[PATCH 7/7] rtems: Add rtems_task_build()
Gedare Bloom
gedare at rtems.org
Sun Aug 30 15:17:50 UTC 2020
On Sun, Aug 30, 2020 at 8:50 AM Sebastian Huber
> On 22/08/2020 09:49, Chris Johns wrote:
> > On 21/8/20 9:51 pm, Sebastian Huber wrote:
> >> In contrast to rtems_task_create() this function creates a task with a
> >> user-provided task storage area.
> > The name is build but it creates a task? I am wondering about
> > rtems_task_create_static or something along this line?
> A function to do a static initialization is a contradiction from my
> point of view. Static initialization means for me that you statically
> initialize a data structure and then it is ready to use (it may involve
> a static constructor).
> The function builds a task from user-provided (stack, attributes, etc.)
> and system-provided (thread control block) components.
yes, as a technical term we usually take "static" to mean something
done at compile/build time.
> >> Close #3959.
> > Sorry, I had not read the ticket's details.
> There is a similar ticket for message queues:
> https://devel.rtems.org/ticket/4007
> > Chris
> >> cpukit/Makefile.am | 1 +
> >> cpukit/include/rtems/rtems/tasks.h | 65 ++++++
> >> cpukit/include/rtems/rtems/tasksimpl.h | 11 +
> >> cpukit/rtems/src/taskbuild.c | 273 ++++++++++++++++++++++++
> >> cpukit/rtems/src/taskcreate.c | 274 +++++--------------------
> >> testsuites/sptests/sp01/init.c | 22 +-
> >> testsuites/sptests/sp01/sp01.doc | 1 +
> >> testsuites/sptests/sp01/system.h | 2 +-
> >> 8 files changed, 413 insertions(+), 236 deletions(-)
> >> create mode 100644 cpukit/rtems/src/taskbuild.c
> >> diff --git a/cpukit/Makefile.am b/cpukit/Makefile.am
> >> index bc56822cf8..e382478eac 100644
> >> --- a/cpukit/Makefile.am
> >> +++ b/cpukit/Makefile.am
> >> @@ -785,6 +785,7 @@ librtemscpu_a_SOURCES += rtems/src/statustext.c
> >> librtemscpu_a_SOURCES += rtems/src/statustoerrno.c
> >> librtemscpu_a_SOURCES += rtems/src/systemeventreceive.c
> >> librtemscpu_a_SOURCES += rtems/src/systemeventsend.c
> >> +librtemscpu_a_SOURCES += rtems/src/taskbuild.c
> >> librtemscpu_a_SOURCES += rtems/src/taskcreate.c
> >> librtemscpu_a_SOURCES += rtems/src/taskdelete.c
> >> librtemscpu_a_SOURCES += rtems/src/taskexit.c
> >> diff --git a/cpukit/include/rtems/rtems/tasks.h b/cpukit/include/rtems/rtems/tasks.h
> >> index 12c323e60e..dff811686a 100644
> >> --- a/cpukit/include/rtems/rtems/tasks.h
> >> +++ b/cpukit/include/rtems/rtems/tasks.h
> >> @@ -164,6 +164,71 @@ rtems_status_code rtems_task_create(
> >> + * @brief This member defines the optional handler to free the task storage
> >> + * area.
> >> + * It may be NULL.
> >> + void ( *storage_free )( void * );
> > Called under what context? What can this call do? For example call the standard
> > heap allocator.
> This is a good question. What about:
> area.
> It is called when the task building aborts due to a failed task create
> extension or the task is deleted. It is called from task context under
> protection of the object allocator lock. It is allowed to call free() in
> this handler.
> devel mailing list
> devel at rtems.org
