[PATCH] Pre Release: Strong APA
Richi Dubey
richidubey at gmail.com
Sat Aug 22 21:54:48 UTC 2020
cpukit/include/rtems/scheduler.h | 6 +-
.../include/rtems/score/schedulerstrongapa.h | 284 ++++--
cpukit/score/src/schedulerstrongapa.c | 920 ++++++++++++++----
3 files changed, 908 insertions(+), 302 deletions(-)
diff --git a/cpukit/include/rtems/scheduler.h b/cpukit/include/rtems/scheduler.h
index 955a83cfb4..b101842ba7 100644
--- a/cpukit/include/rtems/scheduler.h
+++ b/cpukit/include/rtems/scheduler.h
@@ -257,16 +257,14 @@
#define RTEMS_SCHEDULER_STRONG_APA( name, prio_count ) \
static struct { \
Scheduler_strong_APA_Context Base; \
- Chain_Control Ready[ ( prio_count ) ]; \
+ Scheduler_strong_APA_Struct Struct[ CONFIGURE_MAXIMUM_PROCESSORS ]; \
} SCHEDULER_STRONG_APA_CONTEXT_NAME( name )
#define RTEMS_SCHEDULER_TABLE_STRONG_APA( name, obj_name ) \
&SCHEDULER_STRONG_APA_CONTEXT_NAME( name ).Base.Base.Base, \
SCHEDULER_STRONG_APA_ENTRY_POINTS, \
- RTEMS_ARRAY_SIZE( \
- SCHEDULER_STRONG_APA_CONTEXT_NAME( name ).Ready \
- ) - 1, \
+ SCHEDULER_STRONG_APA_MAXIMUM_PRIORITY, \
( obj_name ) \
SCHEDULER_CONTROL_IS_NON_PREEMPT_MODE_SUPPORTED( false ) \
diff --git a/cpukit/include/rtems/score/schedulerstrongapa.h b/cpukit/include/rtems/score/schedulerstrongapa.h
index 0ac28cb439..86d91688e8 100644
--- a/cpukit/include/rtems/score/schedulerstrongapa.h
+++ b/cpukit/include/rtems/score/schedulerstrongapa.h
@@ -6,31 +6,38 @@
* @brief Strong APA Scheduler API
- * Copyright (c) 2013, 2018 embedded brains GmbH. All rights reserved.
+ * Copyright (c) 2020 Richi Dubey
- * embedded brains GmbH
- * Dornierstr. 4
- * 82178 Puchheim
- * Germany
- * <rtems at embedded-brains.de>
+ * <richidubey at gmail.com>
- * The license and distribution terms for this file may be
- * found in the file LICENSE in this distribution or at
+ * Copyright (c) 2013, 2018 embedded brains GmbH. All rights reserved.
+ * embedded brains GmbH
+ * Dornierstr. 4
+ * 82178 Puchheim
+ * Germany
+ * <rtems at embedded-brains.de>
* http://www.rtems.org/license/LICENSE.
#ifndef _RTEMS_SCORE_SCHEDULERSTRONGAPA_H
#define _RTEMS_SCORE_SCHEDULERSTRONGAPA_H
-#include <rtems/score/schedulerpriority.h>
#include <rtems/score/schedulersmp.h>
+#include <rtems/score/percpu.h>
#ifdef __cplusplus
extern "C" {
#endif /* __cplusplus */
+#define STRONG_SCHEDULER_NODE_OF_CHAIN( node ) \
+ RTEMS_CONTAINER_OF( next, Scheduler_strong_APA_Node, Chain )
* @defgroup RTEMSScoreSchedulerStrongAPA Strong APA Scheduler
@@ -38,43 +45,98 @@ extern "C" {
- * This is an implementation of the global fixed priority scheduler (G-FP). It
- * uses one ready chain per priority to ensure constant time insert operations.
- * The scheduled chain uses linear insert operations and has at most processor
- * count entries. Since the processor and priority count are constants all
- * scheduler operations complete in a bounded execution time.
+ * This is an implementation of the Strong APA scheduler defined by
+ * Cerqueira et al. in Linux's Processor Affinity API, Refined:
+ * Shifting Real-Time Tasks Towards Higher Schedulability.
- * The the_thread preempt mode will be ignored.
- * @brief Scheduler context specialization for Strong APA
- * schedulers.
-typedef struct {
- Scheduler_SMP_Context Base;
- Priority_bit_map_Control Bit_map;
- Chain_Control Ready[ RTEMS_ZERO_LENGTH_ARRAY ];
-} Scheduler_strong_APA_Context;
- * @brief Scheduler node specialization for Strong APA
- * schedulers.
+ * @brief Scheduler node specialization for Strong APA schedulers.
typedef struct {
* @brief SMP scheduler node.
Scheduler_SMP_Node Base;
+ * @brief Chain node for Scheduler_strong_APA_Context::All_nodes
+ Chain_Node Chain;
+ * @brief CPU that this node would preempt in the backtracking part of
+ * _Scheduler_strong_APA_Get_highest_ready and
+ * _Scheduler_strong_APA_Do_Enqueue.
