[PATCH v2] bsps/shared/ofw: Implement RTEMS OFW interface
Niteesh G. S. niteesh.gs at gmail.com
Fri Aug 21 17:28:04 UTC 2020
On Thu, Aug 20, 2020 at 1:22 PM G S Niteesh Babu <niteesh.gs at gmail.com>
wrote:
> RTEMS OFW is a FDT only implementation of the OpenFirmWare
> interface. This API is created to be compatible with FreeBSD
> OpenFirmWare interface. The main intention is to make
> porting of FreeBSD drivers to RTEMS easier.
> Most functions implemented have an direct one-one mapping
> with the original OFW API and some extra auxiliary functions
> were implemented to make working with device trees easier in
> RTEMS.
> Update #3784
>  bsps/include/ofw/ofw.h        | 548 +++++++++++++++++++++++++++
>  bsps/include/ofw/ofw_compat.h |  74 ++++
>  bsps/shared/ofw/ofw.c         | 670 ++++++++++++++++++++++++++++++++++
>  spec/build/bsps/obj.yml       |   4 +
>  4 files changed, 1296 insertions(+)
>  create mode 100644 bsps/include/ofw/ofw.h
>  create mode 100644 bsps/include/ofw/ofw_compat.h
>  create mode 100644 bsps/shared/ofw/ofw.c
> diff --git a/bsps/include/ofw/ofw.h b/bsps/include/ofw/ofw.h
> new file mode 100644
> index 0000000000..50f64ff695
> --- /dev/null
> +++ b/bsps/include/ofw/ofw.h
> @@ -0,0 +1,548 @@
> +/* SPDX-License-Identifier: BSD-2-Clause */
> + * @file
> + * @ingroup ofw
> + * RTEMS FDT implementation of OpenFirmWare Interface.
> + * RTEMS OFW is a FDT only implementation of the OpenFirmWare interface.
> + * This API is created to be compatible with FreeBSD OpenFirmWare
> interface.
> + * The main intention is to make porting of FreeBSD drivers to RTEMS
> easier.
> + * Copyright (C) 2020 Niteesh Babu G S <niteesh.gs at gmail.com>
> + * Redistribution and use in source and binary forms, with or without
> + * modification, are permitted provided that the following conditions
> + * are met:
> + * 1. Redistributions of source code must retain the above copyright
> + *    notice, this list of conditions and the following disclaimer.
> + * 2. Redistributions in binary form must reproduce the above copyright
> + *    notice, this list of conditions and the following disclaimer in the
> + *    documentation and/or other materials provided with the distribution.
> + * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
> "AS IS"
> + * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO,
> THE
> + * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR
> PURPOSE
> + * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS
> BE
> + * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
> + * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
> + * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR
> BUSINESS
> + * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
> + * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
> + * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF
> THE
> + * POSSIBILITY OF SUCH DAMAGE.
> +#ifndef _OFW_H
> +#define _OFW_H
> +#ifdef __cplusplus
> +extern "C" {
> +#endif
> +#include <rtems.h>
> +#include <stdint.h>
> +#include <stddef.h>
> + * Represents a node in the device tree. The offset from fdtp to node is
> used
> + * instead of fdt offset to make sure this is compatible with OF
> interface in
> + * FreeBSD.
> +typedef uint32_t  phandle_t;
> + * Represents the effective phandle of the node.
> +typedef uint32_t  ihandle_t;
> + * Represents the data type of the buffer.
> +typedef uint32_t  pcell_t;
> + * @struct rtems_ofw_memory_area
> + * This is used to represent elements(FDT properties) that define
> + * region of memory address.
> +typedef struct {
> +  /** The start address of the memory region. */
> +  uint32_t start;
> +  /** The size of the memory region. */
> +  uint32_t size;
> +} rtems_ofw_memory_area;
> + * @struct rtems_ofw_ranges
> + * This is used to represent the ranges property in the device tree.
> +typedef struct {
> +  /** The physical address within the child bus address space */
> +  uint32_t child_bus;
> +  /** The physical address within the parent bus address space */
> +  uint32_t parent_bus;
> +  /** The size of the range in the child’s address space */
> +  uint32_t size;
> +} rtems_ofw_ranges;
> + * @brief Gets the node that is next to @a node.
