[PATCH v2] c-user: Generate Object Services documentation
    Sebastian Huber
    Wed Dec  2 08:22:06 UTC 2020
The documentation is a consolidation of the comments in Doxygen markup
and the documentation sources in Sphinx markup.  The documentation was
transfered to interface specification items.  The documentation source
files were generated from the items by a script.
Update #3993.
The generated documentation is available here:
https://ftp.rtems.org/pub/rtems/people/sebh/c-user.pdf
v2:
Remove leading '_' from parameter names.
 c-user/object-services/directives.rst   | 978 ++++++++++++++----------
 c-user/object-services/introduction.rst |  93 ++-
 2 files changed, 643 insertions(+), 428 deletions(-)
diff --git a/c-user/object-services/directives.rst b/c-user/object-services/directives.rst
index 87f0f5a..ce7a894 100644
--- a/c-user/object-services/directives.rst
+++ b/c-user/object-services/directives.rst
@@ -1,643 +1,805 @@
 .. SPDX-License-Identifier: CC-BY-SA-4.0
-.. Copyright (C) 1988, 2008 On-Line Applications Research Corporation (OAR)
+.. Copyright (C) 2020 embedded brains GmbH (http://www.embedded-brains.de)
+.. Copyright (C) 1988, 2009 On-Line Applications Research Corporation (OAR)
+.. This file is part of the RTEMS quality process and was automatically
+.. generated.  If you find something that needs to be fixed or
+.. worded better please post a report or patch to an RTEMS mailing list
+.. or raise a bug report:
+.. https://docs.rtems.org/branches/master/user/support/bugs.html
+.. For information on updating and regenerating please refer to:
+.. https://docs.rtems.org/branches/master/eng/req/howto.html
+.. _ObjectServicesDirectives:
 Directives
+This section details the directives of the Object Services. A subsection is
+dedicated to each of this manager's directives and lists the calling sequence,
+parameters, description, return values, and notes of the directive.
+.. Generated from spec:/rtems/object/if/build-id
 .. raw:: latex
-   \clearpage
+    \clearpage
+.. index:: rtems_build_id()
+.. _InterfaceRtemsBuildId:
+rtems_build_id()
+Builds the object identifier from the API, class, MPCI node, and index
+components.
+.. rubric:: CALLING SEQUENCE:
+.. code-block:: c
+    #define rtems_build_id( api, class, node, index )
-.. index:: build object name
-.. index:: rtems_build_name
+.. rubric:: PARAMETERS:
-.. _rtems_build_name:
+``api``
+    This parameter is the API of the object identifier to build.
-BUILD_NAME - Build object name from characters
+``class``
+    This parameter is the class of the object identifier to build.
-CALLING SEQUENCE:
-    .. code-block:: c
+``node``
+    This parameter is the MPCI node of the object identifier to build.
-        rtems_name rtems_build_name(
-            uint8_t c1,
-            uint8_t c2,
-            uint8_t c3,
-            uint8_t c4
+``index``
+    This parameter is the index of the object identifier to build.
-DIRECTIVE STATUS CODES:
-    Returns a name constructed from the four characters.
+.. rubric:: RETURN VALUES:
-DESCRIPTION:
-    This service takes the four characters provided as arguments and constructs
-    a thirty-two bit object name with ``c1`` in the most significant byte and
-    ``c4`` in the least significant byte.
+Returns the object identifier built from the API, class, MPCI node, and index
+components.
-NOTES:
-    This directive is strictly local and does not impact task scheduling.
+.. rubric:: NOTES:
+This directive is strictly local and does not impact task scheduling.
+.. Generated from spec:/rtems/object/if/build-name
 .. raw:: latex
-   \clearpage
+    \clearpage
-.. index:: get name from id
-.. index:: obtain name from id
-.. index:: rtems_object_get_classic_name
+.. index:: rtems_build_name()
-.. _rtems_object_get_classic_name:
+.. _InterfaceRtemsBuildName:
-OBJECT_GET_CLASSIC_NAME - Lookup name from id
+rtems_build_name()
-CALLING SEQUENCE:
-    .. code-block:: c
+Builds the object name composed of the four characters.
