[PATCH v2] bsps/shared/ofw: Implement RTEMS OFW interface
Gedare Bloom
gedare at rtems.org
Mon Aug 24 16:23:04 UTC 2020
On Mon, Aug 24, 2020 at 8:42 AM Niteesh G. S. <niteesh.gs at gmail.com> wrote:
> ping.
pong. Most of us don't volunteer our time on the weekends. Some people
and open-source projects may, and I understand that the timeline for
finishing your project is getting tight, but you do want to be
courteous about other people's time. It is in general our most
precious commodity.
> On Sat, Aug 22, 2020 at 10:15 PM Niteesh G. S. <niteesh.gs at gmail.com> wrote:
>> Hello,
>> I went through the history of the OF implementation in NetBSD and FreeBSD.
>> I have summarized the things I have found out below.
>> The first OF implementation seems to come from NetBSD this is actually BSD-4
>> licensed. FreeBSD and also other BSD have used this as the base and improved
>> the API. For eg functions like OF_getprop_allloc_multi, OF_getencprop were not
>> present in the original OF interface but were added by FreeBSD. And also NetBSD
>> doesn't use KOBJS for function dispatch but rather uses platform-specific OF
>> implementation, that is FDT implementation is present under sys/dev/fdt/fdt_openfirm.c
>> powerPC implementation under arch/powerpc/openfirm.c.
>> NetBSD openfirm.h: https://github.com/NetBSD/src/blob/trunk/sys/dev/ofw/openfirm.h
>> And I think was adding the OF interface FreeBSD has added the BSD-2 license.
>> https://github.com/freebsd/freebsd/commit/d84d862cbd66f3f9ab4ce65fe69893664689c73b
>> This is the commit where they have added OF interface to FreeBSD and from the
>> commit it seems like they have added the BSD-2 license with the interface itself.
>> And the functions where we worry about the similarity are all FreeBSD extension
>> so I guess we won't have any issue since they would come under BSD-2 license.
I think you could attempt to 'match' the imported 4-BSD code to any
current code, and remove it. see what is left.
Alternately, you can copy the code that you know came from commits
with 2-BSD code and see what gaps remain at the end.
My intuition here is that there are few if any original lines of code
left from that first 4-bsd import from NetBSD.
>> Thanks,
>> Niteesh.
>> On Sat, Aug 22, 2020 at 7:23 PM Gedare Bloom <gedare at rtems.org> wrote:
>>> On Fri, Aug 21, 2020 at 11:26 AM Niteesh G. S. <niteesh.gs at gmail.com> wrote:
>>> > On Fri, Aug 21, 2020 at 9:38 PM Gedare Bloom <gedare at rtems.org> wrote:
>>> >> Hi Niteesh,
>>> >> Can you explain how you developed the new code in a way that ensures
>>> >> that we do not have any of the previously 4-BSD licensed code left?
>>> > The FDT implementation of the OF interface present is ofw_fdt.c is, fortunately,
>>> > BSD-2 licensed so I was able to copy/reuse most of it for RTEMS ofw.c
>>> > The interface(openfirm.h) and the implementation(opefirm.c) that calls the
>>> > respective KOBJs functions are BSD-4 licensed. Since it was mentioned that
>>> > copying the interface is fine I don't think there is an issue with it. The OF
>>> > interface in RTEMS is present in ofw_compat.h
>>> > I also want to make note of one thing, there are few functions in ofw.c
>>> > which look exactly the same as the ones present in openfirm.c can you
>>> > please make sure that these functions won't cause any issues.
>>> > Few examples are, rtems_ofw_get_enc_prop_alloc, rtems_ofw_get_enc_prop_alloc_multi.
>>> The similarity in these functions is problematic.
>>> I still think it would be worth the trouble to try to dig through the
>>> history to find exactly what code was introduced with the 4-bsd. I
>>> would guess that came out of netbsd.
>>> > Thanks,
>>> > Niteesh.
>>> >> Gedare
>>> >> On Thu, Aug 20, 2020 at 1:52 AM G S Niteesh Babu <niteesh.gs at gmail.com> wrote:
>>> >> > RTEMS OFW is a FDT only implementation of the OpenFirmWare
>>> >> > interface. This API is created to be compatible with FreeBSD
>>> >> > OpenFirmWare interface. The main intention is to make
>>> >> > porting of FreeBSD drivers to RTEMS easier.
>>> >> > Most functions implemented have an direct one-one mapping
>>> >> > with the original OFW API and some extra auxiliary functions
>>> >> > were implemented to make working with device trees easier in
>>> >> > RTEMS.
