[PATCH v3] Pre-Release Strong-APA
Richi Dubey richidubey at gmail.com
Wed Aug 26 15:24:11 UTC 2020
 cpukit/include/rtems/scheduler.h              |   6 +-
 .../include/rtems/score/schedulerstrongapa.h  | 154 ++-
 cpukit/score/src/schedulerstrongapa.c         | 901 ++++++++++++++----
 3 files changed, 829 insertions(+), 232 deletions(-)
diff --git a/cpukit/include/rtems/scheduler.h b/cpukit/include/rtems/scheduler.h
index 955a83cfb4..6a05c2798a 100644
--- a/cpukit/include/rtems/scheduler.h
+++ b/cpukit/include/rtems/scheduler.h
@@ -257,16 +257,14 @@
   #define RTEMS_SCHEDULER_STRONG_APA( name, prio_count ) \
     static struct { \
       Scheduler_strong_APA_Context Base; \
-      Chain_Control                Ready[ ( prio_count ) ]; \
+      Scheduler_strong_APA_CPU CPU[ CONFIGURE_MAXIMUM_PROCESSORS ]; \
     } SCHEDULER_STRONG_APA_CONTEXT_NAME( name )
   #define RTEMS_SCHEDULER_TABLE_STRONG_APA( name, obj_name ) \
       &SCHEDULER_STRONG_APA_CONTEXT_NAME( name ).Base.Base.Base, \
       SCHEDULER_STRONG_APA_ENTRY_POINTS, \
-      RTEMS_ARRAY_SIZE( \
-        SCHEDULER_STRONG_APA_CONTEXT_NAME( name ).Ready \
-      ) - 1, \
+      SCHEDULER_STRONG_APA_MAXIMUM_PRIORITY, \
       ( obj_name ) \
       SCHEDULER_CONTROL_IS_NON_PREEMPT_MODE_SUPPORTED( false ) \
diff --git a/cpukit/include/rtems/score/schedulerstrongapa.h b/cpukit/include/rtems/score/schedulerstrongapa.h
index 0ac28cb439..2476984cc4 100644
--- a/cpukit/include/rtems/score/schedulerstrongapa.h
+++ b/cpukit/include/rtems/score/schedulerstrongapa.h
@@ -5,32 +5,48 @@
  * @brief Strong APA Scheduler API
- * Copyright (c) 2013, 2018 embedded brains GmbH.  All rights reserved.
+/* SPDX-License-Identifier: BSD-2-Clause
+ * Copyright (C) 2020 Richi Dubey
+ * Copyright (c) 2013, 2018 embedded brains GmbH
- *  embedded brains GmbH
- *  Dornierstr. 4
- *  82178 Puchheim
- *  Germany
- *  <rtems at embedded-brains.de>
+ * are met:
- * The license and distribution terms for this file may be
- * found in the file LICENSE in this distribution or at
- * http://www.rtems.org/license/LICENSE.
 #ifndef _RTEMS_SCORE_SCHEDULERSTRONGAPA_H
 #define _RTEMS_SCORE_SCHEDULERSTRONGAPA_H
-#include <rtems/score/schedulerpriority.h>
 #include <rtems/score/schedulersmp.h>
+#include <rtems/score/percpu.h>
 #ifdef __cplusplus
 extern "C" {
 #endif /* __cplusplus */
+#define STRONG_SCHEDULER_NODE_OF_CHAIN( node ) \
+  RTEMS_CONTAINER_OF( node, Scheduler_strong_APA_Node, Ready_node )
  * @defgroup RTEMSScoreSchedulerStrongAPA Strong APA Scheduler
@@ -38,43 +54,97 @@ extern "C" {
- * This is an implementation of the global fixed priority scheduler (G-FP).  It
- * uses one ready chain per priority to ensure constant time insert operations.
- * The scheduled chain uses linear insert operations and has at most processor
- * count entries.  Since the processor and priority count are constants all
- * scheduler operations complete in a bounded execution time.
- * The the_thread preempt mode will be ignored.
+ * This is an implementation of the Strong APA scheduler defined by
+ * Cerqueira et al. in Linux's Processor Affinity API, Refined:
+ * Shifting Real-Time Tasks Towards Higher Schedulability.
+ * The scheduled and ready nodes are accessed via the
+ * Scheduler_strong_APA_Context::Ready which helps in backtracking when a
+ * node which is executing on a CPU gets blocked. New node is allocated to
+ * the cpu by checking all the executing nodes in the affinity set of the
+ * node and the subsequent nodes executing on the processors in its
+ * affinity set.