-        rtems_status_code rtems_object_get_classic_name(
-            rtems_id      id,
-            rtems_name   *name
-    .. list-table::
-     :class: rtems-table
+.. code-block:: c
-     * - ``RTEMS_SUCCESSFUL``
-       - name looked up successfully
-     * - ``RTEMS_INVALID_ADDRESS``
-       - invalid name pointer
-     * - ``RTEMS_INVALID_ID``
-       - invalid object id
+    #define rtems_build_name( c1, c2, c3, c4 )
-DESCRIPTION:
-    This service looks up the name for the object ``id`` specified and, if
-    found, places the result in ``*name``.
-NOTES:
+``c1``
+    This parameter is the first character of the name.
-.. raw:: latex
+``c2``
+    This parameter is the second character of the name.
-   \clearpage
+``c3``
+    This parameter is the third character of the name.
-.. index:: get object name as string
-.. index:: obtain object name as string
-.. index:: rtems_object_get_name
+``c4``
+    This parameter is the fourth character of the name.
-.. _rtems_object_get_name:
+.. rubric:: DESCRIPTION:
-OBJECT_GET_NAME - Obtain object name as string
+This directive takes the four characters provided as arguments and composes a
+32-bit object name with ``c1`` in the most significant 8-bits and ``c4`` in the
+least significant 8-bits.
-CALLING SEQUENCE:
-    .. code-block:: c
-        char* rtems_object_get_name(
-            rtems_id       id,
-            size_t         length,
-            char          *name
+Returns the object name composed of the four characters.
-    Returns a pointer to the name if successful or ``NULL`` otherwise.
+.. rubric:: NOTES:
-DESCRIPTION:
-    This service looks up the name of the object specified by ``id`` and places
-    it in the memory pointed to by ``name``.  Every attempt is made to return
-    name as a printable string even if the object has the Classic API
-    thirty-two bit style name.
-NOTES:
+.. Generated from spec:/rtems/object/if/get-classic-name
 .. raw:: latex
-   \clearpage
+    \clearpage
-.. index:: set object name
-.. index:: rtems_object_set_name
+.. index:: rtems_object_get_classic_name()
-.. _rtems_object_set_name:
+.. _InterfaceRtemsObjectGetClassicName:
-OBJECT_SET_NAME - Set object name
+rtems_object_get_classic_name()
+Gets the object name associated with the object identifier.
+.. code-block:: c
+    rtems_status_code rtems_object_get_classic_name(
+      rtems_id    id,
+      rtems_name *name
-CALLING SEQUENCE:
-    .. code-block:: c
-        rtems_status_code rtems_object_set_name(
-            rtems_id       id,
-            const char    *name
+``id``
+    This parameter is the object identifier to get the name.
-    .. list-table::
+``name``
+    This parameter is the pointer to an object name variable.  The object name
+    associated with the object identifier will be stored in this variable, in
+    case of a successful operation.
-DESCRIPTION:
-    This service sets the name of ``id`` to that specified by the string
-    located at ``name``.
+:c:macro:`RTEMS_SUCCESSFUL`
+    The requested operation was successful.
-NOTES:
+:c:macro:`RTEMS_INVALID_ADDRESS`
+    The ``name`` parameter was `NULL
+    <https://en.cppreference.com/w/c/types/NULL>`_.
-    If the object specified by ``id`` is of a class that has a string name,
-    this method will free the existing name to the RTEMS Workspace and allocate
-    enough memory from the RTEMS Workspace to make a copy of the string located
-    at ``name``.
+:c:macro:`RTEMS_INVALID_ID`
+    There was no object information available for the object identifier.
