[PATCH v4 1/3] Strict thread-stack isolation
Utkarsh Rai
utkarsh.rai60 at gmail.com
Sat Aug 22 15:18:59 UTC 2020
- These patches are based on the new build system.
- Allocation of page aligned stack has been done through posix_memalign(),
which is a hack.
.../realview-pbx-a9/mmu/bsp-set-mmu-attr.c | 90 +++++++++++++
bsps/shared/start/stackalloc.c | 12 +-
cpukit/include/rtems/score/memoryprotection.h | 83 ++++++++++++
cpukit/include/rtems/score/stack.h | 56 ++++++++
cpukit/include/rtems/score/stackprotection.h | 80 +++++++++++
cpukit/posix/src/shmopen.c | 61 +++++++++
cpukit/score/cpu/arm/cpu_asm.S | 94 +++++++++++++
.../score/cpu/arm/include/rtems/score/cpu.h | 2 +-
cpukit/score/src/stackprotection.c | 125 ++++++++++++++++++
cpukit/score/src/threadhandler.c | 6 +
.../samples/thread_stack_protection/init.c | 114 ++++++++++++++++
.../thread_stack_protection.doc | 2 +
.../thread_stack_protection.scn | 20 +++
13 files changed, 743 insertions(+), 2 deletions(-)
create mode 100644 bsps/arm/realview-pbx-a9/mmu/bsp-set-mmu-attr.c
create mode 100644 cpukit/include/rtems/score/memoryprotection.h
create mode 100644 cpukit/include/rtems/score/stackprotection.h
create mode 100644 cpukit/score/src/stackprotection.c
create mode 100644 testsuites/samples/thread_stack_protection/init.c
create mode 100644 testsuites/samples/thread_stack_protection/thread_stack_protection.doc
create mode 100644 testsuites/samples/thread_stack_protection/thread_stack_protection.scn
diff --git a/bsps/arm/realview-pbx-a9/mmu/bsp-set-mmu-attr.c b/bsps/arm/realview-pbx-a9/mmu/bsp-set-mmu-attr.c
new file mode 100644
index 0000000000..4fba1e2b22
--- /dev/null
+++ b/bsps/arm/realview-pbx-a9/mmu/bsp-set-mmu-attr.c
@@ -0,0 +1,90 @@
+#include <bsp/arm-cp15-start.h>
+#include <rtems/score/memoryprotection.h>
+#include <rtems/score/thread.h>
+#include <libcpu/arm-cp15.h>
+#include <rtems.h>
+static uint32_t translate_flags(uint32_t attr_flags)
+ uint32_t flags;
+ uint32_t memory_attribute;
+ if( ( attr_flags & RTEMS_READ_WRITE ) == RTEMS_READ_WRITE ) {
+ flags |= ARMV7_MMU_READ_WRITE;
+ if ( ( attr_flags & RTEMS_READ_ONLY ) == RTEMS_READ_ONLY ) {
+ flags |= ARMV7_MMU_READ_ONLY;
+ if ( (attr_flags & RTEMS_NO_ACCESS ) == RTEMS_NO_ACCESS ) {
+ flags = 0;
+ * Check for memory-cache operation
+ if( attr_flags & RTEMS_MEMORY_CACHED ) {
+ flags |= ARM_MMU_SECT_TEX_0 | ARM_MMU_SECT_C | ARM_MMU_SECT_B;
+ return flags;
+static rtems_status_code validate_memory( uintptr_t begin, uintptr_t end )
+ /* We can set/unset the memory attributes of the regions between the bsp stack
+ * section and the workspace section only.
+ if( begin < bsp_section_stack_begin || end > bsp_section_work_end ) {
+ return RTEMS_INVALID_ADDRESS;
+ } else {
+ return RTEMS_SUCCESSFUL;
+rtems_status_code _Memory_protection_Set_entries(uintptr_t begin, size_t size, uint32_t flags)
+ uintptr_t end;
+ rtems_interrupt_level irq_level;
+ uint32_t access_flags;
+ end = begin + size;
+ if( validate_memory( begin, end ) == RTEMS_SUCCESSFUL ) {
+ access_flags = translate_flags(flags);
+ * The ARM reference manual instructs to disable all the interrupts before
+ * setting up page table entries.
