[PATCH v2] bsps/shared/ofw: Implement RTEMS OFW interface
Niteesh G. S.
niteesh.gs at gmail.com
Sat Aug 22 16:45:11 UTC 2020
Hello,
I went through the history of the OF implementation in NetBSD and FreeBSD.
I have summarized the things I have found out below.
The first OF implementation seems to come from NetBSD this is actually BSD-4
licensed. FreeBSD and also other BSD have used this as the base and improved
the API. For eg functions like OF_getprop_allloc_multi, OF_getencprop were
not
present in the original OF interface but were added by FreeBSD. And also
NetBSD
doesn't use KOBJS for function dispatch but rather uses platform-specific
OF
implementation, that is FDT implementation is present under
sys/dev/fdt/fdt_openfirm.c
powerPC implementation under arch/powerpc/openfirm.c.
NetBSD openfirm.h:
https://github.com/NetBSD/src/blob/trunk/sys/dev/ofw/openfirm.h
And I think was adding the OF interface FreeBSD has added the BSD-2 license.
https://github.com/freebsd/freebsd/commit/d84d862cbd66f3f9ab4ce65fe69893664689c73b
This is the commit where they have added OF interface to FreeBSD and from
the
commit it seems like they have added the BSD-2 license with the interface
itself.
And the functions where we worry about the similarity are all FreeBSD
extension
so I guess we won't have any issue since they would come under BSD-2
license.
Thanks,
Niteesh.
On Sat, Aug 22, 2020 at 7:23 PM Gedare Bloom <gedare at rtems.org> wrote:
> On Fri, Aug 21, 2020 at 11:26 AM Niteesh G. S. <niteesh.gs at gmail.com>
> wrote:
> > On Fri, Aug 21, 2020 at 9:38 PM Gedare Bloom <gedare at rtems.org> wrote:
> >> Hi Niteesh,
> >> Can you explain how you developed the new code in a way that ensures
> >> that we do not have any of the previously 4-BSD licensed code left?
> > The FDT implementation of the OF interface present is ofw_fdt.c is,
> fortunately,
> > BSD-2 licensed so I was able to copy/reuse most of it for RTEMS ofw.c
> > The interface(openfirm.h) and the implementation(opefirm.c) that calls
> the
> > respective KOBJs functions are BSD-4 licensed. Since it was mentioned
> that
> > copying the interface is fine I don't think there is an issue with it.
> The OF
> > interface in RTEMS is present in ofw_compat.h
> > I also want to make note of one thing, there are few functions in ofw.c
> > which look exactly the same as the ones present in openfirm.c can you
> > please make sure that these functions won't cause any issues.
> > Few examples are, rtems_ofw_get_enc_prop_alloc,
> rtems_ofw_get_enc_prop_alloc_multi.
> The similarity in these functions is problematic.
> I still think it would be worth the trouble to try to dig through the
> history to find exactly what code was introduced with the 4-bsd. I
> would guess that came out of netbsd.
> > Thanks,
> > Niteesh.
> >> Gedare
> >> On Thu, Aug 20, 2020 at 1:52 AM G S Niteesh Babu <niteesh.gs at gmail.com>
> wrote:
> >> > RTEMS OFW is a FDT only implementation of the OpenFirmWare
> >> > interface. This API is created to be compatible with FreeBSD
> >> > OpenFirmWare interface. The main intention is to make
> >> > porting of FreeBSD drivers to RTEMS easier.
> >> > Most functions implemented have an direct one-one mapping
> >> > with the original OFW API and some extra auxiliary functions
> >> > were implemented to make working with device trees easier in
> >> > RTEMS.
> >> > Update #3784
> >> > bsps/include/ofw/ofw.h | 548 +++++++++++++++++++++++++++
> >> > bsps/include/ofw/ofw_compat.h | 74 ++++
> >> > bsps/shared/ofw/ofw.c | 670
> >> > spec/build/bsps/obj.yml | 4 +
> >> > 4 files changed, 1296 insertions(+)
> >> > create mode 100644 bsps/include/ofw/ofw.h
> >> > create mode 100644 bsps/include/ofw/ofw_compat.h
> >> > create mode 100644 bsps/shared/ofw/ofw.c
> >> > diff --git a/bsps/include/ofw/ofw.h b/bsps/include/ofw/ofw.h
> >> > new file mode 100644
> >> > index 0000000000..50f64ff695
> >> > --- /dev/null
> >> > +++ b/bsps/include/ofw/ofw.h
> >> > @@ -0,0 +1,548 @@
> >> > +/* SPDX-License-Identifier: BSD-2-Clause */
> >> > + * @file
> >> > + * @ingroup ofw
> >> > + * RTEMS FDT implementation of OpenFirmWare Interface.
