[PATCH v1 3/3] Add AArch64 ZynpMP BSP
Kinsey Moore
kinsey.moore at oarcorp.com
Tue Dec 1 20:57:55 UTC 2020
This adds a BSP family that runs on the Xilinx Ultrascale+ MPSOC
(ZynqMP) family of chips. It is configured to be usable on the Qemu
ZCU102 machine definition and should be almost trivially portable to
ZynqMP development boards and custom hardware. It is also configured to
be usable with libbsd.
bsps/aarch64/xilinx-zynqmp/console/console.c | 134 ++++++++++++++++++
bsps/aarch64/xilinx-zynqmp/include/bsp.h | 81 +++++++++++
bsps/aarch64/xilinx-zynqmp/include/bsp/irq.h | 72 ++++++++++
bsps/aarch64/xilinx-zynqmp/include/tm27.h | 46 ++++++
bsps/aarch64/xilinx-zynqmp/start/bspstart.c | 49 +++++++
.../xilinx-zynqmp/start/bspstarthooks.c | 50 +++++++
spec/build/bsps/aarch64/xilinx-zynqmp/abi.yml | 22 +++
.../aarch64/xilinx-zynqmp/bspqemuilp32.yml | 21 +++
.../aarch64/xilinx-zynqmp/bspqemulp64.yml | 21 +++
spec/build/bsps/aarch64/xilinx-zynqmp/grp.yml | 44 ++++++
.../aarch64/xilinx-zynqmp/linkcmds_ilp32.yml | 72 ++++++++++
.../aarch64/xilinx-zynqmp/linkcmds_lp64.yml | 71 ++++++++++
spec/build/bsps/aarch64/xilinx-zynqmp/obj.yml | 37 +++++
.../bsps/aarch64/xilinx-zynqmp/optclkuart.yml | 20 +++
.../aarch64/xilinx-zynqmp/optconminor.yml | 15 ++
.../bsps/aarch64/xilinx-zynqmp/optloadoff.yml | 18 +++
.../aarch64/xilinx-zynqmp/optnocachelen.yml | 18 +++
.../bsps/aarch64/xilinx-zynqmp/optramlen.yml | 18 +++
.../bsps/aarch64/xilinx-zynqmp/optramori.yml | 18 +++
.../bsps/aarch64/xilinx-zynqmp/tstqemu.yml | 56 ++++++++
20 files changed, 883 insertions(+)
create mode 100644 bsps/aarch64/xilinx-zynqmp/console/console.c
create mode 100644 bsps/aarch64/xilinx-zynqmp/include/bsp.h
create mode 100644 bsps/aarch64/xilinx-zynqmp/include/bsp/irq.h
create mode 100644 bsps/aarch64/xilinx-zynqmp/include/tm27.h
create mode 100644 bsps/aarch64/xilinx-zynqmp/start/bspstart.c
create mode 100644 bsps/aarch64/xilinx-zynqmp/start/bspstarthooks.c
create mode 100644 spec/build/bsps/aarch64/xilinx-zynqmp/abi.yml
create mode 100644 spec/build/bsps/aarch64/xilinx-zynqmp/bspqemuilp32.yml
create mode 100644 spec/build/bsps/aarch64/xilinx-zynqmp/bspqemulp64.yml
create mode 100644 spec/build/bsps/aarch64/xilinx-zynqmp/grp.yml
create mode 100644 spec/build/bsps/aarch64/xilinx-zynqmp/linkcmds_ilp32.yml
create mode 100644 spec/build/bsps/aarch64/xilinx-zynqmp/linkcmds_lp64.yml
create mode 100644 spec/build/bsps/aarch64/xilinx-zynqmp/obj.yml
create mode 100644 spec/build/bsps/aarch64/xilinx-zynqmp/optclkuart.yml
create mode 100644 spec/build/bsps/aarch64/xilinx-zynqmp/optconminor.yml
create mode 100644 spec/build/bsps/aarch64/xilinx-zynqmp/optloadoff.yml
create mode 100644 spec/build/bsps/aarch64/xilinx-zynqmp/optnocachelen.yml
create mode 100644 spec/build/bsps/aarch64/xilinx-zynqmp/optramlen.yml
create mode 100644 spec/build/bsps/aarch64/xilinx-zynqmp/optramori.yml
create mode 100644 spec/build/bsps/aarch64/xilinx-zynqmp/tstqemu.yml
diff --git a/bsps/aarch64/xilinx-zynqmp/console/console.c b/bsps/aarch64/xilinx-zynqmp/console/console.c
new file mode 100644
index 0000000000..7bd85626d9
--- /dev/null
+++ b/bsps/aarch64/xilinx-zynqmp/console/console.c
@@ -0,0 +1,134 @@
+ * @file
+ * @ingroup RTEMSBSPsAArch64XilinxZynqMP
+ * @brief Console Configuration
+ * Copyright (C) 2020 On-Line Applications Research Corporation (OAR)
+ * Written by Kinsey Moore <kinsey.moore at oarcorp.com>
+ * are met:
+ * notice, this list of conditions and the following disclaimer.