+ rtems_interrupt_disable(irq_level);
+ arm_cp15_set_translation_table_entries(begin, end, access_flags);
+ rtems_interrupt_enable(irq_level);
+rtems_status_code _Memory_protection_Unset_entries(uintptr_t begin, size_t size)
+ uintptr_t end;
+ access_flags = translate_flags( RTEMS_READ_ONLY );
\ No newline at end of file
diff --git a/bsps/shared/start/stackalloc.c b/bsps/shared/start/stackalloc.c
index f7cf7be0f1..bf43e51198 100644
--- a/bsps/shared/start/stackalloc.c
+++ b/bsps/shared/start/stackalloc.c
@@ -25,6 +25,7 @@
#include <rtems/score/heapimpl.h>
#include <bsp/linker-symbols.h>
@@ -43,7 +44,15 @@ void bsp_stack_allocate_init(size_t stack_space_size)
void *bsp_stack_allocate(size_t size)
void *stack = NULL;
+#if defined (RTEMS_THREAD_STACK_PROTECTION)
+ * This is a temporary hack, we need to use _Heap_Allocate_aligned() but the heap
+ * initialization for bsp_stack_heap fails as bsp_section_stack_size is 0. See
+ * bsp_stack_allocate_init().
+ posix_memalign(&stack, 4096 , size);
+ _Memory_protection_Set_entries( stack, size, ( RTEMS_READ_ONLY | RTEMS_MEMORY_CACHED ) );
+#else
if (bsp_stack_heap.area_begin != 0) {
stack = _Heap_Allocate(&bsp_stack_heap, size);
@@ -51,6 +60,7 @@ void *bsp_stack_allocate(size_t size)
if (stack == NULL) {
stack = _Workspace_Allocate(size);
+#endif
return stack;
diff --git a/cpukit/include/rtems/score/memoryprotection.h b/cpukit/include/rtems/score/memoryprotection.h
index 0000000000..be4ce20b22
--- /dev/null
+++ b/cpukit/include/rtems/score/memoryprotection.h
@@ -0,0 +1,83 @@
+ * @file
+ * @ingroup RTEMSScoreMemoryprotection
+ * @brief This file provodes APIs for high-level memory protection
+ * Copyright (C) 2020 Utkarsh Rai
+ * are met:
+ * notice, this list of conditions and the following disclaimer.
+ * notice, this list of conditions and the following disclaimer in the
+ * documentation and/or other materials provided with the distribution.
+#ifndef _RTEMS_SCORE_MEMORYPROTECTION_H
+#define _RTEMS_SCORE_MEMORYPROTECTION_H
+#include <rtems/score/basedefs.h>
+#include <rtems.h>
+#ifdef __cplusplus
+extern "C" {
+#endif
+#define RTEMS_NO_ACCESS 0x00
+#define RTEMS_READ_ONLY 0x01
+#define RTEMS_WRITE_ONLY 0x02
+#define RTEMS_READ_WRITE ( RTEMS_READ_ONLY | RTEMS_WRITE_ONLY )
+#define RTEMS_MEMORY_CACHED 0x04
+ * @brief Define the memory access permission for the specified memory region
+ * @param begin_addr Beginning of the memory region
+ * @param size Size of the memory region
+ * @param flag Memory access flag
+ rtems_status_code _Memory_protection_Set_entries(
+ uintptr_t begin_addr,
+ size_t size,
+ uint32_t flag
+ * @brief Unset the memory access permission for the specified memory region
+ * This operation implicitly sets the specified memory region with 'NO_ACCESS'
+ * flag.