> + * @param[in] node Node offset
> + * @retval Peer node offset Successful operation.
> + * @retval 0 No peer node or invalid node handle
> +phandle_t rtems_ofw_peer(
> +  phandle_t   node
> + * @brief Gets the node that is the child of @a node.
> + * @retval child node offset Successful operation.
> + * @retval 0 No child node or invalid node handle
> +phandle_t rtems_ofw_child(
> +  phandle_t   node
> + * @brief Gets the node that is the parent of @a node.
> +phandle_t rtems_ofw_parent(
> +  phandle_t   node
> + * @brief Gets the length of the property mentioned in @a propname.
> + * @param[in] prop Property name
> + * @retval -1 Invalid node or property
> + * @retval  Length of property on successful operation
> +size_t rtems_ofw_get_prop_len(
> +  phandle_t   node,
> +  const char *propname
> + * @brief Gets the value of property mentioned in @a propname.
> + * @param[out] buf The property value gets stored in this buffer
> (Pre-allocated)
> + * @param[in] len Length of the buffer
> +size_t rtems_ofw_get_prop(
> +  phandle_t    node,
> +  const char  *propname,
> +  void        *buf,
> +  size_t       len
> + * @brief Gets the value of property mentioned in @a prop.
> + * Gets the value of property of @a node and converts the value into the
> host's
> + * endianness.
> buffer(Pre-allocated)
> + * after converted to the host's endianness
> +size_t rtems_ofw_get_enc_prop(
> +  phandle_t    node,
> +  const char  *prop,
> +  pcell_t     *buf,
> +  size_t       len
> + * @brief Checks if the property @a propname is present in @a node.
> + * @param[in] propname Property name
> + *  @retval  0 Property not present.
> + *  @retval  1 Property is present.
> +int rtems_ofw_has_prop(
> +  phandle_t    node,
> + * @brief Searches for property @a propname in @a node.
> + * Searches the node and its parent recursively for the property and
> fills the
> + * buffer with the first found value.
> (Pre-allocated)
> + * @retval  Length of the property if property is found.
> + * @retval  -1 Property is not found.
> +size_t rtems_ofw_search_prop(
> +  phandle_t    node,
> +  void        *buf,
> +  size_t       len
> fills the
> + * buffer with the first value found after converting it to the
> endianness of
> + * the host.
> +size_t rtems_ofw_search_enc_prop(
> +  phandle_t    node,
> +  pcell_t     *buf,
> +  size_t       len
> + * Same as rtems_ofw_getprop, but the @a buf is allocated in this routine
> and
> + * the user is responsible for freeing it.
> + * @param[out] buf The buffer is allocated in this routine and user is
> + * responsible for freeing.
> +size_t rtems_ofw_get_prop_alloc(
> +  phandle_t    node,
> +  void       **buf
> + * @brief Gets multiple values of the property @a propname.
> + * Same as rtems_ofw_getprop_alloc but it can read properties with
> multiple
> + * values.
> + * For eg: reg = <0x1000 0x10 0x2000 0x20>
> + * @param[in] elsz Size of the single value
> + * @retval   Number of values read.
> +size_t rtems_ofw_get_prop_alloc_multi(
> +  phandle_t    node,
> +  int          elsz,
> +  void       **buf
> + * Same as rtems_ofw_getprop_alloc but the value stored in the buffer is
> + * converted into the host's endianness.
> +size_t rtems_ofw_get_enc_prop_alloc(
> +  phandle_t    node,
> +  void       **buf
> + * Same as rtems_ofw_getprop_alloc_multi but the values stored in the
> buffer
> + * are converted to the host's endianness.
> +size_t rtems_ofw_get_enc_prop_alloc_multi(
> +  phandle_t     node,
> +  int           elsz,
> +  void        **buf
> + * @brief Free's the buffers allocated by the rtems_ofw_*_alloc functions.
> + * @param[in] buf Buffer to be freed
> +void rtems_ofw_free(
> +  void   *buf
> + * @brief Finds the next property of @a node.
> + * Finds the next property of the node and when @a propname is NULL it
> returns
> + * the value in the first property.