+ Per_CPU_Control *invoker;
- * @brief The associated ready queue of this node.
+ * @brief The associated affinity set of this node.
- Scheduler_priority_Ready_queue Ready_queue;
+ Processor_mask Affinity;
} Scheduler_strong_APA_Node;
+ * @brief Struct for each index of the variable size arrays
+typedef struct
+ * @brief The node that called this CPU, i.e. a node which has
+ * the cpu at the index of Scheduler_strong_APA_Context::Struct in
+ * its affinity set.
+ Scheduler_Node *caller;
+ * @brief Cpu at the index of Scheduler_strong_APA_Context::Struct
+ * in Queue implementation.
+ Per_CPU_Control *cpu;
+ * @brief Indicates if the CPU at the index of
+ * Scheduler_strong_APA_Context::Struct is already
+ * added to the Queue or not.
+ bool visited;
+} Scheduler_strong_APA_Struct;
+ * @brief Scheduler context for Strong APA scheduler.
+ * Has the structure for scheduler context
+ * and Node defintion for Strong APA scheduler
+typedef struct {
+ * @brief SMP Context to refer to SMP implementation
+ * code.
+ Scheduler_SMP_Context Base;
+ * @brief Chain of all the nodes present in
+ * the system. Accounts for ready and scheduled nodes.
+ Chain_Control All_nodes;
+ * @brief Struct with important variables for each cpu
+ Scheduler_strong_APA_Struct Struct[ RTEMS_ZERO_LENGTH_ARRAY ];
+} Scheduler_strong_APA_Context;
+#define SCHEDULER_STRONG_APA_MAXIMUM_PRIORITY 255
* @brief Entry points for the Strong APA Scheduler.
@@ -100,81 +162,90 @@ typedef struct {
_Scheduler_default_Release_job, \
_Scheduler_default_Cancel_job, \
_Scheduler_default_Tick, \
- _Scheduler_SMP_Start_idle \
- SCHEDULER_OPERATION_DEFAULT_GET_SET_AFFINITY \
+ _Scheduler_strong_APA_Start_idle, \
+ _Scheduler_strong_APA_Set_affinity \
- * @brief Initializes the scheduler.
+ * @brief Initializes the Strong_APA scheduler.
- * @param scheduler The scheduler to initialize.
-void _Scheduler_strong_APA_Initialize( const Scheduler_Control *scheduler );
+ * Sets the chain containing all the nodes to empty
+ * and initializes the SMP scheduler.
+ * @param scheduler used to get reference to Strong APA scheduler context
+ * @retval void
+ * @see _Scheduler_strong_APA_Node_initialize()
+void _Scheduler_strong_APA_Initialize(
+ const Scheduler_Control *scheduler
- * @brief Initializes the node with the given priority.
+ * @brief Called when a node yields the processor
* @param scheduler The scheduler control instance.
- * @param[out] node The node to initialize.
- * @param the_thread The thread of the node to initialize.
- * @param priority The priority for @a node.
+ * @param thread Thread corresponding to @node
+ * @param node Node that yield the processor
-void _Scheduler_strong_APA_Node_initialize(
+void _Scheduler_strong_APA_Yield(
const Scheduler_Control *scheduler,
- Scheduler_Node *node,
- Thread_Control *the_thread,
- Priority_Control priority
+ Thread_Control *thread,
+ Scheduler_Node *node
- * @brief Blocks the thread.
+ * @brief Blocks a node
- * @param scheduler The scheduler control instance.
- * @param[in, out] the_thread The thread to block.
- * @param[in, out] node The node of the thread to block.
+ * Changes the state of the node and extracts it from the queue
+ * calls _Scheduler_SMP_Block().
+ * @param context The scheduler control instance.
+ * @param thread Thread correspoding to the @node.
+ * @param node node which is to be blocked
void _Scheduler_strong_APA_Block(
- * @brief Unblocks the thread.
+ * @brief Unblocks a node
+ * Changes the state of the node and calls _Scheduler_SMP_Unblock().
- * @param[in, out] the_thread The thread to unblock.
- * @param[in, out] node The node of the thread to unblock.
+ * @param node node which is to be unblocked
+ * @see _Scheduler_strong_APA_Enqueue()
+ * @see _Scheduler_strong_APA_Do_update()
void _Scheduler_strong_APA_Unblock(
- * @brief Updates the priority of the node.
+ * @brief Updates the priority of the node
- * @param the_thread The thread for the operation.
- * @param[in, out] node The node to update the priority of.
+ * @param node Node whose priority has to be updated
void _Scheduler_strong_APA_Update_priority(
- * @brief Asks for help.
+ * @brief Calls the SMP Ask_for_help
- * @param the_thread The thread that asks for help.
- * @param node The node of @a the_thread.
- * @retval true The request for help was successful.
- * @retval false The request for help was not successful.
+ * @param scheduler The scheduler control instance.