+ * notice, this list of conditions and the following disclaimer in the
+ * documentation and/or other materials provided with the distribution.
+#include <rtems/console.h>
+#include <rtems/bspIo.h>
+#include <rtems/sysinit.h>
+#include <bsp/irq.h>
+#include <dev/serial/zynq-uart.h>
+#include <bspopts.h>
+static zynq_uart_context zynqmp_uart_instances[2] = {
+ .base = RTEMS_TERMIOS_DEVICE_CONTEXT_INITIALIZER( "Zynq UART 0" ),
+ .regs = (volatile struct zynq_uart *) 0xff000000,
+ .irq = ZYNQMP_IRQ_UART_0
+ .base = RTEMS_TERMIOS_DEVICE_CONTEXT_INITIALIZER( "Zynq UART 1" ),
+ .regs = (volatile struct zynq_uart *) 0xff010000,
+ .irq = ZYNQMP_IRQ_UART_1
+rtems_status_code console_initialize(
+ rtems_device_major_number major,
+ rtems_device_minor_number minor,
+ void *arg
+ size_t i;
+ rtems_termios_initialize();
+ for (i = 0; i < RTEMS_ARRAY_SIZE(zynqmp_uart_instances); ++i) {
+ char uart[] = "/dev/ttySX";
+ uart[sizeof(uart) - 2] = (char) ('0' + i);
+ rtems_termios_device_install(
+ &uart[0],
+ &zynq_uart_handler,
+ NULL,
+ &zynqmp_uart_instances[i].base
+ if (i == BSP_CONSOLE_MINOR) {
+ link(&uart[0], CONSOLE_DEVICE_NAME);
+ return RTEMS_SUCCESSFUL;
+void zynqmp_debug_console_flush(void)
+ zynq_uart_reset_tx_flush(&zynqmp_uart_instances[BSP_CONSOLE_MINOR]);
+static void zynqmp_debug_console_out(char c)
+ rtems_termios_device_context *base =
+ &zynqmp_uart_instances[BSP_CONSOLE_MINOR].base;
+ zynq_uart_write_polled(base, c);
+static void zynqmp_debug_console_init(void)
+ zynq_uart_initialize(base);
+ BSP_output_char = zynqmp_debug_console_out;
+static void zynqmp_debug_console_early_init(char c)
+ zynqmp_debug_console_out(c);
+static int zynqmp_debug_console_in(void)
+ return zynq_uart_read_polled(base);
+BSP_output_char_function_type BSP_output_char = zynqmp_debug_console_early_init;
+BSP_polling_getchar_function_type BSP_poll_char = zynqmp_debug_console_in;
+RTEMS_SYSINIT_ITEM(
+ zynqmp_debug_console_init,
+ RTEMS_SYSINIT_BSP_START,
+ RTEMS_SYSINIT_ORDER_LAST_BUT_5
diff --git a/bsps/aarch64/xilinx-zynqmp/include/bsp.h b/bsps/aarch64/xilinx-zynqmp/include/bsp.h
index 0000000000..bfdb4777b9
--- /dev/null
+++ b/bsps/aarch64/xilinx-zynqmp/include/bsp.h
@@ -0,0 +1,81 @@
+ * @file
+ * @brief Core BSP definitions
+ * are met:
+#ifndef LIBBSP_AARCH64_XILINX_ZYNQMP_BSP_H
+#define LIBBSP_AARCH64_XILINX_ZYNQMP_BSP_H
+ * @addtogroup RTEMSBSPsAArch64
+#ifndef ASM
+#include <bsp/default-initial-extension.h>
+#include <bsp/start.h>
+#include <rtems.h>
+#ifdef __cplusplus
+extern "C" {
+#endif /* __cplusplus */
+#define BSP_ARM_GIC_CPUIF_BASE 0xf9020000
+#define BSP_ARM_GIC_DIST_BASE 0xf9010000
+#define BSP_RESET_SMC
+ * @brief Zynq UltraScale+ MPSoC specific set up of the MMU.