> >> > + * RTEMS OFW is a FDT only implementation of the OpenFirmWare
> interface.
> >> > + * This API is created to be compatible with FreeBSD OpenFirmWare
> interface.
> >> > + * The main intention is to make porting of FreeBSD drivers to RTEMS
> easier.
> >> > + * Copyright (C) 2020 Niteesh Babu G S <niteesh.gs at gmail.com>
> >> > + * Redistribution and use in source and binary forms, with or without
> >> > + * modification, are permitted provided that the following conditions
> >> > + * are met:
> >> > + * 1. Redistributions of source code must retain the above copyright
> >> > + * notice, this list of conditions and the following disclaimer.
> >> > + * 2. Redistributions in binary form must reproduce the above
> copyright
> in the
> >> > + * documentation and/or other materials provided with the
> distribution.
> >> > + * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND
> CONTRIBUTORS "AS IS"
> >> > + * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED
> TO, THE
> >> > + * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A
> PARTICULAR PURPOSE
> >> > + * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR
> CONTRIBUTORS BE
> >> > + * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY,
> OR
> >> > + * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT
> OF
> >> > + * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR
> BUSINESS
> >> > + * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY,
> WHETHER IN
> >> > + * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR
> OTHERWISE)
> >> > + * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF
> ADVISED OF THE
> >> > + * POSSIBILITY OF SUCH DAMAGE.
> >> > +#ifndef _OFW_H
> >> > +#define _OFW_H
> >> > +#ifdef __cplusplus
> >> > +extern "C" {
> >> > +#endif
> >> > +#include <rtems.h>
> >> > +#include <stdint.h>
> >> > +#include <stddef.h>
> >> > + * Represents a node in the device tree. The offset from fdtp to
> node is used
> >> > + * instead of fdt offset to make sure this is compatible with OF
> interface in
> >> > + * FreeBSD.
> >> > +typedef uint32_t phandle_t;
> >> > + * Represents the effective phandle of the node.
> >> > +typedef uint32_t ihandle_t;
> >> > + * Represents the data type of the buffer.
> >> > +typedef uint32_t pcell_t;
> >> > + * @struct rtems_ofw_memory_area
> >> > + * This is used to represent elements(FDT properties) that define
> >> > + * region of memory address.
> >> > +typedef struct {
> >> > + /** The start address of the memory region. */
> >> > + uint32_t start;
> >> > + /** The size of the memory region. */
> >> > + uint32_t size;
> >> > +} rtems_ofw_memory_area;
> >> > + * @struct rtems_ofw_ranges
> >> > + * This is used to represent the ranges property in the device tree.
> >> > +typedef struct {
> >> > + /** The physical address within the child bus address space */
> >> > + uint32_t child_bus;
> >> > + /** The physical address within the parent bus address space */
> >> > + uint32_t parent_bus;
> >> > + /** The size of the range in the child’s address space */
> >> > + uint32_t size;
> >> > +} rtems_ofw_ranges;
> >> > + * @brief Gets the node that is next to @a node.
> >> > + * @param[in] node Node offset
> >> > + * @retval Peer node offset Successful operation.
> >> > + * @retval 0 No peer node or invalid node handle
> >> > +phandle_t rtems_ofw_peer(
> >> > + phandle_t node
> >> > + * @brief Gets the node that is the child of @a node.
> >> > + * @retval child node offset Successful operation.
> >> > + * @retval 0 No child node or invalid node handle
> >> > +phandle_t rtems_ofw_child(
> >> > + phandle_t node
> >> > + * @brief Gets the node that is the parent of @a node.
> >> > +phandle_t rtems_ofw_parent(
> >> > + phandle_t node
> >> > + * @brief Gets the length of the property mentioned in @a propname.
> >> > + * @param[in] prop Property name
> >> > + * @retval -1 Invalid node or property
> >> > + * @retval Length of property on successful operation
> >> > +size_t rtems_ofw_get_prop_len(
> >> > + phandle_t node,
> >> > + const char *propname
> >> > + * @brief Gets the value of property mentioned in @a propname.
> >> > + * @param[out] buf The property value gets stored in this buffer
> (Pre-allocated)
> >> > + * @param[in] len Length of the buffer
> >> > +size_t rtems_ofw_get_prop(
> >> > + phandle_t node,
> >> > + const char *propname,
> >> > + void *buf,
> >> > + size_t len
> >> > + * @brief Gets the value of property mentioned in @a prop.