+ size_t size
+#ifdef __cplusplus
+#endif
+#endif
diff --git a/cpukit/include/rtems/score/stack.h b/cpukit/include/rtems/score/stack.h
index df1df74867..b067d5ed1b 100644
--- a/cpukit/include/rtems/score/stack.h
+++ b/cpukit/include/rtems/score/stack.h
@@ -23,6 +23,7 @@
#define _RTEMS_SCORE_STACK_H
+#include <rtems/confdefs.h>
#ifdef __cplusplus
extern "C" {
@@ -47,6 +48,44 @@ extern "C" {
#define STACK_MINIMUM_SIZE CPU_STACK_MINIMUM_SIZE
+ * The number of stacks that can be shared with a thread. Maybe this should be
+ * a configuration option provided in the rtems/confdefs.h?
+#if CONFIGURE_MAXIMUM_TASKS > 0
+#define SHARED_STACK_NUMBER CONFIGURE_MAXIMUM_TASKS - 1
+#else
+#define SHARED_STACK_NUMBER CONFIGURE_MAXIMUM_POSIX_THREADS - 1
+#endif
+#endif /* RTEMS_THREAD_STACK_PROTECTION */
+#if defined ( RTEMS_THREAD_STACK_PROTECTION )
+ * The following defines the control block of a shared stack. Each stack can have
+ * different sharing attributes.
+typedef struct
+ /** Access flags of the shared stack */
+ /** This is the stack address of the sharing thread*/
+ void* shared_stack_area;
+ /** Stack size of the sharing thread*/
+ size_t shared_stack_size;
+ /** This is the stack address of the target stack. Maybe this area is not
+ * needed but this helps in selecting the target thread during stack sharing.
+ void* target_stack_area;
+ /** Error checking for valid target stack address. This is also used to
+ * distinguish between a normal mmap operation and a stack sharing operation.
+ bool stack_shared;
+} Stack_Shared_attr;
+#endif
* The following defines the control block used to manage each stack.
@@ -55,6 +94,23 @@ typedef struct {
size_t size;
/** This is the low memory address of stack. */
void *area;
+ /** Page table base of the thread stack*/
+ uintptr_t page_table_base;
+ /** Memory access flags of the stack. */
+ /** The shared thread stacks with the target thread. We store the shared
+ * stacks in array, this helps in tracking them during context restoration/
+ * switch. We are using a separate structure for shared stacks, as this
+ * only has the attributes relevant to stack sharing. Having an option like
+ * Stack_Control shared_stacks[] will use up un-necessary memory.
+ Stack_Shared_attr shared_stacks[SHARED_STACK_NUMBER];
+ /** The total number of thread-stacks shared with the target thread.
+ * Note -We cannot have shares_stacks_count > SHARED_STACK_NUMBER.
+ uint32_t shared_stacks_count;
+#endif
} Stack_Control;
diff --git a/cpukit/include/rtems/score/stackprotection.h b/cpukit/include/rtems/score/stackprotection.h
index 0000000000..238ea64c49
--- /dev/null
+++ b/cpukit/include/rtems/score/stackprotection.h
@@ -0,0 +1,80 @@
+ * @file
+ * @ingroup RTEMSScoreStackprotection
+ * @brief Stackprotection API
+ * This include file provides the API for the management of protected thread-
+ * stacks
+ * COPYRIGHT (c) 2020 Utkarsh Rai.
+ * are met:
+#ifndef _RTEMS_SCORE_STACKPROTECTION_H
+#define _RTEMS_SCORE_STACKPROTECTION_H
+#include <rtems/score/stack.h>
+#ifdef __cplusplus
+extern "C" {
+#endif
+ * @brief Share the stack address of a given thread with the target thread.
+ * @param target_stack Stack address of the target thread
+ * @param sharing_stack Stack address of the sharin thread
+int _Stack_protection_Share_stack(
+ void *target_stack,
+ void *sharing_stack,
+ size_t size,
+ uint32_t memory_flag
+ * @brief Swap the restored shared stacks in the page table during context
+ * restoration
+ * We set the entries of the restored stack and mark all the remaining stacks as
+ * 'NO-ACCESS'.
