[PATCH 00/16] c-user: Split up chapter files
Sebastian Huber
Mon Aug 31 06:55:31 UTC 2020
On 30/08/2020 18:41, Gedare Bloom wrote:
> On Sun, Aug 30, 2020 at 10:15 AM Joel Sherrill<joel at rtems.org> wrote:
>> On Sun, Aug 30, 2020, 11:02 AM Joel Sherrill<joel.sherrill at gmail.com> wrote:
>>> On Sun, Aug 30, 2020, 10:22 AM Gedare Bloom<gedare at rtems.org> wrote:
>>>> this is fairly mechanical. My only question is whether it is better to
>>>> keep the longer names for the directory. like... timer_manager/
>>>> instead of timer/ or to avoid abbreviations like rate_monotonic/
>>>> instead of ratemon/
>>> Longer names and subdirectories please. It has worked in the Users Guide.
>>> We are long past 8.3 and 13 character name limits. Just avoid spaces and special characters in names and stick to all lower case.
> Should we explicitly say _manager on each of them though? Or it is ok
> to say timer/ clock/ rate_monotonic/ and so on?
If you prefer long names, then I would simply use the chapter names, for
example "rate-monotonic-manager", "scheduling-concepts", etc.
The directory names of the patch correspond to the header file names in
cpukit/include/rtems/rtems and I used them also for the specification:
https://git.rtems.org/rtems-central/tree/spec/req/rtems
https://git.rtems.org/rtems-central/tree/spec/if/rtems