+ * Provide in the application to override the defaults in the BSP.
+BSP_START_TEXT_SECTION void zynqmp_setup_mmu_and_cache(void);
+void zynqmp_debug_console_flush(void);
+#ifdef __cplusplus
+#endif /* ASM */
+#endif /* LIBBSP_AARCH64_XILINX_ZYNQMP_BSP_H */
diff --git a/bsps/aarch64/xilinx-zynqmp/include/bsp/irq.h b/bsps/aarch64/xilinx-zynqmp/include/bsp/irq.h
index 0000000000..2f4883fd0d
--- /dev/null
+++ b/bsps/aarch64/xilinx-zynqmp/include/bsp/irq.h
@@ -0,0 +1,72 @@
+ * @file
+ * @brief BSP IRQ definitions
+ * are met:
+#ifndef LIBBSP_AARCH64_XILINX_ZYNQMP_IRQ_H
+#define LIBBSP_AARCH64_XILINX_ZYNQMP_IRQ_H
+#ifndef ASM
+#include <rtems/irq.h>
+#include <rtems/irq-extension.h>
+#include <dev/irq/arm-gic-irq.h>
+#ifdef __cplusplus
+extern "C" {
+#define BSP_INTERRUPT_VECTOR_MIN 0
+#define BSP_INTERRUPT_VECTOR_MAX 1023
+/* Interrupts vectors */
+#define BSP_TIMER_VIRT_PPI 27
+#define BSP_TIMER_PHYS_NS_PPI 30
+#define ZYNQMP_IRQ_UART_0 53
+#define ZYNQMP_IRQ_UART_1 54
+#define ZYNQMP_IRQ_ETHERNET_0 89
+#define ZYNQMP_IRQ_ETHERNET_1 91
+#define ZYNQMP_IRQ_ETHERNET_2 93
+#define ZYNQMP_IRQ_ETHERNET_3 95
+#ifdef __cplusplus
+#endif /* ASM */
+#endif /* LIBBSP_AARCH64_XILINX_ZYNQMP_IRQ_H */
diff --git a/bsps/aarch64/xilinx-zynqmp/include/tm27.h b/bsps/aarch64/xilinx-zynqmp/include/tm27.h
index 0000000000..4e41ac872c
--- /dev/null
+++ b/bsps/aarch64/xilinx-zynqmp/include/tm27.h
@@ -0,0 +1,46 @@
+ * @file
+ * @brief BSP tm27 header
+ * are met:
+#ifndef _RTEMS_TMTEST27
+#error "This is an RTEMS internal file you must not include directly."
