[PATCH rtems] bsps/imxrt: Split up dts.
Christian Mauderer
christian.mauderer at embedded-brains.de
Fri Dec 4 09:07:24 UTC 2020
This allows simpler creation of own dts files for custom boards.
Update #4180
bsps/arm/imxrt/dts/imxrt1050-evkb.dts | 287 +-----------------
bsps/arm/imxrt/include/imxrt/imxrt1050.dtsi | 309 ++++++++++++++++++++
spec/build/bsps/arm/imxrt/bspimxrt.yml | 1 +
3 files changed, 312 insertions(+), 285 deletions(-)
create mode 100644 bsps/arm/imxrt/include/imxrt/imxrt1050.dtsi
diff --git a/bsps/arm/imxrt/dts/imxrt1050-evkb.dts b/bsps/arm/imxrt/dts/imxrt1050-evkb.dts
index 968ca1dbdc..8b2c571bba 100644
--- a/bsps/arm/imxrt/dts/imxrt1050-evkb.dts
+++ b/bsps/arm/imxrt/dts/imxrt1050-evkb.dts
@@ -34,293 +34,10 @@
* rtems-bin2c -C -N imxrt_dtb "${BSP_DIR}/dts/imxrt1050-evkb.dtb" "${BSP_DIR}/dts/imxrt1050-evkb.c"
-#include <imxrt/imxrt1050-pinfunc.h>
/dts-v1/;
- #address-cells = <1>;
- #size-cells = <1>;
- chosen: chosen {};
- aliases {
- gpio0 = &gpio1;
- gpio1 = &gpio2;
- gpio2 = &gpio3;
- gpio3 = &gpio4;
- gpio4 = &gpio5;
- nvic: interrupt-controller at e000e100 {
- compatible = "arm,armv7m-nvic";
- interrupt-controller;
- #interrupt-cells = <1>;
- reg = <0xe000e100 0xc00>;
- systick: timer at e000e010 {
- compatible = "arm,armv7m-systick";
- reg = <0xe000e010 0x10>;
- status = "disabled";
- soc {
- compatible = "simple-bus";
- interrupt-parent = <&nvic>;
- ranges;
- aips-bus at 40000000 {
- compatible = "fsl,aips-bus", "simple-bus";
- reg = <0x40000000 0x00100000>;
- ranges;
- gpio5: gpio at 400c0000 {
- compatible = "fsl,imxrt-gpio",
- "fsl,imx6ul-gpio", "fsl,imx35-gpio";
- reg = <0x400c0000 0x4000>;
- interrupts = <88>, <89>;
- gpio-controller;
- #gpio-cells = <2>;
- #interrupt-cells = <2>;
- aips-bus at 40100000 {
- reg = <0x40100000 0x00100000>;
- ranges;
- gpio4: gpio at 401c4000 {
- reg = <0x401c4000 0x4000>;
- interrupts = <86>, <87>;
- gpio-controller;
- gpio3: gpio at 401c0000 {
- reg = <0x401c0000 0x4000>;
- interrupts = <84>, <85>;
- gpio-controller;
- gpio2: gpio at 401bc000 {
- reg = <0x401bc000 0x4000>;
- interrupts = <82>, <83>;
- gpio-controller;
- gpio1: gpio at 401b8000 {
- reg = <0x401b8000 0x4000>;
- interrupts = <80>, <81>, <72>, <73>, <74>,
- <75>, <76>, <77>, <78>, <79>;
- gpio-controller;
- lpuart1: uart at 40184000 {
- compatible = "nxp,imxrt-lpuart";
- reg = <0x40184000 0x4000>;
- interrupts = <20>;
- rtems,path = "/dev/ttyS1";
- lpuart2: uart at 40188000 {
- reg = <0x40188000 0x4000>;
- interrupts = <21>;
- rtems,path = "/dev/ttyS2";
- lpuart3: uart at 4018c000 {
- reg = <0x4018c000 0x4000>;
- interrupts = <22>;
- rtems,path = "/dev/ttyS3";
- lpuart4: uart at 40190000 {
- reg = <0x40190000 0x4000>;
- interrupts = <23>;
- rtems,path = "/dev/ttyS4";
- lpuart5: uart at 40194000 {
- reg = <0x40194000 0x4000>;
- interrupts = <24>;
- rtems,path = "/dev/ttyS5";
- lpuart6: uart at 40198000 {
- reg = <0x40198000 0x4000>;
- interrupts = <25>;
- rtems,path = "/dev/ttyS6";
- lpuart7: uart at 4019c000 {
- reg = <0x4019c000 0x4000>;
- interrupts = <26>;
- rtems,path = "/dev/ttyS7";
- lpuart8: uart at 401a0000 {
- reg = <0x401a0000 0x4000>;
- interrupts = <27>;
- rtems,path = "/dev/ttyS8";