+ * @param thread Thread correspoding to the @node that asks for help.
+ * @param node node associated with @thread
bool _Scheduler_strong_APA_Ask_for_help(
@@ -182,12 +253,13 @@ bool _Scheduler_strong_APA_Ask_for_help(
- * @brief Reconsiders help request.
+ * @brief To Reconsider the help request
- * @param the_thread The thread to reconsider the help request of.
- * @param[in, out] node The node of @a the_thread
+ * @param node Node corresponding to @thread which asks for
+ * reconsideration
void _Scheduler_strong_APA_Reconsider_help_request(
@@ -195,13 +267,13 @@ void _Scheduler_strong_APA_Reconsider_help_request(
- * @brief Withdraws the node.
+ * @brief Withdraws a node
- * @param[in, out] the_thread The thread to change the state to @a next_state.
- * @param[in, out] node The node to withdraw.
- * @param next_state The next state for @a the_thread.
+ * @param node Node that has to be withdrawn
+ * @param next_state the state that the node goes to
void _Scheduler_strong_APA_Withdraw_node(
@@ -210,42 +282,66 @@ void _Scheduler_strong_APA_Withdraw_node(
- * @brief Adds the idle thread to a processor.
+ * @brief Adds a processor to the scheduler instance
+ * and allocates an idle thread to the processor.
- * @param[in, out] The idle thread to add to the processor.
+ * @param idle Idle thread to be allocated to the processor
void _Scheduler_strong_APA_Add_processor(
Thread_Control *idle
- * @brief Removes an idle thread from the given cpu.
- * @param scheduler The scheduler instance.
- * @param cpu The cpu control to remove from @a scheduler.
+ * @brief Removes a processor from the scheduler instance
- * @return The idle thread of the processor.
+ * @param cpu processor that is removed
Thread_Control *_Scheduler_strong_APA_Remove_processor(
- struct Per_CPU_Control *cpu
- * @brief Performs a yield operation.
+ * @brief Initializes the node with the given priority.
- * @param the_thread The thread to yield.
- * @param[in, out] node The node of @a the_thread.
+ * @param[out] node The node to initialize.
+ * @param the_thread The thread of the node to initialize.
+ * @param priority The priority for @a node.
-void _Scheduler_strong_APA_Yield(
+void _Scheduler_strong_APA_Node_initialize(
+ Scheduler_Node *node,
+ Priority_Control priority
+ * @brief Starts an idle thread on a CPU
+ * @param idle Idle Thread
+ * @param cpu processor that gets the idle thread
+void _Scheduler_strong_APA_Start_idle(
+ const Scheduler_Control *scheduler,
+ Thread_Control *idle,
+ * @brief Sets the affinity of the @node_base to @affinity
+bool _Scheduler_strong_APA_Set_affinity(
+ Scheduler_Node *node_base,
+ const Processor_mask *affinity
#ifdef __cplusplus
diff --git a/cpukit/score/src/schedulerstrongapa.c b/cpukit/score/src/schedulerstrongapa.c
index 924cd86412..8ccaa4e4a3 100644
--- a/cpukit/score/src/schedulerstrongapa.c
+++ b/cpukit/score/src/schedulerstrongapa.c
@@ -6,320 +6,765 @@
* @brief Strong APA Scheduler Implementation
- * Copyright (c) 2013, 2016 embedded brains GmbH. All rights reserved.
- * Dornierstr. 4
- * 82178 Puchheim
- * Germany
+ * Dornierstr. 4
+ * 82178 Puchheim
+ * Germany
#ifdef HAVE_CONFIG_H
#include "config.h"
#endif
#include <rtems/score/schedulerstrongapa.h>
-#include <rtems/score/schedulerpriorityimpl.h>
#include <rtems/score/schedulersmpimpl.h>
+#include <rtems/score/assert.h>
+#include <rtems/malloc.h>
-static Scheduler_strong_APA_Context *_Scheduler_strong_APA_Get_self(
- Scheduler_Context *context
+static inline Scheduler_strong_APA_Context *
+_Scheduler_strong_APA_Get_context( const Scheduler_Control *scheduler )
+ return (Scheduler_strong_APA_Context *) _Scheduler_Get_context( scheduler );
+_Scheduler_strong_APA_Get_self( Scheduler_Context *context )
return (Scheduler_strong_APA_Context *) context;
-static Scheduler_strong_APA_Node *
+static inline Scheduler_strong_APA_Node *
_Scheduler_strong_APA_Node_downcast( Scheduler_Node *node )
return (Scheduler_strong_APA_Node *) node;
-static void _Scheduler_strong_APA_Move_from_scheduled_to_ready(
+static inline void _Scheduler_strong_APA_Do_update(
Scheduler_Context *context,
- Scheduler_Node *scheduled_to_ready