+ * @param Control block of the restored stack
+void _Stack_protection_Context_restore(
+ Stack_Control *heir_stack
+#ifdef __cplusplus
+#endif
+#endif
diff --git a/cpukit/posix/src/shmopen.c b/cpukit/posix/src/shmopen.c
index d7f494fd22..1e7fda66f8 100644
--- a/cpukit/posix/src/shmopen.c
+++ b/cpukit/posix/src/shmopen.c
@@ -19,11 +19,13 @@
#include <unistd.h>
#include <fcntl.h>
#include <sys/stat.h>
+#include <string.h>
#include <rtems/libio_.h>
#include <rtems/seterr.h>
#include <rtems/posix/shmimpl.h>
+#include <rtems/posix/pthread.h>
#include <rtems/sysinit.h>
@@ -91,6 +93,61 @@ static int shm_ftruncate( rtems_libio_t *iop, off_t length )
return 0;
+static int shm_stack_ftruncate ( rtems_libio_t *iop, off_t length )
+ int err;
+ Objects_Id id;
+ Objects_Name_or_id_lookup_errors obj_err;
+ Thread_Control *Control;
+ ISR_lock_Context lock_context;
+ size_t size;
+ char *name;
+ POSIX_Shm_Control *shm = iop_to_shm ( iop );
+ name = shm->Object.name.name_p;
+ /** We assign fixed pattern of naming for thread-stacks, and treat them
+ * accordingly.
+ if( strncmp( name, "/taskfs/", 8) == 0 ) {
+ * Obtain the object id of the thread and then get the thread control block
+ * corresponding to that id.
+ obj_err = _Objects_Name_to_id_u32(
+ &_POSIX_Threads_Information.Objects,
+ _Objects_Build_name( name[8], name[9], name[10], name[11]),
+ RTEMS_LOCAL,
+ &id
+ Control = _Thread_Get( id, &lock_context );
+ if( Control != NULL ) {
+ shm->shm_object.handle = Control->Start.Initial_stack.area;
+ if( length != Control->Start.Initial_stack.size) {
+ return ENOMEM;
+ } else {
+ return ENOMEM;
+ }else{
+ _Objects_Allocator_lock();
+ err = (*shm->shm_object.ops->object_resize)( &shm->shm_object, length );
+ if ( err != 0 ) {
+ _Objects_Allocator_unlock();
+ rtems_set_errno_and_return_minus_one( err );
+ _POSIX_Shm_Update_mtime_ctime( shm );
+ return 0;
static int shm_close( rtems_libio_t *iop )
POSIX_Shm_Control *shm = iop_to_shm( iop );
@@ -306,7 +363,11 @@ static const rtems_filesystem_file_handlers_r shm_handlers = {
.ioctl_h = rtems_filesystem_default_ioctl,
.lseek_h = rtems_filesystem_default_lseek,
.fstat_h = shm_fstat,
+ #if defined ( RTEMS_THREAD_STACK_PROTECTION )
+ .ftruncate_h = shm_stack_ftruncate,
+ #else
.ftruncate_h = shm_ftruncate,
+ #endif
.fsync_h = rtems_filesystem_default_fsync_or_fdatasync,
.fdatasync_h = rtems_filesystem_default_fsync_or_fdatasync,
.fcntl_h = rtems_filesystem_default_fcntl,
diff --git a/cpukit/score/cpu/arm/cpu_asm.S b/cpukit/score/cpu/arm/cpu_asm.S
index 66f8ba6032..36b6c50f91 100644
--- a/cpukit/score/cpu/arm/cpu_asm.S
+++ b/cpukit/score/cpu/arm/cpu_asm.S
@@ -66,6 +66,73 @@ DEFINE_FUNCTION_ARM(_CPU_Context_switch)
str r3, [r0, #ARM_CONTEXT_CONTROL_ISR_DISPATCH_DISABLE]
+ * We make a function call to set the memory attributes of the heir
+ * stack and unset that of the executing stack (including shared stacks ).
+ * This will be a simple asm code when done by switching the translation
+ * table base.