>>> >> > Update #3784
>>> >> > bsps/include/ofw/ofw.h | 548 +++++++++++++++++++++++++++
>>> >> > bsps/include/ofw/ofw_compat.h | 74 ++++
>>> >> > bsps/shared/ofw/ofw.c | 670 ++++++++++++++++++++++++++++++++++
>>> >> > spec/build/bsps/obj.yml | 4 +
>>> >> > 4 files changed, 1296 insertions(+)
>>> >> > create mode 100644 bsps/include/ofw/ofw.h
>>> >> > create mode 100644 bsps/include/ofw/ofw_compat.h
>>> >> > create mode 100644 bsps/shared/ofw/ofw.c
>>> >> > diff --git a/bsps/include/ofw/ofw.h b/bsps/include/ofw/ofw.h
>>> >> > new file mode 100644
>>> >> > index 0000000000..50f64ff695
>>> >> > --- /dev/null
>>> >> > +++ b/bsps/include/ofw/ofw.h
>>> >> > @@ -0,0 +1,548 @@
>>> >> > +/* SPDX-License-Identifier: BSD-2-Clause */
>>> >> > + * @file
>>> >> > + * @ingroup ofw
>>> >> > + * RTEMS FDT implementation of OpenFirmWare Interface.
>>> >> > + * RTEMS OFW is a FDT only implementation of the OpenFirmWare interface.
>>> >> > + * This API is created to be compatible with FreeBSD OpenFirmWare interface.
>>> >> > + * The main intention is to make porting of FreeBSD drivers to RTEMS easier.
>>> >> > + * Copyright (C) 2020 Niteesh Babu G S <niteesh.gs at gmail.com>
>>> >> > + * Redistribution and use in source and binary forms, with or without
>>> >> > + * modification, are permitted provided that the following conditions
>>> >> > + * are met:
>>> >> > + * 1. Redistributions of source code must retain the above copyright
>>> >> > + * notice, this list of conditions and the following disclaimer.
>>> >> > + * 2. Redistributions in binary form must reproduce the above copyright
>>> >> > + * notice, this list of conditions and the following disclaimer in the
>>> >> > + * documentation and/or other materials provided with the distribution.
>>> >> > + * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
>>> >> > + * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
>>> >> > + * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
>>> >> > + * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
>>> >> > + * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
>>> >> > + * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
>>> >> > + * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
>>> >> > + * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
>>> >> > + * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
>>> >> > + * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
>>> >> > + * POSSIBILITY OF SUCH DAMAGE.
>>> >> > +#ifndef _OFW_H
>>> >> > +#define _OFW_H
>>> >> > +#ifdef __cplusplus
>>> >> > +extern "C" {
>>> >> > +#endif
>>> >> > +#include <rtems.h>
>>> >> > +#include <stdint.h>
>>> >> > +#include <stddef.h>
>>> >> > + * Represents a node in the device tree. The offset from fdtp to node is used
>>> >> > + * instead of fdt offset to make sure this is compatible with OF interface in
>>> >> > + * FreeBSD.
>>> >> > +typedef uint32_t phandle_t;
>>> >> > + * Represents the effective phandle of the node.
>>> >> > +typedef uint32_t ihandle_t;
>>> >> > + * Represents the data type of the buffer.
>>> >> > +typedef uint32_t pcell_t;
>>> >> > + * @struct rtems_ofw_memory_area
>>> >> > + * This is used to represent elements(FDT properties) that define
>>> >> > + * region of memory address.
>>> >> > +typedef struct {
>>> >> > + /** The start address of the memory region. */
>>> >> > + uint32_t start;
>>> >> > + /** The size of the memory region. */
>>> >> > + uint32_t size;
>>> >> > +} rtems_ofw_memory_area;
>>> >> > + * @struct rtems_ofw_ranges
>>> >> > + * This is used to represent the ranges property in the device tree.
>>> >> > +typedef struct {
>>> >> > + /** The physical address within the child bus address space */
>>> >> > + uint32_t child_bus;
>>> >> > + /** The physical address within the parent bus address space */
>>> >> > + uint32_t parent_bus;
>>> >> > + /** The size of the range in the child’s address space */
>>> >> > + uint32_t size;
>>> >> > +} rtems_ofw_ranges;
>>> >> > + * @brief Gets the node that is next to @a node.
>>> >> > + * @param[in] node Node offset
>>> >> > + * @retval Peer node offset Successful operation.
>>> >> > + * @retval 0 No peer node or invalid node handle
>>> >> > +phandle_t rtems_ofw_peer(
>>> >> > + phandle_t node
>>> >> > + * @brief Gets the node that is the child of @a node.
>>> >> > + * @retval child node offset Successful operation.
>>> >> > + * @retval 0 No child node or invalid node handle
>>> >> > +phandle_t rtems_ofw_child(
>>> >> > + phandle_t node
>>> >> > + * @brief Gets the node that is the parent of @a node.
>>> >> > +phandle_t rtems_ofw_parent(
>>> >> > + phandle_t node
>>> >> > + * @brief Gets the length of the property mentioned in @a propname.
>>> >> > + * @param[in] prop Property name
>>> >> > + * @retval -1 Invalid node or property
>>> >> > + * @retval Length of property on successful operation
>>> >> > +size_t rtems_ofw_get_prop_len(
>>> >> > + phandle_t node,
>>> >> > + const char *propname
>>> >> > + * @brief Gets the value of property mentioned in @a propname.
