[PATCH v2] tester: Change to a simpler TFTP server
    chrisj at rtems.org
    chrisj at rtems.org
    Mon Aug 31 01:59:34 UTC 2020
- Add a simpler TFTP to allow parallel test hardware
- Remove the imported tftpy server
Closes #4063
 tester/rt/tftp.py                    |  41 +-
 tester/rt/tftpserver.py              | 699 +++++++++++++++++++++++++++
 tester/rt/tftpy/COPYING              |  21 -
 tester/rt/tftpy/README               | 115 -----
 tester/rt/tftpy/TftpClient.py        | 107 ----
 tester/rt/tftpy/TftpContexts.py      | 429 ----------------
 tester/rt/tftpy/TftpPacketFactory.py |  47 --
 tester/rt/tftpy/TftpPacketTypes.py   | 494 -------------------
 tester/rt/tftpy/TftpServer.py        | 271 -----------
 tester/rt/tftpy/TftpShared.py        |  52 --
 tester/rt/tftpy/TftpStates.py        | 611 -----------------------
 tester/rt/tftpy/__init__.py          |  27 --
 tester/rtems-tftp-server             |  45 ++
 13 files changed, 766 insertions(+), 2193 deletions(-)
 create mode 100644 tester/rt/tftpserver.py
 delete mode 100644 tester/rt/tftpy/COPYING
 delete mode 100644 tester/rt/tftpy/README
 delete mode 100644 tester/rt/tftpy/TftpClient.py
 delete mode 100644 tester/rt/tftpy/TftpContexts.py
 delete mode 100644 tester/rt/tftpy/TftpPacketFactory.py
 delete mode 100644 tester/rt/tftpy/TftpPacketTypes.py
 delete mode 100644 tester/rt/tftpy/TftpServer.py
 delete mode 100644 tester/rt/tftpy/TftpShared.py
 delete mode 100644 tester/rt/tftpy/TftpStates.py
 delete mode 100644 tester/rt/tftpy/__init__.py
 create mode 100755 tester/rtems-tftp-server
diff --git a/tester/rt/tftp.py b/tester/rt/tftp.py
index d518036..7af3a62 100644
--- a/tester/rt/tftp.py
+++ b/tester/rt/tftp.py
@@ -43,7 +43,7 @@ import sys
 from rtemstoolkit import error
 from rtemstoolkit import reraise
-import tftpy
+import tftpserver
 class tftp(object):
     '''RTEMS Testing TFTP base.'''
@@ -88,7 +88,8 @@ class tftp(object):
     def _stop(self):
         try:
             if self.server:
-                self.server.stop(now = True)
+                self.server.stop()
+            self.finished = True
         except:
             pass
@@ -101,6 +102,10 @@ class tftp(object):
     def _timeout(self):
         self._stop()
+        while self.running or not self.finished:
+            self._unlock('_timeout')
+            time.sleep(0.1)
+            self._lock('_timeout')
         if self.timeout is not None:
             self.timeout()
@@ -119,22 +124,21 @@ class tftp(object):
         return None
     def _listener(self):
-        tftpy_log = logging.getLogger('tftpy')
-        tftpy_log.setLevel(100)
+        self._lock('_listener')
+        exe = self.exe
+        self.exe = None
+        self._unlock('_listener')
+        self.server = tftpserver.tftp_server(host = 'all',
+                                             port = self.port,
+                                             timeout = 1,
+                                             forced_file = exe,
+                                             sessions = 1)
         try:
-            self.server = tftpy.TftpServer(tftproot = '.',
-                                           dyn_file_func = self._exe_handle)
-        except tftpy.TftpException as te:
-            raise error.general('tftp: %s' % (str(te)))
-        if self.server is not None:
-            try:
-                self.server.listen('0.0.0.0', self.port, 0.5)
-            except IOError as ie:
-                if ie.errno == errno.EACCES:
-                    raise error.general('tftp: permissions error: check tftp server port')
-                raise error.general('tftp: io error: %s' % (str(ie)))
+            self.server.start()
+            self.server.run()
+        except:
+            raise
     def _runner(self):
         self._lock('_runner')
@@ -146,9 +150,7 @@ class tftp(object):
         except:
             caught = sys.exc_info()
-        self._init()
         self.running = False
-        self.finished = True
         self.caught = caught
         self._unlock('_runner')
@@ -187,6 +189,7 @@ class tftp(object):
             self._timeout()
         caught = self.caught
         self.caught = None
+        self._init()
         self._unlock('_open')
         if caught is not None:
             reraise.reraise(*caught)
diff --git a/tester/rt/tftpserver.py b/tester/rt/tftpserver.py
new file mode 100644
index 0000000..012aae4
--- /dev/null
+++ b/tester/rt/tftpserver.py
@@ -0,0 +1,699 @@
+# SPDX-License-Identifier: BSD-2-Clause
+'''The TFTP Server handles a read only TFTP session.'''
+# Copyright (C) 2020 Chris Johns (chrisj at rtems.org)
+# Redistribution and use in source and binary forms, with or without
+# modification, are permitted provided that the following conditions
+# are met:
+# 1. Redistributions of source code must retain the above copyright
+#    notice, this list of conditions and the following disclaimer.
+# 2. Redistributions in binary form must reproduce the above copyright
+#    notice, this list of conditions and the following disclaimer in the
+#    documentation and/or other materials provided with the distribution.
+# THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
+# AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
+# IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
+# ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
+# LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
+# CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
+# SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
+# INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
+# CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
+# ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
+# POSSIBILITY OF SUCH DAMAGE.
+from __future__ import print_function
+import argparse
+import os
+import socket
+import sys
+import time
+import threading
+try:
+    import socketserver
+except ImportError:
+    import SocketServer as socketserver
+from rtemstoolkit import error
+from rtemstoolkit import log
+from rtemstoolkit import version
+class tftp_session(object):
+    '''Handle the TFTP session packets initiated on the TFTP port (69).
+    # pylint: disable=useless-object-inheritance
+    # pylint: disable=too-many-instance-attributes
+    opcodes = ['nul', 'RRQ', 'WRQ', 'DATA', 'ACK', 'ERROR', 'OACK']
+    OP_RRQ = 1
+    OP_WRQ = 2
+    OP_DATA = 3
+    OP_ACK = 4
+    OP_ERROR = 5
+    OP_OACK = 6
+    E_NOT_DEFINED = 0
+    E_FILE_NOT_FOUND = 1
+    E_ACCESS_VIOLATION = 2
+    E_DISK_FULL = 3
+    E_ILLEGAL_TFTP_OP = 4
+    E_UKNOWN_TID = 5
+    E_FILE_ALREADY_EXISTS = 6
+    E_NO_SUCH_USER = 7
+    E_NO_ERROR = 10
+    def __init__(self, host, port, base, forced_file, reader=None):
+        # pylint: disable=too-many-arguments
+        self.host = host
+        self.port = port
+        self.base = base
+        self.forced_file = forced_file
+        if reader is None:
+            self.data_reader = self._file_reader
+        else:
+            self.data_reader = reader
+        self.filein = None
+        self.resends_limit = 5
+        # These are here to shut pylint up
+        self.block = 0
+        self.block_size = 512
+        self.timeout = 0
+        self.resends = 0
+        self.finished = False
+        self.filename = None
+        self._reinit()
+    def _reinit(self):
+        '''Reinitialise all the class variables used by the protocol.'''
+        if self.filein is not None:
+            self.filein.close()
+        self.block = 0
+        self.timeout = 0
+        self.resends = 0
+    def _file_reader(self, command, **kwargs):
+        '''The default file reader if the user does not provide one.
+        The call returns a two element tuple where the first element
+        is an error code, and the second element is data if the error
+        code is 0 else it is an error message.
+        # pylint: disable=too-many-return-statements
+        if command == 'open':
+            if 'filename' not in kwargs:
+                raise error.general('tftp-reader: invalid open: no filename')
+            filename = kwargs['filename']
+            try:
+                self.filein = open(filename, 'rb')
+                filesize = os.stat(filename).st_size
+            except FileNotFoundError:
+                return self.E_FILE_NOT_FOUND, 'file not found (%s)' % (
+                    filename)
+            except PermissionError:
+                return self.E_ACCESS_VIOLATION, 'access violation'
+            except IOError as ioe:
+                return self.E_NOT_DEFINED, str(ioe)
+            return self.E_NO_ERROR, str(filesize)
+        if command == 'read':
+            if self.filein is None:
+                raise error.general('tftp-reader: read when not open')
+            if 'blksize' not in kwargs:
+                raise error.general('tftp-reader: invalid read: no blksize')
+            # pylint: disable=bare-except
+            try:
+                return self.E_NO_ERROR, self.filein.read(kwargs['blksize'])
+            except:
+                return self.E_NOT_DEFINED, 'unknown error'
+        if command == 'close':
+            return self.E_NO_ERROR, "closed"
+        return self.E_NOT_DEFINED, 'invalid reader state'
+    @staticmethod
+    def _pack_bytes(data=None):
+        bdata = bytearray()
+        if data is not None:
+            if not isinstance(data, list):
+                data = [data]
+            for item in data:
+                if isinstance(item, int):
+                    bdata.append(item >> 8)
+                    bdata.append(item & 0xff)
+                elif isinstance(item, str):
+                    bdata.extend(item.encode())
+                    bdata.append(0)
+                else:
+                    bdata.extend(item)
+        return bdata
+    def _response(self, opcode, data):
+        code = self.opcodes.index(opcode)
+        if code == 0 or code >= len(self.opcodes):
+            raise error.general('invalid opcode: ' + opcode)
+        bdata = self._pack_bytes([code, data])
+        #print(''.join(format(x, '02x') for x in bdata))
+        return bytes(bdata)
+    def _error_response(self, code, message):
+        if log.tracing:
+            log.trace('tftp: error: %s:%d: %d: %s' %
+                      (self.host, self.port, code, message))
+        return self._response('ERROR', self._pack_bytes([code, message, 0]))
+    def _data_response(self, block, data):
+        if len(data) < self.block_size:
+        return self._response('DATA', self._pack_bytes([block, data]))
+    def _oack_response(self, data):
+        self.resends += 1
+        if self.resends >= self.resends_limit:
+            return self._error_response(self.E_NOT_DEFINED,
+                                        'resend limit reached')
+        return self._response('OACK', self._pack_bytes(data))
+    def _next_block(self, block):
+        # has the current block been acknowledged?
+        if block == self.block:
+            self.resends = 0
+            self.block += 1
+            err, data = self.data_reader('read', blksize=self.block_size)
+            if err != self.E_NO_ERROR:
+                return self._error_response(err, data)
+            # close if the length of data is less than the block size
+                self.data_reader('close')
+        else:
+            self.resends += 1
+        return self._data_response(self.block, data)
+    def _read_req(self, data):
+        # if the last block is not 0 something has gone wrong and
+        # TID match. Restart the session. It could be the client
+        # is a simple implementation that does not move the send
+        # port on each retry.
