[PATCH v2] Adding EPICS7 Package to RSB
Mritunjay Sharma
mritunjaysharma394 at gmail.com
Thu Aug 27 16:23:42 UTC 2020
Thank you for the feedback, Gedare.
Sending in the new patch soon.
Thanks
Mritunjay
On Thu, Aug 27, 2020 at 9:19 PM Gedare Bloom <gedare at rtems.org> wrote:
> Mritunjay,
> On Wed, Aug 26, 2020 at 3:58 PM Mritunjay Sharma
> <mritunjaysharma394 at gmail.com> wrote:
> > Modified as per the suggestions of Dr. Gedare. Please do review
> > Signed-off-by: Mritunjay Sharma <mritunjaysharma394 at gmail.com>
> > .../epics/{epics-7-1.cfg => epics-7.0-1.cfg} | 5 ++--
> > rtems/config/epics/epics-base.bset | 14 +----------
> > .../config/{epics-7-1.cfg => epics-7.0-1.cfg} | 24 ++++++++++++-------
> > 3 files changed, 19 insertions(+), 24 deletions(-)
> > rename rtems/config/epics/{epics-7-1.cfg => epics-7.0-1.cfg} (87%)
> > rename source-builder/config/{epics-7-1.cfg => epics-7.0-1.cfg} (64%)
> > diff --git a/rtems/config/epics/epics-7-1.cfg
> b/rtems/config/epics/epics-7.0-1.cfg
> > similarity index 87%
> > rename from rtems/config/epics/epics-7-1.cfg
> > rename to rtems/config/epics/epics-7.0-1.cfg
> > index 30ed9cb..34270ee 100644
> > --- a/rtems/config/epics/epics-7-1.cfg
> > +++ b/rtems/config/epics/epics-7.0-1.cfg
> > @@ -1,5 +1,5 @@
> > -# EPICS 7
> > +# EPICS 7.0
> > %if %{release} == %{nil}
> > @@ -15,8 +15,7 @@
> > %hash sha512 epics-base-%{epics_version}.tar.gz
> 63edef9d3019e8253b81610286578a1e917cc9df75db3e8f5aaf99210b4fa842be296cf7cbd384726b81b648c4e0d041c4ef266ae81a580940d7613ce8ce48e0
> > # EPICS Build configuration
> > -%include %{_configdir}/epics-7-1.cfg
> > +%include %{_configdir}/epics-7.0-1.cfg
> > diff --git a/rtems/config/epics/epics-base.bset
> b/rtems/config/epics/epics-base.bset
> > index e56fc6a..7ee3815 100644
> > --- a/rtems/config/epics/epics-base.bset
> > +++ b/rtems/config/epics/epics-base.bset
> > @@ -1,26 +1,14 @@
> > # Build set for EPICS
> > %define release 1
> > -# RTEMS Version
> > -%define rtems_version 5
> > -# The RTEMS URL paths.
> > -%include rtems-urls.bset
> > # The RTEMS Package defines
> > %include rtems-package.bset
> > # Build EPICS.
> > -epics/epics-7-1 .
> > \ No newline at end of file
> > +epics/epics-7.0-1
> > diff --git a/source-builder/config/epics-7-1.cfg
> b/source-builder/config/epics-7.0-1.cfg
> > similarity index 64%
> > rename from source-builder/config/epics-7-1.cfg
> > rename to source-builder/config/epics-7.0-1.cfg
> > index 2a52ea5..2a06008 100644
> > --- a/source-builder/config/epics-7-1.cfg
> > +++ b/source-builder/config/epics-7.0-1.cfg
> > @@ -27,7 +27,7 @@ URL: https://epics.mpg.de/
> > %prep
> > build_top=$(pwd)
> > - source_dir_epics="epics-base-%{epics_version}"
> > + # source_dir_epics="epics-base-%{epics_version}"
> you can keep this variable, that wasn't my point.
> > %source setup epics-base -q -n epics-base-%{epics_version}
> I was wondering if you should/could use the variable here?
> > @@ -36,22 +36,30 @@ URL: https://epics.mpg.de/
> > %build
> > build_top=$(pwd)
> > - cd ${source_dir_epics}
> > + cd epics-base-%{epics_version}
> and here. not that the name is likely to change, but it is good
> programming to use a variable to store something that gets used
> repeatedly.
> > %{build_build_flags}
> > - # Using macros to dynamically path to RTEMS_BASE and RTEMS_VERSION
> using --with-rtems-bsp
> > + # Using macros to dynamically path to RTEMS_BASE and RTEMS_VERSION
> using
> > + # --with-rtems-bsp
> > - %{__make} RTEMS_BASE=%{_prefix} RTEMS_VERSION=%{rtems_version}
> CROSS_COMPILER_TARGET_ARCHS=RTEMS-%{with_rtems_bsp}
> > + %{__make} RTEMS_BASE=%{_prefix} \
> > + RTEMS_VERSION=%{rtems_version} \
> > + CROSS_COMPILER_TARGET_ARCHS=RTEMS-%{with_rtems_bsp}
> indent these broken lines, probably two "nesting levels" (maybe 4 spaces?)
> > cd ${build_top}
> > -%install
> > +#%install
> > build_top=$(pwd)
> > - rm -rf $SB_BUILD_ROOT
> > + %{__rmdir} $SB_BUILD_ROOT
> keep source_dir-epics
> > + %{__make} DESTDIR=$SB_BUILD_ROOT \
> > + RTEMS_BASE=%{_prefix} \
> > + CROSS_COMPILER_TARGET_ARCHS=RTEMS-%{with_rtems_bsp} install
> ditto
> > - %{__make} DESTDIR=$SB_BUILD_ROOT RTEMS_BASE=%{_prefix}
> > cd ${build_top}
> after you make these changes and fix the URL, send a new single patch
> with all changes squashed together.
> > 2.25.1
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200827/04741e6e/attachment.html>