-    If the object specified by ``id`` is of a class that has a thirty-two bit
-    integer style name, then the first four characters in ``*name`` will be
-    used to construct the name.  name to the RTEMS Workspace and allocate
+    The object name associated with the object identifier was a string.
+    There was no object associated with the object identifier.
+.. rubric:: NOTES:
+.. Generated from spec:/rtems/object/if/get-name
 .. raw:: latex
-   \clearpage
+    \clearpage
+.. index:: rtems_object_get_name()
+.. _InterfaceRtemsObjectGetName:
+rtems_object_get_name()
+Gets the object name associated with the object identifier as a string.
+.. code-block:: c
+    char *rtems_object_get_name( rtems_id id, size_t length, char *name );
+``id``
+``length``
+    This parameter is the buffer length in bytes.
+``name``
+    This parameter is the pointer to a buffer of the specified length.
-.. index:: obtain API from id
-.. index:: rtems_object_id_get_api
+The object name is stored in the name buffer.  If the name buffer length is
+greater than zero, then the stored object name will be ``NUL`` terminated. The
+stored object name may be truncated to fit the length.  There is no indication
+if a truncation occurred.  Every attempt is made to return name as a printable
+string even if the object has the Classic API 32-bit integer style name.
-.. _rtems_object_id_get_api:
-OBJECT_ID_GET_API - Obtain API from Id
+`NULL <https://en.cppreference.com/w/c/types/NULL>`_
+    The ``length`` parameter was 0.
-CALLING SEQUENCE:
-    .. code-block:: c
-        int rtems_object_id_get_api(
-            rtems_id id
-    Returns the API portion of the object Id.
-DESCRIPTION:
-    This directive returns the API portion of the provided object ``id``.
+Returns the ``name`` parameter value, if there is an object name associated
+with the object identifier.
-NOTES:
+.. rubric:: NOTES:
-    This directive does NOT validate the ``id`` provided.
+This directive may cause the calling task to be preempted due to an obtain and
+release of the object allocator mutex.
+.. Generated from spec:/rtems/object/if/set-name
 .. raw:: latex
-   \clearpage
+    \clearpage
+.. index:: rtems_object_set_name()
+.. _InterfaceRtemsObjectSetName:
+rtems_object_set_name()
+Sets the object name of the object associated with the object identifier.
+.. code-block:: c
+    rtems_status_code rtems_object_set_name( rtems_id id, const char *name );
+``id``
+    This parameter is the object identifier of the object to set the name.
+``name``
+    This parameter is the object name to set.
+This directive will set the object name based upon the user string.
-.. index:: obtain class from object id
-.. index:: rtems_object_id_get_class
-.. _rtems_object_id_get_class:
-OBJECT_ID_GET_CLASS - Obtain Class from Id
+:c:macro:`RTEMS_NO_MEMORY`
+    There was no memory available to duplicate the name.
-CALLING SEQUENCE:
-    .. code-block:: c
+.. rubric:: NOTES:
-        uint32_t rtems_object_id_get_class(
-                 rtems_id id
-    Returns the class portion of the object Id.
+This directive can be used to set the name of objects which do not have a
+naming scheme per their API.
-DESCRIPTION:
-    This directive returns the class portion of the provided object ``id``.
+If the object specified by ``id`` is of a class that has a string name, this
+directive will free the existing name to the RTEMS Workspace and allocate
+enough memory from the RTEMS Workspace to make a copy of the string located at
+``name``.
-NOTES:
+If the object specified by ``id`` is of a class that has a 32-bit integer style
+name, then the first four characters in ``name`` will be used to construct the
+name.
+.. Generated from spec:/rtems/object/if/id-get-api
 .. raw:: latex
-   \clearpage
+    \clearpage
-.. index:: obtain node from object id
-.. index:: rtems_object_id_get_node
+.. index:: rtems_object_id_get_api()
-.. _rtems_object_id_get_node:
+.. _InterfaceRtemsObjectIdGetApi:
-OBJECT_ID_GET_NODE - Obtain Node from Id
+rtems_object_id_get_api()
-CALLING SEQUENCE:
-    .. code-block:: c
+Gets the API component of the object identifier.
