[PATCH v2] bsps: Fix GICv3 arm_gic_trigger_sgi()
Sebastian Huber
Wed Dec 9 16:33:04 UTC 2020
Use the targets parameter to determine the targets of the SGI.
Update #4202.
v2: Fix tm27 test support.
bsps/include/dev/irq/arm-gic-tm27.h | 8 ++++----
bsps/shared/dev/irq/arm-gicv3.c | 2 +-
2 files changed, 5 insertions(+), 5 deletions(-)
diff --git a/bsps/include/dev/irq/arm-gic-tm27.h b/bsps/include/dev/irq/arm-gic-tm27.h
index 95f3077716..8edacc39e4 100644
--- a/bsps/include/dev/irq/arm-gic-tm27.h
+++ b/bsps/include/dev/irq/arm-gic-tm27.h
@@ -79,8 +79,8 @@ static inline void Cause_tm27_intr(void)
rtems_status_code sc = arm_gic_irq_generate_software_irq(
ARM_GIC_TM27_IRQ_LOW,
- ARM_GIC_IRQ_SOFTWARE_IRQ_TO_SELF,
- 0
+ ARM_GIC_IRQ_SOFTWARE_IRQ_TO_ALL_IN_LIST,
+ 1
assert(sc == RTEMS_SUCCESSFUL);
@@ -94,8 +94,8 @@ static inline void Lower_tm27_intr(void)
ARM_GIC_TM27_IRQ_HIGH,
- 0
+ 1
diff --git a/bsps/shared/dev/irq/arm-gicv3.c b/bsps/shared/dev/irq/arm-gicv3.c
index db10371c72..569c7610c4 100644
--- a/bsps/shared/dev/irq/arm-gicv3.c
+++ b/bsps/shared/dev/irq/arm-gicv3.c
@@ -356,7 +356,7 @@ void arm_gic_trigger_sgi(
uint64_t value = ICC_SGIR_AFFINITY2(MPIDR_AFFINITY2_GET(mpidr))
| ICC_SGIR_INTID(vector)
| ICC_SGIR_AFFINITY1(MPIDR_AFFINITY1_GET(mpidr))
- | ICC_SGIR_CPU_TARGET_LIST(1);
+ | ICC_SGIR_CPU_TARGET_LIST(targets);
#ifndef ARM_MULTILIB_ARCH_V4
value |= ICC_SGIR_AFFINITY3(MPIDR_AFFINITY3_GET(mpidr));
#endif
2.26.2