>>> >> > + * @param[out] buf The property value gets stored in this buffer (Pre-allocated)
>>> >> > + * @param[in] len Length of the buffer
>>> >> > +size_t rtems_ofw_get_prop(
>>> >> > + phandle_t node,
>>> >> > + const char *propname,
>>> >> > + void *buf,
>>> >> > + size_t len
>>> >> > + * @brief Gets the value of property mentioned in @a prop.
>>> >> > + * Gets the value of property of @a node and converts the value into the host's
>>> >> > + * endianness.
>>> >> > + * @param[out] buf The property value gets stored in this buffer(Pre-allocated)
>>> >> > + * after converted to the host's endianness
>>> >> > +size_t rtems_ofw_get_enc_prop(
>>> >> > + phandle_t node,
>>> >> > + const char *prop,
>>> >> > + pcell_t *buf,
>>> >> > + size_t len
>>> >> > + * @brief Checks if the property @a propname is present in @a node.
>>> >> > + * @param[in] propname Property name
>>> >> > + * @retval 0 Property not present.
>>> >> > + * @retval 1 Property is present.
>>> >> > +int rtems_ofw_has_prop(
>>> >> > + phandle_t node,
>>> >> > + * @brief Searches for property @a propname in @a node.
>>> >> > + * Searches the node and its parent recursively for the property and fills the
>>> >> > + * buffer with the first found value.
>>> >> > + * @retval Length of the property if property is found.
>>> >> > + * @retval -1 Property is not found.
>>> >> > +size_t rtems_ofw_search_prop(
>>> >> > + phandle_t node,
>>> >> > + void *buf,
>>> >> > + size_t len
>>> >> > + * buffer with the first value found after converting it to the endianness of
>>> >> > + * the host.
>>> >> > +size_t rtems_ofw_search_enc_prop(
>>> >> > + phandle_t node,
>>> >> > + pcell_t *buf,
>>> >> > + size_t len
>>> >> > + * Same as rtems_ofw_getprop, but the @a buf is allocated in this routine and
>>> >> > + * the user is responsible for freeing it.
>>> >> > + * @param[out] buf The buffer is allocated in this routine and user is
>>> >> > + * responsible for freeing.
>>> >> > +size_t rtems_ofw_get_prop_alloc(
>>> >> > + phandle_t node,
>>> >> > + void **buf
>>> >> > + * @brief Gets multiple values of the property @a propname.
>>> >> > + * Same as rtems_ofw_getprop_alloc but it can read properties with multiple
>>> >> > + * values.
>>> >> > + * For eg: reg = <0x1000 0x10 0x2000 0x20>
>>> >> > + * @param[in] elsz Size of the single value
>>> >> > + * @retval Number of values read.
>>> >> > +size_t rtems_ofw_get_prop_alloc_multi(
>>> >> > + phandle_t node,
>>> >> > + int elsz,
>>> >> > + void **buf
>>> >> > + * Same as rtems_ofw_getprop_alloc but the value stored in the buffer is
>>> >> > + * converted into the host's endianness.
>>> >> > +size_t rtems_ofw_get_enc_prop_alloc(
>>> >> > + phandle_t node,
>>> >> > + void **buf
>>> >> > + * Same as rtems_ofw_getprop_alloc_multi but the values stored in the buffer
>>> >> > + * are converted to the host's endianness.
>>> >> > +size_t rtems_ofw_get_enc_prop_alloc_multi(
>>> >> > + phandle_t node,
>>> >> > + int elsz,
>>> >> > + void **buf
>>> >> > + * @brief Free's the buffers allocated by the rtems_ofw_*_alloc functions.
>>> >> > + * @param[in] buf Buffer to be freed
>>> >> > +void rtems_ofw_free(
>>> >> > + void *buf
>>> >> > + * @brief Finds the next property of @a node.
>>> >> > + * Finds the next property of the node and when @a propname is NULL it returns
>>> >> > + * the value in the first property.
>>> >> > + * @param[in] previous Previous property name
>>> >> > + * @param[out] buf The value of the next property gets stored in this buffer
>>> >> > + * (Pre-allocated)
>>> >> > + * @retval -1 node or previous property does not exist
>>> >> > + * @retval 0 no more properties
>>> >> > + * @retval 1 success
>>> >> > +int rtems_ofw_next_prop(
>>> >> > + phandle_t node,
>>> >> > + const char *previous,
>>> >> > + char *buf,
>>> >> > + size_t len
>>> >> > + * @brief Sets the property @name of @a node to @a buf.
>>> >> > + * @param[in] name Property name
>>> >> > + * @param[in] buf Buffer contains the value to be set.
>>> >> > + * @retval -1 node does not exist
>>> >> > + * @retval 0 on success
>>> >> > + * @retval libFDT error codes on unsuccessful setting operation
>>> >> > +int rtems_ofw_set_prop(
>>> >> > + phandle_t node,
>>> >> > + const char *name,
>>> >> > + const void *buf,
>>> >> > + size_t len
>>> >> > + * @brief Converts a device specifier to a fully qualified path name.
