[PATCH] updated python section
Robin Mueller
robin.mueller.m at gmail.com
Wed Dec 2 10:49:33 UTC 2020
user/hosts/windows.rst | 12 ++++++++++++
1 file changed, 12 insertions(+)
diff --git a/user/hosts/windows.rst b/user/hosts/windows.rst
index fac1366..ca8026d 100644
--- a/user/hosts/windows.rst
+++ b/user/hosts/windows.rst
@@ -126,6 +126,18 @@ Python2 package. The MSYS Python is version 3 and the RSB can support version 2
and 3 of Python and it helps handle some of the long paths building GCC can
generate.
+If the following error occurs during a build process
+.. code-block:: none
+ LookupError: unknown encoding: cp65001
+it is recommended to run the following command:
+ export PYTHONIOENCODING=UTF-8
.. _microsoft-windows-installation:
MSYS2
2.29.2