+ Priority_Control new_priority
- Scheduler_strong_APA_Context *self =
- _Scheduler_strong_APA_Get_self( context );
- Scheduler_strong_APA_Node *node =
- _Scheduler_strong_APA_Node_downcast( scheduled_to_ready );
- _Chain_Extract_unprotected( &node->Base.Base.Node.Chain );
- _Scheduler_priority_Ready_queue_enqueue_first(
- &node->Base.Base.Node.Chain,
- &node->Ready_queue,
- &self->Bit_map
+ Scheduler_SMP_Node *smp_node;
+ (void) context;
+ smp_node = _Scheduler_SMP_Node_downcast( node );
+ _Scheduler_SMP_Node_update_priority( smp_node, new_priority );
+static inline bool _Scheduler_strong_APA_Has_ready( Scheduler_Context *context )
+ Scheduler_strong_APA_Context *self = _Scheduler_strong_APA_Get_self( context );
+ bool ret;
+ const Chain_Node *tail;
+ Chain_Node *next;
+ Scheduler_strong_APA_Node *node;
+ tail = _Chain_Immutable_tail( &self->All_nodes );
+ next = _Chain_First( &self->All_nodes );
+ ret = false;
+ while ( next != tail ) {
+ node = (Scheduler_strong_APA_Node *) STRONG_SCHEDULER_NODE_OF_CHAIN( next );
+ if (
+ _Scheduler_SMP_Node_state( &node->Base.Base ) == SCHEDULER_SMP_NODE_READY
+ ret = true;
+ break;
+ next = _Chain_Next( next );
+ return ret;
+static inline void _Scheduler_strong_APA_Allocate_processor(
+ Scheduler_Context *context,
+ Scheduler_Node *scheduled_base,
+ Scheduler_Node *victim_base,
+ Per_CPU_Control *victim_cpu
+ Scheduler_strong_APA_Node *scheduled;
+ (void) victim_base;
+ scheduled = _Scheduler_strong_APA_Node_downcast( scheduled_base );
+ _Scheduler_SMP_Allocate_processor_exact(
+ context,
+ &(scheduled->Base.Base),
+ NULL,
+ victim_cpu
-static void _Scheduler_strong_APA_Move_from_ready_to_scheduled(
+static inline Scheduler_Node * _Scheduler_strong_APA_Find_highest_ready(
+ Scheduler_strong_APA_Context *self,
+ uint32_t front,
+ uint32_t rear
+ Scheduler_Node *highest_ready;
+ Scheduler_strong_APA_Struct *Struct;
+ Chain_Node *next;
+ uint32_t index_assigned_cpu;
+ Priority_Control min_priority_num;
+ Priority_Control curr_priority;
+ Per_CPU_Control *assigned_cpu;
+ Scheduler_SMP_Node_state curr_state;
+ Per_CPU_Control *curr_CPU;
+ bool first_task;
+ Struct = self->Struct;
+ //When the first task accessed has nothing to compare its priority against
+ // So, it is the task with the highest priority witnessed so far!
+ first_task = true;
+ while( front <= rear ) {
+ curr_CPU = Struct[ front ].cpu;
+ front = front + 1;
+ node = (Scheduler_strong_APA_Node*) STRONG_SCHEDULER_NODE_OF_CHAIN( next );
+ //Check if the curr_CPU is in the affinity set of the node
+ if (
+ _Processor_mask_Is_set(&node->Affinity, _Per_CPU_Get_index(curr_CPU))
+ curr_state = _Scheduler_SMP_Node_state( &node->Base.Base );
+ if ( curr_state == SCHEDULER_SMP_NODE_SCHEDULED ) {
+ assigned_cpu = _Thread_Get_CPU( node->Base.Base.user );
+ index_assigned_cpu = _Per_CPU_Get_index( assigned_cpu );
+ if ( Struct[ index_assigned_cpu ].visited == false ) {
+ rear = rear + 1;
+ Struct[ rear ].cpu = assigned_cpu;
+ Struct[ index_assigned_cpu ].visited = true;
+ // The curr CPU of the queue invoked this node to add its CPU
+ // that it is executing on to the queue. So this node might get
+ // preempted because of the invoker curr_CPU and this curr_CPU
+ // is the CPU that node should preempt in case this node
+ // gets preempted.
+ node->invoker = curr_CPU;
+ else if ( curr_state == SCHEDULER_SMP_NODE_READY ) {
+ curr_priority = _Scheduler_Node_get_priority( &node->Base.Base );
+ curr_priority = SCHEDULER_PRIORITY_PURIFY( curr_priority );
+ if ( first_task == true || curr_priority < min_priority_num ) {
+ min_priority_num = curr_priority;
+ highest_ready = &node->Base.Base;
+ first_task = false;
+ //In case this task is directly reachable from thread_CPU
+ return highest_ready;
+static inline Scheduler_Node *_Scheduler_strong_APA_Get_highest_ready(
- Scheduler_Node *ready_to_scheduled
+ Scheduler_Node *filter
+ //Implement the BFS Algorithm for task departure
+ //to get the highest ready task for a particular CPU
+ //return the highest ready Scheduler_Node and Scheduler_Node filter here points
+ // to the victim node that is blocked resulting which this function is called.
