[PATCH v2] eng: Requirements counting shall start at zero
Frank Kühndel frank.kuehndel at embedded-brains.de
Fri Dec 11 15:44:44 UTC 2020
Hello Andrew,
I did not intent to become the authority in numbering files. :-)
Maybe Sebastian has some advice as he knows your application better than
I do. I personally would be pragmatic and do what seems to be an easy to
realize as well as a good solution.
Greetings
Frank
On 12/11/20 4:30 PM, Andrew Butterfield wrote:
> Hello Frank,
>  I have a use case where the numbers will exceed 10 .
> It's not for numbered requirements but numbered test-files.
> These result from different scenarios generated by our SPIN models, as
> part of the qualification activity.
> The files are generated (and numbered) automatically, so the constraints
> are somewhat different.
> For the Events Manager, for example,  I'd expect the final number of
> generated test source files to exceed 10.
> It is unlikely that we would reach 100, though.
> Regards, Andrew
>> On 11 Dec 2020, at 15:16, Frank Kühndel
>> <frank.kuehndel at embedded-brains.de
>> <mailto:frank.kuehndel at embedded-brains.de>> wrote:
>> Hello Joel,
>> On 12/11/20 3:49 PM, Joel Sherrill wrote:
>>> On Fri, Dec 11, 2020, 8:41 AM Frank Kuehndel
>>> <mailto:frank.kuehndel at embedded-brains.de>>> wrote:
>>>    From: Frank Kühndel <frank.kuehndel at embedded-brains.de
>>>     eng/req/req-for-req.rst | 21 +++++++++++++++++++++
>>>     1 file changed, 21 insertions(+)
>>>    diff --git a/eng/req/req-for-req.rst b/eng/req/req-for-req.rst
>>>    index 9225e95..dcc4c11 100644
>>>    --- a/eng/req/req-for-req.rst
>>>    +++ b/eng/req/req-for-req.rst
>>>    @@ -308,6 +308,27 @@ spec:/classic/task/create-err-invname
>>>    +If requirements or the YAML files which contain them are to be
>>>    numbered,
>>>    +the numbering shall start with 0. For example:
>>>    +.. code-block:: none
>>>    +    weak-alias-0.yml
>>>    +    weak-alias-1.yml
>>>    +Smaller numbers shall be prefixed with 0 to the same count of digits
>>>    +as the largest number. For example:
>>> When one goes from 99 to 100 requirements and didn't anticipate having
>>> that many, does this mean all the files will have to be renamed?
>> I can change the text to what Gedare Bloom suggested: "If we know the
>> max count (N) ahead of time, ..."
>> Just from my experience with the requirements for the basedefs, when I
>> create the requirements for an operation, I know the number I end up
>> with before checking them in. The issue we discuss would only cause
>> trouble if later more requirements for the same operation must be added.
>> This is not totally unlikely but it means that one actually has 9 and
>> then need a 10th one.
>>> Should we start with a minimum of three or four digits? What would drive
>>> the number of requirements in a set? How large of a functional area will
>>> a single numbered set contain?
>>> I'm just wondering if it is simpler to just have 001 as a minimum.
>> I think that 99 requirements for a single operation are really out of
>> scope. That will hopefully never ever happen. Even 9 is already a lot.
>> Also it is rather advisable to adapt the names of the requirements to
>> indicate the purpose. The numbering is more for the case that there are
>> two or more requirements on the same topic (like on handling the same
>> bad input argument).
>>  my-function-0
>>  my-function-1
>>  my-function-global-side-effect
>>  my-function-bad-argument-x-error-handling
>>  my-function-bad-argument-y-error-handling
>>  my-function-called-in-wrong-state
>> My opinion is that defining whether we start counting with 0 or with 1
>> makes sense. Everything else seems to me a bit like solving theoretical
>> problems.
>>>    +    alias-00.yml
>>>    +    alias-01.yml
>>>    +    alias-02.yml
>>>    +    alias-09.yml
>>>    +    alias-10.yml
>>>    +    alias-11.yml
>>>     Conflict Free Requirements
>>>    2.26.2
>>>    _______________________________________________
>>>    devel mailing list
>>>    devel at rtems.org <mailto:devel at rtems.org> <mailto:devel at rtems.org
>>> <mailto:devel at rtems.org>>
>>>    http://lists.rtems.org/mailman/listinfo/devel
>>> <http://lists.rtems.org/mailman/listinfo/devel>
>>> <http://lists.rtems.org/mailman/listinfo/devel>>
>> Greetings
>> Frank
>> devel mailing list
> Andrew Butterfield     Tel: +353-1-896-2517     Fax: +353-1-677-2204
> Lero at TCD, Head of Software Foundations & Verification Research Group
> School of Computer Science and Statistics,
> Room G.39, O'Reilly Institute, Trinity College, University of Dublin
>                          http://www.scss.tcd.ie/Andrew.Butterfield/
> <http://www.scss.tcd.ie/Andrew.Butterfield/>
embedded brains GmbH
Herr Frank KÜHNDEL
Dornierstr. 4
82178 Puchheim
Germany
email: frank.kuehndel at embedded-brains.de
phone: +49-89-18 94 741 - 23
fax:   +49-89-18 94 741 - 08
Registernummer: HRB 157899