> >> > + * Gets the value of property of @a node and converts the value into
> the host's
> >> > + * endianness.
> buffer(Pre-allocated)
> >> > + * after converted to the host's endianness
> >> > +size_t rtems_ofw_get_enc_prop(
> >> > + phandle_t node,
> >> > + const char *prop,
> >> > + pcell_t *buf,
> >> > + size_t len
> >> > + * @brief Checks if the property @a propname is present in @a node.
> >> > + * @param[in] propname Property name
> >> > + * @retval 0 Property not present.
> >> > + * @retval 1 Property is present.
> >> > +int rtems_ofw_has_prop(
> >> > + phandle_t node,
> >> > + * @brief Searches for property @a propname in @a node.
> >> > + * Searches the node and its parent recursively for the property and
> fills the
> >> > + * buffer with the first found value.
> (Pre-allocated)
> >> > + * @retval Length of the property if property is found.
> >> > + * @retval -1 Property is not found.
> >> > +size_t rtems_ofw_search_prop(
> >> > + phandle_t node,
> >> > + void *buf,
> >> > + size_t len
> fills the
> >> > + * buffer with the first value found after converting it to the
> endianness of
> >> > + * the host.
> >> > +size_t rtems_ofw_search_enc_prop(
> >> > + phandle_t node,
> >> > + pcell_t *buf,
> >> > + size_t len
> >> > + * Same as rtems_ofw_getprop, but the @a buf is allocated in this
> routine and
> >> > + * the user is responsible for freeing it.
> >> > + * @param[out] buf The buffer is allocated in this routine and user
> is
> >> > + * responsible for freeing.
> >> > +size_t rtems_ofw_get_prop_alloc(
> >> > + phandle_t node,
> >> > + void **buf
> >> > + * @brief Gets multiple values of the property @a propname.
> >> > + * Same as rtems_ofw_getprop_alloc but it can read properties with
> multiple
> >> > + * values.
> >> > + * For eg: reg = <0x1000 0x10 0x2000 0x20>
> >> > + * @param[in] elsz Size of the single value
> is
> >> > + * @retval Number of values read.
> >> > +size_t rtems_ofw_get_prop_alloc_multi(
> >> > + phandle_t node,
> >> > + int elsz,
> >> > + void **buf
> >> > + * Same as rtems_ofw_getprop_alloc but the value stored in the
> buffer is
> >> > + * converted into the host's endianness.
> is
> >> > +size_t rtems_ofw_get_enc_prop_alloc(
> >> > + phandle_t node,
> >> > + void **buf
> >> > + * Same as rtems_ofw_getprop_alloc_multi but the values stored in
> the buffer
> >> > + * are converted to the host's endianness.
> is
> >> > +size_t rtems_ofw_get_enc_prop_alloc_multi(
> >> > + phandle_t node,
> >> > + int elsz,
> >> > + void **buf
> >> > + * @brief Free's the buffers allocated by the rtems_ofw_*_alloc
> functions.
> >> > + * @param[in] buf Buffer to be freed
> >> > +void rtems_ofw_free(
> >> > + void *buf
> >> > + * @brief Finds the next property of @a node.
> >> > + * Finds the next property of the node and when @a propname is NULL
> it returns
> >> > + * the value in the first property.
> >> > + * @param[in] previous Previous property name
> >> > + * @param[out] buf The value of the next property gets stored in
> this buffer
> >> > + * (Pre-allocated)
> >> > + * @retval -1 node or previous property does not exist
> >> > + * @retval 0 no more properties
> >> > + * @retval 1 success
> >> > +int rtems_ofw_next_prop(
> >> > + phandle_t node,
> >> > + const char *previous,
> >> > + char *buf,
> >> > + size_t len
> >> > + * @brief Sets the property @name of @a node to @a buf.
> >> > + * @param[in] name Property name
> >> > + * @param[in] buf Buffer contains the value to be set.
> >> > + * @retval -1 node does not exist
> >> > + * @retval 0 on success
> >> > + * @retval libFDT error codes on unsuccessful setting operation
> >> > +int rtems_ofw_set_prop(
> >> > + phandle_t node,
> >> > + const char *name,
> >> > + const void *buf,
> >> > + size_t len
> >> > + * @brief Converts a device specifier to a fully qualified path name.
> >> > + * @param[in] dev device specifier
> >> > + * @param[out] buf The path is filled into the buffer(Pre-allocated)
> >> > + * @param[in] length of the buffer
> >> > + * @retval -1 always. Unimplemented.