+#endif
+#ifndef __tm27_h
+#define __tm27_h
+#include <dev/irq/arm-gic-tm27.h>
+#endif /* __tm27_h */
diff --git a/bsps/aarch64/xilinx-zynqmp/start/bspstart.c b/bsps/aarch64/xilinx-zynqmp/start/bspstart.c
index 0000000000..be3ce72b11
--- /dev/null
+++ b/bsps/aarch64/xilinx-zynqmp/start/bspstart.c
@@ -0,0 +1,49 @@
+ * @file
+ * @brief BSP Startup
+ * are met:
+#include <bsp.h>
+#include <bsp/bootcard.h>
+#include <bsp/irq-generic.h>
+#include <bsp/linker-symbols.h>
+void bsp_start( void )
+ bsp_interrupt_initialize();
+ rtems_cache_coherent_add_area(
+ bsp_section_nocacheheap_begin,
+ (uintptr_t) bsp_section_nocacheheap_size
diff --git a/bsps/aarch64/xilinx-zynqmp/start/bspstarthooks.c b/bsps/aarch64/xilinx-zynqmp/start/bspstarthooks.c
index 0000000000..653dfeacb3
--- /dev/null
+++ b/bsps/aarch64/xilinx-zynqmp/start/bspstarthooks.c
@@ -0,0 +1,50 @@
+ * @file
+ * @brief BSP Startup Hooks
+ * are met:
+#include <bsp.h>
+BSP_START_TEXT_SECTION void bsp_start_hook_0(void)
+ /* Do nothing */
+BSP_START_TEXT_SECTION void bsp_start_hook_1(void)
+ AArch64_start_set_vector_base();
+ bsp_start_copy_sections();
+ bsp_start_clear_bss();
diff --git a/spec/build/bsps/aarch64/xilinx-zynqmp/abi.yml b/spec/build/bsps/aarch64/xilinx-zynqmp/abi.yml
index 0000000000..92e7d631a6
--- /dev/null
+++ b/spec/build/bsps/aarch64/xilinx-zynqmp/abi.yml
@@ -0,0 +1,22 @@
+SPDX-License-Identifier: CC-BY-SA-4.0 OR BSD-2-Clause
+actions:
+- get-string: null
+- split: null
+- env-append: null
+build-type: option
+copyrights:
+- Copyright (C) 2020 On-Line Applications Research (OAR)
+default:
+- -mcpu=cortex-a53
+default-by-variant:
+- value:
+ - -mcpu=cortex-a53
+ - -mabi=ilp32
+ variants:
+ - aarch64/xilinx_zynqmp_ilp32
+description: |
+ ABI flags
+enabled-by: true
+links: []
+name: ABI_FLAGS
+type: build
diff --git a/spec/build/bsps/aarch64/xilinx-zynqmp/bspqemuilp32.yml b/spec/build/bsps/aarch64/xilinx-zynqmp/bspqemuilp32.yml
index 0000000000..90979b7822
--- /dev/null
+++ b/spec/build/bsps/aarch64/xilinx-zynqmp/bspqemuilp32.yml
@@ -0,0 +1,21 @@
+arch: aarch64
+bsp: xilinx_zynqmp_ilp32
+build-type: bsp
+cflags: []
+copyrights:
+cppflags: []
+enabled-by: true
+family: xilinx-zynqmp
+includes: []
+install: []
+links:
+- role: build-dependency
+ uid: grp
+ uid: tstqemu
+ uid: linkcmds_ilp32
+source: []
+type: build
diff --git a/spec/build/bsps/aarch64/xilinx-zynqmp/bspqemulp64.yml b/spec/build/bsps/aarch64/xilinx-zynqmp/bspqemulp64.yml
index 0000000000..5e3c561f06
--- /dev/null
+++ b/spec/build/bsps/aarch64/xilinx-zynqmp/bspqemulp64.yml
@@ -0,0 +1,21 @@
+arch: aarch64
+bsp: xilinx_zynqmp_lp64
+build-type: bsp
+cflags: []
+copyrights:
+cppflags: []
+enabled-by: true
+includes: []
+install: []
+links:
+ uid: grp
+ uid: tstqemu
+ uid: linkcmds_lp64
+source: []
+type: build
diff --git a/spec/build/bsps/aarch64/xilinx-zynqmp/grp.yml b/spec/build/bsps/aarch64/xilinx-zynqmp/grp.yml
index 0000000000..92183150a0
