Which threads execute _Thread_Handler ?
Richi Dubey
richidubey at gmail.com
Fri Dec 11 07:41:20 UTC 2020
Also, it's weird that neither of the code breaks on setting a breakpoint
at _Thread_Load_environment for the threads that have 'Tasks' as their
entry function.
On Fri, Dec 11, 2020 at 1:07 PM Richi Dubey <richidubey at gmail.com> wrote:
> Thanks for your replies.
> Great suggestion about setting up a breakpoint at _Thread_Handler. After
> setting the breakpoint, the code run by Strong_APA does not break, whereas
> the default scheduler's code does break:
> Default Scheduler (That executes correctly without error):
> Thread 1 hit Breakpoint 7, Tasks (argument=0) at
> /home/richi/quick-start/src/rtems/c/src/../../testsuites/tmtests/tm24/task1.c:110
> 110 Task_count++;
> (gdb) b _Thread_Handler
> Breakpoint 8 at 0x10a67e: file
> /home/richi/quick-start/src/rtems/c/src/../../cpukit/score/src/threadhandler.c,
> line 88.
> (gdb) c
> Continuing.
> Thread 1 hit Breakpoint 8, _Thread_Handler () at
> /home/richi/quick-start/src/rtems/c/src/../../cpukit/score/src/threadhandler.c:88
> 88 executing = _Thread_Executing;
> (gdb)
> Continuing.
> 110 Task_count++;
> Strong APA execution (The execution that fails/give error):
> 110 Task_count++;
> Breakpoint 8 at 0x1086b2: file
> line 88.
> (gdb) c
> Continuing.
> Thread 1 hit Breakpoint 5, _Terminate
> I am going to investigate the scheduler's role in this.
> Thanks,
> Richi.
> On Mon, Dec 7, 2020 at 11:09 AM Sebastian Huber <
> sebastian.huber at embedded-brains.de> wrote:
>> On 05/12/2020 07:13, Richi Dubey wrote:
>> > The stack trace for the thread looks like this:
>> > Tasks (entry function) -> rtems_task_wake_after
>> > ->_Thread_Dispatch_direct -> _Thread_Do_dispatch (where the
>> > _Context_switch function call lies), how can then the heir thread
>> > start executing from the _Thread_Handler? I do not see it in the trace
>> > at all.
>> The context of new threads is set up by _Thread_Load_environment().
>> embedded brains GmbH
>> Herr Sebastian HUBER
>> Dornierstr. 4
>> 82178 Puchheim
>> Germany
>> email: sebastian.huber at embedded-brains.de
>> phone: +49-89-18 94 741 - 16
>> fax: +49-89-18 94 741 - 08
>> Registergericht: Amtsgericht München
>> Registernummer: HRB 157899
>> Vertretungsberechtigte Geschäftsführer: Peter Rasmussen, Thomas Dörfler
>> Unsere Datenschutzerklärung finden Sie hier:
>> https://embedded-brains.de/datenschutzerklaerung/
URL: <http://lists.rtems.org/pipermail/devel/attachments/20201211/da70ce48/attachment.html>