> + * @param[in] previous Previous property name
> + * @param[out] buf The value of the next property gets stored in this
> buffer
> + * (Pre-allocated)
> + * @retval  -1 node or previous property does not exist
> + * @retval   0 no more properties
> + * @retval   1 success
> +int rtems_ofw_next_prop(
> +  phandle_t    node,
> +  const char  *previous,
> +  char        *buf,
> +  size_t       len
> + * @brief Sets the property @name of @a node to @a buf.
> + * @param[in] name Property name
> + * @param[in] buf Buffer contains the value to be set.
> + * @retval  -1 node does not exist
> + * @retval   0 on success
> + * @retval   libFDT error codes on unsuccessful setting operation
> +int rtems_ofw_set_prop(
> +  phandle_t    node,
> +  const char  *name,
> +  const void  *buf,
> +  size_t       len
> + * @brief Converts a device specifier to a fully qualified path name.
> + * @param[in] dev device specifier
> + * @param[out] buf The path is filled into the buffer(Pre-allocated)
> + * @param[in] length of the buffer
> + * @retval  -1 always. Unimplemented.
> +size_t rtems_ofw_canon(
> +  const char  *dev,
> +  char        *buf,
> +  size_t       len
> + * @brief Finds the node at the given path
> + * @param[in] path to the node from root
> + * @retval   node handle on success
> +phandle_t rtems_ofw_find_device(
> +  const char  *path
> + * @brief This routine converts effective phandle @a xref to node offset.
> + * @param[in] xref Node phandle
> + * @retval Node offset on success
> + * @retval Node phandle on failure
> +phandle_t rtems_ofw_node_from_xref(
> +  phandle_t   xref
> + * @brief This routine converts node offset to effective phandle of @a
> node.
> + * @retval Node phandle on success
> + * @retval Node offset on failure
> +phandle_t rtems_ofw_xref_from_node(
> +  phandle_t   node
> + * instance handles(ihandle_t) as same as phandles in the FDT
> implementation
> + * of OF interface.
> + * @brief Converts @a instance handle to phandle.
> + * instance are same as node offsets in FDT.
> + * @param[in] instance Node offset
> + * @retval phandle of node on success.
> + * @retval instance of node on failure.
> +phandle_t rtems_ofw_instance_to_package(
> +  ihandle_t   instance
> + * @brief Find the node's path from phandle.
> + * @param[out] buf Path is filled into this buffer(Pre-allocated).
> + * @param[in] len Length of the buffer.
> +size_t rtems_ofw_package_to_path(
> +  phandle_t   node,
> +  char       *buf,
> +  size_t      len
> + * @brief Find the node's path from ihandle.
> +size_t rtems_ofw_instance_to_path(
> +  ihandle_t  instance,
> +  char      *buf,
> +  size_t     len
> + * @brief Queries the node's reg value.
> + * This routine fills the buffer @a buf with the values in reg property
> of node
> + * @a node. It reads all the values of the property and fills the buffer
> to max
> + * size.
> + * This routine is local to RTEMS OFW and does not have an corresponding
> + * FreeBSD OFW pair.
> + * @param[out] buf Register values are stored in this
> + * @param[in] size Length of the buffer.
> + * @retval -1 If reg property is missing.
> + * @retval  Length of the reg property in bytes.
> +int rtems_ofw_get_reg(
> +  phandle_t              node,
> +  rtems_ofw_memory_area *buf,
> +  size_t                 size
> + * @brief Queries the node's interrupt value.
> + * This routine fills the buffer @a buf with the interrupt number. In
> case of
> + * multiple numbers it fills the buffer to its full extent.
> + * @param[out] buf Interrupt values are stored in this
> + * @retval -1 If interrupts property is missing.
> + * @retval  The number of interrupt numbers read.
> +int rtems_ofw_get_interrupts(
> +  phandle_t            node,
> +  rtems_vector_number *buf,
> +  size_t               size
> + * @brief Queries the node's status.
> + * @retval true  Status is OK or empty.
> + * @retval false Status is not OK or missing.
> +bool rtems_ofw_node_status( phandle_t node );
> + * @brief Gets node phandle from compatible property.
> + * @param[in] compat Compatible string
> + * @retval 0 Node with @a compat as compatible string not found
> + * @retval Node phandle on success.
