[PATCH] rtems: Generate <rtems/rtems/timer.h>
Wed Dec 2 17:42:03 UTC 2020
Looks good to me.
On Wed, Dec 2, 2020 at 1:26 AM Sebastian Huber <
> Change license to BSD-2-Clause according to file histories and
> documentation re-licensing agreement.
> Update #3899.
> Update #3993.
>  cpukit/include/rtems/rtems/timer.h | 705 ++++++++++++++++++++---------
>  1 file changed, 494 insertions(+), 211 deletions(-)
> diff --git a/cpukit/include/rtems/rtems/timer.h
> b/cpukit/include/rtems/rtems/timer.h
> index 244d5603ba..3d454e39ec 100644
> --- a/cpukit/include/rtems/rtems/timer.h
> +++ b/cpukit/include/rtems/rtems/timer.h
> @@ -1,289 +1,493 @@
> +/* SPDX-License-Identifier: BSD-2-Clause */
>   * @file
> - * @ingroup ClassicTimer
> + * @ingroup RTEMSImplClassicTimer
> - * @brief Classic Timer Manager API
> + * @brief This header file provides the Timer Manager API.
> + * Copyright (C) 2020 embedded brains GmbH (http://www.embedded-brains.de
> + * Copyright (C) 1988, 2008 On-Line Applications Research Corporation
> (OAR)
> + * Redistribution and use in source and binary forms, with or without
> + * modification, are permitted provided that the following conditions
> + * are met:
> + * 1. Redistributions of source code must retain the above copyright
> + *    notice, this list of conditions and the following disclaimer.
> + * 2. Redistributions in binary form must reproduce the above copyright
> + *    notice, this list of conditions and the following disclaimer in the
> + *    documentation and/or other materials provided with the distribution.
> + * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
> "AS IS"
> + * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO,
> THE
> + * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR
> PURPOSE
> + * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS
> BE
> + * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
> + * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
> + * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR
> BUSINESS
> + * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
> + * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
> + * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF
> THE
> + * POSSIBILITY OF SUCH DAMAGE.
> - * COPYRIGHT (c) 1989-2011.
> - * On-Line Applications Research Corporation (OAR).
> + * This file is part of the RTEMS quality process and was automatically
> + * generated.  If you find something that needs to be fixed or
> + * worded better please post a report or patch to an RTEMS mailing list
> + * or raise a bug report:
> + * https://docs.rtems.org/branches/master/user/support/bugs.html
> - * Copyright (c) 2009, 2016 embedded brains GmbH.
> + * For information on updating and regenerating please refer to:
> - * The license and distribution terms for this file may be
> - * found in the file LICENSE in this distribution or at
> - * http://www.rtems.org/license/LICENSE.
> + * https://docs.rtems.org/branches/master/eng/req/howto.html
> +/* Generated from spec:/rtems/timer/if/header */
>  #ifndef _RTEMS_RTEMS_TIMER_H
>  #define _RTEMS_RTEMS_TIMER_H
> +#include <stddef.h>
>  #include <rtems/rtems/attr.h>
>  #include <rtems/rtems/status.h>
>  #include <rtems/rtems/tasks.h>
>  #include <rtems/rtems/types.h>
> +#include <rtems/score/watchdogticks.h>
>  #ifdef __cplusplus
>  extern "C" {
>  #endif
> +/* Generated from spec:/rtems/timer/if/group */
> - *  @defgroup ClassicTimer Timers
> + * @defgroup RTEMSAPIClassicTimer Timer Manager
> - *  @ingroup RTEMSAPIClassic
> + * @ingroup RTEMSAPIClassic
> - *  This encapsulates functionality related to the Classic API Timer
> - *  Manager.  This manager provides functionality which allows the
> - *  application to schedule the execution of methods at a specified
> - *  time in the future.  These methods may be scheduled based upon
> - *  interval or wall time and may be executed in either the clock tick
> - *  ISR or in a special dedicated timer server task.
> + * @brief The Timer Manager provides support for timer facilities.