+        if self.block != 0:
+            self._reinit()
+        # Get the filename, mode and options
+        self.filename = self.get_option('filename', data)
+        if self.filename is None:
+                                        'filename not found in request')
+        if self.forced_file is not None:
+            self.filename = self.forced_file
+        # open the reader
+        err, message = self.data_reader('open', filename=self.filename)
+            return self._error_response(err, message)
+        # the no error on open message is the file size
+        try:
+            tsize = int(message)
+        except ValueError:
+            tsize = 0
+        mode = self.get_option('mode', data)
+        if mode is None:
+                                        'mode not found in request')
+        oack_data = self._pack_bytes()
+        value = self.get_option('timeout', data)
+        if value is not None:
+            oack_data += self._pack_bytes(['timeout', value])
+            self.timeout = int(value)
+        value = self.get_option('blksize', data)
+            oack_data += self._pack_bytes(['blksize', value])
+            self.block_size = int(value)
+        else:
+        value = self.get_option('tsize', data)
+        if value is not None and tsize > 0:
+            oack_data += self._pack_bytes(['tsize', str(tsize)])
+        # Send the options ack
+        return self._oack_response(oack_data)
+    def _write_req(self):
+        # WRQ is not supported
+        return self._error_response(self.E_ILLEGAL_TFTP_OP,
+                                    "writes not supported")
+    def _op_ack(self, data):
+        # send the next block of data
+        block = (data[2] << 8) | data[3]
+        return self._next_block(block)
+    def process(self, host, port, data):
+        '''Process the incoming client data sending a response. If the session
+        has finished return None.
+        if host != self.host and port != self.port:
+            return self._error_response(self.E_UKNOWN_TID,
+                                        'unkown transfer ID')
+        if self.finished:
+            return None
+        opcode = (data[0] << 8) | data[1]
+        if opcode == self.OP_RRQ:
+            return self._read_req(data)
+        if opcode in [self.OP_WRQ, self.OP_DATA]:
+            return self._write_req()
+        if opcode == self.OP_ACK:
+            return self._op_ack(data)
+                                    "unknown or unsupported opcode")
+    def decode(self, host, port, data):
+        '''Decode the packet for diagnostic purposes.
+        # pylint: disable=too-many-branches
+        out = ''
+        dlen = len(data)
+        if dlen > 2:
+            if 0 < opcode < len(self.opcodes):
+                if opcode in [self.OP_RRQ, self.OP_WRQ]:
+                    out += '  ' + self.opcodes[opcode] + ', '
+                    i = 2
+                    while data[i] != 0:
+                        out += chr(data[i])
+                        i += 1
+                    while i < dlen - 1:
+                        out += ', '
+                        i += 1
+                            i += 1
+                elif opcode == self.OP_DATA:
+                    out += '#' + str(block) + ', '
+                    if dlen > 4:
+                        out += '%02x%02x..%02x%02x' % (data[4], data[5],
+                                                       data[-2], data[-1])
+                    else:
+                        out += '%02x%02x%02x%02x' % (data[4], data[5], data[6],
+                                                     data[6])
+                    out += ',' + str(dlen - 4)
+                elif opcode == self.OP_ACK:
+                    out += '  ' + self.opcodes[opcode] + ' ' + str(block)
+                elif opcode == self.OP_ERROR:
+                    out += 'E ' + self.opcodes[opcode] + ', '
+                    out += str((data[2] << 8) | (data[3]))
+                    out += ': ' + str(data[4:].decode())
+                    i = 2
+                        i += 1
+                elif opcode == self.OP_OACK:
+                    i = 1
+                        out += ', '
+                        i += 1
+                            i += 1
+            else:
+                out += 'E INV(%d)' % (opcode)
+        else:
+            out += 'E INVALID LENGTH'
+        return out[:2] + '[%s:%d] (%d) ' % (host, port, len(data)) + out[2:]
+    @staticmethod
+    def get_option(option, data):
+        '''Get the option from the TFTP packet.'''
+        dlen = len(data) - 1
+        next_option = False
+        if opcode in [1, 2]:
+            count = 0
+            i = 2
+            while i < dlen:
+                value = ''
+                    value += chr(data[i])
+                    i += 1
+                i += 1
+                if option == 'filename' and count == 0:
+                    return value
+                if option == 'mode' and count == 1:
+                    return value
+                if value == option and (count % 1) == 0:
+                    next_option = True
+                elif next_option:
+                    return value
+                count += 1
+        return None
+    def get_timeout(self, default_timeout, timeout_guard):
+        '''Get the timeout. The timeout can be an option.'''
+        if self.timeout == 0:
+            return self.timeout + timeout_guard
+        return default_timeout
+    def get_block_size(self):
+        '''Get the block size. The block size can be an option.'''
+        return self.block_size
+class udp_handler(socketserver.BaseRequestHandler):
+    '''TFTP UDP handler for a TFTP session.'''
+    def _notice(self, text):
+        if self.server.tftp.notices:
+            log.notice(text)
+        else:
+            log.trace(text)
+    def handle_session(self, index):
+        '''Handle the TFTP session data.'''
+        # pylint: disable=too-many-locals
+        # pylint: disable=broad-except
+        client_ip = self.client_address[0]
+        client_port = self.client_address[1]
+        client = '%s:%i' % (client_ip, client_port)
+        self._notice('] tftp: %d: start: %s' % (index, client))
+        try:
+            session = tftp_session(client_ip, client_port,
+                                   self.server.tftp.base,
+                                   self.server.tftp.forced_file,
+                                   self.server.tftp.reader)
+            response = session.process(client_ip, client_port, self.request[0])
+            if response is not None:
+                if log.tracing and self.server.tftp.packet_trace:
+                    log.trace(' > ' + session.decode(client_ip, client_port,
+                                                     self.request[0]))
+                timeout = session.get_timeout(self.server.tftp.timeout, 1)
+                sock = socket.socket(socket.AF_INET, socket.SOCK_DGRAM)
+                sock.bind(('', 0))
+                sock.settimeout(timeout)
+                while response is not None:
+                        log.trace(
+                            session.decode(client_ip, client_port, response))
+                    sock.sendto(response, (client_ip, client_port))
+                    if session.finished:
+                        break
+                    try:
+                        data, address = sock.recvfrom(2 + 2 +
+                                                      session.get_block_size())
+                            log.trace(
+                                session.decode(address[0], address[1], data))
+                    except socket.error as serr:
+                        if log.tracing:
+                            log.trace('] tftp: %d: receive: %s: error: %s' \
+                                      % (index, client, serr))
+                        return
+                    except socket.gaierror as serr:
+                        if log.tracing:
+                        return
+                    response = session.process(address[0], address[1], data)
+        except error.general as gerr:
+            self._notice('] tftp: %dd: error: %s' % (index, gerr))
+        except error.internal as ierr:
+            self._notice('] tftp: %d: error: %s' % (index, ierr))
+        except error.exit:
+            pass
+        except KeyboardInterrupt:
+            pass
+        except Exception as exp:
+            self._notice('] tftp: %d: error: %s: %s' % (index, type(exp), exp))
+        self._notice('] tftp: %d: end: %s' % (index, client))
+    def handle(self):
+        '''The UDP server handle method.'''
+        if self.server.tftp.sessions is None \
+           or self.server.tftp.session < self.server.tftp.sessions:
+            self.handle_session(self.server.tftp.next_session())
+class udp_server(socketserver.ThreadingMixIn, socketserver.UDPServer):
+    '''UDP server. Default behaviour.'''
+class tftp_server(object):
+    '''TFTP server runs a UDP server to handle TFTP sessions.'''
+                 host,
+                 port,
+                 timeout=10,
+                 base=None,
+                 forced_file=None,
+                 sessions=None,
+                 reader=None):
+        self.lock = threading.Lock()
+        self.notices = False
+        self.packet_trace = False
+        self.timeout = timeout
+        self.host = host
+        self.port = port
+        self.server = None
+        self.server_thread = None
+        if base is None:
+            base = os.getcwd()
+        self.base = base
+        if sessions is not None and not isinstance(sessions, int):
+            raise error.general('tftp session count is not a number')
+        self.sessions = sessions
+        self.session = 0
+        self.reader = reader
+    def __del__(self):
+        self.stop()
+    def _lock(self):
+        self.lock.acquire()
+    def _unlock(self):
+        self.lock.release()
+    def start(self):
+        '''Start the TFTP server. Returns once started.'''
+        # pylint: disable=attribute-defined-outside-init
+        if log.tracing:
+            log.trace('] tftp: server: %s:%i' % (self.host, self.port))
+        if self.host == 'all':
+            host = ''
+        else:
+            host = self.host
+        try:
+            self.server = udp_server((host, self.port), udp_handler)
+            raise error.general('tftp server create: %s' % (exp))
+        # We cannot set tftp in __init__ because the object is created
+        # in a separate package.
+        self.server.tftp = self
+        self.server_thread = threading.Thread(target=self.server.serve_forever)
+        self.server_thread.daemon = True
+        self.server_thread.start()
+    def stop(self):
+        '''Stop the TFTP server and close the server port.'''
+        self._lock()
+        try:
+            if self.server is not None:
+                self.server.shutdown()
+                self.server.server_close()
+        finally:
+            self._unlock()
+    def run(self):
+        '''Run the TFTP server for the specified number of sessions.'''
+        running = True
+        while running:
+            period = 1
+            self._lock()
+            if self.server is None:
+                running = False
+                period = 0
+            elif self.sessions is not None:
+                if self.sessions == 0:
+                    running = False
+                    period = 0
+                else:
+                    period = 0.25
+            self._unlock()
+            if period > 0:
+                time.sleep(period)
+        self.stop()
+    def get_session(self):
+        '''Return the session count.'''
+        count = 0
+        self._lock()
+        try:
+            count = self.session
+        finally:
+            self._unlock()
+        return count
+    def next_session(self):
+        '''Return the next session number.'''
+        count = 0
+        self._lock()
+        try:
+            self.session += 1
+        finally:
+            self._unlock()
+        return count
+    def enable_notices(self):
+        '''Call to enable notices. The server is quiet without this call.'''
+        self._lock()
+        self.notices = True
+        self._unlock()
+    def trace_packets(self):
+        '''Call to enable packet tracing as a diagnostic.'''
+        self._lock()
+        self.packet_trace = True
+        self._unlock()
+def load_log(logfile):
+    '''Set the log file.'''
+    if logfile is None:
+        log.default = log.log(streams=['stdout'])
+    else:
+        log.default = log.log(streams=[logfile])
+def run(args=sys.argv, command_path=None):
+    '''Run a TFTP server session.'''
+    # pylint: disable=dangerous-default-value
+    # pylint: disable=unused-argument
+    # pylint: disable=too-many-statements
+    ecode = 0
+    notice = None
+    server = None
+    try:
+        description = 'A TFTP Server that supports a read only TFTP session.'
