CAN user space API for RTEMS
Gedare Bloom
gedare at rtems.org
Wed Dec 2 17:00:28 UTC 2020
Hello Jan,
There are some interested parties in CAN for RTEMS (but mostly of the
volunteer type). Have a look at Pavel's message from March this year:
https://lists.rtems.org/pipermail/devel/2020-March/058161.html
Gedare
On Wed, Dec 2, 2020 at 8:41 AM <Jan.Sommer at dlr.de> wrote:
> Hello,
> We have some upcoming projects which will use RTEMS and will require CAN.
> RTEMS doesn't have a CAN user interface and as far as I can see there is
> also no such thing in FreeBSD (please correct me if I'm wrong) which we
> could take in via rtems-libbsd.
> Now, our options are to just use keep everything internal and use some
> custom driver (maybe based on some micro controller implementations) or
> contribute some kind of CAN subsystem to RTEMS.
> I find the latter option more appealing, but then the question would be if
> we can use an API known from somewhere else like for spi and i2c and there
> doesn't seem to be a lot of choices:
> - SocketCan --> seems to be too much work to implement in RTEMS (would
> probably need a socket implementation as well). I found some discussions
> about an implementation for FreeBSD, but it seems to have died.
> - Can4Linux: Seems to be still maintained, the header file seems to be
> licensed under 3-Clause BSD. Is uses chardev, so it is probably reasonably
> easy to implement similar to spidev.
> Would there be any interest in having a can4linux implementation in RTEMS?
> Or are there other/better available APIs?
> Best regards,
> Jan
> Deutsches Zentrum für Luft- und Raumfahrt e. V. (DLR)
> German Aerospace Center
> Institute for Software Technology | Software for Space Systems and
> Interactive Visualization | Lilienthalplatz 7 | 38108 Braunschweig | Germany
> Jan Sommer
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20201202/f89652c9/attachment-0001.html>