+/* Save the registers modified during function call */
+ mov r8, r0
+ mov r9, r1
+ mov r10, r2
+/* Load the parameters for function call */
+ mov r0, r1
+ sub r0, r0, #102
+ ldr r1, [r0]
+ ldr r0, [r0, #4]
+ mov r2, #3
+ bl _Memory_protection_Set_entries
+/* Restore the saved registers */
+ mov r0, r8
+ mov r1, r9
+ mov r2, r10
+/* We load the stack-pointer of the heir thread pre-maturely, this is
+ * done as oherwise the *_unset_entries call will execute from the stack of the
+ * executing thread causing fatal exceptions.
+ ldr sp, [r1, #32]
+/* Load the parameters of the function call */
+ mov r1, r0
+ sub r0, r0, #102
+ ldr r1, [r0]
+ ldr r0, [r0, #4]
+ bl _Memory_protection_Unset_entries
+ * Restore the saved registers
+ mov r0, r8
+ mov r1, r9
+ mov r2, r10
+/* Unset the memory entries of the shared stack */
+ sub r0, r0, #102
+ add r6, r0, #16
+.L_shared_stack_restore:
+ ldr r1, [r6, #4]
+ ldr r0, [r6, #8]
+ add r6, #17
+ add r11, #1
+/* We compare with a hard-coded value, this is the number of shared stacks
+ * (SHARED_STACK_NUMBER)
+ cmp r11, #8
+ bne .L_shared_stack_restore
+ mov r0, r8
+ mov r1, r9
+ mov r2, r10
+#endif
#ifdef RTEMS_SMP
* The executing thread no longer executes on this processor. Switch
@@ -95,6 +162,7 @@ DEFINE_FUNCTION_ARM(_CPU_Context_switch)
/* Start restoring context */
.L_restore:
#if !defined(RTEMS_SMP) && defined(ARM_MULTILIB_HAS_LOAD_STORE_EXCLUSIVE)
clrex
#endif
@@ -133,7 +201,33 @@ DEFINE_FUNCTION_ARM(_CPU_Context_switch)
DEFINE_FUNCTION_ARM(_CPU_Context_restore)
mov r1, r0
GET_SELF_CPU_CONTROL r2
+ /* Save the registers modified during function call */
+ mov r8, r0
+ mov r9, r1
+ mov r10, r2
+ /* Load the parameters for function call */
+ mov r1, r0
+ sub r0, r0, #102
+ ldr r1, [r0]
+ ldr r0, [r0, #4]
+ mov r2, #3
+ /* Restore the saved registers */
+ mov r0, r8
+ mov r1, r9
+ mov r2, r10
+ /* Set memory entries of the shared thread stacks */
+#endif
b .L_restore
#ifdef RTEMS_SMP
diff --git a/cpukit/score/cpu/arm/include/rtems/score/cpu.h b/cpukit/score/cpu/arm/include/rtems/score/cpu.h
index b90fb1f394..28d5870856 100644
--- a/cpukit/score/cpu/arm/include/rtems/score/cpu.h
+++ b/cpukit/score/cpu/arm/include/rtems/score/cpu.h
@@ -138,7 +138,7 @@
/* AAPCS, section 5.2.1.2, Stack constraints at a public interface */
#define CPU_STACK_ALIGNMENT 8
-#define CPU_INTERRUPT_STACK_ALIGNMENT CPU_CACHE_LINE_BYTES
+#define CPU_INTERRUPT_STACK_ALIGNMENT 4096
* Bitfield handler macros.
diff --git a/cpukit/score/src/stackprotection.c b/cpukit/score/src/stackprotection.c
index 0000000000..cf2e44e63d
--- /dev/null
+++ b/cpukit/score/src/stackprotection.c
@@ -0,0 +1,125 @@
+ * @file
+ * are met:
+#ifdef HAVE_CONFIG_H
+#include "config.h"
+#endif
+#include <rtems.h>
+#include <rtems/score/stackprotection.h>
+#include <rtems/score/threadimpl.h>
+Stack_Control *heir_stack
+ void* stack_address;
+ size_t stack_size;
+ uint32_t memory_flags;
+ uint32_t index;
+ for(index = 0;index < heir_stack->shared_stacks_count; index++) {
+ stack_address = heir_stack->shared_stacks[index].shared_stack_area;
+ stack_size = heir_stack->shared_stacks[index].shared_stack_size;
+ _Memory_protection_Set_entries( stack_address, stack_size, memory_flags );
+static bool get_target_thread( Thread_Control *Control, void *arg)
+ Stack_Shared_attr *shared_stack;
+ uint32_t count;
+ shared_stack = arg;
+ rtems_status_code err;
+ * Check for the target thread by comparing the stack address. Add the shared stack
+ * attribute structure to the array tracking all the shared stacks.