- * @brief Scheduler context specialization for Strong APA
- * schedulers.
-typedef struct {
-  Scheduler_SMP_Context    Base;
-  Priority_bit_map_Control Bit_map;
-  Chain_Control            Ready[ RTEMS_ZERO_LENGTH_ARRAY ];
-} Scheduler_strong_APA_Context;
- * @brief Scheduler node specialization for Strong APA
- * schedulers.
+ * @brief Scheduler node specialization for Strong APA schedulers.
 typedef struct {
    * @brief SMP scheduler node.
   Scheduler_SMP_Node Base;
+   * @brief Chain node for Scheduler_strong_APA_Context::Ready.
+  Chain_Node Ready_node;
+   * @brief CPU that this node would preempt in the backtracking part of
+   * _Scheduler_strong_APA_Get_highest_ready and
+   * _Scheduler_strong_APA_Do_Enqueue.
+  Per_CPU_Control *cpu_to_preempt;
-   * @brief The associated ready queue of this node.
+   * @brief The associated affinity set of this node.
-  Scheduler_priority_Ready_queue Ready_queue;
+  Processor_mask Affinity;
 } Scheduler_strong_APA_Node;
+ * @brief CPU related variables and a CPU_Control to implement BFS.
+typedef struct
+   * @brief CPU in a queue.
+  Per_CPU_Control *cpu;
+   * @brief The node that would preempt this CPU.
+  Scheduler_Node *preempting_node;
+   * @brief Whether or not this cpu has been added to the queue
+   * (visited in BFS).
+  bool visited;
+   * @brief The node currently executing on this cpu
+   Scheduler_Node *executing;
+} Scheduler_strong_APA_CPU;
+ * @brief Scheduler context and node definition for Strong APA scheduler.
+typedef struct {
+   * @brief @see Scheduler_SMP_Context.
+  Scheduler_SMP_Context Base;
+   * @brief Chain of all the ready and scheduled nodes present in
+   * the Strong APA scheduler.
+  Chain_Control Ready;
+   * @brief Struct with important variables for each cpu.
+  Scheduler_strong_APA_CPU CPU[ RTEMS_ZERO_LENGTH_ARRAY ];
+} Scheduler_strong_APA_Context;
+#define SCHEDULER_STRONG_APA_MAXIMUM_PRIORITY 255
  * @brief Entry points for the Strong APA Scheduler.
@@ -100,8 +170,8 @@ typedef struct {
     _Scheduler_default_Release_job, \
     _Scheduler_default_Cancel_job, \
     _Scheduler_default_Tick, \
-    _Scheduler_SMP_Start_idle \
-    SCHEDULER_OPERATION_DEFAULT_GET_SET_AFFINITY \
+    _Scheduler_SMP_Start_idle, \
+    _Scheduler_strong_APA_Set_affinity \
@@ -246,6 +316,20 @@ void _Scheduler_strong_APA_Yield(
   Scheduler_Node          *node
+ * @brief Sets the affinity .
+ * @param scheduler The scheduler control instance.
+ * @param the_thread The thread to yield.
+ * @param[in, out] node The node of @a the_thread.
+bool _Scheduler_strong_APA_Set_affinity(
+  const Scheduler_Control *scheduler,
+  Thread_Control          *thread,
+  Scheduler_Node          *node_base,
+  const Processor_mask    *affinity
 #ifdef __cplusplus
diff --git a/cpukit/score/src/schedulerstrongapa.c b/cpukit/score/src/schedulerstrongapa.c
index 924cd86412..429bbacece 100644
--- a/cpukit/score/src/schedulerstrongapa.c
+++ b/cpukit/score/src/schedulerstrongapa.c
@@ -6,18 +6,31 @@
  * @brief Strong APA Scheduler Implementation
- * Copyright (c) 2013, 2016 embedded brains GmbH.  All rights reserved.
