[PATCH] doc improvements
Robin Müller
robin.mueller.m at gmail.com
Wed Dec 2 12:48:11 UTC 2020
[PATCH] doc improvements is related to ticket
https://devel.rtems.org/ticket/4187 which can then be closed
On Wed, 2 Dec 2020 at 13:46, Robin Mueller <robin.mueller.m at gmail.com>
wrote:
> user/start/sources.rst | 9 +++++++++
> user/start/tools.rst | 9 ++++++++-
> 2 files changed, 17 insertions(+), 1 deletion(-)
> diff --git a/user/start/sources.rst b/user/start/sources.rst
> index 8c40aa0..fddc439 100644
> --- a/user/start/sources.rst
> +++ b/user/start/sources.rst
> @@ -86,12 +86,21 @@ You can clone the Git repository to get all versions
> of RTEMS including the
> development head. Release branches in Git are kept stable however they
> may
> differ from a release's source archive.
> +For this Quick Start guide, we will switch to the RTEMS 5 branches
> because the
> +master branch does not contain the version 5 `rtems-sparc` build set.
> +If you wich to build with the master branch instead, it is recommended to
> +replace the version number 5 with version 6 everywhere it is used in the
> Quick Start guide.
> .. code-block:: none
> mkdir -p $HOME/quick-start/src
> cd $HOME/quick-start/src
> git clone git://git.rtems.org/rtems-source-builder.git rsb
> + git checkout origin/5
> + git checkout -b 5
> git clone git://git.rtems.org/rtems.git
> + git checkout -b 5
> The :file:`rsb` repository clone contains the :ref:`RTEMS Source Builder
> (RSB)
> <RSB>`. We clone it into :file:`rsb` to get shorter paths during the tool
> diff --git a/user/start/tools.rst b/user/start/tools.rst
> index baa2387..e0fe10d 100644
> --- a/user/start/tools.rst
> +++ b/user/start/tools.rst
> @@ -20,7 +20,14 @@ The tool suite for RTEMS and the RTEMS sources are
> tightly coupled. For
> example, do not use a RTEMS version 5 tool suite with RTEMS version 4.11
> sources and vice versa.
> -Build and install the tool suite:
> +The available build sets can be displayed with:
> +.. code-block:: none
> + cd $HOME/quick-start/src/rsb/rtems
> + ../source-builder/sb-set-builder --list-bsets
> +Build and install the version 5 tool suite for the SPARC architecture:
> 2.29.2
URL: <http://lists.rtems.org/pipermail/devel/attachments/20201202/652c2ffa/attachment.html>
