[PATCH 4/5] bsps/arm: Support system level ARM Generic Timer
Sebastian Huber
Wed Dec 9 16:44:17 UTC 2020
Update #4202.
bsps/shared/dev/clock/arm-generic-timer.c | 13 ++++++++++++-
spec/build/bsps/arm/optgtsysbase.yml | 19 +++++++++++++++++++
spec/build/bsps/arm/optgtsyscntcr.yml | 20 ++++++++++++++++++++
3 files changed, 51 insertions(+), 1 deletion(-)
create mode 100644 spec/build/bsps/arm/optgtsysbase.yml
create mode 100644 spec/build/bsps/arm/optgtsyscntcr.yml
diff --git a/bsps/shared/dev/clock/arm-generic-timer.c b/bsps/shared/dev/clock/arm-generic-timer.c
index f0f29e706f..3046c53a46 100644
--- a/bsps/shared/dev/clock/arm-generic-timer.c
+++ b/bsps/shared/dev/clock/arm-generic-timer.c
@@ -138,11 +138,22 @@ CPU_Counter_ticks _CPU_Counter_read(void)
return (uint32_t) arm_gt_clock_get_count();
+static void arm_gt_system_init(void)
+#ifdef ARM_GENERIC_TIMER_SYSTEM_BASE
+ volatile uint32_t *cntcr;
+ cntcr = (volatile uint32_t *) ARM_GENERIC_TIMER_SYSTEM_BASE;
+ *cntcr = ARM_GENERIC_TIMER_SYSTEM_CNTCR;
+#endif
static void arm_gt_clock_early_init(void)
uint32_t frequency;
- arm_gt_clock_set_control(0x3);
+ arm_gt_system_init();
+ arm_gt_clock_set_control(0x3);
arm_generic_timer_get_config(
&frequency,
&arm_gt_clock_instance.irq
diff --git a/spec/build/bsps/arm/optgtsysbase.yml b/spec/build/bsps/arm/optgtsysbase.yml
new file mode 100644
index 0000000000..9f684baedc
--- /dev/null
+++ b/spec/build/bsps/arm/optgtsysbase.yml
@@ -0,0 +1,19 @@
+SPDX-License-Identifier: CC-BY-SA-4.0 OR BSD-2-Clause
+actions:
+- get-integer: null
+- format-and-define: null
+build-type: option
+copyrights:
+- Copyright (C) 2020 embedded brains GmbH (http://www.embedded-brains.de)
+default: 709033984
+default-by-variant:
+- value: 2856517632
+ variants:
+ - arm/fvp_cortex_r52
+description: |
+ Defines the base address of the memory-mapped system level ARM Generic Timer.
+format: '{:#010x}'
+enabled-by: true
+links: []
+name: ARM_GENERIC_TIMER_SYSTEM_BASE
+type: build
diff --git a/spec/build/bsps/arm/optgtsyscntcr.yml b/spec/build/bsps/arm/optgtsyscntcr.yml
index 0000000000..6278bf0f53
--- /dev/null
+++ b/spec/build/bsps/arm/optgtsyscntcr.yml
@@ -0,0 +1,20 @@
+actions:
+build-type: option
+copyrights:
+default: 1
+- value: 257
+ variants:
+description: |
+ Defines the initialization value of the CNTCR register of the memory-mapped
+ system level ARM Generic Timer.
+format: '{:#010x}'
+enabled-by: true
+links: []
+name: ARM_GENERIC_TIMER_SYSTEM_CNTCR
+type: build
2.26.2