- *  Dornierstr. 4
- *  82178 Puchheim
- *  Germany
+ * are met:
 #ifdef HAVE_CONFIG_H
@@ -25,301 +38,754 @@
 #endif
 #include <rtems/score/schedulerstrongapa.h>
-#include <rtems/score/schedulerpriorityimpl.h>
 #include <rtems/score/schedulersmpimpl.h>
+#include <rtems/score/assert.h>
-static Scheduler_strong_APA_Context *_Scheduler_strong_APA_Get_self(
-  Scheduler_Context *context
+static inline Scheduler_strong_APA_Context *
+_Scheduler_strong_APA_Get_context( const Scheduler_Control *scheduler )
+  return (Scheduler_strong_APA_Context *) _Scheduler_Get_context( scheduler );
+_Scheduler_strong_APA_Get_self( Scheduler_Context *context )
   return (Scheduler_strong_APA_Context *) context;
-static Scheduler_strong_APA_Node *
+static inline Scheduler_strong_APA_Node *
 _Scheduler_strong_APA_Node_downcast( Scheduler_Node *node )
   return (Scheduler_strong_APA_Node *) node;
-static void _Scheduler_strong_APA_Move_from_scheduled_to_ready(
+static inline void _Scheduler_strong_APA_Do_update(
   Scheduler_Context *context,
-  Scheduler_Node    *scheduled_to_ready
+  Scheduler_Node    *node,
+  Priority_Control   new_priority
-  Scheduler_strong_APA_Context *self =
-    _Scheduler_strong_APA_Get_self( context );
-  Scheduler_strong_APA_Node *node =
-    _Scheduler_strong_APA_Node_downcast( scheduled_to_ready );
-  _Chain_Extract_unprotected( &node->Base.Base.Node.Chain );
-  _Scheduler_priority_Ready_queue_enqueue_first(
-    &node->Base.Base.Node.Chain,
-    &node->Ready_queue,
-    &self->Bit_map
+  Scheduler_SMP_Node *smp_node;
+  (void) context;
+  smp_node = _Scheduler_SMP_Node_downcast( node );
+  _Scheduler_SMP_Node_update_priority( smp_node, new_priority );
-static void _Scheduler_strong_APA_Move_from_ready_to_scheduled(
+ * Returns true if the Strong APA scheduler has ready nodes
+ * available for scheduling.
+static inline bool
+    _Scheduler_strong_APA_Has_ready( Scheduler_Context *context )
+  Scheduler_strong_APA_Context *self;
+  const Chain_Node             *tail;
+  Chain_Node                   *next;
+  Scheduler_strong_APA_Node    *node;
+  self = _Scheduler_strong_APA_Get_self( context );
+  tail = _Chain_Immutable_tail( &self->Ready );
+  next = _Chain_First( &self->Ready );
+  while ( next != tail ) {
+    node = (Scheduler_strong_APA_Node *) STRONG_SCHEDULER_NODE_OF_CHAIN( next );
+    if (
+      _Scheduler_SMP_Node_state( &node->Base.Base ) ==
+      SCHEDULER_SMP_NODE_READY
+      return true;
+    next = _Chain_Next( next );
+  return false;
+static inline void _Scheduler_strong_APA_Allocate_processor(
-  Scheduler_Node    *ready_to_scheduled
+  Scheduler_Node    *scheduled_base,
+  Scheduler_Node    *victim_base,
+  Per_CPU_Control   *victim_cpu
+  Scheduler_strong_APA_Node    *scheduled;
-  Scheduler_strong_APA_Node    *node;
-  Priority_Control              insert_priority;
+  (void) victim_base;
+  scheduled = _Scheduler_strong_APA_Node_downcast( scheduled_base );
-  node = _Scheduler_strong_APA_Node_downcast( ready_to_scheduled );
-  _Scheduler_priority_Ready_queue_extract(
-    &self->Bit_map
+  self->CPU[ _Per_CPU_Get_index( victim_cpu ) ].executing = scheduled_base;
+  _Scheduler_SMP_Allocate_processor_exact(
+    context,
+    &(scheduled->Base.Base),
+    NULL,
+    victim_cpu
-  insert_priority = _Scheduler_SMP_Node_priority( &node->Base.Base );
+ * Finds and returns the highest ready node present by accessing the
+ * _Strong_APA_Context->CPU with front and rear values.
+static inline Scheduler_Node * _Scheduler_strong_APA_Find_highest_ready(
+  Scheduler_strong_APA_Context *self,
+  uint32_t                      front,
+  uint32_t                      rear
+  Scheduler_Node              *highest_ready;
+  Scheduler_strong_APA_CPU    *CPU;
+  Chain_Node                  *next;
+  uint32_t                     index_assigned_cpu;
+  Priority_Control             min_priority_num;
+  Priority_Control             curr_priority;
+  Per_CPU_Control             *assigned_cpu;
+  Scheduler_SMP_Node_state     curr_state;
+  Per_CPU_Control             *curr_CPU;
+  bool                         first_task;
+  CPU = self->CPU;
+    * When the first task accessed has nothing to compare its priority against
+    * So, it is the task with the highest priority witnessed so far.