+        nice_cwd = os.path.relpath(os.getcwd())
+        if len(nice_cwd) > len(os.path.abspath(nice_cwd)):
+            nice_cwd = os.path.abspath(nice_cwd)
+        argsp = argparse.ArgumentParser(prog='rtems-tftp-server',
+                                        description=description)
+        argsp.add_argument('-l',
+                           '--log',
+                           help='log file.',
+                           type=str,
+                           default=None)
+        argsp.add_argument('-v',
+                           '--trace',
+                           help='enable trace logging for debugging.',
+                           action='store_true',
+                           default=False)
+        argsp.add_argument('--trace-packets',
+                           help='enable trace logging of packets.',
+                           default=False)
+            '-B',
+            '--bind',
+            help='address to bind the server too (default: %(default)s).',
+            type=str,
+            default='all')
+            '-P',
+            '--port',
+            help='port to bind the server too (default: %(default)s).',
+            type=int,
+            default='69')
+        argsp.add_argument('-t', '--timeout',
+                           help = 'timeout in seconds, client can override ' \
+                           '(default: %(default)s).',
+                           type = int, default = '10')
+            '-b',
+            '--base',
+            help='base path, not checked (default: %(default)s).',
+            type=str,
+            default=nice_cwd)
+            '-F',
+            '--force-file',
+            help='force the file to be downloaded overriding the client.',
+            type=str,
+            default=None)
+        argsp.add_argument('-s', '--sessions',
+                           help = 'number of TFTP sessions to run before exiting ' \
+                           '(default: forever.',
+                           type = int, default = None)
+        argopts = argsp.parse_args(args[1:])
+        load_log(argopts.log)
+        log.notice('RTEMS Tools - TFTP Server, %s' % (version.string()))
+        log.output(log.info(args))
+        log.tracing = argopts.trace
+        server = tftp_server(argopts.bind, argopts.port, argopts.timeout,
+                             argopts.base, argopts.force_file,
+                             argopts.sessions)
+        server.enable_notices()
+        try:
+            server.start()
+            server.run()
+        finally:
+            server.stop()
+        notice = str(gerr)
+        ecode = 1
+        notice = str(ierr)
+        ecode = 1
+        pass
+        notice = 'abort: user terminated'
+        ecode = 1
+    except SystemExit:
+        pass
+    except:
+        notice = 'abort: unknown error'
+        ecode = 1
+    if server is not None:
+        del server
+    if notice is not None:
+        log.stderr(notice)
+    sys.exit(ecode)
+if __name__ == "__main__":
+    run()
diff --git a/tester/rt/tftpy/COPYING b/tester/rt/tftpy/COPYING
deleted file mode 100644
index c9f2c9c..0000000
--- a/tester/rt/tftpy/COPYING
+++ /dev/null
@@ -1,21 +0,0 @@
-The MIT License
-Copyright (c) 2009 Michael P. Soulier
-Permission is hereby granted, free of charge, to any person obtaining a copy
-of this software and associated documentation files (the "Software"), to deal
-in the Software without restriction, including without limitation the rights
-to use, copy, modify, merge, publish, distribute, sublicense, and/or sell
-copies of the Software, and to permit persons to whom the Software is
-furnished to do so, subject to the following conditions:
-The above copyright notice and this permission notice shall be included in
-all copies or substantial portions of the Software.
-THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
-IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
-FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE
-AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
-LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING FROM,
-OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN
-THE SOFTWARE.
diff --git a/tester/rt/tftpy/README b/tester/rt/tftpy/README
index ad7a871..0000000
--- a/tester/rt/tftpy/README
+++ /dev/null
@@ -1,115 +0,0 @@
-Copyright, Michael P. Soulier, 2010.
-About Release 0.6.2:
-Maintenance release to fix a couple of reported issues.
-About Release 0.6.1:
-Maintenance release to fix several reported problems, including a rollover
-at 2^16 blocks, and some contributed work on dynamic file objects.
-About Release 0.6.0:
-Maintenance update to fix several reported issues, including proper
-retransmits on timeouts, and further expansion of unit tests.
-About Release 0.5.1:
-Maintenance update to fix a bug in the server, overhaul the documentation for
-the website, fix a typo in the unit tests, fix a failure to set default
-blocksize, and a divide by zero error in speed calculations for very short
-transfers.
-Also, this release adds support for input/output in client as stdin/stdout
-About Release 0.5.0:
-Complete rewrite of the state machine.
-Now fully implements downloading and uploading.
-About Release 0.4.6:
-Feature release to add the tsize option.
-Thanks to Kuba Kończyk for the patch.
-About Release 0.4.5:
-Bugfix release for compatability issues on Win32, among other small issues.
-About Release 0.4.4:
-Bugfix release for poor tolerance of unsupported options in the server.
-About Release 0.4.3:
-Bugfix release for an issue with the server's detection of the end of the file
-during a download.
-About Release 0.4.2:
-Bugfix release for some small installation issues with earlier Python
-releases.
-About Release 0.4.1:
-Bugfix release to fix the installation path, with some restructuring into a
-tftpy package from the single module used previously.
-About Release 0.4:
-This release adds a TftpServer class with a sample implementation in bin.
-The server uses a single thread with multiple handlers and a select() loop to
-handle multiple clients simultaneously.
-Only downloads are supported at this time.
-About Release 0.3:
-This release fixes a major RFC 1350 compliance problem with the remote TID.
-About Release 0.2:
-This release adds variable block sizes, and general option support,
-implementing RFCs 2347 and 2348. This is accessible in the TftpClient class
-via the options dict, or in the sample client via the --blocksize option.
-About Release 0.1:
-This is an initial release in the spirit of "release early, release often".
-Currently the sample client works, supporting RFC 1350. The server is not yet
-implemented, and RFC 2347 and 2348 support (variable block sizes) is underway,
-planned for 0.2.
-About Tftpy:
-Purpose:
-Tftpy is a TFTP library for the Python programming language. It includes
-client and server classes, with sample implementations. Hooks are included for
-easy inclusion in a UI for populating progress indicators. It supports RFCs
-1350, 2347, 2348 and the tsize option from RFC 2349.
-Dependencies:
-Python 2.3+, hopefully. Let me know if it fails to work.
-Trifles:
-Home page: http://tftpy.sf.net/
-Project page: http://sourceforge.net/projects/tftpy/
-License is the MIT License
-See COPYING in this distribution.
-Limitations:
-- Only 'octet' mode is supported.
-- The only options supported are blksize and tsize.
-Author:
-Michael P. Soulier <msoulier at digitaltorque.ca>
diff --git a/tester/rt/tftpy/TftpClient.py b/tester/rt/tftpy/TftpClient.py
index eb82c05..0000000
--- a/tester/rt/tftpy/TftpClient.py
+++ /dev/null
@@ -1,107 +0,0 @@
-# vim: ts=4 sw=4 et ai:
-# -*- coding: utf8 -*-
-"""This module implements the TFTP Client functionality. Instantiate an
-instance of the client, and then use its upload or download method. Logging is
-performed via a standard logging object set in TftpShared."""
-import types
-import logging
-from .TftpShared import *
-from .TftpPacketTypes import *
-from .TftpContexts import TftpContextClientDownload, TftpContextClientUpload
-log = logging.getLogger('tftpy.TftpClient')
-class TftpClient(TftpSession):
-    """This class is an implementation of a tftp client. Once instantiated, a
-    download can be initiated via the download() method, or an upload via the
-    upload() method."""
-    def __init__(self, host, port=69, options={}, localip = ""):
-        TftpSession.__init__(self)
-        self.context = None
-        self.host = host
-        self.iport = port
-        self.filename = None
-        self.options = options
-        self.localip = localip
-        if 'blksize' in self.options:
-            size = self.options['blksize']
-            tftpassert(int == type(size), "blksize must be an int")
-            if size < MIN_BLKSIZE or size > MAX_BLKSIZE:
-                raise TftpException("Invalid blksize: %d" % size)
-    def download(self, filename, output, packethook=None, timeout=SOCK_TIMEOUT):
-        """This method initiates a tftp download from the configured remote
-        host, requesting the filename passed. It writes the file to output,
-        which can be a file-like object or a path to a local file. If a
-        packethook is provided, it must be a function that takes a single
-        parameter, which will be a copy of each DAT packet received in the
-        form of a TftpPacketDAT object. The timeout parameter may be used to
-        override the default SOCK_TIMEOUT setting, which is the amount of time
-        that the client will wait for a receive packet to arrive.
-        Note: If output is a hyphen, stdout is used."""
-        # We're downloading.
-        log.debug("Creating download context with the following params:")
-        log.debug("host = %s, port = %s, filename = %s" % (self.host, self.iport, filename))
-        log.debug("options = %s, packethook = %s, timeout = %s" % (self.options, packethook, timeout))
-        self.context = TftpContextClientDownload(self.host,
-                                                 self.iport,
-                                                 filename,
-                                                 output,
-                                                 self.options,
-                                                 packethook,
-                                                 timeout,
-                                                 localip = self.localip)
-        self.context.start()
-        # Download happens here
-        self.context.end()
-        metrics = self.context.metrics
-        log.info('')
-        log.info("Download complete.")
-        if metrics.duration == 0:
-            log.info("Duration too short, rate undetermined")
-        else:
-            log.info("Downloaded %.2f bytes in %.2f seconds" % (metrics.bytes, metrics.duration))
-            log.info("Average rate: %.2f kbps" % metrics.kbps)
-        log.info("%.2f bytes in resent data" % metrics.resent_bytes)
-        log.info("Received %d duplicate packets" % metrics.dupcount)
-    def upload(self, filename, input, packethook=None, timeout=SOCK_TIMEOUT):
-        """This method initiates a tftp upload to the configured remote host,
-        uploading the filename passed. It reads the file from input, which
-        can be a file-like object or a path to a local file. If a packethook
-        is provided, it must be a function that takes a single parameter,
-        which will be a copy of each DAT packet sent in the form of a
-        TftpPacketDAT object. The timeout parameter may be used to override
-        the default SOCK_TIMEOUT setting, which is the amount of time that
-        the client will wait for a DAT packet to be ACKd by the server.
-        Note: If input is a hyphen, stdin is used."""
-        self.context = TftpContextClientUpload(self.host,
-                                               self.iport,
-                                               filename,
-                                               input,
-                                               self.options,
-                                               packethook,
-                                               timeout,
-        # Upload happens here
-        log.info('')
-        log.info("Upload complete.")
-        else:
-            log.info("Uploaded %d bytes in %.2f seconds" % (metrics.bytes, metrics.duration))
-        log.info("Resent %d packets" % metrics.dupcount)
diff --git a/tester/rt/tftpy/TftpContexts.py b/tester/rt/tftpy/TftpContexts.py
index da85886..0000000
--- a/tester/rt/tftpy/TftpContexts.py
+++ /dev/null
@@ -1,429 +0,0 @@
-"""This module implements all contexts for state handling during uploads and
-downloads, the main interface to which being the TftpContext base class.
-The concept is simple. Each context object represents a single upload or
-download, and the state object in the context object represents the current
-state of that transfer. The state object has a handle() method that expects
-the next packet in the transfer, and returns a state object until the transfer
-is complete, at which point it returns None. That is, unless there is a fatal
-error, in which case a TftpException is returned instead."""
-from .TftpPacketFactory import TftpPacketFactory
-from .TftpStates import *
-import socket
-import time
-import sys
-import os
-import logging
-log = logging.getLogger('tftpy.TftpContext')
-# Utility classes
-class TftpMetrics(object):
-    """A class representing metrics of the transfer."""
-    def __init__(self):
-        # Bytes transferred
-        self.bytes = 0
-        # Bytes re-sent
-        self.resent_bytes = 0
-        # Duplicate packets received
-        self.dups = {}
-        self.dupcount = 0
-        # Times
-        self.start_time = 0
-        self.end_time = 0
-        self.duration = 0
-        # Rates
-        self.bps = 0
-        self.kbps = 0
-        # Generic errors
-        self.errors = 0
-    def compute(self):
-        # Compute transfer time
-        self.duration = self.end_time - self.start_time
-        if self.duration == 0:
-            self.duration = 1
-        log.debug("TftpMetrics.compute: duration is %s", self.duration)
-        self.bps = (self.bytes * 8.0) / self.duration
-        self.kbps = self.bps / 1024.0
-        log.debug("TftpMetrics.compute: kbps is %s", self.kbps)
-        for key in self.dups:
-            self.dupcount += self.dups[key]
-    def add_dup(self, pkt):
-        """This method adds a dup for a packet to the metrics."""
-        log.debug("Recording a dup of %s", pkt)
-        s = str(pkt)
-        if s in self.dups:
-            self.dups[s] += 1
-        else:
-            self.dups[s] = 1
-        tftpassert(self.dups[s] < MAX_DUPS, "Max duplicates reached")
-# Context classes
-class TftpContext(object):
-    """The base class of the contexts."""
-    def __init__(self, host, port, timeout, localip = ""):
-        """Constructor for the base context, setting shared instance
-        variables."""