> -#define TIMER_CLASS_BIT_TIME_OF_DAY 0x1
> +/* Generated from spec:/rtems/timer/if/class-bit-not-dormant */
> + * @ingroup RTEMSAPIClassicTimer
> + * @brief This timer class bit indicates that the timer is not dormant.
> +#define TIMER_CLASS_BIT_NOT_DORMANT 0x4
> +/* Generated from spec:/rtems/timer/if/class-bit-on-task */
> + * @brief This timer class bit indicates that the timer routine executes
> in a
> + *   task context.
>  #define TIMER_CLASS_BIT_ON_TASK 0x2
> -#define TIMER_CLASS_BIT_NOT_DORMANT 0x4
> +/* Generated from spec:/rtems/timer/if/class-bit-time-of-day */
> + * @brief This timer class bit indicates that the timer uses a time of
> day.
> +#define TIMER_CLASS_BIT_TIME_OF_DAY 0x1
> +/* Generated from spec:/rtems/timer/if/classes */
> - *  The following enumerated type details the classes to which a timer
> - *  may belong.
> + * @brief The timer class indicates how the timer was most recently fired.
>  typedef enum {
> -   * This value indicates the timer is currently not in use.
> +   * @brief This timer class indicates that the timer was never in use.
>    TIMER_DORMANT,
> -   * This value indicates the timer is currently in use as an interval
> -   * timer which will fire in the clock tick ISR.
> +   * @brief This timer class indicates that the timer is currently in use
> as an
> +   *   interval timer which will fire in the context of the clock tick
> ISR.
>    TIMER_INTERVAL = TIMER_CLASS_BIT_NOT_DORMANT,
> -   * timer which will fire in the timer server task.
> as an
> +   *   interval timer which will fire in the context of the Timer Server
> task.
> -  TIMER_INTERVAL_ON_TASK =
> -    TIMER_CLASS_BIT_NOT_DORMANT | TIMER_CLASS_BIT_ON_TASK,
> +  TIMER_INTERVAL_ON_TASK = TIMER_CLASS_BIT_NOT_DORMANT |
> +    TIMER_CLASS_BIT_ON_TASK,
> -   * This value indicates the timer is currently in use as an time of day
> as an
> +   *   time of day timer which will fire in the context of the clock tick
> ISR.
> -  TIMER_TIME_OF_DAY =
> -    TIMER_CLASS_BIT_NOT_DORMANT | TIMER_CLASS_BIT_TIME_OF_DAY,
> +  TIMER_TIME_OF_DAY = TIMER_CLASS_BIT_NOT_DORMANT |
> +    TIMER_CLASS_BIT_TIME_OF_DAY,
> as an
> +   *   time of day timer which will fire in the context of the Timer
> Server task.
> -  TIMER_TIME_OF_DAY_ON_TASK =
> -    TIMER_CLASS_BIT_NOT_DORMANT | TIMER_CLASS_BIT_TIME_OF_DAY |
> +  TIMER_TIME_OF_DAY_ON_TASK = TIMER_CLASS_BIT_NOT_DORMANT |
> +    TIMER_CLASS_BIT_TIME_OF_DAY |
>  } Timer_Classes;
> - *  The following types define a pointer to a timer service routine.
> -typedef void rtems_timer_service_routine;
> +/* Generated from spec:/rtems/timer/if/information */
> - *  This type defines the type used to manage and indirectly invoke
> - *  Timer Service Routines (TSRs).  This defines the prototype and
> interface
> - *  for a function which is to be used as a TSR.
> + * @brief The structure contains information about a timer.
> -typedef rtems_timer_service_routine ( *rtems_timer_service_routine_entry
> -                 rtems_id,
> -                 void *
> +typedef struct {
> +   * @brief The timer class member indicates how the timer was most
> recently
> +   *   fired.
> +  Timer_Classes the_class;
> +   * @brief This member indicates the initial requested interval.
> +  Watchdog_Interval initial;
> +   * @brief This member indicates the time the timer was initially
> scheduled.
> +   * The time is in clock ticks since the clock driver initialization or
> the last
> +   * clock tick counter overflow.