+  first_task = true;
+  //Assert rear < sizeof(Context->CPU)
+  _Assert( rear < CONFIGURE_MAXIMUM_PROCESSOR );
+  while( front <= rear ) {
+    curr_CPU = CPU[ front ].cpu;
+    front = front + 1;
+      node = (Scheduler_strong_APA_Node*) STRONG_SCHEDULER_NODE_OF_CHAIN( next );
+      //Check if the curr_CPU is in the affinity set of the node.
+      if (
+        _Processor_mask_Is_set(&node->Affinity, _Per_CPU_Get_index(curr_CPU))
+        curr_state = _Scheduler_SMP_Node_state( &node->Base.Base );
+        if ( curr_state == SCHEDULER_SMP_NODE_SCHEDULED ) {
+          assigned_cpu = _Thread_Get_CPU( node->Base.Base.user );
+          index_assigned_cpu =  _Per_CPU_Get_index( assigned_cpu );
+          if ( CPU[ index_assigned_cpu ].visited == false ) {
+            rear = rear + 1;
+            CPU[ rear ].cpu = assigned_cpu;
+            CPU[ index_assigned_cpu ].visited = true;
+             * The curr CPU of the queue invoked this node to add its CPU
+             * that it is executing on to the queue. So this node might get
+             * preempted because of the invoker curr_CPU and this curr_CPU
+             * is the CPU that node should preempt in case this node
+             * gets preempted.
+            node->cpu_to_preempt = curr_CPU;
+        else if ( curr_state == SCHEDULER_SMP_NODE_READY ) {
+          curr_priority = _Scheduler_Node_get_priority( &node->Base.Base );
+          curr_priority = SCHEDULER_PRIORITY_PURIFY( curr_priority );
+          if ( first_task == true || curr_priority < min_priority_num ) {
+            min_priority_num = curr_priority;
+  	    highest_ready = &node->Base.Base;
+  	    first_task = false;
+  	     * In case curr_CPU is filter_CPU, we need to store the
+  	     * cpu_to_preempt value so that we go back to SMP_*
+  	     * function, rather than preempting the node ourselves.
+  return highest_ready;
+static inline void  _Scheduler_strong_APA_Move_from_ready_to_scheduled(
+  Scheduler_Context *context,
+  Scheduler_Node    *ready_to_scheduled
+  Priority_Control insert_priority;
+  insert_priority = _Scheduler_SMP_Node_priority( ready_to_scheduled );
   insert_priority = SCHEDULER_PRIORITY_APPEND( insert_priority );
-  _Chain_Insert_ordered_unprotected(
-    &self->Base.Scheduled,
-    &insert_priority,
-    _Scheduler_SMP_Priority_less_equal
+  _Scheduler_SMP_Insert_scheduled(
+    context,
+    ready_to_scheduled,
+    insert_priority
-static void _Scheduler_strong_APA_Insert_ready(
+ * Implement the BFS Algorithm for task departure to get the highest ready task
+ * for a particular CPU, returns the highest ready Scheduler_Node
+ * Scheduler_Node filter here pointst to the victim node that is blocked
+ * resulting which this function is called.
+static inline Scheduler_Node *_Scheduler_strong_APA_Get_highest_ready(
-  Scheduler_Node    *node_base,
+  Scheduler_Node    *filter
+  Per_CPU_Control              *filter_cpu;
+  Scheduler_Node               *curr_node;
+  Scheduler_Node               *next_node;
+  uint32_t	                front;
+  uint32_t	                rear;
+  uint32_t	                cpu_max;
+  uint32_t             	        cpu_index;
-  node = _Scheduler_strong_APA_Node_downcast( node_base );
+  //Denotes front and rear of the queue.
+  front = 0;
+  rear = -1;
-  if ( SCHEDULER_PRIORITY_IS_APPEND( insert_priority ) ) {
-    _Scheduler_priority_Ready_queue_enqueue(
-      &self->Bit_map
-  } else {
-      &self->Bit_map
+  filter_cpu = _Thread_Get_CPU( filter->user );
+  CPU = self->CPU;
+  cpu_max = _SMP_Get_processor_maximum();
+  for ( cpu_index = 0 ; cpu_index < cpu_max ; ++cpu_index ) {
+    CPU[ cpu_index ].visited = false;
+  rear = rear + 1;
+  CPU[ rear ].cpu = filter_cpu;
+  CPU[ _Per_CPU_Get_index( filter_cpu ) ].visited = true;
+  highest_ready = _Scheduler_strong_APA_Find_highest_ready(
+                    self,
+                    front,
+                    rear
+  if ( highest_ready != filter ) {
+     * Backtrack on the path from
+     * filter_cpu to highest_ready, shifting along every task.
