[PATCH 1/2] bsps: Add SMP support to ARM GICv3
Sebastian Huber
Wed Dec 9 13:34:51 UTC 2020
Update #4202.
bsps/shared/dev/irq/arm-gicv3.c | 56 +++++++++++++++++++--------------
1 file changed, 33 insertions(+), 23 deletions(-)
diff --git a/bsps/shared/dev/irq/arm-gicv3.c b/bsps/shared/dev/irq/arm-gicv3.c
index da19300b15..db10371c72 100644
--- a/bsps/shared/dev/irq/arm-gicv3.c
+++ b/bsps/shared/dev/irq/arm-gicv3.c
@@ -131,8 +131,17 @@
#endif /* ARM_MULTILIB_ARCH_V4 */
-#define ARM_GIC_REDIST ((volatile gic_redist *) BSP_ARM_GIC_REDIST_BASE)
-#define ARM_GIC_SGI_PPI (((volatile gic_sgi_ppi *) ((char*)BSP_ARM_GIC_REDIST_BASE + (1 << 16))))
+static volatile gic_redist *gicv3_get_redist(uint32_t cpu_index)
+ return (volatile gic_redist *)
+ (BSP_ARM_GIC_REDIST_BASE + cpu_index * 0x20000);
+static volatile gic_sgi_ppi *gicv3_get_sgi_ppi(uint32_t cpu_index)
+ return (volatile gic_sgi_ppi *)
+ (BSP_ARM_GIC_REDIST_BASE + cpu_index * 0x20000 + 0x10000);
void gicvx_interrupt_dispatch(void)
@@ -149,30 +158,29 @@ void gicvx_interrupt_dispatch(void)
void bsp_interrupt_vector_enable(rtems_vector_number vector)
- volatile gic_dist *dist = ARM_GIC_DIST;
- volatile gic_sgi_ppi *sgi_ppi = ARM_GIC_SGI_PPI;
bsp_interrupt_assert(bsp_interrupt_is_valid_vector(vector));
- /* TODO(kmoore) This could use some cleanup and integration
- * Vectors below 32 are currently routed through the redistributor */
if (vector >= 32) {
+ volatile gic_dist *dist = ARM_GIC_DIST;
gic_id_enable(dist, vector);
} else {
+ volatile gic_sgi_ppi *sgi_ppi =
+ gicv3_get_sgi_ppi(_SMP_Get_current_processor());
sgi_ppi->icspiser[0] = 1 << (vector % 32);
void bsp_interrupt_vector_disable(rtems_vector_number vector)
if (vector >= 32) {
gic_id_disable(dist, vector);
} else {
sgi_ppi->icspicer[0] = 1 << (vector % 32);
@@ -187,21 +195,22 @@ static inline uint32_t get_id_count(volatile gic_dist *dist)
return id_count;
-static void init_cpu_interface(void)
+static void gicv3_init_cpu_interface(void)
+ uint32_t cpu_index = _SMP_Get_current_processor();
uint32_t sre_value = 0x7;
WRITE_SR(ICC_SRE, sre_value);
WRITE_SR(ICC_PMR, GIC_CPUIF_ICCPMR_PRIORITY(0xff));
WRITE_SR(ICC_BPR0, GIC_CPUIF_ICCBPR_BINARY_POINT(0x0));
- volatile gic_redist *redist = ARM_GIC_REDIST;
+ volatile gic_redist *redist = gicv3_get_redist(cpu_index);
uint32_t waker = redist->icrwaker;
uint32_t waker_mask = GIC_REDIST_ICRWAKER_PROCESSOR_SLEEP;
waker &= ~waker_mask;
redist->icrwaker = waker;
/* Set interrupt group to 1NS for SGI/PPI interrupts routed through the redistributor */
+ volatile gic_sgi_ppi *sgi_ppi = gicv3_get_sgi_ppi(cpu_index);
sgi_ppi->icspigrpr[0] = 0xffffffff;
sgi_ppi->icspigrpmodr[0] = 0;
for (int id = 0; id < 32; id++) {
@@ -243,7 +252,7 @@ rtems_status_code bsp_interrupt_facility_initialize(void)
gic_id_set_targets(dist, id, 0x01);
- init_cpu_interface();
+ gicv3_init_cpu_interface();
return RTEMS_SUCCESSFUL;
@@ -256,8 +265,7 @@ BSP_START_TEXT_SECTION void arm_gic_irq_initialize_secondary_cpu(void)
/* Wait */
-#error modify init_cpu_interface to use correct offsets for each CPU
#endif
@@ -269,12 +277,13 @@ rtems_status_code arm_gic_irq_set_priority(
rtems_status_code sc = RTEMS_SUCCESSFUL;
if (bsp_interrupt_is_valid_vector(vector)) {
- if (vector < 32) {
- sgi_ppi->icspiprior[vector] = priority;
- } else {
+ if (vector >= 32) {
gic_id_set_priority(dist, vector, priority);
+ } else {
+ sgi_ppi->icspiprior[vector] = priority;
} else {
sc = RTEMS_INVALID_ID;
@@ -291,12 +300,13 @@ rtems_status_code arm_gic_irq_get_priority(
- *priority = sgi_ppi->icspiprior[vector];
- } else {
*priority = gic_id_get_priority(dist, vector);
+ } else {
+ *priority = sgi_ppi->icspiprior[vector];
} else {
2.26.2
