[PATCH rtems 2/6] bsps/shared: Copy fsl-edma from mpc55xx
Christian Mauderer christian.mauderer at embedded-brains.de
Mon Dec 14 15:28:19 UTC 2020
This is a preparation for making the driver universal.
Update #4180
 bsps/include/fsl/edma.h        | 329 +++++++++++++++
 bsps/include/fsl/regs-edma.h   | 710 +++++++++++++++++++++++++++++++++
 bsps/shared/dev/dma/fsl-edma.c | 329 +++++++++++++++
 3 files changed, 1368 insertions(+)
 create mode 100644 bsps/include/fsl/edma.h
 create mode 100644 bsps/include/fsl/regs-edma.h
 create mode 100644 bsps/shared/dev/dma/fsl-edma.c
diff --git a/bsps/include/fsl/edma.h b/bsps/include/fsl/edma.h
new file mode 100644
index 0000000000..8b7d65d3b6
--- /dev/null
+++ b/bsps/include/fsl/edma.h
@@ -0,0 +1,329 @@
+ * @file
+ * @ingroup RTEMSBSPsPowerPCMPC55XX
+ * @brief Enhanced Direct Memory Access (eDMA).
+ * Copyright (c) 2008-2013 embedded brains GmbH.  All rights reserved.
+ *  embedded brains GmbH
+ *  Dornierstr. 4
+ *  82178 Puchheim
+ *  Germany
+ *  <rtems at embedded-brains.de>
+#ifndef LIBCPU_POWERPC_MPC55XX_EDMA_H
+#define LIBCPU_POWERPC_MPC55XX_EDMA_H
+#include <mpc55xx/regs.h>
+#include <rtems.h>
+#include <rtems/chain.h>
+#ifdef __cplusplus
+extern "C" {
+#endif /* __cplusplus */
+#if MPC55XX_CHIP_FAMILY == 551
+  #define EDMA_CHANNEL_COUNT 16U
+#elif MPC55XX_CHIP_FAMILY == 564
+#elif MPC55XX_CHIP_FAMILY == 567
+  #define EDMA_CHANNEL_COUNT 96U
+#else
+  #define EDMA_CHANNEL_COUNT 64U
+#endif
+#define EDMA_MODULE_COUNT ((EDMA_CHANNEL_COUNT + 63U) / 64U)
+#define EDMA_CHANNELS_PER_MODULE 64U
+#if EDMA_MODULE_COUNT == 1
+  #define EDMA_TCD_BY_CHANNEL_INDEX(channel_index) \
+    (&EDMA.TCD[(channel_index)])
+#elif EDMA_MODULE_COUNT == 2
+    ((channel_index) < EDMA_CHANNELS_PER_MODULE ? \
+      &EDMA_A.TCD[(channel_index)] \
+        : &EDMA_B.TCD[(channel_index) - EDMA_CHANNELS_PER_MODULE])
+#else
+  #error "unsupported module count"
+#endif
+/* FIXME: These values are only valid for the MPC5566 and MPC5674F */
+typedef enum {
+  EDMA_EQADC_A_FISR0_CFFF0 = 0,
+  EDMA_EQADC_A_FISR0_RFDF0 = 1,
+  EDMA_EQADC_A_FISR1_CFFF1 = 2,
+  EDMA_EQADC_A_FISR1_RFDF1 = 3,
+  EDMA_EQADC_A_FISR2_CFFF2 = 4,
+  EDMA_EQADC_A_FISR2_RFDF2 = 5,
+  EDMA_EQADC_A_FISR3_CFFF3 = 6,
+  EDMA_EQADC_A_FISR3_RFDF3 = 7,
+  EDMA_EQADC_A_FISR4_CFFF4 = 8,
+  EDMA_EQADC_A_FISR4_RFDF4 = 9,
+  EDMA_EQADC_A_FISR5_CFFF5 = 10,
+  EDMA_EQADC_A_FISR5_RFDF5 = 11,
+  EDMA_DSPI_B_SR_TFFF = 12,
+  EDMA_DSPI_B_SR_RFDF = 13,
+  EDMA_DSPI_C_SR_TFFF = 14,
+  EDMA_DSPI_C_SR_RFDF = 15,
+  EDMA_DSPI_D_SR_TFFF = 16,
+  EDMA_DSPI_D_SR_RFDF = 17,
+  EDMA_ESCI_A_COMBTX = 18,
+  EDMA_ESCI_A_COMBRX = 19,
+  EDMA_EMIOS_GFR_F0 = 20,
+  EDMA_EMIOS_GFR_F1 = 21,
+  EDMA_EMIOS_GFR_F2 = 22,