-        uint32_t rtems_object_id_get_node(
-                 rtems_id id
-    Returns the node portion of the object Id.
+.. code-block:: c
-DESCRIPTION:
-    This directive returns the node portion of the provided object ``id``.
+    #define rtems_object_id_get_api( id )
-NOTES:
+``id``
+    This parameter is the object identifier with the API component to get.
+Returns the API component of the object identifier.
+.. rubric:: NOTES:
+This directive does not validate the object identifier provided in ``id``.
+A body is also provided.
+.. Generated from spec:/rtems/object/if/id-get-class
 .. raw:: latex
-   \clearpage
+    \clearpage
+.. index:: rtems_object_id_get_class()
-.. index:: obtain index from object id
-.. index:: rtems_object_id_get_index
+.. _InterfaceRtemsObjectIdGetClass:
-.. _rtems_object_id_get_index:
+rtems_object_id_get_class()
-OBJECT_ID_GET_INDEX - Obtain Index from Id
+Gets the class component of the object identifier.
-CALLING SEQUENCE:
-    .. code-block:: c
-        uint16_t rtems_object_id_get_index(
-                 rtems_id id
+.. code-block:: c
-    Returns the index portion of the object Id.
+    #define rtems_object_id_get_class( id )
-DESCRIPTION:
-    This directive returns the index portion of the provided object ``id``.
-NOTES:
+``id``
+    This parameter is the object identifier with the class component to get.
+Returns the class component of the object identifier.
+.. rubric:: NOTES:
+.. Generated from spec:/rtems/object/if/id-get-node
 .. raw:: latex
-   \clearpage
+    \clearpage
+.. index:: rtems_object_id_get_node()
+.. _InterfaceRtemsObjectIdGetNode:
-.. index:: build object id from components
-.. index:: rtems_build_id
+rtems_object_id_get_node()
-.. _rtems_build_id:
+Gets the MPCI node component of the object identifier.
-BUILD_ID - Build Object Id From Components
-CALLING SEQUENCE:
-    .. code-block:: c
+.. code-block:: c
-        rtems_id rtems_build_id(
-            int the_api,
-            int the_class,
-            int the_node,
-            int the_index
+    #define rtems_object_id_get_node( id )
-    Returns an object Id constructed from the provided arguments.
-DESCRIPTION:
-    This service constructs an object Id from the provided ``the_api``,
-    ``the_class``, ``the_node``, and ``the_index``.
+``id``
+    This parameter is the object identifier with the MPCI node component to
+    get.
-NOTES:
-    This directive does NOT validate the arguments provided or the Object id
-    returned.
+Returns the MPCI node component of the object identifier.
+.. rubric:: NOTES:
+.. Generated from spec:/rtems/object/if/id-get-index
 .. raw:: latex
-   \clearpage
+    \clearpage
+.. index:: rtems_object_id_get_index()
+.. _InterfaceRtemsObjectIdGetIndex:
+rtems_object_id_get_index()
-.. index:: obtain minimum API value
-.. index:: rtems_object_id_api_minimum
+Gets the index component of the object identifier.
-.. _rtems_object_id_api_minimum:
-OBJECT_ID_API_MINIMUM - Obtain Minimum API Value
+.. code-block:: c
-CALLING SEQUENCE:
-    .. code-block:: c
+    #define rtems_object_id_get_index( id )
-        int rtems_object_id_api_minimum(void);
-    Returns the minimum valid for the API portion of an object Id.
+``id``
+    This parameter is the object identifier with the index component to get.
-DESCRIPTION:
-    This service returns the minimum valid for the API portion of an object Id.
-NOTES:
+Returns the index component of the object identifier.