> +phandle_t rtems_ofw_find_device_by_compat( const char *compat );
> +#ifdef __cplusplus
> +#endif
> +#endif /* _OFW_H */
> diff --git a/bsps/include/ofw/ofw_compat.h b/bsps/include/ofw/ofw_compat.h
> index 0000000000..be4a5ea3ce
> --- /dev/null
> +++ b/bsps/include/ofw/ofw_compat.h
> @@ -0,0 +1,74 @@
> + * @file
> + * @ingroup ofw
> + * This file defines necessary symbols to make the RTEMS OFW API
> compatible
> + * with FreeBSD OFW.
> + * are met:
> "AS IS"
> THE
> PURPOSE
> BE
> BUSINESS
> THE
> +#ifndef _OFW_COMPAT_H
> +#define _OFW_COMPAT_H
> +#ifdef __cplusplus
> +extern "C" {
> +#endif
> +#include <ofw/ofw.h>
> +#define OF_peer                   rtems_ofw_peer
> +#define OF_child                  rtems_ofw_child
> +#define OF_parent                 rtems_ofw_parent
> +#define OF_getproplen             rtems_ofw_get_prop_len
> +#define OF_getprop                rtems_ofw_get_prop
> +#define OF_getencprop             rtems_ofw_get_enc_prop
> +#define OF_hasprop                rtems_ofw_has_prop
> +#define OF_searchprop             rtems_ofw_search_prop
> +#define OF_searchencprop          rtems_ofw_search_enc_prop
> +#define OF_getprop_alloc          rtems_ofw_get_prop_alloc
> +#define OF_getprop_alloc_multi    rtems_ofw_get_prop_alloc_multi
> +#define OF_getencprop_alloc_multi rtems_ofw_get_enc_prop_alloc_multi
> +#define OF_getencprop_alloc       rtems_ofw_get_enc_prop_alloc
> +#define OF_prop_free              rtems_ofw_free
> +#define OF_nextprop               rtems_ofw_next_prop
> +#define OF_setprop                rtems_ofw_set_prop
> +#define OF_canon                  rtems_ofw_canon
> +#define OF_finddevice             rtems_ofw_find_device
> +#define OF_package_to_path        rtems_ofw_package_to_path
> +#define OF_node_from_xref         rtems_ofw_node_from_xref
> +#define OF_xref_from_node         rtems_ofw_xref_from_node
> +#define OF_instance_to_package    rtems_ofw_instance_to_package
> +#define OF_instance_to_path       rtems_ofw_instance_to_path
> +#ifdef __cplusplus
> +#endif
> +#endif /* _OFW_COMPAT_H */
> diff --git a/bsps/shared/ofw/ofw.c b/bsps/shared/ofw/ofw.c
> index 0000000000..481b29553b
> --- /dev/null
> +++ b/bsps/shared/ofw/ofw.c
> @@ -0,0 +1,670 @@
> + * @file
> + * @ingroup ofw
> + * are met:
> "AS IS"
> THE
> PURPOSE
> BE
> BUSINESS
> THE
> +#ifdef HAVE_CONFIG_H
> +#include "config.h"
> +#endif
> +#include <bsp/fdt.h>
> +#include <sys/param.h>
> +#include <libfdt.h>
> +#include <assert.h>
> +#include <rtems/sysinit.h>
> +const void *fdtp = NULL;
> +static phandle_t rtems_fdt_offset_to_phandle( int offset )
> +  if (offset < 0) {
> +    return 0;
> +  return (phandle_t)offset + fdt_off_dt_struct(fdtp);
> +static int rtems_fdt_phandle_to_offset( phandle_t handle )
> +  int off;
> +  int fdt_off;
> +  off = (int) handle;
> +  fdt_off = fdt_off_dt_struct(fdtp);
> +  if (off < fdt_off) {
> +    return -1;
> +  return off - fdt_off;
> +static void rtems_ofw_init( void ) {
> +  int rv;
> +  const void *fdt;
> +  fdt = bsp_fdt_get();
> +  rv = fdt_check_header(fdt);
> +   * If the FDT is invalid exit through fatal.