> >> > +size_t rtems_ofw_canon(
> >> > + const char *dev,
> >> > + char *buf,
> >> > + size_t len
> >> > + * @brief Finds the node at the given path
> >> > + * @param[in] path to the node from root
> >> > + * @retval node handle on success
> >> > +phandle_t rtems_ofw_find_device(
> >> > + const char *path
> >> > + * @brief This routine converts effective phandle @a xref to node
> offset.
> >> > + * @param[in] xref Node phandle
> >> > + * @retval Node offset on success
> >> > + * @retval Node phandle on failure
> >> > +phandle_t rtems_ofw_node_from_xref(
> >> > + phandle_t xref
> >> > + * @brief This routine converts node offset to effective phandle of
> @a node.
> >> > + * @retval Node phandle on success
> >> > + * @retval Node offset on failure
> >> > +phandle_t rtems_ofw_xref_from_node(
> >> > + phandle_t node
> >> > + * instance handles(ihandle_t) as same as phandles in the FDT
> implementation
> >> > + * of OF interface.
> >> > + * @brief Converts @a instance handle to phandle.
> >> > + * instance are same as node offsets in FDT.
> >> > + * @param[in] instance Node offset
> >> > + * @retval phandle of node on success.
> >> > + * @retval instance of node on failure.
> >> > +phandle_t rtems_ofw_instance_to_package(
> >> > + ihandle_t instance
> >> > + * @brief Find the node's path from phandle.
> >> > + * @param[out] buf Path is filled into this buffer(Pre-allocated).
> >> > + * @param[in] len Length of the buffer.
> >> > +size_t rtems_ofw_package_to_path(
> >> > + phandle_t node,
> >> > + char *buf,
> >> > + size_t len
> >> > + * @brief Find the node's path from ihandle.
> >> > +size_t rtems_ofw_instance_to_path(
> >> > + ihandle_t instance,
> >> > + char *buf,
> >> > + size_t len
> >> > + * @brief Queries the node's reg value.
> >> > + * This routine fills the buffer @a buf with the values in reg
> property of node
> >> > + * @a node. It reads all the values of the property and fills the
> buffer to max
> >> > + * size.
> >> > + * This routine is local to RTEMS OFW and does not have an
> corresponding
> >> > + * FreeBSD OFW pair.
> >> > + * @param[out] buf Register values are stored in this
> >> > + * @param[in] size Length of the buffer.
> >> > + * @retval -1 If reg property is missing.
> >> > + * @retval Length of the reg property in bytes.
> >> > +int rtems_ofw_get_reg(
> >> > + phandle_t node,
> >> > + rtems_ofw_memory_area *buf,
> >> > + size_t size
> >> > + * @brief Queries the node's interrupt value.
> >> > + * This routine fills the buffer @a buf with the interrupt number.
> In case of
> >> > + * multiple numbers it fills the buffer to its full extent.
> corresponding
> >> > + * @param[out] buf Interrupt values are stored in this
> >> > + * @retval -1 If interrupts property is missing.
> >> > + * @retval The number of interrupt numbers read.
> >> > +int rtems_ofw_get_interrupts(
> >> > + phandle_t node,
> >> > + rtems_vector_number *buf,
> >> > + size_t size
> >> > + * @brief Queries the node's status.
> corresponding
> >> > + * @retval true Status is OK or empty.
> >> > + * @retval false Status is not OK or missing.
> >> > +bool rtems_ofw_node_status( phandle_t node );
> >> > + * @brief Gets node phandle from compatible property.
> corresponding
> >> > + * @param[in] compat Compatible string
> >> > + * @retval 0 Node with @a compat as compatible string not found
> >> > + * @retval Node phandle on success.
> >> > +phandle_t rtems_ofw_find_device_by_compat( const char *compat );
> >> > +#ifdef __cplusplus
> >> > +#endif
> >> > +#endif /* _OFW_H */
> >> > diff --git a/bsps/include/ofw/ofw_compat.h
> b/bsps/include/ofw/ofw_compat.h
> >> > index 0000000000..be4a5ea3ce
> >> > --- /dev/null
> >> > +++ b/bsps/include/ofw/ofw_compat.h
> >> > @@ -0,0 +1,74 @@
> >> > + * @file
> >> > + * @ingroup ofw
> >> > + * This file defines necessary symbols to make the RTEMS OFW API
> compatible
> >> > + * with FreeBSD OFW.
> >> > + * are met:
> copyright
> in the
> distribution.
