[PATCH 0/1] Add yaml format to the supported report formats
clrrm at isep.ipp.pt
Wed Dec 2 16:05:14 UTC 2020
Two output formats were supported by RTEMS Tester: json and junit.
This patch adds yaml to the list of supported formats.
The information being stored in the ouput file is the same as the one being
stored for the other formats, with the addition of adding a few more execution
details, such as the output of each test and the "debugger" output.
The feature can be used in the same manner as the other report formats, by
using "--report-format=yaml --report-path=name-of-report".
The patch was tested using leon3 bsp and SIS.
Cláudio Maia (1):
tester/rt/test.py | 104 +++++++++++++++++++++++++++++++++++++++++++++-
1 file changed, 102 insertions(+), 2 deletions(-)
2.17.1