> +  if (rv != 0) {
> +    rtems_fatal_error_occurred(RTEMS_NOT_CONFIGURED);
> +  fdtp = fdt;
> +RTEMS_SYSINIT_ITEM(
> +  rtems_ofw_init,
> +  RTEMS_SYSINIT_BSP_PRE_DRIVERS,
> +  RTEMS_SYSINIT_ORDER_FIRST
> +phandle_t rtems_ofw_peer( phandle_t node )
> +  int offset;
> +  if (node == 0) {
> +    int root = fdt_path_offset(fdtp, "/");
> +    return rtems_fdt_offset_to_phandle(root);
> +  offset = rtems_fdt_phandle_to_offset(node);
> +  if (offset < 0) {
> +    return 0;
> +  offset = fdt_next_subnode(fdtp, offset);
> +  return rtems_fdt_offset_to_phandle(offset);
> +phandle_t rtems_ofw_child( phandle_t node )
> +  int offset;
> +  if (offset < 0) {
> +    return 0;
> +  offset = fdt_first_subnode(fdtp, offset);
> +phandle_t rtems_ofw_parent( phandle_t node )
> +  int offset;
> +  if (offset < 0) {
> +    return 0;
> +  offset = fdt_parent_offset(fdtp, offset);
> +  phandle_t node,
> +  int offset;
> +  int len;
> +  const void *prop;
> +  if (offset < 0) {
> +    return -1;
> +  prop = fdt_getprop(fdtp, offset, propname, &len);
> +  if (prop == NULL && strcmp(propname, "name") == 0) {
> +    fdt_get_name(fdtp, offset, &len);
> +    return len + 1;
> +  if (prop == NULL && strcmp(propname, "/chosen") == 0) {
> +    if (strcmp(propname, "fdtbootcpu") == 0)
> +      return sizeof(pcell_t);
> +    if (strcmp(propname, "fdtmemreserv") == 0)
> +      return 2 * sizeof(uint64_t) * fdt_num_mem_rsv(fdtp);
> +  if (prop == NULL) {
> +    return -1;
> +  return len;
> +  phandle_t    node,
> +  void        *buf,
> +  size_t       bufsize
> +  const void *prop;
> +  int offset;
> +  int len;
> +  uint32_t cpuid;
> +  if (offset < 0) {
> +    return -1;
> +    prop = fdt_get_name(fdtp, offset, &len);
> +    strncpy(buf, prop, bufsize);
> +    return len + 1;
> +    if (strcmp(propname, "fdtbootcpu") == 0) {
> +      cpuid = cpu_to_fdt32(fdt_boot_cpuid_phys(fdtp));
> +      len = sizeof(cpuid);
> +      prop = &cpuid;
> +    if (strcmp(propname, "fdtmemreserv") == 0) {
> +      prop = (char *)fdtp + fdt_off_mem_rsvmap(fdtp);
> +      len = sizeof(uint64_t)*2*fdt_num_mem_rsv(fdtp);
> +    return -1;
> +  bcopy(prop, buf, MIN(len, bufsize));
> +  return len;
> +  phandle_t    node,
> +  const char  *prop,
> +  pcell_t     *buf,
> +  size_t       len
> +  size_t rv;
> +  assert(len % 4 == 0);
> +  rv = rtems_ofw_get_prop(node, prop, buf, len);
> +  if (rv < 0) {
> +    return rv;
> +  for (int i = 0; i < (len / 4); i++) {
> +    buf[i] = fdt32_to_cpu(buf[i]);
> +  return rv;
> +  phandle_t    node,
> +  size_t rv;
> +  rv = rtems_ofw_get_prop_len(node, propname);
> +  return rv >= 0 ? 1 : 0;
> +  phandle_t    node,
> +  void        *buf,
> +  size_t       len
> +  size_t rv;
> +  for (; node != 0; node = rtems_ofw_parent(node)) {
> +    if ((rv = rtems_ofw_get_prop(node, propname, buf, len) != -1)) {
> +      return rv;
> +  return -1;
> +  phandle_t    node,
> +  pcell_t     *buf,
> +  size_t       len
> +  size_t rv;
> +    if ((rv = rtems_ofw_get_enc_prop(node, propname, buf, len) != -1)) {
> +      return rv;
> +  return -1;
> +  phandle_t    node,
> +  void       **buf
> +  size_t len;
> +  *buf = NULL;
> +  if ((len = rtems_ofw_get_prop_len(node, propname)) == -1) {
> +    return -1;
> +  if (len > 0) {
> +    *buf = malloc(len);
> +    if (rtems_ofw_get_prop(node, propname, *buf, len) == -1) {
> +      rtems_ofw_free(buf);
> +      *buf = NULL;
> +      return -1;
> +  return len;
> +  phandle_t    node,
> +  int          elsz,
> +  void       **buf
> +  size_t len;
> +  *buf = NULL;
> +  if ((len = rtems_ofw_get_prop_len(node, propname)) == -1 ||
> +      (len % elsz != 0)) {
> +    return -1;
While going through the code again, a question raised inside me,
In the above code, the function rtems_ofw_get_prop_len returns
a size_t which is an unsigned value, I compare that to -1 is that
OK from a code review point of view or should I change the type
of len to -1?