Scheduler_strong_APA_Context *self;
- Scheduler_strong_APA_Node *node;
- Priority_Control insert_priority;
- self = _Scheduler_strong_APA_Get_self( context );
- node = _Scheduler_strong_APA_Node_downcast( ready_to_scheduled );
+ Per_CPU_Control *filter_cpu;
+ Scheduler_Node *curr_node;
+ Scheduler_Node *next_node;
+ self=_Scheduler_strong_APA_Get_self( context );
+ //Denotes front and rear of the queue
+ uint32_t front;
+ uint32_t rear;
+ uint32_t cpu_max;
+ uint32_t cpu_index;
+ front = 0;
+ rear = -1;
+ filter_cpu = _Thread_Get_CPU( filter->user );
+ cpu_max = _SMP_Get_processor_maximum();
+ for ( cpu_index = 0 ; cpu_index < cpu_max ; ++cpu_index ) {
+ Struct[ cpu_index ].visited = false;
+ rear = rear + 1;
+ Struct[ rear ].cpu = filter_cpu;
+ Struct[ _Per_CPU_Get_index( filter_cpu ) ].visited = true;
+ highest_ready = _Scheduler_strong_APA_Find_highest_ready(
+ self,
+ front,
+ rear
+ if ( highest_ready != filter ) {
+ //Backtrack on the path from
+ //filter_cpu to highest_ready, shifting along every task.
+ node = _Scheduler_strong_APA_Node_downcast( highest_ready );
+ if( node->invoker != filter_cpu ) {
+ // Highest ready is not just directly reachable from the victim cpu
+ // So there is need of task shifting
+ curr_node = &node->Base.Base;
+ next_node = _Thread_Scheduler_get_home_node( node->invoker->heir );
+ _Scheduler_SMP_Enqueue_to_scheduled(
+ context,
+ curr_node,
+ _Thread_Scheduler_get_home_node( node->invoker->heir ),
+ _Scheduler_strong_APA_Allocate_processor
+ node = _Scheduler_strong_APA_Node_downcast( next_node );
+ while( node->invoker != filter_cpu ){
+ _Scheduler_SMP_Preempt(
+ context,
+ curr_node,
+ //To save the last node so that the caller SMP_* function
+ //can do the allocation
+ highest_ready = curr_node;
- _Scheduler_priority_Ready_queue_extract(
- &self->Bit_map
- insert_priority = _Scheduler_SMP_Node_priority( &node->Base.Base );
- insert_priority = SCHEDULER_PRIORITY_APPEND( insert_priority );
- _Chain_Insert_ordered_unprotected(
- &self->Base.Scheduled,
- &insert_priority,
- _Scheduler_SMP_Priority_less_equal
+static inline Scheduler_Node *_Scheduler_strong_APA_Get_lowest_scheduled(
+ Scheduler_Node *filter_base
+ //Checks the lowest scheduled directly reachable task
+ uint32_t cpu_max;
+ Thread_Control *curr_thread;
+ Scheduler_Node *lowest_scheduled;
+ Priority_Control max_priority_num;
+ Scheduler_strong_APA_Node *filter_strong_node;
+ lowest_scheduled = NULL; //To remove compiler warning.
+ max_priority_num = 0;//Max (Lowest) priority encountered so far.
+ filter_strong_node = _Scheduler_strong_APA_Node_downcast( filter_base );
+ //lowest_scheduled is NULL if affinty of a node is 0
+ _Assert( !_Processor_mask_Zero( &filter_strong_node->Affinity ) );
+ //Checks if the CPU is in the affinity set of filter_strong_node
+ if ( _Processor_mask_Is_set( &filter_strong_node->Affinity, cpu_index) ) {
+ Per_CPU_Control *cpu = _Per_CPU_Get_by_index( cpu_index );
+ if ( _Per_CPU_Is_processor_online( cpu ) ) {
+ curr_thread = cpu->heir;
+ curr_node = _Thread_Scheduler_get_home_node( curr_thread );
+ curr_priority = _Scheduler_Node_get_priority( curr_node );
+ if ( curr_priority > max_priority_num ) {
+ lowest_scheduled = curr_node;
+ max_priority_num = curr_priority;
+ return lowest_scheduled;
-static void _Scheduler_strong_APA_Insert_ready(
+static inline void _Scheduler_strong_APA_Extract_from_scheduled(
- Scheduler_Node *node_base,
+ Scheduler_Node *node_to_extract
- node = _Scheduler_strong_APA_Node_downcast( node_base );
+ node = _Scheduler_strong_APA_Node_downcast( node_to_extract );
- if ( SCHEDULER_PRIORITY_IS_APPEND( insert_priority ) ) {
- _Scheduler_priority_Ready_queue_enqueue(
- &self->Bit_map
- } else {
- &self->Bit_map
+ _Scheduler_SMP_Extract_from_scheduled( &self->Base.Base, &node->Base.Base );
+ //Not removing it from All_nodes since the node could go in the ready state.