-        self.file_to_transfer = None
-        self.fileobj = None
-        self.options = None
-        self.packethook = None
-        self.sock = socket.socket(socket.AF_INET, socket.SOCK_DGRAM)
-        if localip != "":
-            self.sock.bind((localip, 0))
-        self.sock.settimeout(timeout)
-        self.timeout = timeout
-        self.state = None
-        self.next_block = 0
-        self.factory = TftpPacketFactory()
-        # Note, setting the host will also set self.address, as it's a property.
-        self.host = host
-        self.port = port
-        # The port associated with the TID
-        self.tidport = None
-        # Metrics
-        self.metrics = TftpMetrics()
-        # Fluag when the transfer is pending completion.
-        self.pending_complete = False
-        # Time when this context last received any traffic.
-        # FIXME: does this belong in metrics?
-        self.last_update = 0
-        # The last packet we sent, if applicable, to make resending easy.
-        self.last_pkt = None
-        # Count the number of retry attempts.
-        self.retry_count = 0
-    def getBlocksize(self):
-        """Fetch the current blocksize for this session."""
-        return int(self.options.get('blksize', 512))
-    def __del__(self):
-        """Simple destructor to try to call housekeeping in the end method if
-        not called explicitely. Leaking file descriptors is not a good
-        thing."""
-        self.end()
-    def checkTimeout(self, now):
-        """Compare current time with last_update time, and raise an exception
-        if we're over the timeout time."""
-        log.debug("checking for timeout on session %s", self)
-        if now - self.last_update > self.timeout:
-            raise TftpTimeout("Timeout waiting for traffic")
-    def start(self):
-        raise NotImplementedError("Abstract method")
-    def end(self, close_fileobj=True):
-        """Perform session cleanup, since the end method should always be
-        called explicitely by the calling code, this works better than the
-        destructor.
-        Set close_fileobj to False so fileobj can be returned open."""
-        log.debug("in TftpContext.end - closing socket")
-        self.sock.close()
-        if close_fileobj and self.fileobj is not None and not self.fileobj.closed:
-            log.debug("self.fileobj is open - closing")
-            self.fileobj.close()
-    def gethost(self):
-        "Simple getter method for use in a property."
-        return self.__host
-    def sethost(self, host):
-        """Setter method that also sets the address property as a result
-        of the host that is set."""
-        self.__host = host
-        self.address = socket.gethostbyname(host)
-    host = property(gethost, sethost)
-    def setNextBlock(self, block):
-        if block >= 2 ** 16:
-            log.debug("Block number rollover to 0 again")
-            block = 0
-        self.__eblock = block
-    def getNextBlock(self):
-        return self.__eblock
-    next_block = property(getNextBlock, setNextBlock)
-    def cycle(self):
-        """Here we wait for a response from the server after sending it
-        something, and dispatch appropriate action to that response."""
-        try:
-            (buffer, (raddress, rport)) = self.sock.recvfrom(MAX_BLKSIZE)
-        except socket.timeout:
-            log.warning("Timeout waiting for traffic, retrying...")
-            raise TftpTimeout("Timed-out waiting for traffic")
-        # Ok, we've received a packet. Log it.
-        log.debug("Received %d bytes from %s:%s",
-                        len(buffer), raddress, rport)
-        # And update our last updated time.
-        self.last_update = time.time()
-        # Decode it.
-        recvpkt = self.factory.parse(buffer)
-        # Check for known "connection".
-        if raddress != self.address:
-            log.warning("Received traffic from %s, expected host %s. Discarding"
-                        % (raddress, self.host))
-        if self.tidport and self.tidport != rport:
-            log.warning("Received traffic from %s:%s but we're "
-                        "connected to %s:%s. Discarding."
-                        % (raddress, rport,
-                        self.host, self.tidport))
-        # If there is a packethook defined, call it. We unconditionally
-        # pass all packets, it's up to the client to screen out different
-        # kinds of packets. This way, the client is privy to things like
-        # negotiated options.
-        if self.packethook:
-            self.packethook(recvpkt)
-        # And handle it, possibly changing state.
-        self.state = self.state.handle(recvpkt, raddress, rport)
-        # If we didn't throw any exceptions here, reset the retry_count to
-        # zero.
-class TftpContextServer(TftpContext):
-    """The context for the server."""
-                 host,
-                 port,
-                 timeout,
-                 root,
-                 dyn_file_func=None,
-                 upload_open=None):
-        TftpContext.__init__(self,
-                             host,
-                             port,
-                             timeout,
-        # At this point we have no idea if this is a download or an upload. We
-        # need to let the start state determine that.
-        self.state = TftpStateServerStart(self)
-        self.root = root
-        self.dyn_file_func = dyn_file_func
-        self.upload_open = upload_open
-    def __str__(self):
-        return "%s:%s %s" % (self.host, self.port, self.state)
-    def start(self, buffer):
-        """Start the state cycle. Note that the server context receives an
-        initial packet in its start method. Also note that the server does not
-        loop on cycle(), as it expects the TftpServer object to manage
-        that."""
-        log.debug("In TftpContextServer.start")
-        self.metrics.start_time = time.time()
-        log.debug("Set metrics.start_time to %s", self.metrics.start_time)
-        pkt = self.factory.parse(buffer)
-        log.debug("TftpContextServer.start() - factory returned a %s", pkt)
-        # Call handle once with the initial packet. This should put us into
-        # the download or the upload state.
-        self.state = self.state.handle(pkt,
-                                       self.host,
-                                       self.port)
-    def end(self):
-        """Finish up the context."""
-        TftpContext.end(self)
-        self.metrics.end_time = time.time()
-        log.debug("Set metrics.end_time to %s", self.metrics.end_time)
-        self.metrics.compute()
-class TftpContextClientUpload(TftpContext):
-    """The upload context for the client during an upload.
-    Note: If input is a hyphen, then we will use stdin."""
-                 host,
-                 port,
-                 filename,
-                 input,
-                 options,
-                 packethook,
-                 timeout,
-                 localip = ""):
-                             host,
-                             port,
-                             timeout,
-                             localip)
-        self.file_to_transfer = filename
-        self.packethook = packethook
-        # If the input object has a read() function,
-        # assume it is file-like.
-        if hasattr(input, 'read'):
-            self.fileobj = input
-        elif input == '-':
-            self.fileobj = sys.stdin
-        else:
-            self.fileobj = open(input, "rb")
-        log.debug("TftpContextClientUpload.__init__()")
-        log.debug("file_to_transfer = %s, options = %s" %
-            (self.file_to_transfer, self.options))
-    def start(self):
-        log.info("Sending tftp upload request to %s" % self.host)
-        log.info("    filename -> %s" % self.file_to_transfer)
-        log.info("    options -> %s" % self.options)
-        log.debug("Set metrics.start_time to %s" % self.metrics.start_time)
-        # FIXME: put this in a sendWRQ method?
-        pkt = TftpPacketWRQ()
-        pkt.filename = self.file_to_transfer
-        pkt.mode = "octet" # FIXME - shouldn't hardcode this
-        pkt.options = self.options
-        self.sock.sendto(pkt.encode().buffer, (self.host, self.port))
-        self.next_block = 1
-        self.last_pkt = pkt
-        # FIXME: should we centralize sendto operations so we can refactor all
-        # saving of the packet to the last_pkt field?
-        self.state = TftpStateSentWRQ(self)
-        while self.state:
-            try:
-                log.debug("State is %s" % self.state)
-                self.cycle()
-            except TftpTimeout as err:
-                log.error(str(err))
-                self.retry_count += 1
-                if self.retry_count >= TIMEOUT_RETRIES:
-                    log.debug("hit max retries, giving up")
-                    raise
-                else:
-                    log.warning("resending last packet")
-                    self.state.resendLast()
-    def end(self):
-        log.debug("Set metrics.end_time to %s" % self.metrics.end_time)
-class TftpContextClientDownload(TftpContext):
-    """The download context for the client during a download.
-    Note: If output is a hyphen, then the output will be sent to stdout."""
-                 host,
-                 port,
-                 filename,
-                 output,
-                 options,
-                 packethook,
-                 timeout,
-                 localip = ""):
-                             host,
-                             port,
-                             timeout,
-                             localip)
-        # FIXME: should we refactor setting of these params?
-        self.filelike_fileobj = False
-        # If the output object has a write() function,
-        if hasattr(output, 'write'):
-            self.fileobj = output
-            self.filelike_fileobj = True
-        # If the output filename is -, then use stdout
-        elif output == '-':
-            self.fileobj = sys.stdout
-        else:
-            self.fileobj = open(output, "wb")
-        log.debug("TftpContextClientDownload.__init__()")
-    def start(self):
-        """Initiate the download."""
-        log.info("Sending tftp download request to %s" % self.host)
-        # FIXME: put this in a sendRRQ method?
-        pkt = TftpPacketRRQ()
-        self.state = TftpStateSentRRQ(self)
-        while self.state:
-            try:
-                self.cycle()
-                    raise
-                else:
-            except TftpFileNotFoundError as err:
-                # If we received file not found, then we should not save the open
-                # output file or we'll be left with a size zero file. Delete it,
-                # if it exists.
-                log.error("Received File not found error")
-                if self.fileobj is not None and not self.filelike_fileobj:
-                    if os.path.exists(self.fileobj.name):
-                        log.debug("unlinking output file of %s", self.fileobj.name)
-                        os.unlink(self.fileobj.name)
-                raise
-    def end(self):
-        TftpContext.end(self, not self.filelike_fileobj)
diff --git a/tester/rt/tftpy/TftpPacketFactory.py b/tester/rt/tftpy/TftpPacketFactory.py
index 41f39a9..0000000
--- a/tester/rt/tftpy/TftpPacketFactory.py
+++ /dev/null
@@ -1,47 +0,0 @@
-"""This module implements the TftpPacketFactory class, which can take a binary
-buffer, and return the appropriate TftpPacket object to represent it, via the
-parse() method."""
-import logging
-log = logging.getLogger('tftpy.TftpPacketFactory')
-class TftpPacketFactory(object):
-    """This class generates TftpPacket objects. It is responsible for parsing
-    raw buffers off of the wire and returning objects representing them, via
-    the parse() method."""
-        self.classes = {
-            1: TftpPacketRRQ,
-            2: TftpPacketWRQ,
-            3: TftpPacketDAT,
-            4: TftpPacketACK,
-            5: TftpPacketERR,
-            6: TftpPacketOACK
-    def parse(self, buffer):
-        """This method is used to parse an existing datagram into its
-        corresponding TftpPacket object. The buffer is the raw bytes off of
-        the network."""
-        log.debug("parsing a %d byte packet" % len(buffer))
-        (opcode,) = struct.unpack(str("!H"), buffer[:2])
-        log.debug("opcode is %d" % opcode)
-        packet = self.__create(opcode)
-        packet.buffer = buffer
-        return packet.decode()
-    def __create(self, opcode):
-        """This method returns the appropriate class object corresponding to
-        the passed opcode."""
-        tftpassert(opcode in self.classes,
-                   "Unsupported opcode: %d" % opcode)
-        packet = self.classes[opcode]()
-        return packet
diff --git a/tester/rt/tftpy/TftpPacketTypes.py b/tester/rt/tftpy/TftpPacketTypes.py
index 3d3bdf8..0000000
--- a/tester/rt/tftpy/TftpPacketTypes.py
+++ /dev/null
@@ -1,494 +0,0 @@
-"""This module implements the packet types of TFTP itself, and the
-corresponding encode and decode methods for them."""
-import struct
-import sys
-import logging
-log = logging.getLogger('tftpy.TftpPacketTypes')
-class TftpSession(object):
-    """This class is the base class for the tftp client and server. Any shared
-    code should be in this class."""
-    # FIXME: do we need this anymore?