+    node = _Scheduler_strong_APA_Node_downcast( highest_ready );
+     * Highest ready is not just directly reachable from the victim cpu
+     * So there is need of task shifting .
+    while( node->cpu_to_preempt !=  filter_cpu ){
+      curr_node = &node->Base.Base;
+      next_node = CPU[ _Per_CPU_Get_index( node->cpu_to_preempt ) ].executing;
+      _Scheduler_SMP_Preempt(
+        context,
+        curr_node,
+        next_node,
+        _Scheduler_strong_APA_Allocate_processor
+      if( curr_node == highest_ready) {
+        _Scheduler_strong_APA_Move_from_ready_to_scheduled(context, curr_node);
+      node = _Scheduler_strong_APA_Node_downcast( next_node );
+     * To save the last node so that the caller SMP_* function
+     * can do the allocation
+      highest_ready = curr_node;
-static void _Scheduler_strong_APA_Extract_from_ready(
+ * Checks the lowest scheduled directly reachable task
+static inline Scheduler_Node *_Scheduler_strong_APA_Get_lowest_scheduled(
-  Scheduler_Node    *the_thread
+  Scheduler_Node    *filter_base
-    _Scheduler_strong_APA_Node_downcast( the_thread );
-    &self->Bit_map
+  uint32_t	                cpu_max;
+  Scheduler_Node               *lowest_scheduled;
+  Priority_Control              max_priority_num;
+  Scheduler_strong_APA_Node    *filter_strong_node;
+  lowest_scheduled = NULL; // To remove compiler warning.
+  max_priority_num = 0;    // Max (Lowest) priority encountered so far.
+  filter_strong_node = _Scheduler_strong_APA_Node_downcast( filter_base );
+  //lowest_scheduled is NULL if affinty of a node is 0
+  _Assert( !_Processor_mask_Zero( &filter_strong_node->Affinity ) );
+    //Checks if the CPU is in the affinity set of filter_strong_node
+    if ( _Processor_mask_Is_set( &filter_strong_node->Affinity, cpu_index) ) {
+      Per_CPU_Control *cpu = _Per_CPU_Get_by_index( cpu_index );
+      if ( _Per_CPU_Is_processor_online( cpu ) ) {
+        curr_node = self->CPU[ _Per_CPU_Get_index( cpu ) ].executing;
+        curr_priority = _Scheduler_Node_get_priority( curr_node );
+        if ( curr_priority > max_priority_num ) {
+          lowest_scheduled = curr_node;
+          max_priority_num = curr_priority;
+  _Assert( lowest_scheduled != NULL );
+  return lowest_scheduled;
-static void _Scheduler_strong_APA_Do_update(
+static inline void _Scheduler_strong_APA_Extract_from_scheduled(
-  Scheduler_Node *node_to_update,
-  Priority_Control new_priority
+  Scheduler_Node    *node_to_extract
-    _Scheduler_strong_APA_Node_downcast( node_to_update );
-  _Scheduler_SMP_Node_update_priority( &node->Base, new_priority );
-  _Scheduler_priority_Ready_queue_update(
-    SCHEDULER_PRIORITY_UNMAP( new_priority ),
-    &self->Bit_map,
-    &self->Ready[ 0 ]
+  node = _Scheduler_strong_APA_Node_downcast( node_to_extract );
+  _Scheduler_SMP_Extract_from_scheduled( &self->Base.Base, &node->Base.Base );
+  //Not removing it from Ready since the node could go in the READY state.
