[PATCH] eng: Requirements counting shall start at zero
Andrew Butterfield
Andrew.Butterfield at scss.tcd.ie
Wed Dec 9 13:47:53 UTC 2020
Hi Frank,
I plan to generate numbered test sources - should these also be numbered from 0?
E.g. tr-model-events-mgr-n.c - I was going to have `n` range from 1..N -- should I adopt the same convention as you suggest for consistency?
Regards, Andrew
> On 9 Dec 2020, at 13:36, Frank Kuehndel <frank.kuehndel at embedded-brains.de> wrote:
> From: Frank Kühndel <frank.kuehndel at embedded-brains.de>
> eng/req/req-for-req.rst | 8 ++++++++
> 1 file changed, 8 insertions(+)
> diff --git a/eng/req/req-for-req.rst b/eng/req/req-for-req.rst
> index 9225e95..8345e35 100644
> --- a/eng/req/req-for-req.rst
> +++ b/eng/req/req-for-req.rst
> @@ -308,6 +308,14 @@ spec:/classic/task/create-err-invname
> +If requirements or the YAML files which contain them are to be numbered,
> +the numbering shall start with 0. For example:
> +.. code-block:: none
> + weak-alias-0.yml
> + weak-alias-1.yml
> Conflict Free Requirements
> 2.26.2
> devel mailing list
> devel at rtems.org
Andrew Butterfield Tel: +353-1-896-2517 Fax: +353-1-677-2204
Lero at TCD, Head of Software Foundations & Verification Research Group
School of Computer Science and Statistics,
Room G.39, O'Reilly Institute, Trinity College, University of Dublin
http://www.scss.tcd.ie/Andrew.Butterfield/
URL: <http://lists.rtems.org/pipermail/devel/attachments/20201209/1f63605e/attachment.html>