+ if( Control->Start.Initial_stack.area == shared_stack->target_stack_area) {
+ count = Control->Start.Initial_stack.shared_stacks_count + 1;
+ if(count >= SHARED_STACK_NUMBER) {
+ return false;
+ Control->Start.Initial_stack.shared_stacks[count].access_flags =
+ shared_stack->access_flags;
+ Control->Start.Initial_stack.shared_stacks[count].shared_stack_area =
+ shared_stack->shared_stack_area;
+ Control->Start.Initial_stack.shared_stacks[count].shared_stack_size =
+ shared_stack->shared_stack_size;
+ Control->Start.Initial_stack.shared_stacks[count].target_stack_area =
+ shared_stack->target_stack_area;
+ Control->Start.Initial_stack.shared_stacks_count = count;
+ err = _Memory_protection_Set_entries(
+ shared_stack->shared_stack_area,
+ shared_stack->shared_stack_size,
+ shared_stack->access_flags );
+ if( err = RTEMS_SUCCESSFUL ) {
+ Control->Start.Initial_stack.shared_stacks[count].stack_shared =
+ shared_stack->stack_shared = true;
+ return true;
+ } else {
+ return false;
+ void* target_stack,
+ void* sharing_stack,
+ size_t size,
+ Thread_Control *target_thread;
+ Stack_Shared_attr shared_stack;
+ shared_stack.access_flags= memory_flag;
+ shared_stack.shared_stack_area = sharing_stack;
+ shared_stack.target_stack_area = target_stack;
+ shared_stack.shared_stack_size = size;
+ shared_stack.stack_shared = false;
+ _Thread_Iterate( get_target_thread, &shared_stack );
+ if( shared_stack.stack_shared == true ) {
+ return 0;
+ } else {
+ return -1;
diff --git a/cpukit/score/src/threadhandler.c b/cpukit/score/src/threadhandler.c
index 6742b0b391..de5ba8ea3b 100644
--- a/cpukit/score/src/threadhandler.c
+++ b/cpukit/score/src/threadhandler.c
@@ -22,6 +22,7 @@
#include <rtems/score/interr.h>
#include <rtems/score/isrlevel.h>
#include <rtems/score/userextimpl.h>
@@ -94,6 +95,11 @@ void _Thread_Handler( void )
level = executing->Start.isr_level;
_ISR_Set_level( level );
+ * Switch-out the shared thread-stacks
+ _Stackprotection_Context_restore( &executing->Start.Initial_stack );
* Initialize the floating point context because we do not come
* through _Thread_Dispatch on our first invocation. So the normal
diff --git a/testsuites/samples/thread_stack_protection/init.c b/testsuites/samples/thread_stack_protection/init.c
index 0000000000..d24d13850a
--- /dev/null
+++ b/testsuites/samples/thread_stack_protection/init.c
@@ -0,0 +1,114 @@
+#endif
+#include <rtems.h>
+#include <tmacros.h>
+#include <pthread.h>
+const char rtems_test_name[] = " THREAD STACK PROTECTION ";
+static void fatal_extension(
+ rtems_fatal_source source,
+ bool is_internal,
+ rtems_fatal_code error
+ if (source == RTEMS_FATAL_SOURCE_EXCEPTION)
+ printk("Internal Exception Occured \n");
+ exit(0);
+void* Test_routine( void* arg )
+void *POSIX_Init( void *argument )
+ void *stack_addr1;
+ void *stack_addr2;
+ size_t stack_size1;
+ size_t stack_size2;
+ pthread_t id1;
+ pthread_t id2;
+ pthread_attr_t attr1;
+ pthread_attr_t attr2;
+ Thread_Control Control;
+ TEST_BEGIN();
+ * We set the stack size as 8Kb.