-_Scheduler_strong_APA_Get_context( const Scheduler_Control *scheduler )
+static inline void _Scheduler_strong_APA_Extract_from_ready(
-  return (Scheduler_strong_APA_Context *) _Scheduler_Get_context( scheduler );
+  _Assert( !_Chain_Is_empty(self->Ready) );
+  _Assert( !_Chain_Is_node_off_chain( &node->Ready_node ) );
+   _Chain_Extract_unprotected( &node->Ready_node );	//Removed from Ready
+   _Chain_Set_off_chain( &node->Ready_node );
-void _Scheduler_strong_APA_Initialize( const Scheduler_Control *scheduler )
+static inline void _Scheduler_strong_APA_Insert_ready(
-    _Scheduler_strong_APA_Get_context( scheduler );
-  _Scheduler_SMP_Initialize( &self->Base );
-  _Priority_bit_map_Initialize( &self->Bit_map );
-  _Scheduler_priority_Ready_queue_initialize(
-    &self->Ready[ 0 ],
-    scheduler->maximum_priority
+  node = _Scheduler_strong_APA_Node_downcast( node_base );
+  if( _Chain_Is_node_off_chain( &node->Ready_node ) ) {
+    _Chain_Append_unprotected( &self->Ready, &node->Ready_node );
-void _Scheduler_strong_APA_Node_initialize(
-  const Scheduler_Control *scheduler,
-  Scheduler_Node          *node,
-  Thread_Control          *the_thread,
-  Priority_Control         priority
+static inline void _Scheduler_strong_APA_Move_from_scheduled_to_ready(
+  Scheduler_Node    *scheduled_to_ready
-  Scheduler_Context            *context;
-  Scheduler_strong_APA_Context *self;
-  Scheduler_strong_APA_Node    *the_node;
-  the_node = _Scheduler_strong_APA_Node_downcast( node );
-  _Scheduler_SMP_Node_initialize(
-    scheduler,
-    &the_node->Base,
-    the_thread,
-    priority
+  _Scheduler_SMP_Extract_from_scheduled( context, scheduled_to_ready );
+  insert_priority = _Scheduler_SMP_Node_priority( scheduled_to_ready );
-  context = _Scheduler_Get_context( scheduler );
-  self = _Scheduler_strong_APA_Get_self( context );
-    &the_node->Ready_queue,
-    SCHEDULER_PRIORITY_UNMAP( priority ),
-    &self->Bit_map,
-    &self->Ready[ 0 ]
+  _Scheduler_strong_APA_Insert_ready(
+    context,
+    scheduled_to_ready,
+    insert_priority
-static bool _Scheduler_strong_APA_Has_ready( Scheduler_Context *context )
+static inline Scheduler_Node* _Scheduler_strong_APA_Get_lowest_reachable(
+  uint32_t                      front,
+  uint32_t                      rear,
+  Per_CPU_Control             **cpu_to_preempt
+  Scheduler_Node              *lowest_reachable;
+  uint32_t	               cpu_max;
+  Thread_Control              *curr_thread;
+  Scheduler_strong_APA_Node   *curr_strong_node; //Current Strong_APA_Node
+  max_priority_num = 0; //Max (Lowest) priority encountered so far.
+  CPU = self->CPU;
+    curr_node = CPU[ _Per_CPU_Get_index( curr_CPU ) ].executing;
+    curr_thread = curr_node->user;
+    curr_strong_node = _Scheduler_strong_APA_Node_downcast( curr_node );
+      lowest_reachable = curr_node;
+      *cpu_to_preempt = curr_CPU;
+    if ( !curr_thread->is_idle ) {
+        if ( _Processor_mask_Is_set( &curr_strong_node->Affinity, cpu_index ) ) {
+          //Checks if the thread_CPU is in the affinity set of the node
+          if ( _Per_CPU_Is_processor_online( cpu ) && CPU[ cpu_index ].visited == false ) {
+            rear = rear + 1;
+            CPU[ rear ].cpu = cpu;
+            CPU[ cpu_index ].visited = true;
+            CPU[ cpu_index ].preempting_node = curr_node;
-  return !_Priority_bit_map_Is_empty( &self->Bit_map );
+  return lowest_reachable;
-static Scheduler_Node *_Scheduler_strong_APA_Get_highest_ready(
+static inline bool _Scheduler_strong_APA_Do_enqueue(
+  Scheduler_Node    *lowest_reachable,
+  Priority_Control  insert_priority,
+  bool                          needs_help;
+  Priority_Control              node_priority;
+  Priority_Control              lowest_priority;
+  CPU = self->CPU;
+  node_priority = _Scheduler_Node_get_priority( node );
+  node_priority = SCHEDULER_PRIORITY_PURIFY( node_priority );
+  lowest_priority =  _Scheduler_Node_get_priority( lowest_reachable );
+  lowest_priority = SCHEDULER_PRIORITY_PURIFY( lowest_priority );