-    pass
-class TftpPacketWithOptions(object):
-    """This class exists to permit some TftpPacket subclasses to share code
-    regarding options handling. It does not inherit from TftpPacket, as the
-    goal is just to share code here, and not cause diamond inheritance."""
-        self.options = {}
-    # Always use unicode strings, except at the encode/decode barrier.
-    # Simpler to keep things clear.
-    def setoptions(self, options):
-        log.debug("in TftpPacketWithOptions.setoptions")
-        log.debug("options: %s", options)
-        myoptions = {}
-        for key in options:
-            newkey = key
-            if isinstance(key, bytes):
-                newkey = newkey.decode('ascii')
-            newval = options[key]
-            if isinstance(newval, bytes):
-                newval = newval.decode('ascii')
-            myoptions[newkey] = newval
-            log.debug("populated myoptions with %s = %s", newkey, myoptions[newkey])
-        log.debug("setting options hash to: %s", myoptions)
-        self._options = myoptions
-    def getoptions(self):
-        log.debug("in TftpPacketWithOptions.getoptions")
-        return self._options
-    # Set up getter and setter on options to ensure that they are the proper
-    # type. They should always be strings, but we don't need to force the
-    # client to necessarily enter strings if we can avoid it.
-    options = property(getoptions, setoptions)
-    def decode_options(self, buffer):
-        """This method decodes the section of the buffer that contains an
-        unknown number of options. It returns a dictionary of option names and
-        values."""
-        fmt = b"!"
-        options = {}
-        log.debug("decode_options: buffer is: %s", repr(buffer))
-        log.debug("size of buffer is %d bytes", len(buffer))
-        if len(buffer) == 0:
-            log.debug("size of buffer is zero, returning empty hash")
-            return {}
-        # Count the nulls in the buffer. Each one terminates a string.
-        log.debug("about to iterate options buffer counting nulls")
-        length = 0
-        for i in range(len(buffer)):
-            if ord(buffer[i:i+1]) == 0:
-                log.debug("found a null at length %d", length)
-                if length > 0:
-                    fmt += b"%dsx" % length
-                    length = -1
-                else:
-                    raise TftpException("Invalid options in buffer")
-            length += 1
-        log.debug("about to unpack, fmt is: %s", fmt)
-        mystruct = struct.unpack(fmt, buffer)
-        tftpassert(len(mystruct) % 2 == 0,
-                   "packet with odd number of option/value pairs")
-        for i in range(0, len(mystruct), 2):
-            key = mystruct[i].decode('ascii')
-            val = mystruct[i+1].decode('ascii')
-            log.debug("setting option %s to %s", key, val)
-            log.debug("types are %s and %s", type(key), type(val))
-            options[key] = val
-        return options
-class TftpPacket(object):
-    """This class is the parent class of all tftp packet classes. It is an
-    abstract class, providing an interface, and should not be instantiated
-    directly."""
-        self.opcode = 0
-        self.buffer = None
-    def encode(self):
-        """The encode method of a TftpPacket takes keyword arguments specific
-        to the type of packet, and packs an appropriate buffer in network-byte
-        order suitable for sending over the wire.
-        This is an abstract method."""
-    def decode(self):
-        """The decode method of a TftpPacket takes a buffer off of the wire in
-        network-byte order, and decodes it, populating internal properties as
-        appropriate. This can only be done once the first 2-byte opcode has
-        already been decoded, but the data section does include the entire
-        datagram.
-class TftpPacketInitial(TftpPacket, TftpPacketWithOptions):
-    """This class is a common parent class for the RRQ and WRQ packets, as
-    they share quite a bit of code."""
-        TftpPacket.__init__(self)
-        TftpPacketWithOptions.__init__(self)
-        self.mode = None
-    def encode(self):
-        """Encode the packet's buffer from the instance variables."""
-        tftpassert(self.filename, "filename required in initial packet")
-        tftpassert(self.mode, "mode required in initial packet")
-        # Make sure filename and mode are bytestrings.
-        filename = self.filename
-        mode = self.mode
-        if not isinstance(filename, bytes):
-            filename = filename.encode('ascii')
-        if not isinstance(self.mode, bytes):
-            mode = mode.encode('ascii')
-        ptype = None
-        if self.opcode == 1: ptype = "RRQ"
-        else:                ptype = "WRQ"
-        log.debug("Encoding %s packet, filename = %s, mode = %s",
-            ptype, filename, mode)
-        for key in self.options:
-            log.debug("    Option %s = %s", key, self.options[key])
-        fmt = b"!H"
-        fmt += b"%dsx" % len(filename)
-        if mode == b"octet":
-            fmt += b"5sx"
-        else:
-            raise AssertionError("Unsupported mode: %s" % mode)
-        # Add options. Note that the options list must be bytes.
-        options_list = []
-        if len(list(self.options.keys())) > 0:
-            log.debug("there are options to encode")
-                # Populate the option name
-                name = key
-                if not isinstance(name, bytes):
-                    name = name.encode('ascii')
-                options_list.append(name)
-                fmt += b"%dsx" % len(name)
-                # Populate the option value
-                value = self.options[key]
-                # Work with all strings.
-                if isinstance(value, int):
-                    value = str(value)
-                if not isinstance(value, bytes):
-                    value = value.encode('ascii')
-                options_list.append(value)
-                fmt += b"%dsx" % len(value)
-        log.debug("fmt is %s", fmt)
-        log.debug("options_list is %s", options_list)
-        log.debug("size of struct is %d", struct.calcsize(fmt))
-        self.buffer = struct.pack(fmt,
-                                  self.opcode,
-                                  filename,
-                                  mode,
-                                  *options_list)
-        log.debug("buffer is %s", repr(self.buffer))
-        return self
-    def decode(self):
-        tftpassert(self.buffer, "Can't decode, buffer is empty")
-        # FIXME - this shares a lot of code with decode_options
-        nulls = 0
-        fmt = b""
-        nulls = length = tlength = 0
-        log.debug("in decode: about to iterate buffer counting nulls")
-        subbuf = self.buffer[2:]
-        for i in range(len(subbuf)):
-            if ord(subbuf[i:i+1]) == 0:
-                nulls += 1
-                log.debug("found a null at length %d, now have %d", length, nulls)
-                length = -1
-                # At 2 nulls, we want to mark that position for decoding.
-                if nulls == 2:
-                    break
-            length += 1
-            tlength += 1
-        log.debug("hopefully found end of mode at length %d", tlength)
-        # length should now be the end of the mode.
-        tftpassert(nulls == 2, "malformed packet")
-        shortbuf = subbuf[:tlength+1]
-        log.debug("about to unpack buffer with fmt: %s", fmt)
-        log.debug("unpacking buffer: %s", repr(shortbuf))
-        mystruct = struct.unpack(fmt, shortbuf)
-        tftpassert(len(mystruct) == 2, "malformed packet")
-        self.filename = mystruct[0].decode('ascii')
-        self.mode = mystruct[1].decode('ascii').lower() # force lc - bug 17
-        log.debug("set filename to %s", self.filename)
-        log.debug("set mode to %s", self.mode)
-        self.options = self.decode_options(subbuf[tlength+1:])
-        log.debug("options dict is now %s", self.options)
-        return self
-class TftpPacketRRQ(TftpPacketInitial):
-            2 bytes    string   1 byte     string   1 byte
-    RRQ/  | 01/02 |  Filename  |   0  |    Mode    |   0  |
-    WRQ     -----------------------------------------------
-        TftpPacketInitial.__init__(self)
-        self.opcode = 1
-        s = 'RRQ packet: filename = %s' % self.filename
-        s += ' mode = %s' % self.mode
-        if self.options:
-            s += '\n    options = %s' % self.options
-        return s
-class TftpPacketWRQ(TftpPacketInitial):
-        self.opcode = 2
-        s = 'WRQ packet: filename = %s' % self.filename
-        if self.options:
-        return s
-class TftpPacketDAT(TftpPacket):
-            2 bytes    2 bytes       n bytes
-    DATA  | 03    |   Block #  |    Data    |
-        self.opcode = 3
-        self.blocknumber = 0
-        self.data = None
-        s = 'DAT packet: block %s' % self.blocknumber
-        if self.data:
-            s += '\n    data: %d bytes' % len(self.data)
-        return s
-    def encode(self):
-        """Encode the DAT packet. This method populates self.buffer, and
-        returns self for easy method chaining."""
-        if len(self.data) == 0:
-            log.debug("Encoding an empty DAT packet")
-        data = self.data
-        if not isinstance(self.data, bytes):
-            data = self.data.encode('ascii')
-        fmt = b"!HH%ds" % len(data)
-                                  self.opcode,
-                                  self.blocknumber,
-                                  data)
-        return self
-    def decode(self):
-        """Decode self.buffer into instance variables. It returns self for
-        easy method chaining."""
-        # We know the first 2 bytes are the opcode. The second two are the
-        # block number.
-        (self.blocknumber,) = struct.unpack(str("!H"), self.buffer[2:4])
-        log.debug("decoding DAT packet, block number %d", self.blocknumber)
-        log.debug("should be %d bytes in the packet total", len(self.buffer))
-        # Everything else is data.
-        self.data = self.buffer[4:]
-        log.debug("found %d bytes of data", len(self.data))
-        return self
-class TftpPacketACK(TftpPacket):
-            2 bytes    2 bytes
-    ACK   | 04    |   Block #  |
-        self.opcode = 4
-        return 'ACK packet: block %d' % self.blocknumber
-    def encode(self):
-        log.debug("encoding ACK: opcode = %d, block = %d",
-            self.opcode, self.blocknumber)
-        self.buffer = struct.pack(str("!HH"), self.opcode, self.blocknumber)
-        return self
-    def decode(self):
-        if len(self.buffer) > 4:
-            log.debug("detected TFTP ACK but request is too large, will truncate")
-            log.debug("buffer was: %s", repr(self.buffer))
-            self.buffer = self.buffer[0:4]
-        self.opcode, self.blocknumber = struct.unpack(str("!HH"), self.buffer)
-        log.debug("decoded ACK packet: opcode = %d, block = %d",
-        return self
-class TftpPacketERR(TftpPacket):
-            2 bytes  2 bytes        string    1 byte
-    ERROR | 05    |  ErrorCode |   ErrMsg   |   0  |
-    Error Codes
-    Value     Meaning
-    0         Not defined, see error message (if any).
-    1         File not found.
-    2         Access violation.
-    3         Disk full or allocation exceeded.
-    4         Illegal TFTP operation.
-    5         Unknown transfer ID.
-    6         File already exists.
-    7         No such user.
-    8         Failed to negotiate options
-        self.opcode = 5
-        self.errorcode = 0
-        # FIXME: We don't encode the errmsg...
-        self.errmsg = None
-        # FIXME - integrate in TftpErrors references?
-        self.errmsgs = {
-            1: b"File not found",
-            2: b"Access violation",
-            3: b"Disk full or allocation exceeded",
-            4: b"Illegal TFTP operation",
-            5: b"Unknown transfer ID",
-            6: b"File already exists",
-            7: b"No such user",
-            8: b"Failed to negotiate options"
-        s = 'ERR packet: errorcode = %d' % self.errorcode
-        s += '\n    msg = %s' % self.errmsgs.get(self.errorcode, '')
-        return s
-    def encode(self):
-        """Encode the DAT packet based on instance variables, populating
-        self.buffer, returning self."""
-        fmt = b"!HH%dsx" % len(self.errmsgs[self.errorcode])
-        log.debug("encoding ERR packet with fmt %s", fmt)
-                                  self.opcode,
-                                  self.errorcode,
-                                  self.errmsgs[self.errorcode])
-        return self
-    def decode(self):
-        "Decode self.buffer, populating instance variables and return self."