>>> >> > + * @param[in] dev device specifier
>>> >> > + * @param[out] buf The path is filled into the buffer(Pre-allocated)
>>> >> > + * @param[in] length of the buffer
>>> >> > + * @retval -1 always. Unimplemented.
>>> >> > +size_t rtems_ofw_canon(
>>> >> > + const char *dev,
>>> >> > + char *buf,
>>> >> > + size_t len
>>> >> > + * @brief Finds the node at the given path
>>> >> > + * @param[in] path to the node from root
>>> >> > + * @retval node handle on success
>>> >> > +phandle_t rtems_ofw_find_device(
>>> >> > + const char *path
>>> >> > + * @brief This routine converts effective phandle @a xref to node offset.
>>> >> > + * @param[in] xref Node phandle
>>> >> > + * @retval Node offset on success
>>> >> > + * @retval Node phandle on failure
>>> >> > +phandle_t rtems_ofw_node_from_xref(
>>> >> > + phandle_t xref
>>> >> > + * @brief This routine converts node offset to effective phandle of @a node.
>>> >> > + * @retval Node phandle on success
>>> >> > + * @retval Node offset on failure
>>> >> > +phandle_t rtems_ofw_xref_from_node(
>>> >> > + phandle_t node
>>> >> > + * instance handles(ihandle_t) as same as phandles in the FDT implementation
>>> >> > + * of OF interface.
>>> >> > + * @brief Converts @a instance handle to phandle.
>>> >> > + * instance are same as node offsets in FDT.
>>> >> > + * @param[in] instance Node offset
>>> >> > + * @retval phandle of node on success.
>>> >> > + * @retval instance of node on failure.
>>> >> > +phandle_t rtems_ofw_instance_to_package(
>>> >> > + ihandle_t instance
>>> >> > + * @brief Find the node's path from phandle.
>>> >> > + * @param[out] buf Path is filled into this buffer(Pre-allocated).
>>> >> > + * @param[in] len Length of the buffer.
>>> >> > +size_t rtems_ofw_package_to_path(
>>> >> > + phandle_t node,
>>> >> > + char *buf,
>>> >> > + size_t len
>>> >> > + * @brief Find the node's path from ihandle.
>>> >> > +size_t rtems_ofw_instance_to_path(
>>> >> > + ihandle_t instance,
>>> >> > + char *buf,
>>> >> > + size_t len
>>> >> > + * @brief Queries the node's reg value.
>>> >> > + * This routine fills the buffer @a buf with the values in reg property of node
>>> >> > + * @a node. It reads all the values of the property and fills the buffer to max
>>> >> > + * size.
>>> >> > + * This routine is local to RTEMS OFW and does not have an corresponding
>>> >> > + * FreeBSD OFW pair.
>>> >> > + * @param[out] buf Register values are stored in this buffer(Pre-allocated).
>>> >> > + * @param[in] size Length of the buffer.
>>> >> > + * @retval -1 If reg property is missing.
>>> >> > + * @retval Length of the reg property in bytes.
>>> >> > +int rtems_ofw_get_reg(
>>> >> > + phandle_t node,
>>> >> > + rtems_ofw_memory_area *buf,
>>> >> > + size_t size
>>> >> > + * @brief Queries the node's interrupt value.
>>> >> > + * This routine fills the buffer @a buf with the interrupt number. In case of
>>> >> > + * multiple numbers it fills the buffer to its full extent.
>>> >> > + * @param[out] buf Interrupt values are stored in this buffer(Pre-allocated).
>>> >> > + * @retval -1 If interrupts property is missing.
>>> >> > + * @retval The number of interrupt numbers read.
>>> >> > +int rtems_ofw_get_interrupts(
>>> >> > + phandle_t node,
>>> >> > + rtems_vector_number *buf,
>>> >> > + size_t size
>>> >> > + * @brief Queries the node's status.
>>> >> > + * @retval true Status is OK or empty.
>>> >> > + * @retval false Status is not OK or missing.
>>> >> > +bool rtems_ofw_node_status( phandle_t node );
>>> >> > + * @brief Gets node phandle from compatible property.
>>> >> > + * @param[in] compat Compatible string
>>> >> > + * @retval 0 Node with @a compat as compatible string not found
>>> >> > + * @retval Node phandle on success.
>>> >> > +phandle_t rtems_ofw_find_device_by_compat( const char *compat );
>>> >> > +#ifdef __cplusplus
>>> >> > +#endif
>>> >> > +#endif /* _OFW_H */
>>> >> > diff --git a/bsps/include/ofw/ofw_compat.h b/bsps/include/ofw/ofw_compat.h
>>> >> > index 0000000000..be4a5ea3ce
>>> >> > --- /dev/null
>>> >> > +++ b/bsps/include/ofw/ofw_compat.h
>>> >> > @@ -0,0 +1,74 @@
>>> >> > + * @file
>>> >> > + * @ingroup ofw
>>> >> > + * This file defines necessary symbols to make the RTEMS OFW API compatible
>>> >> > + * with FreeBSD OFW.