-static void _Scheduler_strong_APA_Extract_from_ready(
+static inline void _Scheduler_strong_APA_Extract_from_ready(
- Scheduler_Node *the_thread
- _Scheduler_strong_APA_Node_downcast( the_thread );
- &self->Bit_map
+ Scheduler_strong_APA_Context *self;
+ self = _Scheduler_strong_APA_Get_self( context );
+ _Assert( !_Chain_Is_empty(self->All_nodes) );
+ _Assert( !_Chain_Is_node_off_chain( &node->Chain ) );
+ _Chain_Extract_unprotected( &node->Chain ); //Removed from All_nodes
+ _Chain_Set_off_chain( &node->Chain );
-static void _Scheduler_strong_APA_Do_update(
+static inline void _Scheduler_strong_APA_Insert_ready(
- Scheduler_Node *node_to_update,
- Priority_Control new_priority
+ Priority_Control insert_priority
- _Scheduler_strong_APA_Node_downcast( node_to_update );
- _Scheduler_SMP_Node_update_priority( &node->Base, new_priority );
- _Scheduler_priority_Ready_queue_update(
- SCHEDULER_PRIORITY_UNMAP( new_priority ),
- &self->Bit_map,
- &self->Ready[ 0 ]
-_Scheduler_strong_APA_Get_context( const Scheduler_Control *scheduler )
- return (Scheduler_strong_APA_Context *) _Scheduler_Get_context( scheduler );
+ node = _Scheduler_strong_APA_Node_downcast( node_base );
+ if(_Chain_Is_node_off_chain( &node->Chain ) )
+ _Chain_Append_unprotected( &self->All_nodes, &node->Chain );
+static inline void _Scheduler_strong_APA_Move_from_scheduled_to_ready(
+ Scheduler_Node *scheduled_to_ready
- _Scheduler_strong_APA_Get_context( scheduler );
+ Priority_Control insert_priority;
- _Scheduler_SMP_Initialize( &self->Base );
- _Priority_bit_map_Initialize( &self->Bit_map );
- _Scheduler_priority_Ready_queue_initialize(
- &self->Ready[ 0 ],
- scheduler->maximum_priority
+ _Scheduler_SMP_Extract_from_scheduled( context, scheduled_to_ready );
+ insert_priority = _Scheduler_SMP_Node_priority( scheduled_to_ready );
+ _Scheduler_strong_APA_Insert_ready(
+ context,
+ scheduled_to_ready,
+ insert_priority
- const Scheduler_Control *scheduler,
+static inline void _Scheduler_strong_APA_Move_from_ready_to_scheduled(
+ Scheduler_Node *ready_to_scheduled
- Scheduler_Context *context;
- Scheduler_strong_APA_Context *self;
- Scheduler_strong_APA_Node *the_node;
- the_node = _Scheduler_strong_APA_Node_downcast( node );
- _Scheduler_SMP_Node_initialize(
- scheduler,
- &the_node->Base,
- the_thread,
- priority
- context = _Scheduler_Get_context( scheduler );
- &the_node->Ready_queue,
- SCHEDULER_PRIORITY_UNMAP( priority ),
- &self->Bit_map,
- &self->Ready[ 0 ]
+ _Scheduler_strong_APA_Extract_from_ready( context, ready_to_scheduled );
+ insert_priority = _Scheduler_SMP_Node_priority( ready_to_scheduled );
+ insert_priority = SCHEDULER_PRIORITY_APPEND( insert_priority );
+ _Scheduler_SMP_Insert_scheduled(
+ context,
+ ready_to_scheduled,
+ insert_priority
+ //Note: The node still stays in the All_nodes chain
-static bool _Scheduler_strong_APA_Has_ready( Scheduler_Context *context )
+static inline Scheduler_Node* _Scheduler_strong_APA_Get_lowest_reachable(
+ uint32_t front,
+ uint32_t rear,
+ Per_CPU_Control **cpu_to_preempt
- return !_Priority_bit_map_Is_empty( &self->Bit_map );
+ Scheduler_Node *lowest_reachable;
+ uint32_t cpu_max;
+ Scheduler_strong_APA_Node *curr_strong_node; //Current Strong_APA_Node
+ curr_thread = curr_CPU->heir;
+ curr_strong_node = _Scheduler_strong_APA_Node_downcast( curr_node );
+ lowest_reachable = curr_node;
+ *cpu_to_preempt = curr_CPU;
+ if ( !curr_thread->is_idle ) {
+ if ( _Processor_mask_Is_set( &curr_strong_node->Affinity, cpu_index ) ) {
+ //Checks if the thread_CPU is in the affinity set of the node
+ if ( _Per_CPU_Is_processor_online( cpu ) && Struct[ cpu_index ].visited == false ) {
+ rear = rear + 1;
+ Struct[ rear ].cpu = cpu;
+ Struct[ cpu_index ].visited = true;
+ Struct[ cpu_index ].caller = curr_node;
+ return lowest_reachable;
-static Scheduler_Node *_Scheduler_strong_APA_Get_highest_ready(
+static inline bool _Scheduler_strong_APA_Do_enqueue(
+ Scheduler_Node *lowest_reachable,
+ Priority_Control insert_priority,