+  EDMA_EMIOS_GFR_F3 = 23,
+  EDMA_EMIOS_GFR_F4 = 24,
+  EDMA_EMIOS_GFR_F8 = 25,
+  EDMA_EMIOS_GFR_F9 = 26,
+  EDMA_ETPU_CDTRSR_A_DTRS0 = 27,
+  EDMA_ETPU_CDTRSR_A_DTRS1 = 28,
+  EDMA_ETPU_CDTRSR_A_DTRS2 = 29,
+  EDMA_ETPU_CDTRSR_A_DTRS14 = 30,
+  EDMA_ETPU_CDTRSR_A_DTRS15 = 31,
+  EDMA_DSPI_A_SR_TFFF = 32,
+  EDMA_DSPI_A_SR_RFDF = 33,
+  EDMA_ESCI_B_COMBTX = 34,
+  EDMA_ESCI_B_COMBRX = 35,
+  EDMA_EMIOS_GFR_F6 = 36,
+  EDMA_EMIOS_GFR_F7 = 37,
+  EDMA_EMIOS_GFR_F10 = 38,
+  EDMA_EMIOS_GFR_F11 = 39,
+  EDMA_EMIOS_GFR_F16 = 40,
+  EDMA_EMIOS_GFR_F17 = 41,
+  EDMA_EMIOS_GFR_F18 = 42,
+  EDMA_EMIOS_GFR_F19 = 43,
+  EDMA_ETPU_CDTRSR_A_DTRS12 = 44,
+  EDMA_ETPU_CDTRSR_A_DTRS13 = 45,
+  EDMA_ETPU_CDTRSR_A_DTRS28 = 46,
+  EDMA_ETPU_CDTRSR_A_DTRS29 = 47,
+  EDMA_SIU_EISR_EIF0 = 48,
+  EDMA_SIU_EISR_EIF1 = 49,
+  EDMA_SIU_EISR_EIF2 = 50,
+  EDMA_SIU_EISR_EIF3 = 51,
+  EDMA_ETPU_CDTRSR_B_DTRS0 = 52,
+  EDMA_ETPU_CDTRSR_B_DTRS1 = 53,
+  EDMA_ETPU_CDTRSR_B_DTRS2 = 54,
+  EDMA_ETPU_CDTRSR_B_DTRS3 = 55,
+  EDMA_ETPU_CDTRSR_B_DTRS12 = 56,
+  EDMA_ETPU_CDTRSR_B_DTRS13 = 57,
+  EDMA_ETPU_CDTRSR_B_DTRS14 = 58,
+  EDMA_ETPU_CDTRSR_B_DTRS15 = 59,
+  EDMA_ETPU_CDTRSR_B_DTRS28 = 60,
+  EDMA_ETPU_CDTRSR_B_DTRS29 = 61,
+  EDMA_ETPU_CDTRSR_B_DTRS30 = 62,
+  EDMA_ETPU_CDTRSR_B_DTRS31 = 63
+  #if MPC55XX_CHIP_FAMILY == 567
+    EDMA_EQADC_B_FISR0_CFFF0 = 64 + 0,
+    EDMA_EQADC_B_FISR0_RFDF0 = 64 + 1,
+    EDMA_EQADC_B_FISR1_CFFF1 = 64 + 2,
+    EDMA_EQADC_B_FISR1_RFDF1 = 64 + 3,
+    EDMA_EQADC_B_FISR2_CFFF2 = 64 + 4,
+    EDMA_EQADC_B_FISR2_RFDF2 = 64 + 5,
+    EDMA_EQADC_B_FISR3_CFFF3 = 64 + 6,
+    EDMA_EQADC_B_FISR3_RFDF3 = 64 + 7,
+    EDMA_EQADC_B_FISR4_CFFF4 = 64 + 8,
+    EDMA_EQADC_B_FISR4_RFDF4 = 64 + 9,
+    EDMA_EQADC_B_FISR5_CFFF5 = 64 + 10,
+    EDMA_EQADC_B_FISR5_RFDF5 = 64 + 11,
+    EDMA_DECFILTER_A_IB = 64 + 12,
+    EDMA_DECFILTER_A_OB = 64 + 13,
+    EDMA_DECFILTER_B_IB = 64 + 14,
+    EDMA_DECFILTER_B_OB = 64 + 15,
+    EDMA_DECFILTER_C_IB = 64 + 16,
+    EDMA_DECFILTER_C_OB = 64 + 17,
+    EDMA_DECFILTER_D_IB = 64 + 18,
+    EDMA_DECFILTER_D_OB = 64 + 19,
+    EDMA_DECFILTER_E_IB = 64 + 20,
+    EDMA_DECFILTER_E_OB = 64 + 21,
+    EDMA_DECFILTER_F_IB = 64 + 22,
+    EDMA_DECFILTER_F_OB = 64 + 23,
+    EDMA_DECFILTER_G_IB = 64 + 24,
+    EDMA_DECFILTER_G_OB = 64 + 25,
+    EDMA_DECFILTER_H_IB = 64 + 26,
+    EDMA_DECFILTER_H_OB = 64 + 27
+  #endif
+} edma_channel;
+typedef struct edma_channel_context {
+  rtems_chain_node node;
+  volatile struct tcd_t *edma_tcd;
+  void (*done)(struct edma_channel_context *, uint32_t);
+} edma_channel_context;
+void mpc55xx_edma_init(void);
+ * @brief Obtains an eDMA channel.
+ * @retval RTEMS_SUCCESSFUL Successful operation.