--- /dev/null
+++ b/spec/build/bsps/aarch64/xilinx-zynqmp/grp.yml
@@ -0,0 +1,44 @@
+build-type: group
+copyrights:
+enabled-by: true
+includes: []
+install: []
+ldflags: []
+links:
+ uid: ../grp
+ uid: ../start
+ uid: abi
+ uid: obj
+ uid: optloadoff
+ uid: optnocachelen
+ uid: optramlen
+ uid: optramori
+ uid: optclkuart
+ uid: optconminor
+ uid: ../../obj
+ uid: ../../objirq
+ uid: ../../optcachedata
+ uid: ../../optcacheinst
+ uid: ../../opto2
+ uid: ../../bspopts
+type: build
+use-after: []
+use-before: []
diff --git a/spec/build/bsps/aarch64/xilinx-zynqmp/linkcmds_ilp32.yml b/spec/build/bsps/aarch64/xilinx-zynqmp/linkcmds_ilp32.yml
index 0000000000..88ed23f1c8
--- /dev/null
+++ b/spec/build/bsps/aarch64/xilinx-zynqmp/linkcmds_ilp32.yml
@@ -0,0 +1,72 @@
+build-type: config-file
+content: |
+ * SPDX-License-Identifier: BSD-2-Clause
+ * are met:
+ MEMORY {
+ RAM : ORIGIN = ${BSP_XILINX_ZYNQMP_RAM_BASE} + ${BSP_XILINX_ZYNQMP_LOAD_OFFSET}, LENGTH = ${BSP_XILINX_ZYNQMP_RAM_LENGTH} - ${BSP_XILINX_ZYNQMP_LOAD_OFFSET} - ${BSP_XILINX_ZYNQMP_NOCACHE_LENGTH}
+ NOCACHE : ORIGIN = ${BSP_XILINX_ZYNQMP_RAM_BASE} + ${BSP_XILINX_ZYNQMP_RAM_LENGTH} - ${BSP_XILINX_ZYNQMP_NOCACHE_LENGTH}, LENGTH = ${BSP_XILINX_ZYNQMP_NOCACHE_LENGTH}
+ REGION_ALIAS ("REGION_START", RAM);
+ REGION_ALIAS ("REGION_VECTOR", RAM);
+ REGION_ALIAS ("REGION_TEXT", RAM);
+ REGION_ALIAS ("REGION_TEXT_LOAD", RAM);
+ REGION_ALIAS ("REGION_RODATA", RAM);
+ REGION_ALIAS ("REGION_RODATA_LOAD", RAM);
+ REGION_ALIAS ("REGION_DATA", RAM);
+ REGION_ALIAS ("REGION_DATA_LOAD", RAM);
+ REGION_ALIAS ("REGION_FAST_TEXT", RAM);
+ REGION_ALIAS ("REGION_FAST_TEXT_LOAD", RAM);
+ REGION_ALIAS ("REGION_FAST_DATA", RAM);
+ REGION_ALIAS ("REGION_FAST_DATA_LOAD", RAM);
+ REGION_ALIAS ("REGION_BSS", RAM);
+ REGION_ALIAS ("REGION_WORK", RAM);
+ REGION_ALIAS ("REGION_STACK", RAM);
+ REGION_ALIAS ("REGION_NOCACHE", NOCACHE);
+ REGION_ALIAS ("REGION_NOCACHE_LOAD", NOCACHE);
+ bsp_stack_exception_size = DEFINED (bsp_stack_exception_size) ? bsp_stack_exception_size : 1024;
+ bsp_section_rwbarrier_align = DEFINED (bsp_section_rwbarrier_align) ? bsp_section_rwbarrier_align : 1M;
+ bsp_vector_table_in_start_section = 1;
+ OUTPUT_FORMAT ("elf32-littleaarch64")
+ OUTPUT_ARCH (aarch64:ilp32)
+ bsp_set_align = 4;
+ INCLUDE linkcmds.base
+copyrights:
+enabled-by: true
+install-path: ${BSP_LIBDIR}
+links: []
+target: linkcmds
+type: build
diff --git a/spec/build/bsps/aarch64/xilinx-zynqmp/linkcmds_lp64.yml b/spec/build/bsps/aarch64/xilinx-zynqmp/linkcmds_lp64.yml
index 0000000000..e6388d27df
--- /dev/null
+++ b/spec/build/bsps/aarch64/xilinx-zynqmp/linkcmds_lp64.yml
@@ -0,0 +1,71 @@
+content: |
+ * are met:
+ MEMORY {
+ OUTPUT_FORMAT ("elf64-littleaarch64")
+ OUTPUT_ARCH (aarch64)
+copyrights:
+enabled-by: true
+links: []
+target: linkcmds
+type: build
diff --git a/spec/build/bsps/aarch64/xilinx-zynqmp/obj.yml b/spec/build/bsps/aarch64/xilinx-zynqmp/obj.yml