-        buflen = len(self.buffer)
-        tftpassert(buflen >= 4, "malformed ERR packet, too short")
-        log.debug("Decoding ERR packet, length %s bytes", buflen)
-        if buflen == 4:
-            log.debug("Allowing this affront to the RFC of a 4-byte packet")
-            fmt = b"!HH"
-            log.debug("Decoding ERR packet with fmt: %s", fmt)
-            self.opcode, self.errorcode = struct.unpack(fmt,
-                                                        self.buffer)
-        else:
-            log.debug("Good ERR packet > 4 bytes")
-            fmt = b"!HH%dsx" % (len(self.buffer) - 5)
-            self.opcode, self.errorcode, self.errmsg = struct.unpack(fmt,
-        self.buffer)
-        log.error("ERR packet - errorcode: %d, message: %s"
-                     % (self.errorcode, self.errmsg))
-        return self
-class TftpPacketOACK(TftpPacket, TftpPacketWithOptions):
-    |  opc  |  opt1  | 0 | value1 | 0 |  optN  | 0 | valueN | 0 |
-        self.opcode = 6
-        return 'OACK packet:\n    options = %s' % self.options
-    def encode(self):
-        fmt = b"!H" # opcode
-        options_list = []
-        log.debug("in TftpPacketOACK.encode")
-            if not isinstance(key, bytes):
-                key = key.encode('ascii')
-            log.debug("looping on option key %s", key)
-            log.debug("value is %s", value)
-            fmt += b"%dsx" % len(key)
-            options_list.append(key)
-        self.buffer = struct.pack(fmt, self.opcode, *options_list)
-        return self
-    def decode(self):
-        self.options = self.decode_options(self.buffer[2:])
-        return self
-    def match_options(self, options):
-        """This method takes a set of options, and tries to match them with
-        its own. It can accept some changes in those options from the server as
-        part of a negotiation. Changed or unchanged, it will return a dict of
-        the options so that the session can update itself to the negotiated
-        options."""
-        for name in self.options:
-            if name in options:
-                if name == 'blksize':
-                    # We can accept anything between the min and max values.
-                    size = int(self.options[name])
-                    if size >= MIN_BLKSIZE and size <= MAX_BLKSIZE:
-                        log.debug("negotiated blksize of %d bytes", size)
-                        options['blksize'] = size
-                    else:
-                        raise TftpException("blksize %s option outside allowed range" % size)
-                elif name == 'tsize':
-                    if size < 0:
-                        raise TftpException("Negative file sizes not supported")
-                else:
-                    raise TftpException("Unsupported option: %s" % name)
-        return True
diff --git a/tester/rt/tftpy/TftpServer.py b/tester/rt/tftpy/TftpServer.py
index 2789322..0000000
--- a/tester/rt/tftpy/TftpServer.py
+++ /dev/null
@@ -1,271 +0,0 @@
-"""This module implements the TFTP Server functionality. Instantiate an
-instance of the server, and then run the listen() method to listen for client
-requests. Logging is performed via a standard logging object set in
-TftpShared."""
-import socket, os, time
-import select
-import threading
-import logging
-from errno import EINTR
-from .TftpContexts import TftpContextServer
-log = logging.getLogger('tftpy.TftpServer')
-class TftpServer(TftpSession):
-    """This class implements a tftp server object. Run the listen() method to
-    listen for client requests.
-    tftproot is the path to the tftproot directory to serve files from and/or
-    write them to.
-    dyn_file_func is a callable that takes a requested download
-    path that is not present on the file system and must return either a
-    file-like object to read from or None if the path should appear as not
-    found. This permits the serving of dynamic content.
-    upload_open is a callable that is triggered on every upload with the
-    requested destination path and server context. It must either return a
-    file-like object ready for writing or None if the path is invalid."""
-                 tftproot='/tftpboot',
-        self.listenip = None
-        self.listenport = None
-        self.sock = None
-        # FIXME: What about multiple roots?
-        self.root = os.path.abspath(tftproot)
-        # A dict of sessions, where each session is keyed by a string like
-        # ip:tid for the remote end.
-        self.sessions = {}
-        # A threading event to help threads synchronize with the server
-        # is_running state.
-        self.is_running = threading.Event()
-        self.shutdown_gracefully = False
-        self.shutdown_immediately = False
-        for name in 'dyn_file_func', 'upload_open':
-            attr = getattr(self, name)
-            if attr and not callable(attr):
-                raise TftpException("{} supplied, but it is not callable.".format(name))
-        if os.path.exists(self.root):
-            log.debug("tftproot %s does exist", self.root)
-            if not os.path.isdir(self.root):
-                raise TftpException("The tftproot must be a directory.")
-            else:
-                log.debug("tftproot %s is a directory" % self.root)
-                if os.access(self.root, os.R_OK):
-                    log.debug("tftproot %s is readable" % self.root)
-                else:
-                    raise TftpException("The tftproot must be readable")
-                if os.access(self.root, os.W_OK):
-                    log.debug("tftproot %s is writable" % self.root)
-                else:
-                    log.warning("The tftproot %s is not writable" % self.root)
-        else:
-            raise TftpException("The tftproot does not exist.")
-        if self.sock is not None:
-            try:
-                self.sock.close()
-            except:
-                pass
-    def listen(self, listenip="", listenport=DEF_TFTP_PORT,
-               timeout=SOCK_TIMEOUT):
-        """Start a server listening on the supplied interface and port. This
-        defaults to INADDR_ANY (all interfaces) and UDP port 69. You can also
-        supply a different socket timeout value, if desired."""
-        tftp_factory = TftpPacketFactory()
-        # Don't use new 2.5 ternary operator yet
-        # listenip = listenip if listenip else '0.0.0.0'
-        if not listenip: listenip = '0.0.0.0'
-        log.info("Server requested on ip %s, port %s" % (listenip, listenport))
-        try:
-            # FIXME - sockets should be non-blocking
-            self.sock.setsockopt(socket.SOL_SOCKET, socket.SO_REUSEADDR, 1)
-            self.sock.bind((listenip, listenport))
-            _, self.listenport = self.sock.getsockname()
-        except socket.error as err:
-            # Reraise it for now.
-            raise err
-        self.is_running.set()
-        log.info("Starting receive loop...")
-        while True:
-            log.debug("shutdown_immediately is %s" % self.shutdown_immediately)
-            log.debug("shutdown_gracefully is %s" % self.shutdown_gracefully)
-            if self.shutdown_immediately:
-                log.warning("Shutting down now. Session count: %d" %
-                         len(self.sessions))
-                self.sock.close()
-                for key in self.sessions:
-                    self.sessions[key].end()
-                self.sessions = []
-                break
-            elif self.shutdown_gracefully:
-                if not self.sessions:
-                    log.warning("In graceful shutdown mode and all "
-                             "sessions complete.")
-                    self.sock.close()
-                    break
-            # Build the inputlist array of sockets to select() on.
-            inputlist = []
-            inputlist.append(self.sock)
-                inputlist.append(self.sessions[key].sock)
-            # Block until some socket has input on it.
-            log.debug("Performing select on this inputlist: %s", inputlist)
-            try:
-                readyinput, readyoutput, readyspecial = \
-                        select.select(inputlist, [], [], SOCK_TIMEOUT)
-            except select.error as err:
-                if err[0] == EINTR:
-                    # Interrupted system call
-                    log.debug("Interrupted syscall, retrying")
-                    continue
-                else:
-                    raise
-            deletion_list = []
-            # Handle the available data, if any. Maybe we timed-out.
-            for readysock in readyinput:
-                # Is the traffic on the main server socket? ie. new session?
-                if readysock == self.sock:
-                    log.debug("Data ready on our main socket")
-                    buffer, (raddress, rport) = self.sock.recvfrom(MAX_BLKSIZE)
-                    log.debug("Read %d bytes", len(buffer))
-                    if self.shutdown_gracefully:
-                        log.warning("Discarding data on main port, "
-                                 "in graceful shutdown mode")
-                        continue
-                    # Forge a session key based on the client's IP and port,
-                    # which should safely work through NAT.
-                    key = "%s:%s" % (raddress, rport)
-                    if not key in self.sessions:
-                        log.debug("Creating new server context for "
-                                     "session key = %s" % key)
-                        try:
-                            self.sessions[key] = TftpContextServer(raddress,
-        rport,
-        timeout,
-        self.root,
-        self.dyn_file_func,
-        self.upload_open)
-                            self.sessions[key].start(buffer)
-                        except TftpException as err:
-                            deletion_list.append(key)
-                            log.error("Fatal exception thrown from "
-                                      "session %s: %s" % (key, str(err)))
-                        except KeyboardInterrupt:
-                            pass
-                        except:
-                    else:
-                        log.warning("received traffic on main socket for "
-                                 "existing session??")
-                    log.info("Currently handling these sessions:")
-                    for session_key, session in list(self.sessions.items()):
-                        log.info("    %s" % session)
-                else:
-                    # Must find the owner of this traffic.
-                        if readysock == self.sessions[key].sock:
-                            log.debug("Matched input to session key %s"
-                                % key)
-                            try:
-                                self.sessions[key].cycle()
-                                if self.sessions[key].state == None:
-                                    log.info("Successful transfer.")
-                                          "session %s: %s"
-                                          % (key, str(err)))
-                            # Break out of for loop since we found the correct
-                            # session.
-                            break
-                    else:
-                        log.error("Can't find the owner for this packet. "
-                                  "Discarding.")
-            log.debug("Looping on all sessions to check for timeouts")
-            now = time.time()
-                try:
-                    self.sessions[key].checkTimeout(now)
-                    self.sessions[key].retry_count += 1
-                    if self.sessions[key].retry_count >= TIMEOUT_RETRIES:
-                        log.debug("hit max retries on %s, giving up" %
-                            self.sessions[key])
-                    else:
-                        log.debug("resending on session %s" % self.sessions[key])
-                        self.sessions[key].state.resendLast()
-            log.debug("Iterating deletion list.")
-            for key in deletion_list:
-                log.info('')
-                log.info("Session %s complete" % key)
-                if key in self.sessions:
-                    log.debug("Gathering up metrics from session before deleting")
-                    metrics = self.sessions[key].metrics
-                    else:
-                        log.info("Transferred %d bytes in %.2f seconds"
-                            % (metrics.bytes, metrics.duration))
-                    log.info("%d duplicate packets" % metrics.dupcount)
-                    log.debug("Deleting session %s" % key)
-                    del self.sessions[key]
-                    log.debug("Session list is now %s" % self.sessions)
-                else:
-                    log.warning(
-                        "Strange, session %s is not on the deletion list" % key)
-        self.is_running.clear()
-        log.debug("server returning from while loop")
-        self.shutdown_gracefully = self.shutdown_immediately = False
-    def stop(self, now=False):
-        """Stop the server gracefully. Do not take any new transfers,
-        but complete the existing ones. If force is True, drop everything
-        and stop. Note, immediately will not interrupt the select loop, it
-        will happen when the server returns on ready data, or a timeout.
-        ie. SOCK_TIMEOUT"""
-        if now:
-            self.shutdown_immediately = True
-        else:
-            self.shutdown_gracefully = True
diff --git a/tester/rt/tftpy/TftpShared.py b/tester/rt/tftpy/TftpShared.py
index 88530c3..0000000
--- a/tester/rt/tftpy/TftpShared.py
+++ /dev/null
@@ -1,52 +0,0 @@
-"""This module holds all objects shared by all other modules in tftpy."""
-MIN_BLKSIZE = 8
-DEF_BLKSIZE = 512
-MAX_BLKSIZE = 65536
-SOCK_TIMEOUT = 5
-MAX_DUPS = 20
-TIMEOUT_RETRIES = 5
-DEF_TFTP_PORT = 69
-# A hook for deliberately introducing delay in testing.
