[PATCH rtems 6/6] bsps/imxrt: Add ioctl to LPSPI to get registers
Christian Mauderer
christian.mauderer at embedded-brains.de
Mon Dec 14 15:28:23 UTC 2020
This allows an application to get the registers of the LPSPI. That is
usefull for applications that want to use DMA for a very specialized and
highly optimized communication.
Update #4180
bsps/arm/imxrt/include/imxrt/lpspi.h | 54 ++++++++++++++++++++++++++
bsps/arm/imxrt/spi/imxrt-lpspi.c | 20 ++++++++++
spec/build/bsps/arm/imxrt/bspimxrt.yml | 1 +
3 files changed, 75 insertions(+)
create mode 100644 bsps/arm/imxrt/include/imxrt/lpspi.h
diff --git a/bsps/arm/imxrt/include/imxrt/lpspi.h b/bsps/arm/imxrt/include/imxrt/lpspi.h
new file mode 100644
index 0000000000..8a87f28da9
--- /dev/null
+++ b/bsps/arm/imxrt/include/imxrt/lpspi.h
@@ -0,0 +1,54 @@
+ * Copyright (C) 2020 embedded brains GmbH (http://www.embedded-brains.de)
+ * are met:
+ * notice, this list of conditions and the following disclaimer.
+ * notice, this list of conditions and the following disclaimer in the
+ * documentation and/or other materials provided with the distribution.
+#ifndef LIBBSP_ARM_IMXRT_IMXRT_LPSPI_H
+#define LIBBSP_ARM_IMXRT_IMXRT_LPSPI_H
+#include <sys/ioccom.h>
+#ifdef __cplusplus
+extern "C" {
+#endif /* __cplusplus */
+#define IMXRT_LPSPI_IOC_MAGIC 's'
+ * @brief Fetch the raw registers.
+ * This allows to do some special operations. Note that if you do something
+ * fancy, you should lock the hardware by obtaining the bus with the
+ * SPI_BUS_OBTAIN ioctl first. With that, the normal driver can't be used by
+ * other tasks. Also note that you should leave the registers in a clean state
+ * before releasing the bus again.
+#define IMXRT_LPSPI_GET_REGISTERS _IOR(IMXRT_LPSPI_IOC_MAGIC, 0, LPSPI_Type *)
+#ifdef __cplusplus
+#endif /* LIBBSP_ARM_IMXRT_IMXRT_LPSPI_H */
diff --git a/bsps/arm/imxrt/spi/imxrt-lpspi.c b/bsps/arm/imxrt/spi/imxrt-lpspi.c
index 6da3ffdecf..06d8f715d9 100644
--- a/bsps/arm/imxrt/spi/imxrt-lpspi.c
+++ b/bsps/arm/imxrt/spi/imxrt-lpspi.c
@@ -34,6 +34,7 @@
#include <dev/spi/spi.h>
#include <fsl_clock.h>
#include <libfdt.h>
+#include <imxrt/lpspi.h>
struct imxrt_lpspi_bus {
spi_bus base;
@@ -471,6 +472,24 @@ static clock_ip_name_t imxrt_lpspi_clock_ip(volatile LPSPI_Type *regs)
return kCLOCK_IpInvalid;
+static int imxrt_lpspi_ioctl(spi_bus *base, ioctl_command_t command, void *arg)
+ struct imxrt_lpspi_bus *bus;
+ bus = (struct imxrt_lpspi_bus *) base;
+ int err = 0;
+ switch (command) {
+ case IMXRT_LPSPI_GET_REGISTERS:
+ *(volatile LPSPI_Type**)arg = bus->regs;
+ break;
+ default:
+ err = -EINVAL;
+ break;
+ return err;
void imxrt_lpspi_init(void)
const void *fdt;
@@ -523,6 +542,7 @@ void imxrt_lpspi_init(void)
bus->base.transfer = imxrt_lpspi_transfer;
bus->base.destroy = imxrt_lpspi_destroy;
bus->base.setup = imxrt_lpspi_setup;
+ bus->base.ioctl = imxrt_lpspi_ioctl;
eno = spi_bus_register(&bus->base, bus_path);
if (eno != 0) {
diff --git a/spec/build/bsps/arm/imxrt/bspimxrt.yml b/spec/build/bsps/arm/imxrt/bspimxrt.yml
index be4a4bb566..3044fda998 100644
--- a/spec/build/bsps/arm/imxrt/bspimxrt.yml
+++ b/spec/build/bsps/arm/imxrt/bspimxrt.yml
@@ -103,6 +103,7 @@ install:
source:
- bsps/arm/imxrt/include/imxrt/imxrt1050.dtsi
- bsps/arm/imxrt/include/imxrt/imxrt1050-pinfunc.h
+ - bsps/arm/imxrt/include/imxrt/lpspi.h
- bsps/arm/imxrt/include/imxrt/memory.h
- bsps/arm/imxrt/include/imxrt/mpu-config.h
- destination: ${BSP_LIBDIR}
2.26.2
