[PATCH v3] samples/unlimited: Prevent compile error
Kinsey Moore kinsey.moore at oarcorp.com
Thu Dec 3 15:24:24 UTC 2020
For architectures with relatively large minimum stack sizes, this test
breaks during compilation due to a static check. The init task stack
size should not need to be set for this test.
 testsuites/samples/unlimited/system.h | 1 -
 1 file changed, 1 deletion(-)
diff --git a/testsuites/samples/unlimited/system.h b/testsuites/samples/unlimited/system.h
index 2624a696df..4138b658fe 100644
--- a/testsuites/samples/unlimited/system.h
+++ b/testsuites/samples/unlimited/system.h
@@ -50,7 +50,6 @@ extern void test3(void);
 #define TASK_ALLOCATION_SIZE     (5)
 #define CONFIGURE_UNLIMITED_OBJECTS
 #define CONFIGURE_UNLIMITED_ALLOCATION_SIZE TASK_ALLOCATION_SIZE
-#define CONFIGURE_INIT_TASK_STACK_SIZE (8 * 1024)
 #include <rtems/confdefs.h>
2.20.1