index 0000000000..2ca4ef093b
--- /dev/null
+++ b/spec/build/bsps/aarch64/xilinx-zynqmp/obj.yml
@@ -0,0 +1,37 @@
+build-type: objects
+cflags: []
+copyrights:
+cppflags: []
+cxxflags: []
+enabled-by: true
+includes: []
+install:
+- destination: ${BSP_INCLUDEDIR}
+ source:
+ - bsps/aarch64/xilinx-zynqmp/include/bsp.h
+ - bsps/aarch64/xilinx-zynqmp/include/tm27.h
+- destination: ${BSP_INCLUDEDIR}/bsp
+ source:
+ - bsps/aarch64/xilinx-zynqmp/include/bsp/irq.h
+links: []
+source:
+- bsps/aarch64/shared/cache/cache.c
+- bsps/aarch64/xilinx-zynqmp/console/console.c
+- bsps/aarch64/xilinx-zynqmp/start/bspstart.c
+- bsps/aarch64/xilinx-zynqmp/start/bspstarthooks.c
+- bsps/shared/dev/getentropy/getentropy-cpucounter.c
+- bsps/shared/dev/serial/console-termios-init.c
+- bsps/shared/dev/serial/console-termios.c
+- bsps/shared/start/bspfatal-default.c
+- bsps/shared/start/bspgetworkarea-default.c
+- bsps/shared/start/bspreset-arm-psci.c
+- bsps/shared/start/sbrk.c
+- bsps/shared/dev/irq/arm-gicv2.c
+- bsps/aarch64/shared/irq/irq-arm-gicvx-aarch64.c
+- bsps/shared/irq/irq-default-handler.c
+- bsps/shared/dev/btimer/btimer-cpucounter.c
+- bsps/shared/dev/clock/arm-generic-timer.c
+- bsps/aarch64/shared/clock/arm-generic-timer-aarch64.c
+type: build
diff --git a/spec/build/bsps/aarch64/xilinx-zynqmp/optclkuart.yml b/spec/build/bsps/aarch64/xilinx-zynqmp/optclkuart.yml
index 0000000000..d663d6f640
--- /dev/null
+++ b/spec/build/bsps/aarch64/xilinx-zynqmp/optclkuart.yml
@@ -0,0 +1,20 @@
+actions:
+- get-integer: null
+- define: null
+build-type: option
+copyrights:
+default: 100000000
+- value: 100000000
+ variants:
+ - aarch64/xilinx_zynqmp_ilp32.*
+ - aarch64/xilinx_zynqmp_lp64.*
+description: |
+ Zynq UART clock frequency in Hz
+enabled-by: true
+format: '{}'
+links: []
+name: ZYNQ_CLOCK_UART
+type: build
diff --git a/spec/build/bsps/aarch64/xilinx-zynqmp/optconminor.yml b/spec/build/bsps/aarch64/xilinx-zynqmp/optconminor.yml
index 0000000000..55074c6dac
--- /dev/null
+++ b/spec/build/bsps/aarch64/xilinx-zynqmp/optconminor.yml
@@ -0,0 +1,15 @@
+actions:
+- get-boolean: null
+- define-condition: null
+build-type: option
+copyrights:
+- Copyright (C) 2020 embedded brains GmbH (http://www.embedded-brains.de)
+default: true
+default-by-variant: []
+description: |
+ minor number of console device
+enabled-by: true
+links: []
+name: BSP_CONSOLE_MINOR
+type: build
diff --git a/spec/build/bsps/aarch64/xilinx-zynqmp/optloadoff.yml b/spec/build/bsps/aarch64/xilinx-zynqmp/optloadoff.yml
index 0000000000..4546006c7e
--- /dev/null
+++ b/spec/build/bsps/aarch64/xilinx-zynqmp/optloadoff.yml
@@ -0,0 +1,18 @@
+actions:
+- assert-uint32: null
+- env-assign: null
+- format-and-define: null
+build-type: option
+copyrights:
+default: 32768
+description: |
+ offset of RAM region from memory area base
+enabled-by: true
+format: '{:#010x}'
+links: []
+name: BSP_XILINX_ZYNQMP_LOAD_OFFSET
