rtems waf, examples, and RTEMS_POSIX_API
Tue Dec 1 06:31:00 UTC 2020
On 30/11/2020 21:43, Joel Sherrill wrote:
> On Mon, Nov 30, 2020 at 1:06 PM Sebastian Huber
> <sebastian.huber at embedded-brains.de
> <mailto:sebastian.huber at embedded-brains.de>> wrote:
>     On 30/11/2020 20:00, Joel Sherrill wrote:
>     >     Applications can use something like:
>     >     #if __RTEMS_MAJOR__ >= 5
>     >     POSIX threads are always enabled ...
>     >     #endif
>     > This is a change to our public API that was completely unnecessary.
>     > We do not require changes to application code when it can be
>     avoided.
>     If you enable the POSIX API, then you don't have to change
>     anything in
>     your application. You can use now more of the POSIX API without
>     having
>     to enable it explicitly. It is up to you if you want to rely on
>     this or not.
> What about rtems-libbsd? It fails to build because of this flag having
> changed
> meaning.
> I think we broke a contract on what the meaning of a published
> feature macro means.
Sorry, I still don't understand the problem. You always had to build
libbsd with a BSP which was configured with --enable-posix.
Since now more POSIX APIs are enabled by default, we may remove this
check from libbsd. However, this requires someone with enough time to
implement and test this.
embedded brains GmbH
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
email: sebastian.hubere at embedded-brains.de
phone: +49-89-18 94 741 - 16
fax:   +49-89-18 94 741 - 08
Registernummer: HRB 157899