> TO, THE
> PARTICULAR PURPOSE
> CONTRIBUTORS BE
> OR
> OF
> BUSINESS
> WHETHER IN
> OTHERWISE)
> ADVISED OF THE
> >> > +#ifndef _OFW_COMPAT_H
> >> > +#define _OFW_COMPAT_H
> >> > +#ifdef __cplusplus
> >> > +extern "C" {
> >> > +#endif
> >> > +#include <ofw/ofw.h>
> >> > +#define OF_peer rtems_ofw_peer
> >> > +#define OF_child rtems_ofw_child
> >> > +#define OF_parent rtems_ofw_parent
> >> > +#define OF_getproplen rtems_ofw_get_prop_len
> >> > +#define OF_getprop rtems_ofw_get_prop
> >> > +#define OF_getencprop rtems_ofw_get_enc_prop
> >> > +#define OF_hasprop rtems_ofw_has_prop
> >> > +#define OF_searchprop rtems_ofw_search_prop
> >> > +#define OF_searchencprop rtems_ofw_search_enc_prop
> >> > +#define OF_getprop_alloc rtems_ofw_get_prop_alloc
> >> > +#define OF_getprop_alloc_multi rtems_ofw_get_prop_alloc_multi
> >> > +#define OF_getencprop_alloc_multi rtems_ofw_get_enc_prop_alloc_multi
> >> > +#define OF_getencprop_alloc rtems_ofw_get_enc_prop_alloc
> >> > +#define OF_prop_free rtems_ofw_free
> >> > +#define OF_nextprop rtems_ofw_next_prop
> >> > +#define OF_setprop rtems_ofw_set_prop
> >> > +#define OF_canon rtems_ofw_canon
> >> > +#define OF_finddevice rtems_ofw_find_device
> >> > +#define OF_package_to_path rtems_ofw_package_to_path
> >> > +#define OF_node_from_xref rtems_ofw_node_from_xref
> >> > +#define OF_xref_from_node rtems_ofw_xref_from_node
> >> > +#define OF_instance_to_package rtems_ofw_instance_to_package
> >> > +#define OF_instance_to_path rtems_ofw_instance_to_path
> >> > +#ifdef __cplusplus
> >> > +#endif
> >> > +#endif /* _OFW_COMPAT_H */
> >> > diff --git a/bsps/shared/ofw/ofw.c b/bsps/shared/ofw/ofw.c
> >> > index 0000000000..481b29553b
> >> > --- /dev/null
> >> > +++ b/bsps/shared/ofw/ofw.c
> >> > @@ -0,0 +1,670 @@
> >> > + * @file
> >> > + * @ingroup ofw
> >> > + * are met:
> copyright
> in the
> distribution.
> TO, THE
> PARTICULAR PURPOSE
> CONTRIBUTORS BE
> OR
> OF
> BUSINESS
> WHETHER IN
> OTHERWISE)
> ADVISED OF THE
> >> > +#ifdef HAVE_CONFIG_H
> >> > +#include "config.h"
> >> > +#endif
> >> > +#include <bsp/fdt.h>
> >> > +#include <sys/param.h>
> >> > +#include <libfdt.h>
> >> > +#include <assert.h>
> >> > +#include <rtems/sysinit.h>
> >> > +const void *fdtp = NULL;
> >> > +static phandle_t rtems_fdt_offset_to_phandle( int offset )
> >> > + if (offset < 0) {
> >> > + return 0;
> >> > + return (phandle_t)offset + fdt_off_dt_struct(fdtp);
> >> > +static int rtems_fdt_phandle_to_offset( phandle_t handle )
> >> > + int off;
> >> > + int fdt_off;
> >> > + off = (int) handle;
> >> > + fdt_off = fdt_off_dt_struct(fdtp);
> >> > + if (off < fdt_off) {
> >> > + return -1;
> >> > + return off - fdt_off;
> >> > +static void rtems_ofw_init( void ) {
> >> > + int rv;
> >> > + const void *fdt;
> >> > + fdt = bsp_fdt_get();
> >> > + rv = fdt_check_header(fdt);
> >> > + * If the FDT is invalid exit through fatal.