-DELAY_BLOCK = 0
-def tftpassert(condition, msg):
-    """This function is a simple utility that will check the condition
-    passed for a false state. If it finds one, it throws a TftpException
-    with the message passed. This just makes the code throughout cleaner
-    by refactoring."""
-    if not condition:
-        raise TftpException(msg)
-class TftpErrors(object):
-    """This class is a convenience for defining the common tftp error codes,
-    and making them more readable in the code."""
-    NotDefined = 0
-    FileNotFound = 1
-    AccessViolation = 2
-    DiskFull = 3
-    IllegalTftpOp = 4
-    UnknownTID = 5
-    FileAlreadyExists = 6
-    NoSuchUser = 7
-    FailedNegotiation = 8
-class TftpException(Exception):
-    """This class is the parent class of all exceptions regarding the handling
-    of the TFTP protocol."""
-    pass
-class TftpTimeout(TftpException):
-    """This class represents a timeout error waiting for a response from the
-    other end."""
-    pass
-class TftpFileNotFoundError(TftpException):
-    """This class represents an error condition where we received a file
-    not found error."""
-    pass
diff --git a/tester/rt/tftpy/TftpStates.py b/tester/rt/tftpy/TftpStates.py
index 42bac1d..0000000
--- a/tester/rt/tftpy/TftpStates.py
+++ /dev/null
@@ -1,611 +0,0 @@
-"""This module implements all state handling during uploads and downloads, the
-main interface to which being the TftpState base class.
-import os
-import logging
-log = logging.getLogger('tftpy.TftpStates')
-# State classes
-class TftpState(object):
-    """The base class for the states."""
-    def __init__(self, context):
-        """Constructor for setting up common instance variables. The involved
-        file object is required, since in tftp there's always a file
-        involved."""
-        self.context = context
-    def handle(self, pkt, raddress, rport):
-        """An abstract method for handling a packet. It is expected to return
-        a TftpState object, either itself or a new state."""
-    def handleOACK(self, pkt):
-        """This method handles an OACK from the server, syncing any accepted
-        options."""
-        if len(pkt.options.keys()) > 0:
-            if pkt.match_options(self.context.options):
-                log.info("Successful negotiation of options")
-                # Set options to OACK options
-                self.context.options = pkt.options
-                for key in self.context.options:
-                    log.info("    %s = %s" % (key, self.context.options[key]))
-            else:
-                log.error("Failed to negotiate options")
-                raise TftpException("Failed to negotiate options")
-        else:
-            raise TftpException("No options found in OACK")
-    def returnSupportedOptions(self, options):
-        """This method takes a requested options list from a client, and
-        returns the ones that are supported."""
-        # We support the options blksize and tsize right now.
-        # FIXME - put this somewhere else?
-        accepted_options = {}
-        for option in options:
-            if option == 'blksize':
-                # Make sure it's valid.
-                if int(options[option]) > MAX_BLKSIZE:
-                    log.info("Client requested blksize greater than %d "
-                             "setting to maximum" % MAX_BLKSIZE)
-                    accepted_options[option] = MAX_BLKSIZE
-                elif int(options[option]) < MIN_BLKSIZE:
-                    log.info("Client requested blksize less than %d "
-                             "setting to minimum" % MIN_BLKSIZE)
-                    accepted_options[option] = MIN_BLKSIZE
-                else:
-                    accepted_options[option] = options[option]
-            elif option == 'tsize':
-                log.debug("tsize option is set")
-                accepted_options['tsize'] = 0
-            else:
-                log.info("Dropping unsupported option '%s'" % option)
-        log.debug("Returning these accepted options: %s", accepted_options)
-        return accepted_options
-    def sendDAT(self):
-        """This method sends the next DAT packet based on the data in the
-        context. It returns a boolean indicating whether the transfer is
-        finished."""
-        finished = False
-        blocknumber = self.context.next_block
-        # Test hook
-        if DELAY_BLOCK and DELAY_BLOCK == blocknumber:
-            import time
-            log.debug("Deliberately delaying 10 seconds...")
-            time.sleep(10)
-        dat = None
-        blksize = self.context.getBlocksize()
-        buffer = self.context.fileobj.read(blksize)
-        log.debug("Read %d bytes into buffer", len(buffer))
-        if len(buffer) < blksize:
-            log.info("Reached EOF on file %s"
-                % self.context.file_to_transfer)
-            finished = True
-        dat = TftpPacketDAT()
-        dat.data = buffer
-        dat.blocknumber = blocknumber
-        self.context.metrics.bytes += len(dat.data)
-        log.debug("Sending DAT packet %d", dat.blocknumber)
-        self.context.sock.sendto(dat.encode().buffer,
-                                 (self.context.host, self.context.tidport))
-        if self.context.packethook:
-            self.context.packethook(dat)
-        self.context.last_pkt = dat
-        return finished
-    def sendACK(self, blocknumber=None):
-        """This method sends an ack packet to the block number specified. If
-        none is specified, it defaults to the next_block property in the
-        parent context."""
-        log.debug("In sendACK, passed blocknumber is %s", blocknumber)
-        if blocknumber is None:
-        log.info("Sending ack to block %d" % blocknumber)
-        ackpkt = TftpPacketACK()
-        ackpkt.blocknumber = blocknumber
-        self.context.sock.sendto(ackpkt.encode().buffer,
-                                  self.context.tidport))
-        self.context.last_pkt = ackpkt
-    def sendError(self, errorcode):
-        """This method uses the socket passed, and uses the errorcode to
-        compose and send an error packet."""
-        log.debug("In sendError, being asked to send error %d", errorcode)
-        errpkt = TftpPacketERR()
-        errpkt.errorcode = errorcode
-        if self.context.tidport == None:
-            log.debug("Error packet received outside session. Discarding")
-        else:
-            self.context.sock.sendto(errpkt.encode().buffer,
-        self.context.last_pkt = errpkt
-    def sendOACK(self):
-        """This method sends an OACK packet with the options from the current
-        context."""
-        log.debug("In sendOACK with options %s", self.context.options)
-        pkt = TftpPacketOACK()
-        pkt.options = self.context.options
-        self.context.sock.sendto(pkt.encode().buffer,
-        self.context.last_pkt = pkt
-    def resendLast(self):
-        "Resend the last sent packet due to a timeout."
-        log.warning("Resending packet %s on sessions %s"
-            % (self.context.last_pkt, self))
-        self.context.metrics.resent_bytes += len(self.context.last_pkt.buffer)
-        self.context.metrics.add_dup(self.context.last_pkt)
-        sendto_port = self.context.tidport
-        if not sendto_port:
-            # If the tidport wasn't set, then the remote end hasn't even
-            # started talking to us yet. That's not good. Maybe it's not
-            # there.
-            sendto_port = self.context.port
-        self.context.sock.sendto(self.context.last_pkt.encode().buffer,
-                                 (self.context.host, sendto_port))
-            self.context.packethook(self.context.last_pkt)
-    def handleDat(self, pkt):
-        """This method handles a DAT packet during a client download, or a
-        server upload."""
-        log.info("Handling DAT packet - block %d" % pkt.blocknumber)
-        log.debug("Expecting block %s", self.context.next_block)
-        if pkt.blocknumber == self.context.next_block:
-            log.debug("Good, received block %d in sequence", pkt.blocknumber)
-            self.sendACK()
-            self.context.next_block += 1
-            log.debug("Writing %d bytes to output file", len(pkt.data))
-            self.context.fileobj.write(pkt.data)
-            self.context.metrics.bytes += len(pkt.data)
-            # Check for end-of-file, any less than full data packet.
-            if len(pkt.data) < self.context.getBlocksize():
-                log.info("End of file detected")
-                return None
-        elif pkt.blocknumber < self.context.next_block:
-            if pkt.blocknumber == 0:
-                log.warning("There is no block zero!")
-                self.sendError(TftpErrors.IllegalTftpOp)
-                raise TftpException("There is no block zero!")
-            log.warning("Dropping duplicate block %d" % pkt.blocknumber)
-            self.context.metrics.add_dup(pkt)
-            log.debug("ACKing block %d again, just in case", pkt.blocknumber)
-            self.sendACK(pkt.blocknumber)
-        else:
-            # FIXME: should we be more tolerant and just discard instead?
-            msg = "Whoa! Received future block %d but expected %d" \
-                % (pkt.blocknumber, self.context.next_block)
-            log.error(msg)
-        # Default is to ack
-        return TftpStateExpectDAT(self.context)
-class TftpServerState(TftpState):
-    """The base class for server states."""
-        TftpState.__init__(self, context)
-        # This variable is used to store the absolute path to the file being
-        # managed.
-        self.full_path = None
-    def serverInitial(self, pkt, raddress, rport):
-        """This method performs initial setup for a server context transfer,
-        put here to refactor code out of the TftpStateServerRecvRRQ and
-        TftpStateServerRecvWRQ classes, since their initial setup is
-        identical. The method returns a boolean, sendoack, to indicate whether
-        it is required to send an OACK to the client."""
-        options = pkt.options
-        sendoack = False
-        if not self.context.tidport:
-            self.context.tidport = rport
-            log.info("Setting tidport to %s" % rport)
-        log.debug("Setting default options, blksize")
-        self.context.options = { 'blksize': DEF_BLKSIZE }
-        if options:
-            log.debug("Options requested: %s", options)
-            supported_options = self.returnSupportedOptions(options)
-            self.context.options.update(supported_options)
-            sendoack = True
-        # FIXME - only octet mode is supported at this time.
-        if pkt.mode != 'octet':
-            #self.sendError(TftpErrors.IllegalTftpOp)
-            #raise TftpException("Only octet transfers are supported at this time.")
-            log.warning("Received non-octet mode request. I'll reply with binary data.")
-        # test host/port of client end
-        if self.context.host != raddress or self.context.port != rport:
-            self.sendError(TftpErrors.UnknownTID)
-            log.error("Expected traffic from %s:%s but received it "
-                            "from %s:%s instead."
-                            % (self.context.host,
-                               self.context.port,
-                               raddress,
-                               rport))
-            # FIXME: increment an error count?
-            # Return same state, we're still waiting for valid traffic.
-            return self
-        log.debug("Requested filename is %s", pkt.filename)
-        # Build the filename on this server and ensure it is contained
-        # in the specified root directory.
-        # Filenames that begin with server root are accepted. It's
-        # assumed the client and server are tightly connected and this
-        # provides backwards compatibility.
-        # Filenames otherwise are relative to the server root. If they
-        # begin with a '/' strip it off as otherwise os.path.join will
-        # treat it as absolute (regardless of whether it is ntpath or
-        # posixpath module
-        if pkt.filename.startswith(self.context.root):
-            full_path = pkt.filename
-        else:
-            full_path = os.path.join(self.context.root, pkt.filename.lstrip('/'))
-        # Use abspath to eliminate any remaining relative elements
-        # (e.g. '..') and ensure that is still within the server's
-        # root directory
-        self.full_path = os.path.abspath(full_path)
-        log.debug("full_path is %s", full_path)
-        if self.full_path.startswith(self.context.root):
-            log.info("requested file is in the server root - good")
-        else:
-            log.warning("requested file is not within the server root - bad")
-            raise TftpException("bad file path")
-        self.context.file_to_transfer = pkt.filename
-        return sendoack
-class TftpStateServerRecvRRQ(TftpServerState):
-    """This class represents the state of the TFTP server when it has just
-    received an RRQ packet."""
-        "Handle an initial RRQ packet as a server."
-        log.debug("In TftpStateServerRecvRRQ.handle")
-        sendoack = self.serverInitial(pkt, raddress, rport)
-        path = self.full_path
-        log.info("Opening file %s for reading" % path)
-        if os.path.exists(path):
-            # Note: Open in binary mode for win32 portability, since win32
-            # blows.