+.. rubric:: NOTES:
+.. Generated from spec:/rtems/object/if/id-api-minimum
 .. raw:: latex
-   \clearpage
+    \clearpage
+.. index:: rtems_object_id_api_minimum()
+.. _InterfaceRtemsObjectIdApiMinimum:
+rtems_object_id_api_minimum()
-.. index:: obtain maximum API value
-.. index:: rtems_object_id_api_maximum
+Gets the lowest valid value for the API component of an object identifier.
-.. _rtems_object_id_api_maximum:
-OBJECT_ID_API_MAXIMUM - Obtain Maximum API Value
+.. code-block:: c
-CALLING SEQUENCE:
-    .. code-block:: c
+    #define rtems_object_id_api_minimum()
-        int rtems_object_id_api_maximum(void);
-    Returns the maximum valid for the API portion of an object Id.
+Returns the lowest valid value for the API component of an object identifier.
-DESCRIPTION:
-    This service returns the maximum valid for the API portion of an object Id.
+.. rubric:: NOTES:
-NOTES:
+.. Generated from spec:/rtems/object/if/id-api-maximum
 .. raw:: latex
-   \clearpage
+    \clearpage
+.. index:: rtems_object_id_api_maximum()
+.. _InterfaceRtemsObjectIdApiMaximum:
-.. index:: obtain minimum class value
-.. index:: rtems_object_api_minimum_class
+rtems_object_id_api_maximum()
-.. _rtems_object_api_minimum_class:
+Gets the highest valid value for the API component of an object identifier.
-OBJECT_API_MINIMUM_CLASS - Obtain Minimum Class Value
-CALLING SEQUENCE:
-    .. code-block:: c
+.. code-block:: c
-        int rtems_object_api_minimum_class(
-            int api
+    #define rtems_object_id_api_maximum()
-    If ``api`` is not valid, -1 is returned.
-    If successful, this service returns the minimum valid for the class portion
-    of an object Id for the specified ``api``.
+Returns the highest valid value for the API component of an object identifier.
-DESCRIPTION:
-    This service returns the minimum valid for the class portion of an object
-    Id for the specified ``api``.
+.. rubric:: NOTES:
-NOTES:
+.. Generated from spec:/rtems/object/if/api-minimum-class
 .. raw:: latex
-   \clearpage
+    \clearpage
+.. index:: rtems_object_api_minimum_class()
+.. _InterfaceRtemsObjectApiMinimumClass:
-.. index:: obtain maximum class value
-.. index:: rtems_object_api_maximum_class
+rtems_object_api_minimum_class()
-.. _rtems_object_api_maximum_class:
+Gets the lowest valid class value of the object API.
-OBJECT_API_MAXIMUM_CLASS - Obtain Maximum Class Value
-CALLING SEQUENCE:
-    .. code-block:: c
+.. code-block:: c
-        int rtems_object_api_maximum_class(
-            int api
+    int rtems_object_api_minimum_class( int api );
-    If successful, this service returns the maximum valid for the class portion
+``api``
+    This parameter is the object API to get the lowest valid class value.
-DESCRIPTION:
-    This service returns the maximum valid for the class portion of an object
-NOTES:
+``-1``
+    The object API was invalid.
+Returns the lowest valid class value of the object API.
+.. rubric:: NOTES:
+.. Generated from spec:/rtems/object/if/api-maximum-class
 .. raw:: latex
-   \clearpage
+    \clearpage
+.. index:: rtems_object_api_maximum_class()
+.. _InterfaceRtemsObjectApiMaximumClass:
+rtems_object_api_maximum_class()
+Gets the highest valid class value of the object API.
-.. index:: obtain minimum class value for an API
-.. index:: rtems_object_id_api_minimum_class
-.. _rtems_object_id_api_minimum_class:
+.. code-block:: c
-OBJECT_ID_API_MINIMUM_CLASS - Obtain Minimum Class Value for an API
+    int rtems_object_api_maximum_class( int api );
-CALLING SEQUENCE:
-    .. code-block:: c
-        int rtems_object_get_id_api_minimum_class(
-            int api
+``api``
+    This parameter is the object API to get the highest valid class value.