> >> > + if (rv != 0) {
> >> > + rtems_fatal_error_occurred(RTEMS_NOT_CONFIGURED);
> >> > + fdtp = fdt;
> >> > +RTEMS_SYSINIT_ITEM(
> >> > + rtems_ofw_init,
> >> > + RTEMS_SYSINIT_BSP_PRE_DRIVERS,
> >> > + RTEMS_SYSINIT_ORDER_FIRST
> >> > +phandle_t rtems_ofw_peer( phandle_t node )
> >> > + int offset;
> >> > + if (node == 0) {
> >> > + int root = fdt_path_offset(fdtp, "/");
> >> > + return rtems_fdt_offset_to_phandle(root);
> >> > + offset = rtems_fdt_phandle_to_offset(node);
> >> > + if (offset < 0) {
> >> > + return 0;
> >> > + offset = fdt_next_subnode(fdtp, offset);
> >> > + return rtems_fdt_offset_to_phandle(offset);
> >> > +phandle_t rtems_ofw_child( phandle_t node )
> >> > + int offset;
> >> > + if (offset < 0) {
> >> > + return 0;
> >> > + offset = fdt_first_subnode(fdtp, offset);
> >> > +phandle_t rtems_ofw_parent( phandle_t node )
> >> > + int offset;
> >> > + if (offset < 0) {
> >> > + return 0;
> >> > + offset = fdt_parent_offset(fdtp, offset);
> >> > + phandle_t node,
> >> > + int offset;
> >> > + int len;
> >> > + const void *prop;
> >> > + if (offset < 0) {
> >> > + return -1;
> >> > + prop = fdt_getprop(fdtp, offset, propname, &len);
> >> > + if (prop == NULL && strcmp(propname, "name") == 0) {
> >> > + fdt_get_name(fdtp, offset, &len);
> >> > + return len + 1;
> >> > + if (prop == NULL && strcmp(propname, "/chosen") == 0) {
> >> > + if (strcmp(propname, "fdtbootcpu") == 0)
> >> > + return sizeof(pcell_t);
> >> > + if (strcmp(propname, "fdtmemreserv") == 0)
> >> > + return 2 * sizeof(uint64_t) * fdt_num_mem_rsv(fdtp);
> >> > + if (prop == NULL) {
> >> > + return -1;
> >> > + return len;
> >> > + phandle_t node,
> >> > + void *buf,
> >> > + size_t bufsize
> >> > + const void *prop;
> >> > + int offset;
> >> > + int len;
> >> > + uint32_t cpuid;
> >> > + if (offset < 0) {
> >> > + return -1;
> >> > + prop = fdt_get_name(fdtp, offset, &len);
> >> > + strncpy(buf, prop, bufsize);
> >> > + return len + 1;
> >> > + if (strcmp(propname, "fdtbootcpu") == 0) {
> >> > + cpuid = cpu_to_fdt32(fdt_boot_cpuid_phys(fdtp));
> >> > + len = sizeof(cpuid);
> >> > + prop = &cpuid;
> >> > + if (strcmp(propname, "fdtmemreserv") == 0) {
> >> > + prop = (char *)fdtp + fdt_off_mem_rsvmap(fdtp);
> >> > + len = sizeof(uint64_t)*2*fdt_num_mem_rsv(fdtp);
> >> > + return -1;
> >> > + bcopy(prop, buf, MIN(len, bufsize));
> >> > + return len;
> >> > + phandle_t node,
> >> > + const char *prop,
> >> > + pcell_t *buf,
> >> > + size_t len
> >> > + size_t rv;
> >> > + assert(len % 4 == 0);
> >> > + rv = rtems_ofw_get_prop(node, prop, buf, len);
> >> > + if (rv < 0) {
> >> > + return rv;
> >> > + for (int i = 0; i < (len / 4); i++) {
> >> > + buf[i] = fdt32_to_cpu(buf[i]);
> >> > + return rv;
> >> > + phandle_t node,
> >> > + size_t rv;
> >> > + rv = rtems_ofw_get_prop_len(node, propname);
> >> > + return rv >= 0 ? 1 : 0;
> >> > + phandle_t node,
> >> > + void *buf,
> >> > + size_t len
> >> > + size_t rv;
> >> > + for (; node != 0; node = rtems_ofw_parent(node)) {
> >> > + if ((rv = rtems_ofw_get_prop(node, propname, buf, len) != -1)) {
> >> > + return rv;
> >> > + return -1;
> >> > + phandle_t node,
> >> > + pcell_t *buf,
> >> > + size_t len
> >> > + size_t rv;
> >> > + if ((rv = rtems_ofw_get_enc_prop(node, propname, buf, len) !=
> -1)) {
> >> > + return rv;
> >> > + return -1;
> >> > + phandle_t node,
> >> > + void **buf
> >> > + size_t len;
> >> > + *buf = NULL;
> >> > + if ((len = rtems_ofw_get_prop_len(node, propname)) == -1) {