> +  Watchdog_Interval start_time;
> +   * @brief This member indicates the time the timer was scheduled to
> fire.
> the last
> +  Watchdog_Interval stop_time;
> +} rtems_timer_information;
> +/* Generated from spec:/rtems/timer/if/get-information */
> - * @brief RTEMS Create Timer
> + * @brief Gets information about the timer.
> + * This directive returns information about the timer.
> + * This directive will not cause the running task to be preempted.
> + * @param id is the timer identifier.
> - * This routine implements the rtems_timer_create directive. The
> - * timer will have the name name. It returns the id of the
> - * created timer in ID.
> + * @param[out] the_info is the pointer to a timer information variable.
> The
> + *   information about the timer will be stored in this variable, in case
> of a
> + *   successful operation.
> - * @param[in] name is the timer name
> - * @param[out] id is the pointer to timer id
> + * @retval ::RTEMS_SUCCESSFUL The requested operation was successful.
> - * @retval RTEMS_SUCCESSFUL if successful or error code if unsuccessful
> + * @retval ::RTEMS_INVALID_ADDRESS The ``the_info`` parameter was NULL.
> + * @retval ::RTEMS_INVALID_ID There was no timer associated with the
> identifier
> + *   specified by ``id``.
> -rtems_status_code rtems_timer_create(
> -  rtems_name    name,
> -  rtems_id     *id
> +rtems_status_code rtems_timer_get_information(
> +  rtems_id                 id,
> +  rtems_timer_information *the_info
> +/* Generated from spec:/rtems/timer/if/server-default-priority */
> - * @brief RTEMS Timer Name to Id
> + * @brief This constant represents the default value for the task
> priority of
> + *   the Timer Server.
> - * This routine implements the rtems_timer_ident directive.
> - * This directive returns the timer ID associated with name.
> - * If more than one timer is named name, then the timer
> - * to which the ID belongs is arbitrary.
> + * When given this priority, a special high priority not accessible via
> the
> + * Classic API is used.
> +#define RTEMS_TIMER_SERVER_DEFAULT_PRIORITY ( (rtems_task_priority) -1 )
> +/* Generated from spec:/rtems/timer/if/service-routine */
> - * @param[in] name is the user defined message queue name
> - * @param[in] id is the pointer to timer id
> + * @brief This type defines the return type of routines which can be
> fired by
> + *   directives of the Timer Manager.
> and
> - * id filled with the message queue id
> + * This type can be used to document timer service routines in the source
> code.
> -rtems_status_code rtems_timer_ident(
> -  rtems_name    name,
> -  rtems_id     *id
> +typedef void rtems_timer_service_routine;
> +/* Generated from spec:/rtems/timer/if/service-routine-entry */
> - *  @brief rtems_timer_cancel
> - *  This routine implements the rtems_timer_cancel directive.  It is used
> - *  to stop the timer associated with ID from firing.
> + * @brief This type defines the prototype of routines which can be fired
> by
> -rtems_status_code rtems_timer_cancel(
> -  rtems_id   id
> +typedef rtems_timer_service_routine ( *rtems_timer_service_routine_entry
> )( rtems_id, void * );
> +/* Generated from spec:/rtems/timer/if/create */
> - * @brief RTEMS Delete Timer
> + * @brief Creates a timer.
> + * This directive creates a timer.  The assigned object identifier is
> returned
> + * in ``id``.  This identifier is used to access the timer with other
> timer
> + * related directives.
> + * This directive may cause the calling task to be preempted due to an
> obtain
> + * and release of the object allocator mutex.
> - * This routine implements the rtems_timer_delete directive. The
> - * timer indicated by ID is deleted.
> + * For control and maintenance of the timer, RTEMS allocates a TMCB from
> the
+ * local TMCB free pool and initializes it.
> - * @param[in] id is the timer id
> + * In SMP configurations, the processor of the currently executing thread
> + * determines the processor used for the created timer.  During the
> life-time
> + * of the timer this processor is used to manage the timer internally.
> - * @retval This method returns RTEMS_SUCCESSFUL if there was not an
> - *         error. Otherwise, a status code is returned indicating the
> - *         source of the error.
