CMake support
Fri Dec 11 00:14:49 UTC 2020
On Thu, Dec 10, 2020 at 5:58 PM Chris Johns <chrisj at rtems.org> wrote:
> On 11/12/20 8:51 am, Robin Müller wrote:
> > Hello,
> > I created a repository on github for the first version of what a CMake
> support
> > for RTEMS might look like:
> > https://github.com/rmspacefish/rtems-cmake
> > <https://github.com/rmspacefish/rtems-cmake>
> Awesome and thanks. :)
Agreed. Bear with us being picky. We want things to be as
consistent as possible across BSPs, architectures, RTEMS versions,
and (hopefully) build systems.
> > I tried to extract generic components like determining library paths into
> > functions  (RTEMSGeneric.cmake)
> > and there is a hardware specific file where flags for specific
> > BSPs/Architectures can be set (RTEMSHardware.cmake).
> > I was able to compile both the hello project and my STM32 blinky project
> with
> > really similar and short CMake files which simply call
> rtems_general_config.
> > with a simple command like
> > cmake -DRTEMS_INST=$RTEMS_INST -DRTEMS_BSP=arm/stm32h7
> Would it be possible to align the naming to be consistent with the names we
> currently have? We use --rtems-tools for the path to the tools so would
> RTEMS_TOOLS work?
> We also provide the ability to specify where RTEMS (the RTEMS BSP) is
> installed.
> In some configurations we have a prefix, where the application or library
> being
> built are installed plus the RTEMS tools path and the RTEMS BSP path. They
> can
> all be the same or different.
> I am not sure what cmake does for the prefix so I will use PREFIX in my
> examples:
>  cmake -DPREFIX=/install-point -DRTEMS_BSP=arm/stm32h7
> Internally RTEMS_TOOLS and RTEMS would be set to PREFIX.
>  cmake -DPREFIX=/install-point -DRTEMS_TOOLS=/tools-path
> RTEMS_TOOLS is defined and RTEMS is set to RTEMS_TOOLS.
> Finally we can have:
>  cmake -DPREFIX=/install-path \
>        -DRTEMS=/bsp-path \
> All are left as defined on the command line.
> We have this separation so you can build a set of tools and build different
> branches of RTEMS and then different branches of the application or
> library for
> any of those combinations. A typical user will use the first or second
> option
> and if testing new releases or versions you can separate out the various
> paths.
> Separating the paths lets you some parts without having to build all the
> parts.
> > or
> > cmake -DRTEMS_INST=$RTEMS_INST -DRTEMS_BSP=sparc/erc32
> > and then cmake --build .
> > I made a test repository containing everything :
> > https://github.com/rmspacefish/rtems-demo
> > <https://github.com/rmspacefish/rtems-demo>
> > Maybe this could be a part of the RTEMS repositories?
> This could be possible. It will come down to people using the package and
> the
> demand. The rtems_waf package is a top level RTEMS repo because it is used
> in
> libbsd and examples.
> The rtems-examples repo maybe be a good place to look at adding support and
> making it visible to the wider RTEMS community. I am not sure if this
> would be a
> submodule to github or not. I would love to hear what others think.
If it is just an example, I'd prefer not to have another git repo. But if
it turns out
to work like the waf where you can close the rtems_cmake repo as a
submodule,
execute a couple of commands, and poof you can build an application, I'd be
ok
with it being a repo. I hope that makes sense -- example vs reusable
infrastructure.
Thinking long term, when we have examples, not infrastructure,
rtems-examples could have a build_systems subdirectory and
then cmake, meson, scons, etc.
> > In any case, I think it
> > can help people who would like to build their application
> > with CMake. The hello world example for CMake would be similar to
> building the
> > waf example for the sparc/erc32, with the difference that the
> > CMake support would have to be cloned and the build commands are a
> little bit
> > different.
> This is a really great start and I thank you for it. We are open to
> supporting
> all build systems. It is about individuals providing the support and then
> being
> thee to maintain it over a period of time.
+1
--joel
> Chris
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20201210/bd869be6/attachment-0001.html>