> >> > + return -1;
> >> > + if (len > 0) {
> >> > + *buf = malloc(len);
> >> > + if (rtems_ofw_get_prop(node, propname, *buf, len) == -1) {
> >> > + rtems_ofw_free(buf);
> >> > + *buf = NULL;
> >> > + return -1;
> >> > + return len;
> >> > + phandle_t node,
> >> > + int elsz,
> >> > + void **buf
> >> > + size_t len;
> >> > + *buf = NULL;
> >> > + if ((len = rtems_ofw_get_prop_len(node, propname)) == -1 ||
> >> > + (len % elsz != 0)) {
> >> > + return -1;
> >> > + if (len > 0) {
> >> > + *buf = NULL;
> >> > + return -1;
> >> > + return (len / elsz);
> >> > + phandle_t node,
> >> > + void **buf
> >> > + size_t len;
> >> > + *buf = NULL;
> >> > + return -1;
> >> > + if (len > 0) {
> >> > + if (rtems_ofw_get_enc_prop(node, propname, *buf, len) == -1) {
> >> > + *buf = NULL;
> >> > + return -1;
> >> > + return len;
> >> > + phandle_t node,
> >> > + int elsz,
> >> > + void **buf
> >> > + size_t len;
> >> > + *buf = NULL;
> >> > + return -1;
> >> > + if (len > 0) {
> >> > + *buf = NULL;
> >> > + return -1;
> >> > +void rtems_ofw_free( void *buf )
> >> > + free(buf);
> >> > + phandle_t node,
> >> > + char *buf,
> >> > + size_t len
> >> > + const void *name;
> >> > + const void *prop;
> >> > + int offset;
> >> > + if (offset < 0) {
> >> > + return -1;
> >> > + if (previous == NULL) {
> >> > + offset = fdt_first_property_offset(fdtp, offset);
> >> > + } else {
> >> > + fdt_for_each_property_offset(offset, fdtp, offset) {
> >> > + prop = fdt_getprop_by_offset(fdtp, offset, (const char
> **)&name, NULL);
> >> > + if (prop == NULL)
> >> > + return -1;
> >> > + if (strcmp(previous, name) != 0)
> >> > + continue;
> >> > + offset = fdt_next_property_offset(fdtp, offset);
> >> > + break;
> >> > + if (offset < 0)
> >> > + return 0;
> >> > + prop = fdt_getprop_by_offset(fdtp, offset, (const char **)&name,
> &offset);
> >> > + if (prop == NULL)
> >> > + return -1;
> >> > + strncpy(buf, name, len);
> >> > + return 1;
> >> > + phandle_t node,
> >> > + const char *name,
> >> > + const void *buf,
> >> > + size_t len
> >> > + int offset;
> >> > + if (offset < 0)
> >> > + return -1;
> >> > + if (fdt_setprop_inplace(fdtp, offset, name, buf, len) != 0)
> >> > + return (fdt_setprop(fdtp, offset, name, buf, len));
> >> > + return 0;
> >> > +phandle_t rtems_ofw_find_device( const char *path )
> >> > + int offset;
> >> > + offset = fdt_path_offset(fdtp, path);
> >> > + if (offset < 0)
> >> > + return -1;
> >> > +static phandle_t rtems_ofw_get_effective_phandle(
> >> > + phandle_t node,
> >> > + phandle_t xref
> >> > + phandle_t child;
> >> > + phandle_t ref;
> >> > + for (child = rtems_ofw_child(node); child != 0; child =
> rtems_ofw_peer(child)) {
> >> > + ref = rtems_ofw_get_effective_phandle(child, xref);
> >> > + if (ref != -1)
> >> > + return ref;
> >> > + if (rtems_ofw_get_enc_prop(child, "phandle", &ref, sizeof(ref))
> == -1 &&
> >> > + rtems_ofw_get_enc_prop(child, "ibm,phandle", &ref,
> sizeof(ref)) == -1 &&
> >> > + rtems_ofw_get_enc_prop(child, "linux,phandle", &ref,
> sizeof(ref)) == -1
> >> > + continue;
> >> > + if (ref == xref)
> >> > + return child;
> >> > + return -1;
> >> > +phandle_t rtems_ofw_node_from_xref( phandle_t xref )
> >> > + phandle_t node;
> >> > + if ((node = rtems_ofw_get_effective_phandle(rtems_ofw_peer(0),
> xref)) == -1)
> >> > + return xref;
> >> > + return node;
> >> > +phandle_t rtems_ofw_xref_from_node( phandle_t node )
> >> > + phandle_t ref;
> >> > + if (rtems_ofw_get_enc_prop(node, "phandle", &ref, sizeof(ref))