>>> >> > + * are met:
>>> >> > +#ifndef _OFW_COMPAT_H
>>> >> > +#define _OFW_COMPAT_H
>>> >> > +#ifdef __cplusplus
>>> >> > +extern "C" {
>>> >> > +#endif
>>> >> > +#include <ofw/ofw.h>
>>> >> > +#define OF_peer rtems_ofw_peer
>>> >> > +#define OF_child rtems_ofw_child
>>> >> > +#define OF_parent rtems_ofw_parent
>>> >> > +#define OF_getproplen rtems_ofw_get_prop_len
>>> >> > +#define OF_getprop rtems_ofw_get_prop
>>> >> > +#define OF_getencprop rtems_ofw_get_enc_prop
>>> >> > +#define OF_hasprop rtems_ofw_has_prop
>>> >> > +#define OF_searchprop rtems_ofw_search_prop
>>> >> > +#define OF_searchencprop rtems_ofw_search_enc_prop
>>> >> > +#define OF_getprop_alloc rtems_ofw_get_prop_alloc
>>> >> > +#define OF_getprop_alloc_multi rtems_ofw_get_prop_alloc_multi
>>> >> > +#define OF_getencprop_alloc_multi rtems_ofw_get_enc_prop_alloc_multi
>>> >> > +#define OF_getencprop_alloc rtems_ofw_get_enc_prop_alloc
>>> >> > +#define OF_prop_free rtems_ofw_free
>>> >> > +#define OF_nextprop rtems_ofw_next_prop
>>> >> > +#define OF_setprop rtems_ofw_set_prop
>>> >> > +#define OF_canon rtems_ofw_canon
>>> >> > +#define OF_finddevice rtems_ofw_find_device
>>> >> > +#define OF_package_to_path rtems_ofw_package_to_path
>>> >> > +#define OF_node_from_xref rtems_ofw_node_from_xref
>>> >> > +#define OF_xref_from_node rtems_ofw_xref_from_node
>>> >> > +#define OF_instance_to_package rtems_ofw_instance_to_package
>>> >> > +#define OF_instance_to_path rtems_ofw_instance_to_path
>>> >> > +#ifdef __cplusplus
>>> >> > +#endif
>>> >> > +#endif /* _OFW_COMPAT_H */
>>> >> > diff --git a/bsps/shared/ofw/ofw.c b/bsps/shared/ofw/ofw.c
>>> >> > index 0000000000..481b29553b
>>> >> > --- /dev/null
>>> >> > +++ b/bsps/shared/ofw/ofw.c
>>> >> > @@ -0,0 +1,670 @@
>>> >> > + * @file
>>> >> > + * @ingroup ofw
>>> >> > + * are met:
>>> >> > +#ifdef HAVE_CONFIG_H
>>> >> > +#include "config.h"
>>> >> > +#endif
>>> >> > +#include <bsp/fdt.h>
>>> >> > +#include <sys/param.h>
>>> >> > +#include <libfdt.h>
>>> >> > +#include <assert.h>
>>> >> > +#include <rtems/sysinit.h>
>>> >> > +const void *fdtp = NULL;
>>> >> > +static phandle_t rtems_fdt_offset_to_phandle( int offset )
>>> >> > + if (offset < 0) {
>>> >> > + return 0;
>>> >> > + return (phandle_t)offset + fdt_off_dt_struct(fdtp);
>>> >> > +static int rtems_fdt_phandle_to_offset( phandle_t handle )
>>> >> > + int off;
>>> >> > + int fdt_off;
>>> >> > + off = (int) handle;
>>> >> > + fdt_off = fdt_off_dt_struct(fdtp);
>>> >> > + if (off < fdt_off) {
>>> >> > + return -1;
>>> >> > + return off - fdt_off;
>>> >> > +static void rtems_ofw_init( void ) {
>>> >> > + int rv;
>>> >> > + const void *fdt;
>>> >> > + fdt = bsp_fdt_get();
>>> >> > + rv = fdt_check_header(fdt);
>>> >> > + * If the FDT is invalid exit through fatal.