+ * @retval RTEMS_RESOURCE_IN_USE The channel is already in use.
+rtems_status_code mpc55xx_edma_obtain_channel_by_tcd(
+void mpc55xx_edma_release_channel_by_tcd(volatile struct tcd_t *edma_tcd);
+ * @brief Obtains an eDMA channel and registers the channel context.
+ * The done handler of the channel context will be called
+ * - during minor or major loop completions if interrupts are enabled in the
+ *   corresponding TCD, or
+ * - in case a channel error occurs.
+ * An error status value not equal to zero indicates an error.
+ * @retval RTEMS_IO_ERROR Unable to install interrupt handler for this channel.
+rtems_status_code mpc55xx_edma_obtain_channel(
+  edma_channel_context *ctx,
+  unsigned irq_priority
+void mpc55xx_edma_release_channel(edma_channel_context *ctx);
+ * @brief Copies a source TCD to an eDMA TCD.
+ * The DONE flag of the eDMA TCD is cleared before the actual copy operation.
+ * This enables the setting of channel link or scatter/gather options.
+ * This function can be used to start the channel if the START flags is
+ * set in the source TCD.
+void mpc55xx_edma_copy(
+  volatile struct tcd_t *edma_tcd,
+  const struct tcd_t *source_tcd
+ * @brief Copies a source TCD to an eDMA TCD and enables hardware requests.
+void mpc55xx_edma_copy_and_enable_hardware_requests(
+void mpc55xx_edma_sg_link(
+static inline volatile struct EDMA_tag *mpc55xx_edma_by_tcd(
+  return (volatile struct EDMA_tag *)
+    ((uintptr_t) edma_tcd & ~(uintptr_t) 0x1fff);
+static inline unsigned mpc55xx_edma_channel_by_tcd(
+  volatile struct EDMA_tag *edma = mpc55xx_edma_by_tcd(edma_tcd);
+  return edma_tcd - &edma->TCD[0];
+static inline void mpc55xx_edma_enable_hardware_requests(
+  unsigned channel = edma_tcd - &edma->TCD[0];
+  edma->SERQR.R = (uint8_t) channel;
+static inline void mpc55xx_edma_disable_hardware_requests(
+  edma->CERQR.R = (uint8_t) channel;
+static inline void mpc55xx_edma_enable_error_interrupts(
+  edma->SEEIR.R = (uint8_t) channel;
+static inline void mpc55xx_edma_disable_error_interrupts(
+  edma->CEEIR.R = (uint8_t) channel;
+static inline void mpc55xx_edma_set_start(
+  edma->SSBR.R = (uint8_t) channel;
+static inline void mpc55xx_edma_clear_done(
+  edma->CDSBR.R = (uint8_t) channel;
+static inline void mpc55xx_edma_clear_interrupts(
+  edma->CIRQR.R = (uint8_t) channel;
+static inline bool mpc55xx_edma_is_done(
+  return edma_tcd->BMF.B.DONE;
+#ifdef __cplusplus
+#endif /* LIBCPU_POWERPC_MPC55XX_EDMA_H */
diff --git a/bsps/include/fsl/regs-edma.h b/bsps/include/fsl/regs-edma.h
index 0000000000..fda47dc1e6
--- /dev/null
+++ b/bsps/include/fsl/regs-edma.h
@@ -0,0 +1,710 @@
+ * @file
+ * Copyright (c) 2011 embedded brains GmbH.  All rights reserved.