+ Per_CPU_Control *cpu_to_preempt
- (void) node;
- return (Scheduler_Node *) _Scheduler_priority_Ready_queue_first(
- &self->Bit_map,
- &self->Ready[ 0 ]
+ bool needs_help;
+ Priority_Control node_priority;
+ Priority_Control lowest_priority;
+ Thread_Control *next_thread;
+ node_priority = _Scheduler_Node_get_priority( node );
+ node_priority = SCHEDULER_PRIORITY_PURIFY( node_priority );
+ lowest_priority = _Scheduler_Node_get_priority( lowest_reachable );
+ lowest_priority = SCHEDULER_PRIORITY_PURIFY( lowest_priority );
+ if( lowest_priority > node_priority ) {
+ //_Thread_Get_CPU(lowest_reachable->user) to lowest_reachable, shifting
+ //along every task
+ curr_node = Struct[ _Per_CPU_Get_index(cpu_to_preempt) ].caller;
+ curr_strong_node->invoker = cpu_to_preempt;
+ //Save which cpu to preempt in invoker value of the node
+ while( curr_node != node ) {
+ curr_CPU = _Thread_Get_CPU( curr_node->user );
+ curr_node = Struct[ _Per_CPU_Get_index( curr_CPU ) ].caller;
+ curr_strong_node->invoker = curr_CPU;
+ next_thread = curr_strong_node->invoker->heir;
+ next_node = _Thread_Scheduler_get_home_node( next_thread );
+ node_priority = _Scheduler_Node_get_priority( curr_node );
+ context,
+ curr_node,
+ node_priority,
+ next_node,
+ _Scheduler_SMP_Insert_scheduled,
+ _Scheduler_strong_APA_Move_from_scheduled_to_ready,
+ curr_node = next_node;
+ while( curr_node != lowest_reachable) {
+ //curr_node preempts the next_node;
+ context,
+ curr_node,
+ next_node,
+ _Scheduler_strong_APA_Move_from_scheduled_to_ready(context, lowest_reachable);
+ needs_help = false;
+ } else {
+ needs_help = true;
+ //Add it to All_nodes chain since it is now either scheduled or just ready.
+ _Scheduler_strong_APA_Insert_ready(context,node,insert_priority);
+ return needs_help;
-void _Scheduler_strong_APA_Block(
+static inline bool _Scheduler_strong_APA_Enqueue(
- Scheduler_Context *context = _Scheduler_Get_context( scheduler );
+ //Idea: BFS Algorithm for task arrival
+ //Enqueue node either in the scheduled chain or in the ready chain
+ //node is the newly arrived node and is not scheduled.
+ uint32_t cpu_max;
+ Per_CPU_Control *cpu_to_preempt;
+ Scheduler_strong_APA_Node *strong_node;
+ uint32_t front;
+ uint32_t rear;
+ front = 0;
+ rear = -1;
- _Scheduler_SMP_Block(
+ strong_node = _Scheduler_strong_APA_Node_downcast( node );
+ if ( _Processor_mask_Is_set( &strong_node->Affinity, cpu_index) ) {
+ rear = rear + 1;
+ Struct[ cpu_index ].caller = node;
+ //This assert makes sure that there always exist an element in the
+ // Queue when we start the queue traversal.
+ _Assert( !_Processor_mask_Zero( &strong_node->Affinity ) );
+ lowest_reachable = _Scheduler_strong_APA_Get_lowest_reachable(
+ self,
+ front,
+ rear,
+ &cpu_to_preempt
+ return _Scheduler_strong_APA_Do_enqueue(
+ context,
+ lowest_reachable,
+ node,
+ insert_priority,
+ cpu_to_preempt
+static inline bool _Scheduler_strong_APA_Enqueue_scheduled(
+ return _Scheduler_SMP_Enqueue_scheduled(
context,
- the_thread,
node,
- _Scheduler_SMP_Extract_from_scheduled,
+ insert_priority,
+ _Scheduler_SMP_Priority_less_equal,
_Scheduler_strong_APA_Extract_from_ready,
_Scheduler_strong_APA_Get_highest_ready,
+ _Scheduler_strong_APA_Insert_ready,
_Scheduler_strong_APA_Move_from_ready_to_scheduled,
- _Scheduler_SMP_Allocate_processor_exact
-static bool _Scheduler_strong_APA_Enqueue(
+static inline bool _Scheduler_strong_APA_Do_ask_for_help(
+ Thread_Control *the_thread,
- return _Scheduler_SMP_Enqueue(
+ return _Scheduler_SMP_Ask_for_help(
context,
+ the_thread,
node,
- insert_priority,
- _Scheduler_SMP_Get_lowest_scheduled,
+ _Scheduler_strong_APA_Get_lowest_scheduled,
-static bool _Scheduler_strong_APA_Enqueue_scheduled(
+static inline void _Scheduler_strong_APA_Register_idle(
+ Scheduler_Node *idle_base,
- return _Scheduler_SMP_Enqueue_scheduled(
+ (void) context;
+ (void) idle_base;
+ (void) cpu;
+ //We do not maintain a variable to access the scheduled
+ //node for a CPU. So this function does nothing.