> + * @param name is the name of the timer.
> + * @param[out] id is the pointer to an object identifier variable.  The
> + *   identifier of the created timer object will be stored in this
> variable, in
> + *   case of a successful operation.
> + * @retval ::RTEMS_INVALID_NAME The timer name was invalid.
> + * @retval ::RTEMS_INVALID_ADDRESS The ``id`` parameter was NULL.
> + * @retval ::RTEMS_TOO_MANY There was no inactive object available to
> create a
> + *   new timer.  The number of timers available to the application is
> + *   configured through the #CONFIGURE_MAXIMUM_TIMERS configuration
> option.
> -rtems_status_code rtems_timer_delete(
> -  rtems_id   id
> +rtems_status_code rtems_timer_create( rtems_name name, rtems_id *id );
> +/* Generated from spec:/rtems/timer/if/ident */
> - * @brief RTEMS Timer Fire After
> - * This routine implements the rtems_timer_fire_after directive. It
> - * initiates the timer associated with ID to fire in ticks clock ticks.
> - * When the timer fires, the routine will be invoked in the context
> - * of the rtems_clock_tick directive which is normally invoked as
> - * part of servicing a periodic interupt.
> - * @param[in] ticks is the interval until routine is fired
> - * @param[in] routine is the routine to schedule
> - * @param[in] user_data is the passed as argument to routine when it is
> fired
> + * @brief Identifies a timer by the object name.
> + * This directive obtains the timer identifier associated with the timer
> name
> + * specified in ``name``.
> + * If the timer name is not unique, then the timer identifier will match
> the
> + * first timer with that name in the search order.  However, this timer
> + * identifier is not guaranteed to correspond to the desired timer.  The
> timer
> + * identifier is used with other timer related directives to access the
> timer.
> + * The objects are searched from lowest to the highest index.  Only the
> local
> + * node is searched.
> + * @param name is the object name to look up.
> object
> + *   identifier of an object with the specified name will be stored in
> this
> + *   variable, in case of a successful operation.
> + * @retval ::RTEMS_INVALID_NAME The ``name`` parameter was 0.
> + * @retval ::RTEMS_INVALID_NAME There was no object with the specified
> name on
> + *   the local node.
> -rtems_status_code rtems_timer_fire_after(
> -  rtems_id                           id,
> -  rtems_interval                     ticks,
> -  rtems_timer_service_routine_entry  routine,
> -  void                              *user_data
> +rtems_status_code rtems_timer_ident( rtems_name name, rtems_id *id );
> +/* Generated from spec:/rtems/timer/if/cancel */
> - * @brief RTEMS Timer Server Fire After
> - * This routine implements the rtems_timer_server_fire_after directive. It
> - * ticks. When the timer fires, the routine will be invoked by the
> - * Timer Server in the context of a task NOT IN THE CONTEXT of the
> - * clock tick interrupt.
> fired
> + * @brief Cancels the timer.
> + * This directive cancels the timer specified in the ``id`` parameter.
> This
> + * timer will be reinitiated by the next invocation of
> rtems_timer_reset(),
> + * rtems_timer_fire_after(), or rtems_timer_fire_when() with the same
> timer
> + * identifier.
> identifier
> -rtems_status_code rtems_timer_server_fire_after(
> -  rtems_id                           id,
> -  void                              *user_data
> +rtems_status_code rtems_timer_cancel( rtems_id id );
> +/* Generated from spec:/rtems/timer/if/delete */
> - * @brief RTEMS Timer Fire When
> - * This routine implements the rtems_timer_fire_when directive. It
> - * initiates the timer associated with ID to fire at wall_time
> - * @param[in] wall_time is the time of day to fire timer
> fired
> + * @brief Deletes the timer.
> + * This directive deletes the timer specified by the ``id`` parameter.
> If the
> + * timer is running, it is automatically canceled.
> obtain
> + * The TMCB for the deleted timer is reclaimed by RTEMS.
> + * A timer can be deleted by a task other than the task which created the
> + * timer.