+type: build
diff --git a/spec/build/bsps/aarch64/xilinx-zynqmp/optnocachelen.yml b/spec/build/bsps/aarch64/xilinx-zynqmp/optnocachelen.yml
index 0000000000..58d2c34b41
--- /dev/null
+++ b/spec/build/bsps/aarch64/xilinx-zynqmp/optnocachelen.yml
@@ -0,0 +1,18 @@
+actions:
+- env-assign: null
+build-type: option
+copyrights:
+default: 0x100000
+description: |
+ length of nocache RAM region
+enabled-by: true
+format: '{:#010x}'
+links: []
+name: BSP_XILINX_ZYNQMP_NOCACHE_LENGTH
+type: build
diff --git a/spec/build/bsps/aarch64/xilinx-zynqmp/optramlen.yml b/spec/build/bsps/aarch64/xilinx-zynqmp/optramlen.yml
index 0000000000..4599773985
--- /dev/null
+++ b/spec/build/bsps/aarch64/xilinx-zynqmp/optramlen.yml
@@ -0,0 +1,18 @@
+actions:
+- env-assign: null
+build-type: option
+copyrights:
+default: 0x10000000
+description: |
+ length of memory area available to the BSP
+enabled-by: true
+format: '{:#010x}'
+links: []
+name: BSP_XILINX_ZYNQMP_RAM_LENGTH
+type: build
diff --git a/spec/build/bsps/aarch64/xilinx-zynqmp/optramori.yml b/spec/build/bsps/aarch64/xilinx-zynqmp/optramori.yml
index 0000000000..73c89995ba
--- /dev/null
+++ b/spec/build/bsps/aarch64/xilinx-zynqmp/optramori.yml
@@ -0,0 +1,18 @@
+actions:
+- env-assign: null
+build-type: option
+copyrights:
+default: 0x40018000
+description: |
+ base address of memory area available to the BSP
+enabled-by: true
+format: '{:#010x}'
+links: []
+name: BSP_XILINX_ZYNQMP_RAM_BASE
+type: build
diff --git a/spec/build/bsps/aarch64/xilinx-zynqmp/tstqemu.yml b/spec/build/bsps/aarch64/xilinx-zynqmp/tstqemu.yml
index 0000000000..a5b08eca10
--- /dev/null
+++ b/spec/build/bsps/aarch64/xilinx-zynqmp/tstqemu.yml
@@ -0,0 +1,56 @@
+actions:
+- set-test-state:
+ # expected to fail
+ minimum: exclude
+ # expected to fail, zynq UART implements set_attributes, but always returns failure
+ spconsole01: exclude
+ # test broken under 64bit due to SIZE_MAX differences
+ validation-0: expected-fail
+ # don't compile due to toolchain issues
+ spconfig01: exclude
+ spmisc01: exclude
+ # tests that are passing intermittently
+ spcpucounter01: indeterminate
+ rtmonuse: indeterminate
+ sp37: indeterminate
+ sp68: indeterminate
+ sp04: indeterminate
+ sp20: indeterminate
+ sp69: indeterminate
+ rtmonusxtimes01: indeterminate
+ spedfsched02: indeterminate
+ spedfsched04: indeterminate
+ psxtimes01: indeterminate
+ sprmsched01: indeterminate
+ sptimecounter02: indeterminate
+ sptimecounter04: indeterminate
+ ttest02: indeterminate
+ # tests that pass nominally, but fail under Qemu when the host is under
+ # heavy load
+ psx12: indeterminate
+ spintrcritical03: indeterminate
+ spintrcritical04: indeterminate
+ spintrcritical05: indeterminate
+build-type: option
+copyrights:
+default: null
+description: ''
+enabled-by: true
+links:
+ uid: ../../tstnoiconv
+ uid: ../../tstnojffs2
+ uid: ../../tstnolibdl
+ uid: ../../tstnorfs
+type: build
2.20.1
