[PATCH 2/3] user: Add A53 Qemu run instructions
Fri Dec 11 21:55:26 UTC 2020
On Fri, Dec 11, 2020 at 11:58 AM Kinsey Moore <kinsey.moore at oarcorp.com>
wrote:
> *From:* Gedare Bloom <gedare at rtems.org>
> *Sent:* Friday, December 11, 2020 07:41
> *To:* Kinsey Moore <kinsey.moore at oarcorp.com>
> *Cc:* devel at rtems.org
> *Subject:* Re: [PATCH 2/3] user: Add A53 Qemu run instructions
> On Tue, Dec 8, 2020 at 11:03 AM Kinsey Moore <kinsey.moore at oarcorp.com>
> wrote:
>  user/bsps/aarch64/a53.rst | 7 +++++++
>  1 file changed, 7 insertions(+)
> diff --git a/user/bsps/aarch64/a53.rst b/user/bsps/aarch64/a53.rst
> index 73735b1..e3a89f8 100644
> --- a/user/bsps/aarch64/a53.rst
> +++ b/user/bsps/aarch64/a53.rst
> @@ -25,3 +25,10 @@ Console Driver
>  The console driver supports the default Qemu emulated ARM PL011 PrimeCell
> UART.
> +Running Executables
> +Executables generated by these BSPs can be run using the following
> command::
> +qemu-system-aarch64 -no-reboot -nographic -serial mon:stdio -machine
> virt,gic_version=3 -cpu cortex-a53 -m 4096 -kernel example.exe
> Check the line break on PDF, maybe typeset an explicit line break \
> I’ll break this one as well as the one in the ZynqMP BSP docs. Did you
> want to see another patchset or is it otherwise good to commit?
looks good otherwise
> Kinsey
URL: <http://lists.rtems.org/pipermail/devel/attachments/20201211/d43313a1/attachment.html>