+ *  Obere Lagerstr. 30
+ *  82178 Puchheim
+ *  Germany
+ * Copyright:
+ *  Freescale Semiconductor, INC. All Rights Reserved.
+ *  You are hereby granted a copyright license to use, modify, and
+ *  distribute the SOFTWARE so long as this entire notice is
+ *  retained without alteration in any modified and/or redistributed
+ *  versions, and that such modified versions are clearly identified
+ *  as such. No licenses are granted by implication, estoppel or
+ *  otherwise under any patents or trademarks of Freescale
+ *  Semiconductor, Inc. This software is provided on an "AS IS"
+ *  basis and without warranty.
+ *  To the maximum extent permitted by applicable law, Freescale
+ *  Semiconductor DISCLAIMS ALL WARRANTIES WHETHER EXPRESS OR IMPLIED,
+ *  INCLUDING IMPLIED WARRANTIES OF MERCHANTABILITY OR FITNESS FOR A
+ *  PARTICULAR PURPOSE AND ANY WARRANTY AGAINST INFRINGEMENT WITH
+ *  REGARD TO THE SOFTWARE (INCLUDING ANY MODIFIED VERSIONS THEREOF)
+ *  AND ANY ACCOMPANYING WRITTEN MATERIALS.
+ *  To the maximum extent permitted by applicable law, IN NO EVENT
+ *  SHALL Freescale Semiconductor BE LIABLE FOR ANY DAMAGES WHATSOEVER
+ *  (INCLUDING WITHOUT LIMITATION, DAMAGES FOR LOSS OF BUSINESS PROFITS,
+ *  BUSINESS INTERRUPTION, LOSS OF BUSINESS INFORMATION, OR OTHER
+ *  PECUNIARY LOSS) ARISING OF THE USE OR INABILITY TO USE THE SOFTWARE.
+ *  Freescale Semiconductor assumes no responsibility for the
+ *  maintenance and support of this software
+#ifndef LIBCPU_POWERPC_MPC55XX_REGS_EDMA_H
+#define LIBCPU_POWERPC_MPC55XX_REGS_EDMA_H
+#include <stdint.h>
+#include <bspopts.h>
+#ifdef  __cplusplus
+extern "C" {
+#endif
+/*                          MODULE : eDMA                                   */
+    struct EDMA_tag {
+        union EDMA_CR_tag {
+            uint32_t R;
+            struct {
+#if MPC55XX_CHIP_FAMILY == 566 || MPC55XX_CHIP_FAMILY == 567
+                uint32_t:14;
+                uint32_t CX:1;
+                uint32_t ECX:1;
+#else
+                uint32_t:16;
+#endif
+                uint32_t GRP3PRI:2;
+                uint32_t GRP2PRI:2;
+                uint32_t GRP1PRI:2;
+                uint32_t GRP0PRI:2;
+                uint32_t EMLM:1;
+                uint32_t CLM:1;
+                uint32_t HALT:1;
+                uint32_t HOE:1;
+#else
+                  uint32_t:4;
+#endif
+                uint32_t ERGA:1;
+                uint32_t ERCA:1;
+                uint32_t EDBG:1;
+                uint32_t EBW:1;
+            } B;
+        } CR;                   /* Control Register */
+        union {
+            uint32_t R;
+            struct {
+                uint32_t VLD:1;
+                uint32_t:14;
+                uint32_t ECX:1;
+#else
+                  uint32_t:15;
+#endif
+                uint32_t GPE:1;
+                uint32_t CPE:1;
+                uint32_t ERRCHN:6;
+                uint32_t SAE:1;
+                uint32_t SOE:1;
+                uint32_t DAE:1;
+                uint32_t DOE:1;
+                uint32_t NCE:1;
+                uint32_t SGE:1;
+                uint32_t SBE:1;
+                uint32_t DBE:1;
+            } B;
+        } ESR;                  /* Error Status Register */
+        union {
+            uint32_t R;
+            struct {
+                uint32_t ERQ63:1;
+                uint32_t ERQ62:1;
+                uint32_t ERQ61:1;
+                uint32_t ERQ60:1;
+                uint32_t ERQ59:1;
+                uint32_t ERQ58:1;
+                uint32_t ERQ57:1;
+                uint32_t ERQ56:1;
+                uint32_t ERQ55:1;
+                uint32_t ERQ54:1;
+                uint32_t ERQ53:1;
+                uint32_t ERQ52:1;
+                uint32_t ERQ51:1;
+                uint32_t ERQ50:1;
+                uint32_t ERQ49:1;
+                uint32_t ERQ48:1;
+                uint32_t ERQ47:1;