- iomuxc: pinctrl at 401f8000 {
- compatible = "nxp,imxrt1050-iomuxc";
- reg = <0x401f8000 0x4000>;
- aips-bus at 40200000 {
- reg = <0x40200000 0x00100000>;
- ranges;
- fec1: ethernet at 402d8000 {
- compatible = "fsl,imxrt-fec", "fsl,imx6ul-fec";
- reg = <0x402d8000 0x4000>;
- interrupt-names = "int0", "pps";
- interrupts = <114>, <115>;
- fsl,num-tx-queues = <1>;
- fsl,num-rx-queues = <1>;
- phy-mode = "rmii";
- aips-bus at 40300000 {
- reg = <0x40300000 0x00100000>;
- ranges;
- lpspi1: lpspi at 40394000 {
- #size-cells = <0>;
- compatible = "nxp,imxrt-lpspi";
- reg = <0x40394000 0x4000>;
- interrupts = <32>;
- rtems,path = "/dev/spi1";
- lpspi2: lpspi at 40398000 {
- reg = <0x40398000 0x4000>;
- interrupts = <33>;
- rtems,path = "/dev/spi2";
- lpspi3: lpspi at 4039c000 {
- reg = <0x4039c000 0x4000>;
- interrupts = <34>;
- rtems,path = "/dev/spi3";
- lpspi4: lpspi at 403a0000 {
- reg = <0x403a0000 0x4000>;
- interrupts = <35>;
- rtems,path = "/dev/spi4";
- lpi2c1: lpi2c at 403f0000 {
- compatible = "nxp,imxrt-lpi2c";
- reg = <0x403f0000 0x4000>;
- interrupts = <28>;
- rtems,path = "/dev/i2c1";
- lpi2c2: lpi2c at 403f4000 {
- reg = <0x403f4000 0x4000>;
- interrupts = <29>;
- rtems,path = "/dev/i2c2";
- lpi2c3: lpi2c at 403f8000 {
- reg = <0x403f8000 0x4000>;
- interrupts = <30>;
- rtems,path = "/dev/i2c3";
- lpi2c4: lpi2c at 403fc000 {
- reg = <0x403fc000 0x4000>;
- interrupts = <31>;
- rtems,path = "/dev/i2c4";
+#include <imxrt/imxrt1050-pinfunc.h>
+#include <imxrt/imxrt1050.dtsi>
&lpuart1 {
pinctrl-0 = <&pinctrl_lpuart1>;
diff --git a/bsps/arm/imxrt/include/imxrt/imxrt1050.dtsi b/bsps/arm/imxrt/include/imxrt/imxrt1050.dtsi
new file mode 100644
index 0000000000..ea55eff723
--- /dev/null
+++ b/bsps/arm/imxrt/include/imxrt/imxrt1050.dtsi
@@ -0,0 +1,309 @@
+ * Copyright (C) 2020 embedded brains GmbH (http://www.embedded-brains.de)
+ * are met:
+ * notice, this list of conditions and the following disclaimer.
+ * notice, this list of conditions and the following disclaimer in the
+ * documentation and/or other materials provided with the distribution.
+ #address-cells = <1>;
+ #size-cells = <1>;
+ chosen: chosen {};
+ aliases {
+ gpio0 = &gpio1;
+ gpio1 = &gpio2;
+ gpio2 = &gpio3;
+ gpio3 = &gpio4;
+ gpio4 = &gpio5;
+ nvic: interrupt-controller at e000e100 {
+ compatible = "arm,armv7m-nvic";
+ interrupt-controller;
+ #interrupt-cells = <1>;
+ reg = <0xe000e100 0xc00>;
+ systick: timer at e000e010 {
+ compatible = "arm,armv7m-systick";
+ reg = <0xe000e010 0x10>;
+ status = "disabled";
+ soc {
+ compatible = "simple-bus";
+ interrupt-parent = <&nvic>;
+ ranges;
+ aips-bus at 40000000 {
+ compatible = "fsl,aips-bus", "simple-bus";
+ reg = <0x40000000 0x00100000>;
+ ranges;
+ gpio5: gpio at 400c0000 {
+ compatible = "fsl,imxrt-gpio",
+ "fsl,imx6ul-gpio", "fsl,imx35-gpio";
+ reg = <0x400c0000 0x4000>;
+ interrupts = <88>, <89>;
+ gpio-controller;
+ #gpio-cells = <2>;
+ #interrupt-cells = <2>;
+ aips-bus at 40100000 {
+ reg = <0x40100000 0x00100000>;
+ ranges;
+ gpio4: gpio at 401c4000 {
+ reg = <0x401c4000 0x4000>;
+ interrupts = <86>, <87>;
+ gpio-controller;
+ gpio3: gpio at 401c0000 {
+ reg = <0x401c0000 0x4000>;
