[PATCH v2 2/4] samples/unlimited: Prevent compile error
Kinsey Moore
kinsey.moore at oarcorp.com
Thu Dec 3 01:12:23 UTC 2020
For architectures with relatively large minimum stack sizes, ensure that
the init task stack size is at least the minimum stack size to prevent a
configuration error during compilation.
testsuites/samples/unlimited/system.h | 3 ++-
1 file changed, 2 insertions(+), 1 deletion(-)
diff --git a/testsuites/samples/unlimited/system.h b/testsuites/samples/unlimited/system.h
index 2624a696df..dafbf9f92e 100644
--- a/testsuites/samples/unlimited/system.h
+++ b/testsuites/samples/unlimited/system.h
@@ -12,6 +12,7 @@
+#include <sys/param.h>
/* functions */
@@ -50,7 +51,7 @@ extern void test3(void);
#define TASK_ALLOCATION_SIZE (5)
#define CONFIGURE_UNLIMITED_OBJECTS
#define CONFIGURE_UNLIMITED_ALLOCATION_SIZE TASK_ALLOCATION_SIZE
-#define CONFIGURE_INIT_TASK_STACK_SIZE (8 * 1024)
+#define CONFIGURE_INIT_TASK_STACK_SIZE MAX(8 * 1024, CONFIGURE_MINIMUM_TASK_STACK_SIZE)
#include <rtems/confdefs.h>
2.20.1