-    If successful, this service returns the index corresponding to the first
-    object class of the specified ``api``.
+``0``
-DESCRIPTION:
-    This service returns the index for the first object class associated with
-    the specified ``api``.
+Returns the highest valid class value of the object API.
-NOTES:
+.. rubric:: NOTES:
+.. Generated from spec:/rtems/object/if/get-api-name
 .. raw:: latex
-   \clearpage
+    \clearpage
+.. index:: rtems_object_get_api_name()
+.. _InterfaceRtemsObjectGetApiName:
+rtems_object_get_api_name()
+Gets a descriptive name of the object API.
+.. code-block:: c
-.. index:: obtain maximum class value for an API
-.. index:: rtems_object_id_api_maximum_class
+    const char *rtems_object_get_api_name( int api );
-.. _rtems_object_id_api_maximum_class:
-OBJECT_ID_API_MAXIMUM_CLASS - Obtain Maximum Class Value for an API
+``api``
+    This parameter is the object API to get the name.
-CALLING SEQUENCE:
-    .. code-block:: c
-        int rtems_object_get_api_maximum_class(
-            int api
+"BAD API"
+    The API was invalid.
+Returns a descriptive name of the API, if the API was valid.
-    If successful, this service returns the index corresponding to the last
+.. rubric:: NOTES:
-DESCRIPTION:
-    This service returns the index for the last object class associated with
-NOTES:
+The string returned is from constant space.  Do not modify or free it.
+.. Generated from spec:/rtems/object/if/get-api-class-name
 .. raw:: latex
-   \clearpage
+    \clearpage
+.. index:: rtems_object_get_api_class_name()
+.. _InterfaceRtemsObjectGetApiClassName:
+rtems_object_get_api_class_name()
+Gets a descriptive name of the object class of the object API.
+.. code-block:: c
-.. index:: obtain API name
-.. index:: rtems_object_get_api_name
+    const char *rtems_object_get_api_class_name( int the_api, int the_class );
-.. _rtems_object_get_api_name:
-OBJECT_GET_API_NAME - Obtain API Name
+``the_api``
+    This parameter is the object API of the object class.
-CALLING SEQUENCE:
-    .. code-block:: c
+``the_class``
+    This parameter is the object class of the object API to get the name.
-        const char* rtems_object_get_api_name(
-            int api
-    If ``api`` is not valid, the string ``"BAD API"`` is returned.
+"BAD API"
-    If successful, this service returns a pointer to a string containing the
-    name of the specified ``api``.
+"BAD CLASS"
+    The class of the API was invalid.
-DESCRIPTION:
-    This service returns the name of the specified ``api``.
+Returns a descriptive name of the class of the API, if the class of the API and
+the API were valid.
-NOTES:
+.. rubric:: NOTES:
-    The string returned is from constant space.  Do not modify or free it.
+.. Generated from spec:/rtems/object/if/get-class-information
 .. raw:: latex
-   \clearpage
+    \clearpage
+.. index:: rtems_object_get_class_information()
+.. _InterfaceRtemsObjectGetClassInformation:
+rtems_object_get_class_information()
+Gets the object class information of the object class of the object API.
+.. code-block:: c
-.. index:: obtain class name
-.. index:: rtems_object_get_api_class_name
+    rtems_status_code rtems_object_get_class_information(
+      int                                 the_api,
+      int                                 the_class,
+      rtems_object_api_class_information *info
-.. _rtems_object_get_api_class_name:
-OBJECT_GET_API_CLASS_NAME - Obtain Class Name
+``the_api``
-CALLING SEQUENCE:
-    .. code-block:: c
+``the_class``
+    This parameter is the object class of the object API to get the class
+    information.
-        const char *rtems_object_get_api_class_name(
-            int the_api,
-            int the_class
+``info``
+    This parameter is the pointer to an object class information variable.  The
+    object class information of the class of the API will be stored in this
+    variable, in case of a successful operation.