+  if( lowest_priority > node_priority ) {
+    //Backtrack on the path from
+    //_Thread_Get_CPU(lowest_reachable->user) to lowest_reachable, shifting
+    //along every task
+    curr_node = CPU[ _Per_CPU_Get_index(cpu_to_preempt) ].preempting_node;
+    curr_strong_node->cpu_to_preempt = cpu_to_preempt;
+    //Save which cpu to preempt in cpu_to_preempt value of the node
+    while ( curr_node != node ) {
+      curr_CPU = _Thread_Get_CPU( curr_node->user );
+      curr_node = CPU[ _Per_CPU_Get_index( curr_CPU ) ].preempting_node;
+      curr_strong_node->cpu_to_preempt =  curr_CPU;
+    curr_CPU = curr_strong_node->cpu_to_preempt;
+    next_node = CPU[ _Per_CPU_Get_index( curr_CPU ) ].executing;
+    node_priority = _Scheduler_Node_get_priority( curr_node );
+    _Scheduler_SMP_Enqueue_to_scheduled(
+      context,
+      curr_node,
+      node_priority,
+      next_node,
+      _Scheduler_SMP_Insert_scheduled,
+      _Scheduler_strong_APA_Move_from_scheduled_to_ready,
-  (void) node;
+    curr_node = next_node;
-  return (Scheduler_Node *) _Scheduler_priority_Ready_queue_first(
-    &self->Bit_map,
-    &self->Ready[ 0 ]
+    while( curr_node !=  lowest_reachable ) {
+      //curr_node preempts the next_node;
+	context,
+	curr_node,
+	next_node,
+    _Scheduler_strong_APA_Move_from_scheduled_to_ready( context, lowest_reachable );
+    needs_help = false;
+  } else {
+    needs_help = true;
+  //Add it to Ready chain since it is now either scheduled or just ready.
+  _Scheduler_strong_APA_Insert_ready(context,node,insert_priority);
+  return needs_help;
-void _Scheduler_strong_APA_Block(
+ * BFS Algorithm for task arrival
+ * Enqueue node either in the scheduled chain or in the ready chain.
+ * node is the newly arrived node and is currently not scheduled.
+static inline bool _Scheduler_strong_APA_Enqueue(
-  Scheduler_Context *context = _Scheduler_Get_context( scheduler );
+  uint32_t	                cpu_max;
+  Scheduler_strong_APA_Node    *strong_node;
-  _Scheduler_SMP_Block(
+  uint32_t	front;
+  uint32_t	rear;
+  front = 0;
+  rear = -1;
+  strong_node = _Scheduler_strong_APA_Node_downcast( node );
+  CPU = self->CPU;
+    if ( _Processor_mask_Is_set( &strong_node->Affinity, cpu_index) ) {
+        rear = rear + 1;
+        CPU[ cpu_index ].preempting_node = node;
+  //This assert makes sure that there always exist an element in the
+  // Queue when we start the queue traversal.
+  _Assert( !_Processor_mask_Zero( &strong_node->Affinity ) );
+  lowest_reachable = _Scheduler_strong_APA_Get_lowest_reachable(
+                       self,
+                       front,
+                       rear,
+                       &cpu_to_preempt
+  return _Scheduler_strong_APA_Do_enqueue(
+           context,
+           lowest_reachable,
+           node,
+           insert_priority,
+           cpu_to_preempt
+static inline bool _Scheduler_strong_APA_Enqueue_scheduled(
+  return _Scheduler_SMP_Enqueue_scheduled(
     context,
-    the_thread,
     node,
-    _Scheduler_SMP_Extract_from_scheduled,
+    insert_priority,
+    _Scheduler_SMP_Priority_less_equal,
     _Scheduler_strong_APA_Extract_from_ready,
     _Scheduler_strong_APA_Get_highest_ready,
+    _Scheduler_strong_APA_Insert_ready,
     _Scheduler_strong_APA_Move_from_ready_to_scheduled,
-    _Scheduler_SMP_Allocate_processor_exact
-static bool _Scheduler_strong_APA_Enqueue(
+static inline bool _Scheduler_strong_APA_Do_ask_for_help(
+  Thread_Control    *the_thread,
-  return _Scheduler_SMP_Enqueue(
+  return _Scheduler_SMP_Ask_for_help(
     context,
+    the_thread,
     node,
-    insert_priority,
-    _Scheduler_SMP_Get_lowest_scheduled,
+    _Scheduler_strong_APA_Get_lowest_scheduled,
-static bool _Scheduler_strong_APA_Enqueue_scheduled(
+static inline void _Scheduler_strong_APA_Register_idle(
+  Scheduler_Node    *idle_base,
-  return _Scheduler_SMP_Enqueue_scheduled(
+  (void) context;
+  (void) idle_base;
+  (void) cpu;
+   * We do not maintain a variable to access the scheduled
+   * node for a CPU. So this function does nothing.
