[PATCH] Adding EPICS7 Package to RSB
Mritunjay Sharma
mritunjaysharma394 at gmail.com
Tue Aug 25 22:35:42 UTC 2020
This patch add supports for EPICS7 Package to RTEMS RSB.
Signed-off-by: Mritunjay Sharma <mritunjaysharma394 at gmail.com>
rtems/config/epics/epics-7-1.cfg | 22 +++++++++++
rtems/config/epics/epics-base.bset | 26 +++++++++++++
source-builder/config/epics-7-1.cfg | 57 +++++++++++++++++++++++++++++
3 files changed, 105 insertions(+)
create mode 100644 rtems/config/epics/epics-7-1.cfg
create mode 100644 rtems/config/epics/epics-base.bset
create mode 100644 source-builder/config/epics-7-1.cfg
diff --git a/rtems/config/epics/epics-7-1.cfg b/rtems/config/epics/epics-7-1.cfg
new file mode 100644
index 0000000..30ed9cb
--- /dev/null
+++ b/rtems/config/epics/epics-7-1.cfg
@@ -0,0 +1,22 @@
+# EPICS 7
+%if %{release} == %{nil}
+ %define release 1
+%endif
+%include %{_configdir}/rtems-bsp.cfg
+# EPICS Version
+%define epics_version 7.0
+%hash sha512 epics-base-%{epics_version}.tar.gz 63edef9d3019e8253b81610286578a1e917cc9df75db3e8f5aaf99210b4fa842be296cf7cbd384726b81b648c4e0d041c4ef266ae81a580940d7613ce8ce48e0
+# EPICS Build configuration
+%include %{_configdir}/epics-7-1.cfg
diff --git a/rtems/config/epics/epics-base.bset b/rtems/config/epics/epics-base.bset
index 0000000..e56fc6a
--- /dev/null
+++ b/rtems/config/epics/epics-base.bset
@@ -0,0 +1,26 @@
+# Build set for EPICS
+%define release 1
+# RTEMS Version
+%define rtems_version 5
+# The RTEMS URL paths.
+%include rtems-urls.bset
+# The RTEMS Package defines
+%include rtems-package.bset
+# Build EPICS.
+epics/epics-7-1 .
\ No newline at end of file
diff --git a/source-builder/config/epics-7-1.cfg b/source-builder/config/epics-7-1.cfg
index 0000000..2a52ea5
--- /dev/null
+++ b/source-builder/config/epics-7-1.cfg
@@ -0,0 +1,57 @@
+# EPICS 7.x.x Version 1.
+# This configuration file configure's, make's and install's EPICS.
+%define release 1
+%endif
+Name: epics-base-%{epics_version}-%{_host}-%{release}
+Summary: EPICS v%{epics_version} for target %{_target} on host %{_host}
+Version: %{epics_version}
+Release: %{release}
+URL: https://epics.mpg.de/
+# Source
+%source set epics-base https://gitlab.fhi.mpg.de/junkes/epics-base/-/archive/%{epics_version}/epics-base-%{epics_version}.tar.gz
+# Prepare the source code.
+%prep
+ build_top=$(pwd)
+ source_dir_epics="epics-base-%{epics_version}"
+ %source setup epics-base -q -n epics-base-%{epics_version}
+ cd ${build_top}
+%build
+ build_top=$(pwd)
+ cd ${source_dir_epics}
+ %{build_build_flags}
+ # Using macros to dynamically path to RTEMS_BASE and RTEMS_VERSION using --with-rtems-bsp
+ %{__make} RTEMS_BASE=%{_prefix} RTEMS_VERSION=%{rtems_version} CROSS_COMPILER_TARGET_ARCHS=RTEMS-%{with_rtems_bsp}
+ cd ${build_top}
+%install
+ build_top=$(pwd)
+ rm -rf $SB_BUILD_ROOT
+ %{__make} DESTDIR=$SB_BUILD_ROOT RTEMS_BASE=%{_prefix} RTEMS_VERSION=%{rtems_version} CROSS_COMPILER_TARGET_ARCHS=RTEMS-%{with_rtems_bsp}
+ cd ${build_top}
2.25.1
