlimited.c
index 463a0ecb5d..6f2dec7388 100644
--- a/cpukit/score/src/threadallocateunlimited.c
+++ b/cpukit/score/src/threadallocateunlimited.c
@@ -36,6 +36,7 @@
#endif
diff --git a/cpukit/score/src/threadinitialize.c b/cpukit/score/src/threadinitialize.c
index 691f56388e..d85615e4b9 100644
--- a/cpukit/score/src/threadinitialize.c
+++ b/cpukit/score/src/threadinitialize.c
@@ -19,6 +19,7 @@
#endif
#include <rtems/score/stackimpl.h>
#include <rtems/score/tls.h>
diff --git a/cpukit/score/src/threadrestart.c b/cpukit/score/src/threadrestart.c
index 4e892f75f1..d51a22032c 100644
--- a/cpukit/score/src/threadrestart.c
+++ b/cpukit/score/src/threadrestart.c
@@ -25,6 +25,7 @@
#include <rtems/score/apimutex.h>
#include <rtems/score/isrlock.h>
diff --git a/testsuites/sptests/spfreechain01/init.c b/testsuites/sptests/spfreechain01/init.c
index 72cd7920c5..8132757031 100644
--- a/testsuites/sptests/spfreechain01/init.c
+++ b/testsuites/sptests/spfreechain01/init.c
@@ -12,7 +12,7 @@
#include <tmacros.h>
const char rtems_test_name[] = "SPFREECHAIN 1";
2.26.2