+                uint32_t ERQ46:1;
+                uint32_t ERQ45:1;
+                uint32_t ERQ44:1;
+                uint32_t ERQ43:1;
+                uint32_t ERQ42:1;
+                uint32_t ERQ41:1;
+                uint32_t ERQ40:1;
+                uint32_t ERQ39:1;
+                uint32_t ERQ38:1;
+                uint32_t ERQ37:1;
+                uint32_t ERQ36:1;
+                uint32_t ERQ35:1;
+                uint32_t ERQ34:1;
+                uint32_t ERQ33:1;
+                uint32_t ERQ32:1;
+            } B;
+        } ERQRH;                /* DMA Enable Request Register High */
+        union {
+            uint32_t R;
+            struct {
+                uint32_t ERQ31:1;
+                uint32_t ERQ30:1;
+                uint32_t ERQ29:1;
+                uint32_t ERQ28:1;
+                uint32_t ERQ27:1;
+                uint32_t ERQ26:1;
+                uint32_t ERQ25:1;
+                uint32_t ERQ24:1;
+                uint32_t ERQ23:1;
+                uint32_t ERQ22:1;
+                uint32_t ERQ21:1;
+                uint32_t ERQ20:1;
+                uint32_t ERQ19:1;
+                uint32_t ERQ18:1;
+                uint32_t ERQ17:1;
+                uint32_t ERQ16:1;
+                uint32_t ERQ15:1;
+                uint32_t ERQ14:1;
+                uint32_t ERQ13:1;
+                uint32_t ERQ12:1;
+                uint32_t ERQ11:1;
+                uint32_t ERQ10:1;
+                uint32_t ERQ09:1;
+                uint32_t ERQ08:1;
+                uint32_t ERQ07:1;
+                uint32_t ERQ06:1;
+                uint32_t ERQ05:1;
+                uint32_t ERQ04:1;
+                uint32_t ERQ03:1;
+                uint32_t ERQ02:1;
+                uint32_t ERQ01:1;
+                uint32_t ERQ00:1;
+            } B;
+        } ERQRL;                /* DMA Enable Request Register Low */
+        union {
+            uint32_t R;
+            struct {
+                uint32_t EEI63:1;
+                uint32_t EEI62:1;
+                uint32_t EEI61:1;
+                uint32_t EEI60:1;
+                uint32_t EEI59:1;
+                uint32_t EEI58:1;
+                uint32_t EEI57:1;
+                uint32_t EEI56:1;
+                uint32_t EEI55:1;
+                uint32_t EEI54:1;
+                uint32_t EEI53:1;
+                uint32_t EEI52:1;
+                uint32_t EEI51:1;
+                uint32_t EEI50:1;
+                uint32_t EEI49:1;
+                uint32_t EEI48:1;
+                uint32_t EEI47:1;
+                uint32_t EEI46:1;
+                uint32_t EEI45:1;
+                uint32_t EEI44:1;
+                uint32_t EEI43:1;
+                uint32_t EEI42:1;
+                uint32_t EEI41:1;
+                uint32_t EEI40:1;
+                uint32_t EEI39:1;
+                uint32_t EEI38:1;
+                uint32_t EEI37:1;
+                uint32_t EEI36:1;
+                uint32_t EEI35:1;
+                uint32_t EEI34:1;
+                uint32_t EEI33:1;
+                uint32_t EEI32:1;
+            } B;
+        } EEIRH;                /* DMA Enable Error Interrupt Register High */
+        union {
+            uint32_t R;
+            struct {
+                uint32_t EEI31:1;
+                uint32_t EEI30:1;
+                uint32_t EEI29:1;
+                uint32_t EEI28:1;
+                uint32_t EEI27:1;
+                uint32_t EEI26:1;
+                uint32_t EEI25:1;
+                uint32_t EEI24:1;
+                uint32_t EEI23:1;
+                uint32_t EEI22:1;
+                uint32_t EEI21:1;
+                uint32_t EEI20:1;
+                uint32_t EEI19:1;
+                uint32_t EEI18:1;
+                uint32_t EEI17:1;
+                uint32_t EEI16:1;
+                uint32_t EEI15:1;
+                uint32_t EEI14:1;