+ stack_size1 = 8192;
+ stack_size2 = 8192;
+ printf("%d %d \n",sizeof(Control.Post_switch_actions), sizeof(Control.Start.tls_area));
+ * We allocate page-aligned memory of the stack from the application.
+ posix_memalign(&stack_addr1, sysconf( _SC_PAGESIZE ), stack_size1 );
+ posix_memalign(&stack_addr2, sysconf( _SC_PAGESIZE ), stack_size2 );
+ pthread_attr_init( &attr1 );
+ pthread_attr_init( &attr2 );
+ * We set the stack size and address of the thread from the application itself
+ pthread_attr_setstack( &attr1, stack_addr1, stack_size1 );
+ pthread_attr_setstack( &attr2, stack_addr2, stack_size2 );
+ pthread_create( &id1, &attr1, Test_routine, NULL );
+ pthread_create( &id2, &attr2, Test_routine, NULL );
+ * We set the memory attributes of the stack from the application.
+ _Memory_protection_Set_entries( stack_addr1, stack_size1, RTEMS_NO_ACCESS | RTEMS_MEMORY_CACHED );
+ _Memory_protection_Set_entries( stack_addr2, stack_size2, RTEMS_NO_ACCESS | RTEMS_MEMORY_CACHED );
+ pthread_join( id1, NULL );
+ * Write to the stack address of thread1 after it has been switched out.
+ printf("Writing to the stack of thread1 \n");
+ //memset(stack_addr1, 0, stack_size1);
+ pthread_join( id2, NULL );
+ * Write to the stack address of thread2 after it has been switched out.
+ TEST_END();
+ rtems_test_exit( 0 );
+/* configuration information */
+#define CONFIGURE_INIT
+#define CONFIGURE_APPLICATION_NEEDS_SIMPLE_CONSOLE_DRIVER
+#define CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
+#define CONFIGURE_INITIAL_EXTENSIONS RTEMS_TEST_INITIAL_EXTENSION
+#define CONFIGURE_MAXIMUM_POSIX_THREADS 2
+#define CONFIGURE_POSIX_INIT_THREAD_TABLE
+#define CONFIGURE_INITIAL_EXTENSIONS { .fatal = fatal_extension }
+#define CONFIGURE_TASK_STACK_ALLOCATOR_INIT bsp_stack_allocate_init
+#define CONFIGURE_TASK_STACK_ALLOCATOR bsp_stack_allocate
+#define CONFIGURE_TASK_STACK_DEALLOCATOR bsp_stack_free
+#include <bsp/stackalloc.h>
diff --git a/testsuites/samples/thread_stack_protection/thread_stack_protection.doc b/testsuites/samples/thread_stack_protection/thread_stack_protection.doc
index 0000000000..c5c9cdfa81
--- /dev/null
+++ b/testsuites/samples/thread_stack_protection/thread_stack_protection.doc
@@ -0,0 +1,2 @@
+This test sample demonstrates the thread stack protection functionality. We try
+to write to the stack of a switched-out thread.
diff --git a/testsuites/samples/thread_stack_protection/thread_stack_protection.scn b/testsuites/samples/thread_stack_protection/thread_stack_protection.scn
index 0000000000..1d36d0dfaf
--- /dev/null
+++ b/testsuites/samples/thread_stack_protection/thread_stack_protection.scn
@@ -0,0 +1,20 @@
+*** BEGIN OF TEST THREAD STACK PROTECTION ***
+*** TEST VERSION: 5.0.0.a3b39c9e567f3f1ef5ab01de78b113e61b11853b-modified
+*** TEST STATE: EXPECTED_PASS
+*** TEST BUILD: RTEMS_NETWORKING RTEMS_POSIX_API
+*** TEST TOOLS: 7.5.0 20191114 (RTEMS 5, RSB 5 (3bd11fd4898b), Newlib 7947581)
+Creating thread1
+Creating thread2
+Joining thread1
+Writing to the stack of thread1
+Internal Exception Occured
2.17.1