>>> >> > + if (rv != 0) {
>>> >> > + rtems_fatal_error_occurred(RTEMS_NOT_CONFIGURED);
>>> >> > + fdtp = fdt;
>>> >> > +RTEMS_SYSINIT_ITEM(
>>> >> > + rtems_ofw_init,
>>> >> > + RTEMS_SYSINIT_BSP_PRE_DRIVERS,
>>> >> > + RTEMS_SYSINIT_ORDER_FIRST
>>> >> > +phandle_t rtems_ofw_peer( phandle_t node )
>>> >> > + int offset;
>>> >> > + if (node == 0) {
>>> >> > + int root = fdt_path_offset(fdtp, "/");
>>> >> > + return rtems_fdt_offset_to_phandle(root);
>>> >> > + offset = rtems_fdt_phandle_to_offset(node);
>>> >> > + if (offset < 0) {
>>> >> > + return 0;
>>> >> > + offset = fdt_next_subnode(fdtp, offset);
>>> >> > + return rtems_fdt_offset_to_phandle(offset);
>>> >> > +phandle_t rtems_ofw_child( phandle_t node )
>>> >> > + int offset;
>>> >> > + if (offset < 0) {
>>> >> > + return 0;
>>> >> > + offset = fdt_first_subnode(fdtp, offset);
>>> >> > +phandle_t rtems_ofw_parent( phandle_t node )
>>> >> > + int offset;
>>> >> > + if (offset < 0) {
>>> >> > + return 0;
>>> >> > + offset = fdt_parent_offset(fdtp, offset);
>>> >> > + phandle_t node,
>>> >> > + int offset;
>>> >> > + int len;
>>> >> > + const void *prop;
>>> >> > + if (offset < 0) {
>>> >> > + return -1;
>>> >> > + prop = fdt_getprop(fdtp, offset, propname, &len);
>>> >> > + if (prop == NULL && strcmp(propname, "name") == 0) {
>>> >> > + fdt_get_name(fdtp, offset, &len);
>>> >> > + return len + 1;
>>> >> > + if (prop == NULL && strcmp(propname, "/chosen") == 0) {
>>> >> > + if (strcmp(propname, "fdtbootcpu") == 0)
>>> >> > + return sizeof(pcell_t);
>>> >> > + if (strcmp(propname, "fdtmemreserv") == 0)
>>> >> > + return 2 * sizeof(uint64_t) * fdt_num_mem_rsv(fdtp);
>>> >> > + if (prop == NULL) {
>>> >> > + return -1;
>>> >> > + return len;
>>> >> > + phandle_t node,
>>> >> > + void *buf,
>>> >> > + size_t bufsize
>>> >> > + const void *prop;
>>> >> > + int offset;
>>> >> > + int len;
>>> >> > + uint32_t cpuid;
>>> >> > + if (offset < 0) {
>>> >> > + return -1;
>>> >> > + prop = fdt_get_name(fdtp, offset, &len);
>>> >> > + strncpy(buf, prop, bufsize);
>>> >> > + return len + 1;
>>> >> > + if (strcmp(propname, "fdtbootcpu") == 0) {
>>> >> > + cpuid = cpu_to_fdt32(fdt_boot_cpuid_phys(fdtp));
>>> >> > + len = sizeof(cpuid);
>>> >> > + prop = &cpuid;
>>> >> > + if (strcmp(propname, "fdtmemreserv") == 0) {
>>> >> > + prop = (char *)fdtp + fdt_off_mem_rsvmap(fdtp);
>>> >> > + len = sizeof(uint64_t)*2*fdt_num_mem_rsv(fdtp);
>>> >> > + return -1;
>>> >> > + bcopy(prop, buf, MIN(len, bufsize));
>>> >> > + return len;
>>> >> > + phandle_t node,
>>> >> > + const char *prop,
>>> >> > + pcell_t *buf,
>>> >> > + size_t len
>>> >> > + size_t rv;
>>> >> > + assert(len % 4 == 0);
>>> >> > + rv = rtems_ofw_get_prop(node, prop, buf, len);
>>> >> > + if (rv < 0) {
>>> >> > + return rv;
>>> >> > + for (int i = 0; i < (len / 4); i++) {
>>> >> > + buf[i] = fdt32_to_cpu(buf[i]);
>>> >> > + return rv;
>>> >> > + phandle_t node,
>>> >> > + size_t rv;
>>> >> > + rv = rtems_ofw_get_prop_len(node, propname);
>>> >> > + return rv >= 0 ? 1 : 0;
>>> >> > + phandle_t node,
>>> >> > + void *buf,
>>> >> > + size_t len
>>> >> > + size_t rv;
>>> >> > + for (; node != 0; node = rtems_ofw_parent(node)) {
>>> >> > + if ((rv = rtems_ofw_get_prop(node, propname, buf, len) != -1)) {
>>> >> > + return rv;
>>> >> > + return -1;
>>> >> > + phandle_t node,
>>> >> > + pcell_t *buf,
>>> >> > + size_t len
>>> >> > + size_t rv;
>>> >> > + if ((rv = rtems_ofw_get_enc_prop(node, propname, buf, len) != -1)) {
>>> >> > + return rv;
>>> >> > + return -1;
>>> >> > + phandle_t node,
>>> >> > + void **buf
>>> >> > + size_t len;
>>> >> > + *buf = NULL;
>>> >> > + if ((len = rtems_ofw_get_prop_len(node, propname)) == -1) {