+                uint32_t EEI13:1;
+                uint32_t EEI12:1;
+                uint32_t EEI11:1;
+                uint32_t EEI10:1;
+                uint32_t EEI09:1;
+                uint32_t EEI08:1;
+                uint32_t EEI07:1;
+                uint32_t EEI06:1;
+                uint32_t EEI05:1;
+                uint32_t EEI04:1;
+                uint32_t EEI03:1;
+                uint32_t EEI02:1;
+                uint32_t EEI01:1;
+                uint32_t EEI00:1;
+            } B;
+        } EEIRL;                /* DMA Enable Error Interrupt Register Low */
+        union {                /* DMA Set Enable Request Register */
+            uint8_t R;
+            struct {
+                uint8_t NOP:1;
+                uint8_t SERQ:7;
+            } B;
+        } SERQR;
+        union {                /* DMA Clear Enable Request Register */
+            uint8_t R;
+            struct {
+                uint8_t NOP:1;
+                uint8_t CERQ:7;
+            } B;
+        } CERQR;
+        union {                /* DMA Set Enable Error Interrupt Register */
+            uint8_t R;
+            struct {
+                uint8_t NOP:1;
+                uint8_t SEEI:7;
+            } B;
+        } SEEIR;
+        union {                /* DMA Clear Enable Error Interrupt Register */
+            uint8_t R;
+            struct {
+                uint8_t NOP:1;
+                uint8_t CEEI:7;
+            } B;
+        } CEEIR;
+        union {                /* DMA Clear Interrupt Request Register */
+            uint8_t R;
+            struct {
+                uint8_t NOP:1;
+                uint8_t CINT:7;
+            } B;
+        } CIRQR;
+        union {                  /* DMA Clear error Register */
+            uint8_t R;
+            struct {
+                uint8_t NOP:1;
+                uint8_t CERR:7;
+            } B;
+        } CER;
+        union {                 /* Set Start Bit Register */
+            uint8_t R;
+            struct {
+                uint8_t NOP:1;
+                uint8_t SSB:7;
+            } B;
+        } SSBR;
+        union {                /* Clear Done Status Bit Register */
+            uint8_t R;
+            struct {
+                uint8_t NOP:1;
+                uint8_t CDSB:7;
+            } B;
+        } CDSBR;
+        union {
+            uint32_t R;
+            struct {
+                uint32_t INT63:1;
+                uint32_t INT62:1;
+                uint32_t INT61:1;
+                uint32_t INT60:1;
+                uint32_t INT59:1;
+                uint32_t INT58:1;
+                uint32_t INT57:1;
+                uint32_t INT56:1;
+                uint32_t INT55:1;
+                uint32_t INT54:1;
+                uint32_t INT53:1;
+                uint32_t INT52:1;
+                uint32_t INT51:1;
+                uint32_t INT50:1;
+                uint32_t INT49:1;
+                uint32_t INT48:1;
+                uint32_t INT47:1;
+                uint32_t INT46:1;
+                uint32_t INT45:1;
+                uint32_t INT44:1;
+                uint32_t INT43:1;
+                uint32_t INT42:1;
+                uint32_t INT41:1;
+                uint32_t INT40:1;
+                uint32_t INT39:1;
+                uint32_t INT38:1;
+                uint32_t INT37:1;
+                uint32_t INT36:1;
+                uint32_t INT35:1;
+                uint32_t INT34:1;
+                uint32_t INT33:1;
+                uint32_t INT32:1;
+            } B;
+        } IRQRH;                /* DMA Interrupt Request High */
+        union {
+            uint32_t R;
+            struct {
+                uint32_t INT31:1;
+                uint32_t INT30:1;
+                uint32_t INT29:1;
+                uint32_t INT28:1;
+                uint32_t INT27:1;
+                uint32_t INT26:1;
