GMP is now a required dependency for building GDB
Sebastian Huber
Wed Dec 2 08:56:28 UTC 2020
Hello Chris,
On 19/11/2020 09:52, Sebastian Huber wrote:
> On 19/11/2020 09:33, Sebastian Huber wrote:
>> On 17/11/2020 14:49, Joel Sherrill wrote:
>>> The GMP library is not available by default on FreeBSD systems.
>>> For GCC
>>> we include a fixed version and build it together with GCC. What
>>> should
>>> be do for GDB?
>>> I would lean to including the same version in GDB that we do in GCC.
>>> Is this like gcc in that if they find it in the source tree, they
>>> will use it?
>> Ok, I will try this approach.
> This didn't work. I guess we need to to something similar to libexpat.
what would be your approach to build the latest GDB on FreeBSD?
embedded brains GmbH
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
email: sebastian.hubere at embedded-brains.de
phone: +49-89-18 94 741 - 16
fax: +49-89-18 94 741 - 08
Registernummer: HRB 157899