>>> >> > + return -1;
>>> >> > + if (len > 0) {
>>> >> > + *buf = malloc(len);
>>> >> > + if (rtems_ofw_get_prop(node, propname, *buf, len) == -1) {
>>> >> > + rtems_ofw_free(buf);
>>> >> > + *buf = NULL;
>>> >> > + return -1;
>>> >> > + return len;
>>> >> > + phandle_t node,
>>> >> > + int elsz,
>>> >> > + void **buf
>>> >> > + size_t len;
>>> >> > + *buf = NULL;
>>> >> > + if ((len = rtems_ofw_get_prop_len(node, propname)) == -1 ||
>>> >> > + (len % elsz != 0)) {
>>> >> > + return -1;
>>> >> > + if (len > 0) {
>>> >> > + *buf = NULL;
>>> >> > + return -1;
>>> >> > + return (len / elsz);
>>> >> > + phandle_t node,
>>> >> > + void **buf
>>> >> > + size_t len;
>>> >> > + *buf = NULL;
>>> >> > + return -1;
>>> >> > + if (len > 0) {
>>> >> > + if (rtems_ofw_get_enc_prop(node, propname, *buf, len) == -1) {
>>> >> > + *buf = NULL;
>>> >> > + return -1;
>>> >> > + return len;
>>> >> > + phandle_t node,
>>> >> > + int elsz,
>>> >> > + void **buf
>>> >> > + size_t len;
>>> >> > + *buf = NULL;
>>> >> > + return -1;
>>> >> > + if (len > 0) {
>>> >> > + *buf = NULL;
>>> >> > + return -1;
>>> >> > +void rtems_ofw_free( void *buf )
>>> >> > + free(buf);
>>> >> > + phandle_t node,
>>> >> > + char *buf,
>>> >> > + size_t len
>>> >> > + const void *name;
>>> >> > + const void *prop;
>>> >> > + int offset;
>>> >> > + if (offset < 0) {
>>> >> > + return -1;
>>> >> > + if (previous == NULL) {
>>> >> > + offset = fdt_first_property_offset(fdtp, offset);
>>> >> > + } else {
>>> >> > + fdt_for_each_property_offset(offset, fdtp, offset) {
>>> >> > + prop = fdt_getprop_by_offset(fdtp, offset, (const char **)&name, NULL);
>>> >> > + if (prop == NULL)
>>> >> > + return -1;
>>> >> > + if (strcmp(previous, name) != 0)
>>> >> > + continue;
>>> >> > + offset = fdt_next_property_offset(fdtp, offset);
>>> >> > + break;
>>> >> > + if (offset < 0)
>>> >> > + return 0;
>>> >> > + prop = fdt_getprop_by_offset(fdtp, offset, (const char **)&name, &offset);
>>> >> > + if (prop == NULL)
>>> >> > + return -1;
>>> >> > + strncpy(buf, name, len);
>>> >> > + return 1;
>>> >> > + phandle_t node,
>>> >> > + const char *name,
>>> >> > + const void *buf,
>>> >> > + size_t len
>>> >> > + int offset;
>>> >> > + if (offset < 0)
>>> >> > + return -1;
>>> >> > + if (fdt_setprop_inplace(fdtp, offset, name, buf, len) != 0)
>>> >> > + return (fdt_setprop(fdtp, offset, name, buf, len));
>>> >> > + return 0;
>>> >> > +phandle_t rtems_ofw_find_device( const char *path )
>>> >> > + int offset;
>>> >> > + offset = fdt_path_offset(fdtp, path);
>>> >> > + if (offset < 0)
>>> >> > + return -1;
>>> >> > +static phandle_t rtems_ofw_get_effective_phandle(
>>> >> > + phandle_t node,
>>> >> > + phandle_t xref
>>> >> > + phandle_t child;
>>> >> > + phandle_t ref;
>>> >> > + for (child = rtems_ofw_child(node); child != 0; child = rtems_ofw_peer(child)) {
>>> >> > + ref = rtems_ofw_get_effective_phandle(child, xref);
>>> >> > + if (ref != -1)
>>> >> > + return ref;
>>> >> > + if (rtems_ofw_get_enc_prop(child, "phandle", &ref, sizeof(ref)) == -1 &&
>>> >> > + rtems_ofw_get_enc_prop(child, "ibm,phandle", &ref, sizeof(ref)) == -1 &&
>>> >> > + rtems_ofw_get_enc_prop(child, "linux,phandle", &ref, sizeof(ref)) == -1
>>> >> > + continue;
>>> >> > + if (ref == xref)
>>> >> > + return child;
>>> >> > + return -1;
>>> >> > +phandle_t rtems_ofw_node_from_xref( phandle_t xref )
>>> >> > + phandle_t node;
>>> >> > + if ((node = rtems_ofw_get_effective_phandle(rtems_ofw_peer(0), xref)) == -1)
>>> >> > + return xref;
>>> >> > + return node;
>>> >> > +phandle_t rtems_ofw_xref_from_node( phandle_t node )
>>> >> > + phandle_t ref;