> +  if (len > 0) {
> +      *buf = NULL;
> +      return -1;
> +  return (len / elsz);
> +  phandle_t    node,
> +  void       **buf
> +  size_t len;
> +  *buf = NULL;
> +    return -1;
> +  if (len > 0) {
> +    if (rtems_ofw_get_enc_prop(node, propname, *buf, len) == -1) {
> +      *buf = NULL;
> +      return -1;
> +  return len;
> +  phandle_t     node,
> +  int           elsz,
> +  void        **buf
> +  size_t len;
> +  *buf = NULL;
> +    return -1;
> +  if (len > 0) {
> +      *buf = NULL;
> +      return -1;
> +void rtems_ofw_free( void *buf )
> +  free(buf);
> +  phandle_t    node,
> +  char        *buf,
> +  size_t       len
> +  const void *name;
> +  const void *prop;
> +  int offset;
> +  if (offset < 0) {
> +    return -1;
> +  if (previous == NULL) {
> +    offset = fdt_first_property_offset(fdtp, offset);
> +  } else {
> +    fdt_for_each_property_offset(offset, fdtp, offset) {
> +      prop = fdt_getprop_by_offset(fdtp, offset, (const char **)&name,
> NULL);
> +      if (prop == NULL)
> +        return -1;
> +      if (strcmp(previous, name) != 0)
> +        continue;
> +      offset = fdt_next_property_offset(fdtp, offset);
> +      break;
> +  if (offset < 0)
> +    return 0;
> &offset);
> +  if (prop == NULL)
> +    return -1;
> +  strncpy(buf, name, len);
> +  return 1;
> +  phandle_t    node,
> +  const char  *name,
> +  const void  *buf,
> +  size_t       len
> +  int offset;
> +  if (offset < 0)
> +    return -1;
> +  if (fdt_setprop_inplace(fdtp, offset, name, buf, len) != 0)
> +    return (fdt_setprop(fdtp, offset, name, buf, len));
> +  return 0;
> +phandle_t rtems_ofw_find_device( const char *path )
> +  int offset;
> +  offset = fdt_path_offset(fdtp, path);
> +  if (offset < 0)
> +    return -1;
> +static phandle_t rtems_ofw_get_effective_phandle(
> +  phandle_t node,
> +  phandle_t xref
> +  phandle_t child;
> +  phandle_t ref;
> +  for (child = rtems_ofw_child(node); child != 0; child =
> rtems_ofw_peer(child)) {
> +    ref = rtems_ofw_get_effective_phandle(child, xref);
> +    if (ref != -1)
> +      return ref;
> +    if (rtems_ofw_get_enc_prop(child, "phandle", &ref, sizeof(ref)) == -1
> +        rtems_ofw_get_enc_prop(child, "ibm,phandle", &ref, sizeof(ref))
> == -1 &&
> +        rtems_ofw_get_enc_prop(child, "linux,phandle", &ref, sizeof(ref))
> == -1
> +      continue;
> +    if (ref == xref)
> +      return child;
> +  return -1;
> +phandle_t rtems_ofw_node_from_xref( phandle_t xref )
> +  phandle_t node;
> +  if ((node = rtems_ofw_get_effective_phandle(rtems_ofw_peer(0), xref))
> == -1)
> +    return xref;
> +  return node;
> +phandle_t rtems_ofw_xref_from_node( phandle_t node )
> +  phandle_t ref;
> +    if (rtems_ofw_get_enc_prop(node, "phandle", &ref, sizeof(ref)) == -1
> +        rtems_ofw_get_enc_prop(node, "ibm,phandle", &ref, sizeof(ref)) ==
> -1 &&
> +        rtems_ofw_get_enc_prop(node, "linux,phandle", &ref, sizeof(ref))
> == -1)
> +      return node;
> +    return ref;
> +phandle_t rtems_ofw_instance_to_package( ihandle_t instance )