> == -1 &&
> >> > + rtems_ofw_get_enc_prop(node, "ibm,phandle", &ref,
> >> > + rtems_ofw_get_enc_prop(node, "linux,phandle", &ref,
> sizeof(ref)) == -1)
> >> > + return node;
> >> > + return ref;
> >> > +phandle_t rtems_ofw_instance_to_package( ihandle_t instance )
> >> > + return rtems_ofw_node_from_xref(instance);
> >> > + phandle_t node,
> >> > + char *buf,
> >> > + size_t len
> >> > + int offset;
> >> > + int rv;
> >> > + rv = fdt_get_path(fdtp, offset, buf, len);
> >> > + if (rv != 0)
> >> > + return -1;
> >> > + return rv;
> >> > + char *buf,
> >> > + size_t len
> >> > + int offset;
> >> > + int rv;
> >> > + offset = rtems_ofw_instance_to_package(instance);
> >> > + offset = rtems_fdt_phandle_to_offset(offset);
> >> > + if (rv != 0)
> >> > + return -1;
> >> > + return rv;
> >> > + phandle_t node,
> >> > + size_t size
> >> > + int len;
> >> > + int offset;
> >> > + int nranges;
> >> > + int nregs;
> >> > + phandle_t parent;
> >> > + rtems_ofw_ranges range;
> >> > + const rtems_ofw_ranges *ptr;
> >> > + len = rtems_ofw_get_enc_prop(node, "reg", (pcell_t *)buf, size);
> >> > + if (len <= 0) {
> >> > + return len;
> >> > + nregs = MIN(len, size) / sizeof(rtems_ofw_memory_area);
> >> > + for (parent = rtems_ofw_parent(node); parent > 0;
> >> > + parent = rtems_ofw_parent(parent)) {
> >> > + offset = rtems_fdt_phandle_to_offset(parent);
> >> > + ptr = fdt_getprop(fdtp, offset, "ranges", &len);
> >> > + if (len < 0) {
> >> > + break;
> >> > + nranges = len / sizeof(rtems_ofw_ranges);
> >> > + offset = 0;
> >> > + for (int i=0; i < nregs; i++) {
> >> > + for (int j=0; j < nranges; j++) {
> >> > + range.parent_bus = fdt32_to_cpu(ptr[j].parent_bus);
> >> > + range.child_bus = fdt32_to_cpu(ptr[j].child_bus);
> >> > + range.size = fdt32_to_cpu(ptr[j].size);
> >> > + if (buf[i].start >= range.child_bus &&
> >> > + buf[i].start < range.child_bus + range.size) {
> >> > + offset = range.parent_bus - range.child_bus;
> >> > + break;
> >> > + buf[i].start += offset;
> >> > + return nregs;
> >> > + phandle_t node,
> >> > + size_t size
> >> > + int rv;
> >> > + rv = rtems_ofw_get_enc_prop(node, "interrupts", buf, size);
> >> > + if (rv <= 0) {
> >> > + return rv;
> >> > + return MIN(size, rv) / sizeof(rtems_vector_number);
> >> > + int len;
> >> > + const char buf[10];
> >> > + len = rtems_ofw_get_prop(node, "status", &buf[0], sizeof(buf));
> >> > + if ((len == -1) ||
> >> > + (strncmp(buf, "okay", MIN(5, len)) == 0) ||
> >> > + (strncmp(buf, "ok", MIN(3, len)) == 0)) {
> >> > + return true;
> >> > + return false;
> >> > + int offset;
> >> > + offset = fdt_node_offset_by_compatible(fdtp, -1, compat);
> >> > diff --git a/spec/build/bsps/obj.yml b/spec/build/bsps/obj.yml
> >> > index 8809238057..141ba25f5e 100644
> >> > --- a/spec/build/bsps/obj.yml
> >> > +++ b/spec/build/bsps/obj.yml
> >> > @@ -24,6 +24,9 @@ install:
> >> > - bsps/include/bsp/u-boot.h
> >> > - bsps/include/bsp/uart-output-char.h
> >> > - bsps/include/bsp/utility.h
> >> > +- destination: ${BSP_INCLUDEDIR}/ofw
> >> > + source:
> >> > + - bsps/include/ofw/ofw.h
> >> > - destination: ${BSP_INCLUDEDIR}/libchip
> >> > source:
> >> > - bsps/include/libchip/am29lv160.h
> >> > @@ -104,4 +107,5 @@ source:
> >> > - bsps/shared/dev/serial/z85c30_reg.c
> >> > - bsps/shared/start/bootcard.c
> >> > - bsps/shared/rtems-version.c
> >> > +- bsps/shared/ofw/ofw.c
> >> > type: build
> >> > 2.17.1
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200822/c89d07fa/attachment-0001.html>