> identifier
> -rtems_status_code rtems_timer_fire_when(
> -  rtems_id                            id,
> -  rtems_time_of_day                  *wall_time,
> -  void                               *user_data
> +rtems_status_code rtems_timer_delete( rtems_id id );
> +/* Generated from spec:/rtems/timer/if/fire-after */
> - *  @brief RTEMS Timer Server Fire When Directive
> + * @brief Fires the timer after the interval.
> - *  Timer Manager - RTEMS Timer Server Fire When Directive
> + * This directive initiates the timer specified by ``id``.  If the timer
> is
> + * running, it is automatically canceled before being initiated.  The
> timer is
> + * scheduled to fire after an interval of clock ticks has passed
> specified by
> + * ``ticks``.  When the timer fires, the timer service routine
> ``routine`` will
> + * be invoked with the argument ``user_data`` in the context of the clock
> tick
> + * ISR.
> - *  This routine implements the rtems_timer_server_fire_when directive.
> It
> - *  When the timer fires, the routine will be invoked by the
> + * @param ticks is the interval until the routine is fired in clock ticks.
> + * @param routine is the routine to schedule.
> + * @param user_data is the argument passed to the routine when it is
> fired.
> + * @retval ::RTEMS_INVALID_NUMBER The ``ticks`` parameter was 0.
> + * @retval ::RTEMS_INVALID_ADDRESS The ``routine`` parameter was NULL.
> identifier
> -rtems_status_code rtems_timer_server_fire_when(
> -  rtems_id                            id,
> -  void                               *user_data
> +rtems_status_code rtems_timer_fire_after(
> +  rtems_id                          id,
> +  rtems_interval                    ticks,
> +  rtems_timer_service_routine_entry routine,
> +  void                             *user_data
> +/* Generated from spec:/rtems/timer/if/fire-when */
> - *  @brief RTEMS Timer Reset
> + * @brief Fires the timer at the time of day.
> - *  Timer Manager - RTEMS Timer Reset
> is
> timer is
> + * scheduled to fire at the time of day specified by ``wall_time``.  When
> the
> + * timer fires, the timer service routine ``routine`` will be invoked
> with the
> + * argument ``user_data`` in the context of the clock tick ISR.
> - *  This routine implements the rtems_timer_reset directive.  It is used
> - *  to reinitialize the interval timer associated with ID just as if
> - *  rtems_timer_fire_after were re-invoked with the same arguments that
> - *  were used to initiate this timer.
> + * @param wall_time is the time of day when the routine is fired.
> fired.
> + * @retval ::RTEMS_NOT_DEFINED The system date and time was not set.
> + * @retval ::RTEMS_INVALID_ADDRESS The ``wall_time`` parameter was NULL.
> + * @retval ::RTEMS_INVALID_CLOCK The time of day was invalid.
> identifier
> -rtems_status_code rtems_timer_reset(
> -  rtems_id   id
> +rtems_status_code rtems_timer_fire_when(
> +  rtems_id                          id,
> +  rtems_time_of_day                *wall_time,
> +  void                             *user_data
> +/* Generated from spec:/rtems/timer/if/initiate-server */
> - *  @brief Initiates the timer server.
> - *  This directive creates and starts the server for task-based timers.
> - *  It must be invoked before any task-based timers can be initiated.
> + * @brief Initiates the Timer Server.
> - *  @param priority The timer server task priority.
> - *  @param stack_size The stack size in bytes for the timer server task.
> - *  @param attribute_set The timer server task attributes.
> + * This directive initiates the Timer Server task.  This task is
> responsible
> + * for executing all timers initiated via the
> rtems_timer_server_fire_after()
> + * or rtems_timer_server_fire_when() directives.
> - *  @return This method returns RTEMS_SUCCESSFUL if successful and an
> - *          error code otherwise.
> obtain
> + * The Timer Server task is created using the rtems_task_create()
> directive and
> + * must be accounted for when configuring the system.
> + * @param priority is the task priority.
> + * @param stack_size is the task stack size in bytes.
> + * @param attribute_set is the task attribute set.