-    If ``the_api`` is not valid, the string ``"BAD API"`` is returned.
-    If ``the_class`` is not valid, the string ``"BAD CLASS"`` is returned.
-    name of the specified ``the_api`` / ``the_class`` pair.
+    The ``info`` parameter was `NULL
-DESCRIPTION:
-    This service returns the name of the object class indicated by the
-    specified ``the_api`` and ``the_class``.
+:c:macro:`RTEMS_INVALID_NUMBER`
+    The class of the API or the API was invalid.
-NOTES:
+.. rubric:: NOTES:
+.. Generated from spec:/rtems/object/if/get-local-node
 .. raw:: latex
-   \clearpage
+    \clearpage
-.. index:: obtain class information
-.. index:: rtems_object_get_class_information
+.. index:: rtems_object_get_local_node()
-.. _rtems_object_get_class_information:
+.. _InterfaceRtemsObjectGetLocalNode:
-OBJECT_GET_CLASS_INFORMATION - Obtain Class Information
+rtems_object_get_local_node()
-CALLING SEQUENCE:
-    .. code-block:: c
+Gets the local MPCI node number.
-        rtems_status_code rtems_object_get_class_information(
-            int                                 the_api,
-            int                                 the_class,
-            rtems_object_api_class_information *info
-    .. list-table::
+.. code-block:: c
-       - information obtained successfully
-       - ``info`` is NULL
-     * - ``RTEMS_INVALID_NUMBER``
-       - invalid ``api`` or ``the_class``
+    uint16_t rtems_object_get_local_node( void );
-    If successful, the structure located at ``info`` will be filled in with
-    information about the specified ``api`` / ``the_class`` pairing.
-DESCRIPTION:
-    This service returns information about the object class indicated by the
-    specified ``api`` and ``the_class``. This structure is defined as follows:
+Returns the local MPCI node number.
-    .. code-block:: c
+.. rubric:: NOTES:
-        typedef struct {
-            rtems_id  minimum_id;
-            rtems_id  maximum_id;
-            int       maximum;
-            bool      auto_extend;
-            int       unallocated;
-        } rtems_object_api_class_information;
-NOTES:
+.. Generated from spec:/rtems/object/if/id-initial
 .. raw:: latex
-   \clearpage
+    \clearpage
+.. index:: RTEMS_OBJECT_ID_INITIAL()
+.. _InterfaceRTEMSOBJECTIDINITIAL:
+RTEMS_OBJECT_ID_INITIAL()
+Builds the object identifier with the lowest index from the API, class, and
+MPCI node components.
+.. code-block:: c
+    #define RTEMS_OBJECT_ID_INITIAL( api, class, node )
-.. index:: obtain local node
-.. index:: rtems_object_get_local_node
-.. _rtems_object_get_local_node:
+``api``
-OBJECT_GET_LOCAL_NODE - Obtain Local Node
+``class``
-CALLING SEQUENCE:
-    .. code-block:: c
+``node``
-        uint16_t rtems_object_get_local_node( void );
-    NONE
+Returns the object identifier with the lowest index built from the API, class,
+and MPCI node components.
-DESCRIPTION:
-    This service returns the local MPCI node.