-            self.context.fileobj = open(path, "rb")
-        elif self.context.dyn_file_func:
-            log.debug("No such file %s but using dyn_file_func", path)
-            self.context.fileobj = \
-                self.context.dyn_file_func(self.context.file_to_transfer, raddress=raddress, rport=rport)
-            if self.context.fileobj is None:
-                log.debug("dyn_file_func returned 'None', treating as "
-                          "FileNotFound")
-                self.sendError(TftpErrors.FileNotFound)
-                raise TftpException("File not found: %s" % path)
-        else:
-            log.warn("File not found: %s", path)
-            raise TftpException("File not found: {}".format(path))
-        # Options negotiation.
-        if sendoack and 'tsize' in self.context.options:
-            # getting the file size for the tsize option. As we handle
-            # file-like objects and not only real files, we use this seeking
-            # method instead of asking the OS
-            self.context.fileobj.seek(0, os.SEEK_END)
-            tsize = str(self.context.fileobj.tell())
-            self.context.fileobj.seek(0, 0)
-            self.context.options['tsize'] = tsize
-        if sendoack:
-            # Note, next_block is 0 here since that's the proper
-            # acknowledgement to an OACK.
-            # FIXME: perhaps we do need a TftpStateExpectOACK class...
-            self.sendOACK()
-            # Note, self.context.next_block is already 0.
-        else:
-            self.context.next_block = 1
-            log.debug("No requested options, starting send...")
-            self.context.pending_complete = self.sendDAT()
-        # Note, we expect an ack regardless of whether we sent a DAT or an
-        # OACK.
-        return TftpStateExpectACK(self.context)
-        # Note, we don't have to check any other states in this method, that's
-        # up to the caller.
-class TftpStateServerRecvWRQ(TftpServerState):
-    received a WRQ packet."""
-    def make_subdirs(self):
-        """The purpose of this method is to, if necessary, create all of the
-        subdirectories leading up to the file to the written."""
-        # Pull off everything below the root.
-        subpath = self.full_path[len(self.context.root):]
-        log.debug("make_subdirs: subpath is %s", subpath)
-        # Split on directory separators, but drop the last one, as it should
-        # be the filename.
-        dirs = subpath.split(os.sep)[:-1]
-        log.debug("dirs is %s", dirs)
-        current = self.context.root
-        for dir in dirs:
-            if dir:
-                current = os.path.join(current, dir)
-                if os.path.isdir(current):
-                    log.debug("%s is already an existing directory", current)
-                else:
-                    os.mkdir(current, 0o700)
-        "Handle an initial WRQ packet as a server."
-        log.debug("In TftpStateServerRecvWRQ.handle")
-        if self.context.upload_open:
-            f = self.context.upload_open(path, self.context)
-            if f is None:
-                self.sendError(TftpErrors.AccessViolation)
-                raise TftpException("Dynamic path %s not permitted" % path)
-            else:
-                self.context.fileobj = f
-        else:
-            log.info("Opening file %s for writing" % path)
-                # FIXME: correct behavior?
-                log.warning("File %s exists already, overwriting..." % (
-                    self.context.file_to_transfer))
-            # FIXME: I think we should upload to a temp file and not overwrite
-            # the existing file until the file is successfully uploaded.
-            self.make_subdirs()
-            self.context.fileobj = open(path, "wb")
-        if sendoack:
-            log.debug("Sending OACK to client")
-            self.sendOACK()
-        else:
-            log.debug("No requested options, expecting transfer to begin...")
-            self.sendACK()
-        # Whether we're sending an oack or not, we're expecting a DAT for
-        # block 1
-        # We may have sent an OACK, but we're expecting a DAT as the response
-        # to either the OACK or an ACK, so lets unconditionally use the
-        # TftpStateExpectDAT state.
-class TftpStateServerStart(TftpState):
-    """The start state for the server. This is a transitory state since at
-    this point we don't know if we're handling an upload or a download. We
-    will commit to one of them once we interpret the initial packet."""
-        """Handle a packet we just received."""
-        log.debug("In TftpStateServerStart.handle")
-        if isinstance(pkt, TftpPacketRRQ):
-            log.debug("Handling an RRQ packet")
-            return TftpStateServerRecvRRQ(self.context).handle(pkt,
-                                                               raddress,
-                                                               rport)
-        elif isinstance(pkt, TftpPacketWRQ):
-            log.debug("Handling a WRQ packet")
-            return TftpStateServerRecvWRQ(self.context).handle(pkt,
-                                                               raddress,
-                                                               rport)
-        else:
-            raise TftpException("Invalid packet to begin up/download: %s" % pkt)
-class TftpStateExpectACK(TftpState):
-    """This class represents the state of the transfer when a DAT was just
-    sent, and we are waiting for an ACK from the server. This class is the
-    same one used by the client during the upload, and the server during the
-    download."""
-        "Handle a packet, hopefully an ACK since we just sent a DAT."
-        if isinstance(pkt, TftpPacketACK):
-            log.debug("Received ACK for packet %d" % pkt.blocknumber)
-            # Is this an ack to the one we just sent?
-            if self.context.next_block == pkt.blocknumber:
-                if self.context.pending_complete:
-                    log.info("Received ACK to final DAT, we're done.")
-                    return None
-                else:
-                    log.debug("Good ACK, sending next DAT")
-                    log.debug("Incremented next_block to %d",
-                        self.context.next_block)
-                log.warning("Received duplicate ACK for block %d"
-                    % pkt.blocknumber)
-            else:
-                log.warning("Oooh, time warp. Received ACK to packet we "
-                         "didn't send yet. Discarding.")
-                self.context.metrics.errors += 1
-            return self
-        elif isinstance(pkt, TftpPacketERR):
-            log.error("Received ERR packet from peer: %s" % str(pkt))
-            raise TftpException("Received ERR packet from peer: %s" % str(pkt))
-        else:
-            log.warning("Discarding unsupported packet: %s" % str(pkt))
-            return self
-class TftpStateExpectDAT(TftpState):
-    """Just sent an ACK packet. Waiting for DAT."""
-        """Handle the packet in response to an ACK, which should be a DAT."""
-        if isinstance(pkt, TftpPacketDAT):
-            return self.handleDat(pkt)
-        # Every other packet type is a problem.
-        elif isinstance(pkt, TftpPacketACK):
-            # Umm, we ACK, you don't.
-            raise TftpException("Received ACK from peer when expecting DAT")
-            raise TftpException("Received WRQ from peer when expecting DAT")
-            raise TftpException("Received ERR from peer: " + str(pkt))
-        else:
-            raise TftpException("Received unknown packet type from peer: " + str(pkt))
-class TftpStateSentWRQ(TftpState):
-    """Just sent an WRQ packet for an upload."""
-            log.debug("Set remote port for session to %s", rport)
-        # If we're going to successfully transfer the file, then we should see
-        # either an OACK for accepted options, or an ACK to ignore options.
-        if isinstance(pkt, TftpPacketOACK):
-            log.info("Received OACK from server")
-            try:
-                self.handleOACK(pkt)
-            except TftpException:
-                self.sendError(TftpErrors.FailedNegotiation)
-                raise
-            else:
-                log.debug("Sending first DAT packet")
-                log.debug("Changing state to TftpStateExpectACK")
-            log.info("Received ACK from server")
-            log.debug("Apparently the server ignored our options")
-            # The block number should be zero.
-                log.debug("Ack blocknumber is zero as expected")
-            else:
-                log.warning("Discarding ACK to block %s" % pkt.blocknumber)
-                log.debug("Still waiting for valid response from server")
-                return self
-            raise TftpException("Received ERR from server: %s" % pkt)
-        elif isinstance(pkt, TftpPacketRRQ):
-            raise TftpException("Received RRQ from server while in upload")
-        elif isinstance(pkt, TftpPacketDAT):
-            raise TftpException("Received DAT from server while in upload")
-        else:
-            raise TftpException("Received unknown packet type from server: %s" % pkt)
-        # By default, no state change.
-        return self
-class TftpStateSentRRQ(TftpState):
-    """Just sent an RRQ packet."""
-        """Handle the packet in response to an RRQ to the server."""
-            log.info("Set remote port for session to %s" % rport)
-        # Now check the packet type and dispatch it properly.
-            try:
-                log.error("Failed to negotiate options: %s" % str(err))
-                raise
-            else:
-                log.debug("Sending ACK to OACK")
-                self.sendACK(blocknumber=0)
-                log.debug("Changing state to TftpStateExpectDAT")
-            # If there are any options set, then the server didn't honour any
-            # of them.
-            log.info("Received DAT from server")
-            if self.context.options:
-                log.info("Server ignored options, falling back to defaults")
-            # Umm, we ACK, the server doesn't.
-            raise TftpException("Received ACK from server while in download")
-            raise TftpException("Received WRQ from server while in download")
-            log.debug("Received ERR packet: %s", pkt)
-            if pkt.errorcode == TftpErrors.FileNotFound:
-                raise TftpFileNotFoundError("File not found")
-            else:
-                raise TftpException("Received ERR from server: {}".format(pkt))
-        else:
-        return self
diff --git a/tester/rt/tftpy/__init__.py b/tester/rt/tftpy/__init__.py
deleted file mode 100644
index 71b8e3d..0000000
--- a/tester/rt/tftpy/__init__.py
+++ /dev/null
@@ -1,27 +0,0 @@
-This library implements the tftp protocol, based on rfc 1350.
-http://www.faqs.org/rfcs/rfc1350.html
-At the moment it implements only a client class, but will include a server,
-with support for variable block sizes.
-As a client of tftpy, this is the only module that you should need to import
-directly. The TftpClient and TftpServer classes can be reached through it.
-import sys
-# Make sure that this is at least Python 2.7
-required_version = (2, 7)
-if sys.version_info < required_version:
-    raise ImportError("Requires at least Python 2.7")
-from . import TftpPacketTypes
-from . import TftpPacketFactory
-from .TftpClient import TftpClient
-from .TftpServer import TftpServer
-from . import TftpContexts
-from . import TftpStates
diff --git a/tester/rtems-tftp-server b/tester/rtems-tftp-server
new file mode 100755
index 0000000..361809a
--- /dev/null
+++ b/tester/rtems-tftp-server
@@ -0,0 +1,45 @@
+#! /usr/bin/env python
+# SPDX-License-Identifier: BSD-2-Clause
+'''A command line standalone TFTP Server. This is useful when testing
+and setting up a TFTP target.'''
+# Copyright (C) 2020 Chris Johns (chrisj at rtems.org)
+# Redistribution and use in source and binary forms, with or without
+# modification, are permitted provided that the following conditions
+# are met:
+# 1. Redistributions of source code must retain the above copyright
+#    notice, this list of conditions and the following disclaimer.
+# 2. Redistributions in binary form must reproduce the above copyright
+#    notice, this list of conditions and the following disclaimer in the
+#    documentation and/or other materials provided with the distribution.
+# THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
+# AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
+# IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
+# ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
+# LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
+# CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
+# SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
+# INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
+# CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
+# ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
+# POSSIBILITY OF SUCH DAMAGE.
+# pylint: disable=invalid-name
+from __future__ import print_function
+import os
+import sys
+base = os.path.dirname(os.path.abspath(sys.argv[0]))
+rtems = os.path.dirname(base)
+sys.path = [rtems] + sys.path
+try:
+    import rt.tftpserver
+    rt.tftpserver.run(sys.argv)
+except ImportError:
+    print("Incorrect RTEMS Tools installation", file=sys.stderr)
+    sys.exit(1)
2.24.1