+static inline void _Scheduler_strong_APA_Do_set_affinity(
+ void *arg
+ const Processor_mask *affinity;
+ affinity = arg;
+ node->Affinity = *affinity;
+void _Scheduler_strong_APA_Initialize( const Scheduler_Control *scheduler )
+ _Scheduler_strong_APA_Get_context( scheduler );
+ _Scheduler_SMP_Initialize( &self->Base );
+ _Chain_Initialize_empty( &self->All_nodes );
+ Scheduler_Context *context = _Scheduler_Get_context( scheduler );
+ _Scheduler_SMP_Yield(
context,
+ thread,
node,
- insert_priority,
- _Scheduler_SMP_Priority_less_equal,
- _Scheduler_strong_APA_Get_highest_ready,
- _Scheduler_strong_APA_Insert_ready,
- _Scheduler_SMP_Insert_scheduled,
- _Scheduler_strong_APA_Move_from_ready_to_scheduled,
+ _Scheduler_strong_APA_Enqueue,
+ _Scheduler_strong_APA_Enqueue_scheduled
-void _Scheduler_strong_APA_Unblock(
+void _Scheduler_strong_APA_Block(
- _Scheduler_SMP_Unblock(
+//The extract from ready automatically removes the node from All_nodes chain.
+ _Scheduler_SMP_Block(
context,
- the_thread,
+ thread,
node,
- _Scheduler_strong_APA_Do_update,
- _Scheduler_strong_APA_Enqueue
+ _Scheduler_strong_APA_Extract_from_scheduled,
+ _Scheduler_strong_APA_Extract_from_ready,
+ _Scheduler_strong_APA_Get_highest_ready,
+ _Scheduler_strong_APA_Move_from_ready_to_scheduled,
-static bool _Scheduler_strong_APA_Do_ask_for_help(
- Scheduler_Context *context,
+void _Scheduler_strong_APA_Unblock(
- return _Scheduler_SMP_Ask_for_help(
+ _Scheduler_SMP_Unblock(
context,
- the_thread,
+ thread,
node,
- _Scheduler_strong_APA_Move_from_scheduled_to_ready,
- _Scheduler_SMP_Allocate_processor_lazy
+ _Scheduler_strong_APA_Do_update,
@@ -327,7 +772,7 @@ void _Scheduler_strong_APA_Update_priority(
_Scheduler_SMP_Update_priority(
context,
- the_thread,
+ thread,
node,
@@ -345,7 +790,11 @@ bool _Scheduler_strong_APA_Ask_for_help(
- return _Scheduler_strong_APA_Do_ask_for_help( context, the_thread, node );
+ return _Scheduler_strong_APA_Do_ask_for_help(
+ context,
+ the_thread,
+ node
@@ -381,7 +830,7 @@ void _Scheduler_strong_APA_Withdraw_node(
@@ -397,7 +846,7 @@ void _Scheduler_strong_APA_Add_processor(
idle,
_Scheduler_strong_APA_Has_ready,
_Scheduler_strong_APA_Enqueue_scheduled,
- _Scheduler_SMP_Do_nothing_register_idle
+ _Scheduler_strong_APA_Register_idle
@@ -416,20 +865,83 @@ Thread_Control *_Scheduler_strong_APA_Remove_processor(
+ _Scheduler_SMP_Node_initialize( scheduler, smp_node, the_thread, priority );
+ _Processor_mask_Assign(
+ &strong_node->Affinity,
+ _SMP_Get_online_processors()
- _Scheduler_SMP_Yield(
+ Scheduler_Context *context;
+ context = _Scheduler_Get_context( scheduler );
+ _Scheduler_SMP_Do_start_idle(
context,
- the_thread,
- node,
- _Scheduler_strong_APA_Extract_from_ready,
- _Scheduler_strong_APA_Enqueue,
- _Scheduler_strong_APA_Enqueue_scheduled
+ idle,
+ cpu,
+ Processor_mask local_affinity;
+ _Processor_mask_And( &local_affinity, &context->Processors, affinity );
+ if ( _Processor_mask_Is_zero( &local_affinity ) ) {
+ return false;
+ if ( _Processor_mask_Is_equal( &node->Affinity, affinity ) )
+ return true; //Nothing to do. Return true.
+ _Processor_mask_Assign( &node->Affinity, &local_affinity );
+ _Scheduler_SMP_Set_affinity(
+ context,
+ thread,
+ node_base,
+ &local_affinity,
+ _Scheduler_strong_APA_Do_set_affinity,
+ return true;
2.17.1