+static inline  void  _Scheduler_strong_APA_Do_set_affinity(
+  void              *arg
+  node->Affinity = *(( const Processor_mask *) arg);
+void _Scheduler_strong_APA_Initialize( const Scheduler_Control *scheduler )
+  Scheduler_strong_APA_Context *self =
+      _Scheduler_strong_APA_Get_context( scheduler );
+  _Scheduler_SMP_Initialize( &self->Base );
+  _Chain_Initialize_empty( &self->Ready );
+void _Scheduler_strong_APA_Yield(
+  Scheduler_Context *context = _Scheduler_Get_context( scheduler );
+  _Scheduler_SMP_Yield(
     context,
+    thread,
     node,
-    insert_priority,
-    _Scheduler_SMP_Priority_less_equal,
-    _Scheduler_strong_APA_Get_highest_ready,
-    _Scheduler_strong_APA_Insert_ready,
-    _Scheduler_SMP_Insert_scheduled,
-    _Scheduler_strong_APA_Move_from_ready_to_scheduled,
+    _Scheduler_strong_APA_Enqueue,
+    _Scheduler_strong_APA_Enqueue_scheduled
-void _Scheduler_strong_APA_Unblock(
+void _Scheduler_strong_APA_Block(
-  _Scheduler_SMP_Unblock(
+  //The extract from ready automatically removes the node from Ready chain.
+  _Scheduler_SMP_Block(
     context,
-    the_thread,
+    thread,
     node,
-    _Scheduler_strong_APA_Do_update,
-    _Scheduler_strong_APA_Enqueue
+    _Scheduler_strong_APA_Extract_from_scheduled,
+    _Scheduler_strong_APA_Extract_from_ready,
+    _Scheduler_strong_APA_Get_highest_ready,
+    _Scheduler_strong_APA_Move_from_ready_to_scheduled,
-static bool _Scheduler_strong_APA_Do_ask_for_help(
-  Scheduler_Context *context,
+void _Scheduler_strong_APA_Unblock(
-  return _Scheduler_SMP_Ask_for_help(
+  _Scheduler_SMP_Unblock(
     context,
-    the_thread,
+    thread,
     node,
-    _Scheduler_strong_APA_Move_from_scheduled_to_ready,
-    _Scheduler_SMP_Allocate_processor_lazy
+    _Scheduler_strong_APA_Do_update,
 void _Scheduler_strong_APA_Update_priority(
@@ -327,7 +793,7 @@ void _Scheduler_strong_APA_Update_priority(
   _Scheduler_SMP_Update_priority(
     context,
-    the_thread,
+    thread,
     node,
@@ -345,7 +811,11 @@ bool _Scheduler_strong_APA_Ask_for_help(
-  return _Scheduler_strong_APA_Do_ask_for_help( context, the_thread, node );
+  return _Scheduler_strong_APA_Do_ask_for_help(
+    context,
+    the_thread,
+    node
 void _Scheduler_strong_APA_Reconsider_help_request(
@@ -381,7 +851,7 @@ void _Scheduler_strong_APA_Withdraw_node(
@@ -416,20 +886,65 @@ Thread_Control *_Scheduler_strong_APA_Remove_processor(
-void _Scheduler_strong_APA_Yield(
+void _Scheduler_strong_APA_Node_initialize(
+  Priority_Control         priority
-  _Scheduler_SMP_Yield(
-    context,
-    the_thread,
-    node,
-    _Scheduler_strong_APA_Extract_from_ready,
-    _Scheduler_strong_APA_Enqueue,
-    _Scheduler_strong_APA_Enqueue_scheduled
+  _Scheduler_SMP_Node_initialize( scheduler, smp_node, the_thread, priority );
+  _Processor_mask_Assign(
+    &strong_node->Affinity,
+   _SMP_Get_online_processors()
+  Scheduler_Context         *context;
+  Processor_mask             local_affinity;
+  context = _Scheduler_Get_context( scheduler );
+  _Processor_mask_And( &local_affinity, &context->Processors, affinity );
+  if ( _Processor_mask_Is_zero( &local_affinity ) ) {
+    return false;
+  if ( _Processor_mask_Is_equal( &node->Affinity, affinity ) )
+    return true;	//Nothing to do. Return true.
+ _Processor_mask_Assign( &node->Affinity, &local_affinity );
+ _Scheduler_SMP_Set_affinity(
+   context,
+   thread,
+   node_base,
+   &local_affinity,
+   _Scheduler_strong_APA_Do_set_affinity,
+  return true;
2.17.1