+.. rubric:: NOTES:
-NOTES:
diff --git a/c-user/object-services/introduction.rst b/c-user/object-services/introduction.rst
index 3c7ff18..6e7f4af 100644
--- a/c-user/object-services/introduction.rst
+++ b/c-user/object-services/introduction.rst
@@ -1,47 +1,100 @@
+.. Generated from spec:/rtems/object/if/group
+.. _ObjectServicesIntroduction:
 Introduction
+.. The following list was generated from:
+.. spec:/rtems/object/if/build-id
+.. spec:/rtems/object/if/build-name
+.. spec:/rtems/object/if/get-classic-name
+.. spec:/rtems/object/if/get-name
+.. spec:/rtems/object/if/set-name
+.. spec:/rtems/object/if/id-get-api
+.. spec:/rtems/object/if/id-get-class
+.. spec:/rtems/object/if/id-get-node
+.. spec:/rtems/object/if/id-get-index
+.. spec:/rtems/object/if/id-api-minimum
+.. spec:/rtems/object/if/id-api-maximum
+.. spec:/rtems/object/if/api-minimum-class
+.. spec:/rtems/object/if/api-maximum-class
+.. spec:/rtems/object/if/get-api-name
+.. spec:/rtems/object/if/get-api-class-name
+.. spec:/rtems/object/if/get-class-information
+.. spec:/rtems/object/if/get-local-node
+.. spec:/rtems/object/if/id-initial
 RTEMS provides a collection of services to assist in the management and usage
 of the objects created and utilized via other managers.  These services assist
 in the manipulation of RTEMS objects independent of the API used to create
-them.  The object related services provided by RTEMS are:
+them. The directives provided by the Object Services are:
-- :ref:`rtems_build_id`
+* :ref:`InterfaceRtemsBuildId` - Builds the object identifier from the API,
+  class, MPCI node, and index components.
-- :ref:`rtems_build_name`
+* :ref:`InterfaceRtemsBuildName` - Builds the object name composed of the four
+  characters.
-- :ref:`rtems_object_get_classic_name`
+* :ref:`InterfaceRtemsObjectGetClassicName` - Gets the object name associated
+  with the object identifier.
-- :ref:`rtems_object_get_name`
+* :ref:`InterfaceRtemsObjectGetName` - Gets the object name associated with the
+  object identifier as a string.
-- :ref:`rtems_object_set_name`
+* :ref:`InterfaceRtemsObjectSetName` - Sets the object name of the object
+  associated with the object identifier.
-- :ref:`rtems_object_id_get_api`
+* :ref:`InterfaceRtemsObjectIdGetApi` - Gets the API component of the object
+  identifier.
-- :ref:`rtems_object_id_get_class`
+* :ref:`InterfaceRtemsObjectIdGetClass` - Gets the class component of the
+  object identifier.
-- :ref:`rtems_object_id_get_node`
+* :ref:`InterfaceRtemsObjectIdGetNode` - Gets the MPCI node component of the
-- :ref:`rtems_object_id_get_index`
+* :ref:`InterfaceRtemsObjectIdGetIndex` - Gets the index component of the
+* :ref:`InterfaceRtemsObjectIdApiMinimum` - Gets the lowest valid value for the
+  API component of an object identifier.
-- :ref:`rtems_object_id_api_minimum`
+* :ref:`InterfaceRtemsObjectIdApiMaximum` - Gets the highest valid value for
+  the API component of an object identifier.
-- :ref:`rtems_object_id_api_maximum`
+* :ref:`InterfaceRtemsObjectApiMinimumClass` - Gets the lowest valid class
+  value of the object API.
-- :ref:`rtems_object_id_api_minimum_class`
+* :ref:`InterfaceRtemsObjectApiMaximumClass` - Gets the highest valid class
-- :ref:`rtems_object_id_api_maximum_class`
+* :ref:`InterfaceRtemsObjectGetApiName` - Gets a descriptive name of the object
+  API.
-- :ref:`rtems_object_get_api_name`
+* :ref:`InterfaceRtemsObjectGetApiClassName` - Gets a descriptive name of the
+  object class of the object API.
-- :ref:`rtems_object_get_api_class_name`
+* :ref:`InterfaceRtemsObjectGetClassInformation` - Gets the object class
+  information of the object class of the object API.
-- :ref:`rtems_object_get_class_information`
+* :ref:`InterfaceRtemsObjectGetLocalNode` - Gets the local MPCI node number.
-- :ref:`rtems_object_get_local_node`
+* :ref:`InterfaceRTEMSOBJECTIDINITIAL` - Builds the object identifier with the
+  lowest index from the API, class, and MPCI node components.
2.26.2