> + * @retval ::RTEMS_INCORRECT_STATE The Timer Server was already initiated.
> + * @retval ::RTEMS_INVALID_PRIORITY The task priority was invalid.
> + * @retval ::RTEMS_TOO_MANY There was no inactive task object available to
> + *   create the Timer Server task.
> + * @retval ::RTEMS_UNSATISFIED There was not enough memory to allocate
> the task
> + *   storage area.  The task storage area contains the task stack, the
> + *   thread-local storage, and the floating point context.
> + * @retval ::RTEMS_UNSATISFIED One of the task create extensions failed to
>  rtems_status_code rtems_timer_initiate_server(
>    rtems_task_priority priority,
> @@ -291,50 +495,129 @@ rtems_status_code rtems_timer_initiate_server(
>    rtems_attribute     attribute_set
> - *  This is the default value for the priority of the Timer Server.
> - *  When given this priority, a special high priority not accessible
> - *  via the Classic API is used.
> -#define RTEMS_TIMER_SERVER_DEFAULT_PRIORITY (uint32_t) -1
> +/* Generated from spec:/rtems/timer/if/server-fire-after */
> - *  This is the structure filled in by the timer get information
> - *  service.
> + * @brief Fires the timer after the interval using the Timer Server.
> is
> timer is
> specified by
> ``routine`` will
> + * be invoked with the argument ``user_data`` in the context of the Timer
> + * Server task.
> fired.
> + * @retval ::RTEMS_INCORRECT_STATE The Timer Server was not initiated.
> identifier
> -typedef struct {
> -  /** This indicates the current type of the timer. */
> -  Timer_Classes      the_class;
> -  /** This indicates the initial requested interval. */
> -  Watchdog_Interval  initial;
> -  /** This indicates the time the timer was initially scheduled. */
> -  Watchdog_Interval  start_time;
> -  /** This indicates the time the timer is scheduled to fire. */
> -  Watchdog_Interval  stop_time;
> -} rtems_timer_information;
> +rtems_status_code rtems_timer_server_fire_after(
> +  rtems_id                          id,
> +  void                             *user_data
> +/* Generated from spec:/rtems/timer/if/server-fire-when */
> - * @brief RTEMS Get Timer Information
> - * This routine implements the rtems_timer_get_information directive.
> - * This directive returns information about the timer.
> + * @brief Fires the timer at the time of day using the Timer Server.
> is
> timer is
> the
> with the
> + * argument ``user_data`` in the context of the Timer Server task.
> - * @param[in] the_info is the pointer to timer information block
> fired.
> and
> - *             *the_info region information block filled in
> identifier
> -rtems_status_code rtems_timer_get_information(
> -  rtems_id                 id,
> -  rtems_timer_information *the_info
> +rtems_status_code rtems_timer_server_fire_when(
> +  rtems_id                          id,
> +  void                             *user_data
> +/* Generated from spec:/rtems/timer/if/reset */
> + * @brief Resets the timer.
> + * This directive resets the timer specified by ``id``.  This timer must
> have
> + * been previously initiated with either the rtems_timer_fire_after() or
> + * rtems_timer_server_fire_after() directive.  If active the timer is
> canceled,
> + * after which the timer is reinitiated using the same interval and timer
> + * service routine which the original rtems_timer_fire_after() or
> + * rtems_timer_server_fire_after() directive used.
> + * If the timer has not been used or the last usage of this timer was by a
> + * rtems_timer_fire_when() or rtems_timer_server_fire_when() directive,
> then
> + * the ::RTEMS_NOT_DEFINED error is returned.
> + * Restarting a cancelled after timer results in the timer being
> reinitiated
> + * with its previous timer service routine and interval.
> identifier
> + * @retval ::RTEMS_NOT_DEFINED The timer was not of the interval class.
> +rtems_status_code rtems_timer_reset( rtems_id id );
>  #ifdef __cplusplus
>  #endif
> -#endif
> -/* end of include file */
> +#endif /* _RTEMS_RTEMS_TIMER_H */
> 2.26.2
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20201202/2e59ad0e/attachment-0001.html>