> +  return rtems_ofw_node_from_xref(instance);
> +  phandle_t   node,
> +  char       *buf,
> +  size_t      len
> +  int offset;
> +  int rv;
> +  rv = fdt_get_path(fdtp, offset, buf, len);
> +  if (rv != 0)
> +    return -1;
> +  return rv;
> +  char      *buf,
> +  size_t     len
> +  int offset;
> +  int rv;
> +  offset = rtems_ofw_instance_to_package(instance);
> +  offset = rtems_fdt_phandle_to_offset(offset);
> +  if (rv != 0)
> +    return -1;
> +  return rv;
> +  phandle_t              node,
> +  size_t                 size
> +  int len;
> +  int offset;
> +  int nranges;
> +  int nregs;
> +  phandle_t parent;
> +  rtems_ofw_ranges range;
> +  const rtems_ofw_ranges *ptr;
> +  len = rtems_ofw_get_enc_prop(node, "reg", (pcell_t *)buf, size);
> +  if (len <= 0) {
> +    return len;
> +  nregs = MIN(len, size) / sizeof(rtems_ofw_memory_area);
> +  for (parent = rtems_ofw_parent(node); parent > 0;
> +      parent = rtems_ofw_parent(parent)) {
> +    offset = rtems_fdt_phandle_to_offset(parent);
> +    ptr = fdt_getprop(fdtp, offset, "ranges", &len);
> +    if (len < 0) {
> +      break;
> +    nranges = len / sizeof(rtems_ofw_ranges);
> +    offset = 0;
> +    for (int i=0; i < nregs; i++) {
> +      for (int j=0; j < nranges; j++) {
> +        range.parent_bus = fdt32_to_cpu(ptr[j].parent_bus);
> +        range.child_bus = fdt32_to_cpu(ptr[j].child_bus);
> +        range.size = fdt32_to_cpu(ptr[j].size);
> +        if (buf[i].start >= range.child_bus &&
> +            buf[i].start < range.child_bus + range.size) {
> +          offset = range.parent_bus - range.child_bus;
> +          break;
> +      buf[i].start += offset;
> +  return nregs;
> +  phandle_t            node,
> +  size_t               size
> +  int rv;
> +  rv = rtems_ofw_get_enc_prop(node, "interrupts", buf, size);
> +  if (rv <= 0) {
> +    return rv;
> +  return MIN(size, rv) / sizeof(rtems_vector_number);
> +  int len;
> +  const char buf[10];
> +  len = rtems_ofw_get_prop(node, "status", &buf[0], sizeof(buf));
> +  if ((len == -1) ||
> +      (strncmp(buf, "okay", MIN(5, len)) == 0) ||
> +      (strncmp(buf, "ok", MIN(3, len)) == 0)) {
> +      return true;
> +  return false;
> +  int offset;
> +  offset = fdt_node_offset_by_compatible(fdtp, -1, compat);
> diff --git a/spec/build/bsps/obj.yml b/spec/build/bsps/obj.yml
> index 8809238057..141ba25f5e 100644
> --- a/spec/build/bsps/obj.yml
> +++ b/spec/build/bsps/obj.yml
> @@ -24,6 +24,9 @@ install:
>    - bsps/include/bsp/u-boot.h
>    - bsps/include/bsp/uart-output-char.h
>    - bsps/include/bsp/utility.h
> +- destination: ${BSP_INCLUDEDIR}/ofw
> +  source:
> +  - bsps/include/ofw/ofw.h
>  - destination: ${BSP_INCLUDEDIR}/libchip
>    source:
>    - bsps/include/libchip/am29lv160.h
> @@ -104,4 +107,5 @@ source:
>  - bsps/shared/dev/serial/z85c30_reg.c
>  - bsps/shared/start/bootcard.c
>  - bsps/shared/rtems-version.c
> +- bsps/shared/ofw/ofw.c
>  type: build
> 2.17.1
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200821/42a906f9/attachment-0001.html>