+ interrupts = <84>, <85>;
+ gpio-controller;
+ gpio2: gpio at 401bc000 {
+ reg = <0x401bc000 0x4000>;
+ interrupts = <82>, <83>;
+ gpio-controller;
+ gpio1: gpio at 401b8000 {
+ reg = <0x401b8000 0x4000>;
+ interrupts = <80>, <81>, <72>, <73>, <74>,
+ <75>, <76>, <77>, <78>, <79>;
+ gpio-controller;
+ lpuart1: uart at 40184000 {
+ compatible = "nxp,imxrt-lpuart";
+ reg = <0x40184000 0x4000>;
+ interrupts = <20>;
+ rtems,path = "/dev/ttyS1";
+ lpuart2: uart at 40188000 {
+ reg = <0x40188000 0x4000>;
+ interrupts = <21>;
+ rtems,path = "/dev/ttyS2";
+ lpuart3: uart at 4018c000 {
+ reg = <0x4018c000 0x4000>;
+ interrupts = <22>;
+ rtems,path = "/dev/ttyS3";
+ lpuart4: uart at 40190000 {
+ reg = <0x40190000 0x4000>;
+ interrupts = <23>;
+ rtems,path = "/dev/ttyS4";
+ lpuart5: uart at 40194000 {
+ reg = <0x40194000 0x4000>;
+ interrupts = <24>;
+ rtems,path = "/dev/ttyS5";
+ lpuart6: uart at 40198000 {
+ reg = <0x40198000 0x4000>;
+ interrupts = <25>;
+ rtems,path = "/dev/ttyS6";
+ lpuart7: uart at 4019c000 {
+ reg = <0x4019c000 0x4000>;
+ interrupts = <26>;
+ rtems,path = "/dev/ttyS7";
+ lpuart8: uart at 401a0000 {
+ reg = <0x401a0000 0x4000>;
+ interrupts = <27>;
+ rtems,path = "/dev/ttyS8";
+ iomuxc: pinctrl at 401f8000 {
+ compatible = "nxp,imxrt1050-iomuxc";
+ reg = <0x401f8000 0x4000>;
+ aips-bus at 40200000 {
+ reg = <0x40200000 0x00100000>;
+ ranges;
+ fec1: ethernet at 402d8000 {
+ compatible = "fsl,imxrt-fec", "fsl,imx6ul-fec";
+ reg = <0x402d8000 0x4000>;
+ interrupt-names = "int0", "pps";
+ interrupts = <114>, <115>;
+ fsl,num-tx-queues = <1>;
+ fsl,num-rx-queues = <1>;
+ phy-mode = "rmii";
+ aips-bus at 40300000 {
+ reg = <0x40300000 0x00100000>;
+ ranges;
+ lpspi1: lpspi at 40394000 {
+ #size-cells = <0>;
+ compatible = "nxp,imxrt-lpspi";
+ reg = <0x40394000 0x4000>;
+ interrupts = <32>;
+ rtems,path = "/dev/spi1";
+ lpspi2: lpspi at 40398000 {
+ reg = <0x40398000 0x4000>;
+ interrupts = <33>;
+ rtems,path = "/dev/spi2";
+ lpspi3: lpspi at 4039c000 {
+ reg = <0x4039c000 0x4000>;
+ interrupts = <34>;
+ rtems,path = "/dev/spi3";
+ lpspi4: lpspi at 403a0000 {
+ reg = <0x403a0000 0x4000>;
+ interrupts = <35>;
+ rtems,path = "/dev/spi4";
+ lpi2c1: lpi2c at 403f0000 {
+ compatible = "nxp,imxrt-lpi2c";
+ reg = <0x403f0000 0x4000>;
+ interrupts = <28>;
+ rtems,path = "/dev/i2c1";
+ lpi2c2: lpi2c at 403f4000 {
+ reg = <0x403f4000 0x4000>;
+ interrupts = <29>;
+ rtems,path = "/dev/i2c2";
+ lpi2c3: lpi2c at 403f8000 {
+ reg = <0x403f8000 0x4000>;
+ interrupts = <30>;
+ rtems,path = "/dev/i2c3";
+ lpi2c4: lpi2c at 403fc000 {
+ reg = <0x403fc000 0x4000>;
+ interrupts = <31>;
+ rtems,path = "/dev/i2c4";
diff --git a/spec/build/bsps/arm/imxrt/bspimxrt.yml b/spec/build/bsps/arm/imxrt/bspimxrt.yml
index cc9659dee0..85c51e04a8 100644
--- a/spec/build/bsps/arm/imxrt/bspimxrt.yml
+++ b/spec/build/bsps/arm/imxrt/bspimxrt.yml
@@ -95,6 +95,7 @@ install:
- bsps/arm/imxrt/include/bsp/irq.h
- destination: ${BSP_INCLUDEDIR}/imxrt
source:
+ - bsps/arm/imxrt/include/imxrt/imxrt1050.dtsi
- bsps/arm/imxrt/include/imxrt/imxrt1050-pinfunc.h
- bsps/arm/imxrt/include/imxrt/memory.h
- bsps/arm/imxrt/include/imxrt/mpu-config.h
2.26.2