>>> >> > + if (rtems_ofw_get_enc_prop(node, "phandle", &ref, sizeof(ref)) == -1 &&
>>> >> > + rtems_ofw_get_enc_prop(node, "ibm,phandle", &ref, sizeof(ref)) == -1 &&
>>> >> > + rtems_ofw_get_enc_prop(node, "linux,phandle", &ref, sizeof(ref)) == -1)
>>> >> > + return node;
>>> >> > + return ref;
>>> >> > +phandle_t rtems_ofw_instance_to_package( ihandle_t instance )
>>> >> > + return rtems_ofw_node_from_xref(instance);
>>> >> > + phandle_t node,
>>> >> > + char *buf,
>>> >> > + size_t len
>>> >> > + int offset;
>>> >> > + int rv;
>>> >> > + rv = fdt_get_path(fdtp, offset, buf, len);
>>> >> > + if (rv != 0)
>>> >> > + return -1;
>>> >> > + return rv;
>>> >> > + char *buf,
>>> >> > + size_t len
>>> >> > + int offset;
>>> >> > + int rv;
>>> >> > + offset = rtems_ofw_instance_to_package(instance);
>>> >> > + offset = rtems_fdt_phandle_to_offset(offset);
>>> >> > + if (rv != 0)
>>> >> > + return -1;
>>> >> > + return rv;
>>> >> > + phandle_t node,
>>> >> > + size_t size
>>> >> > + int len;
>>> >> > + int offset;
>>> >> > + int nranges;
>>> >> > + int nregs;
>>> >> > + phandle_t parent;
>>> >> > + rtems_ofw_ranges range;
>>> >> > + const rtems_ofw_ranges *ptr;
>>> >> > + len = rtems_ofw_get_enc_prop(node, "reg", (pcell_t *)buf, size);
>>> >> > + if (len <= 0) {
>>> >> > + return len;
>>> >> > + nregs = MIN(len, size) / sizeof(rtems_ofw_memory_area);
>>> >> > + for (parent = rtems_ofw_parent(node); parent > 0;
>>> >> > + parent = rtems_ofw_parent(parent)) {
>>> >> > + offset = rtems_fdt_phandle_to_offset(parent);
>>> >> > + ptr = fdt_getprop(fdtp, offset, "ranges", &len);
>>> >> > + if (len < 0) {
>>> >> > + break;
>>> >> > + nranges = len / sizeof(rtems_ofw_ranges);
>>> >> > + offset = 0;
>>> >> > + for (int i=0; i < nregs; i++) {
>>> >> > + for (int j=0; j < nranges; j++) {
>>> >> > + range.parent_bus = fdt32_to_cpu(ptr[j].parent_bus);
>>> >> > + range.child_bus = fdt32_to_cpu(ptr[j].child_bus);
>>> >> > + range.size = fdt32_to_cpu(ptr[j].size);
>>> >> > + if (buf[i].start >= range.child_bus &&
>>> >> > + buf[i].start < range.child_bus + range.size) {
>>> >> > + offset = range.parent_bus - range.child_bus;
>>> >> > + break;
>>> >> > + buf[i].start += offset;
>>> >> > + return nregs;
>>> >> > + phandle_t node,
>>> >> > + size_t size
>>> >> > + int rv;
>>> >> > + rv = rtems_ofw_get_enc_prop(node, "interrupts", buf, size);
>>> >> > + if (rv <= 0) {
>>> >> > + return rv;
>>> >> > + return MIN(size, rv) / sizeof(rtems_vector_number);
>>> >> > + int len;
>>> >> > + const char buf[10];
>>> >> > + len = rtems_ofw_get_prop(node, "status", &buf[0], sizeof(buf));
>>> >> > + if ((len == -1) ||
>>> >> > + (strncmp(buf, "okay", MIN(5, len)) == 0) ||
>>> >> > + (strncmp(buf, "ok", MIN(3, len)) == 0)) {
>>> >> > + return true;
>>> >> > + return false;
>>> >> > + int offset;
>>> >> > + offset = fdt_node_offset_by_compatible(fdtp, -1, compat);
>>> >> > diff --git a/spec/build/bsps/obj.yml b/spec/build/bsps/obj.yml
>>> >> > index 8809238057..141ba25f5e 100644
>>> >> > --- a/spec/build/bsps/obj.yml
>>> >> > +++ b/spec/build/bsps/obj.yml
>>> >> > @@ -24,6 +24,9 @@ install:
>>> >> > - bsps/include/bsp/u-boot.h
>>> >> > - bsps/include/bsp/uart-output-char.h
>>> >> > - bsps/include/bsp/utility.h
>>> >> > +- destination: ${BSP_INCLUDEDIR}/ofw
>>> >> > + source:
>>> >> > + - bsps/include/ofw/ofw.h
>>> >> > - destination: ${BSP_INCLUDEDIR}/libchip
>>> >> > source:
>>> >> > - bsps/include/libchip/am29lv160.h
>>> >> > @@ -104,4 +107,5 @@ source:
>>> >> > - bsps/shared/dev/serial/z85c30_reg.c
>>> >> > - bsps/shared/start/bootcard.c
>>> >> > - bsps/shared/rtems-version.c
>>> >> > +- bsps/shared/ofw/ofw.c
>>> >> > type: build
>>> >> > 2.17.1
