Build FreeBSD: FAILED 6/rtems-arm on x86_64-freebsd12.1 (arm-rtems6-gcc-c25f7ea-newlib-21ec498-x86_64-freebsd12.1-1)
Fri Dec 11 17:27:36 UTC 2020
On 11/12/2020 18:22, sebastian.huber at embedded-brains.de wrote:
> /usr/home/user/rtems-source-builder/rtems/build/arm-rtems6-gcc-c25f7ea-newlib-21ec498-x86_64-freebsd12.1-1/build/./gcc/xgcc
> -B/usr/home/user/rtems-source-builder/rtems/build/arm-rtems6-gcc-c25f7ea-newlib-21ec498-x86_64-freebsd12.1-1/build/./gcc/  -xc -nostdinc /dev/null -S -o /dev/null -fself-test=../../gnu-mirror-gcc-c25f7ea/gcc/testsuite/selftests
> -B/usr/home/user/rtems-source-builder/rtems/build/arm-rtems6-gcc-c25f7ea-newlib-21ec498-x86_64-freebsd12.1-1/build/./gcc/  -xc++ -nostdinc /dev/null -S -o /dev/null -fself-test=../../gnu-mirror-gcc-c25f7ea/gcc/testsuite/selftests
> ld-elf.so.1: Shared object "libgmp.so.10" not found, required by "cc1"
> ld-elf.so.1: Shared object "libgmp.so.10" not found, required by "cc1plus"
It seems that adding GMP to the GDB build breaks the GCC build.
embedded brains GmbH
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax:   +49-89-18 94 741 - 08
Registernummer: HRB 157899