+                uint32_t INT25:1;
+                uint32_t INT24:1;
+                uint32_t INT23:1;
+                uint32_t INT22:1;
+                uint32_t INT21:1;
+                uint32_t INT20:1;
+                uint32_t INT19:1;
+                uint32_t INT18:1;
+                uint32_t INT17:1;
+                uint32_t INT16:1;
+                uint32_t INT15:1;
+                uint32_t INT14:1;
+                uint32_t INT13:1;
+                uint32_t INT12:1;
+                uint32_t INT11:1;
+                uint32_t INT10:1;
+                uint32_t INT09:1;
+                uint32_t INT08:1;
+                uint32_t INT07:1;
+                uint32_t INT06:1;
+                uint32_t INT05:1;
+                uint32_t INT04:1;
+                uint32_t INT03:1;
+                uint32_t INT02:1;
+                uint32_t INT01:1;
+                uint32_t INT00:1;
+            } B;
+        } IRQRL;                /* DMA Interrupt Request Low */
+        union {
+            uint32_t R;
+            struct {
+                uint32_t ERR63:1;
+                uint32_t ERR62:1;
+                uint32_t ERR61:1;
+                uint32_t ERR60:1;
+                uint32_t ERR59:1;
+                uint32_t ERR58:1;
+                uint32_t ERR57:1;
+                uint32_t ERR56:1;
+                uint32_t ERR55:1;
+                uint32_t ERR54:1;
+                uint32_t ERR53:1;
+                uint32_t ERR52:1;
+                uint32_t ERR51:1;
+                uint32_t ERR50:1;
+                uint32_t ERR49:1;
+                uint32_t ERR48:1;
+                uint32_t ERR47:1;
+                uint32_t ERR46:1;
+                uint32_t ERR45:1;
+                uint32_t ERR44:1;
+                uint32_t ERR43:1;
+                uint32_t ERR42:1;
+                uint32_t ERR41:1;
+                uint32_t ERR40:1;
+                uint32_t ERR39:1;
+                uint32_t ERR38:1;
+                uint32_t ERR37:1;
+                uint32_t ERR36:1;
+                uint32_t ERR35:1;
+                uint32_t ERR34:1;
+                uint32_t ERR33:1;
+                uint32_t ERR32:1;
+            } B;
+        } ERH;                  /* DMA Error High */
+        union {
+            uint32_t R;
+            struct {
+                uint32_t ERR31:1;
+                uint32_t ERR30:1;
+                uint32_t ERR29:1;
+                uint32_t ERR28:1;
+                uint32_t ERR27:1;
+                uint32_t ERR26:1;
+                uint32_t ERR25:1;
+                uint32_t ERR24:1;
+                uint32_t ERR23:1;
+                uint32_t ERR22:1;
+                uint32_t ERR21:1;
+                uint32_t ERR20:1;
+                uint32_t ERR19:1;
+                uint32_t ERR18:1;
+                uint32_t ERR17:1;
+                uint32_t ERR16:1;
+                uint32_t ERR15:1;
+                uint32_t ERR14:1;
+                uint32_t ERR13:1;
+                uint32_t ERR12:1;
+                uint32_t ERR11:1;
+                uint32_t ERR10:1;
+                uint32_t ERR09:1;
+                uint32_t ERR08:1;
+                uint32_t ERR07:1;
+                uint32_t ERR06:1;
+                uint32_t ERR05:1;
+                uint32_t ERR04:1;
+                uint32_t ERR03:1;
+                uint32_t ERR02:1;
+                uint32_t ERR01:1;
+                uint32_t ERR00:1;
+            } B;
+        } ERL;                  /* DMA Error Low */
+        union {                  /* hardware request status high */
+            uint32_t R;
+            struct {
+                uint32_t HRS63:1;
+                uint32_t HRS62:1;
+                uint32_t HRS61:1;
+                uint32_t HRS60:1;
+                uint32_t HRS59:1;
+                uint32_t HRS58:1;
+                uint32_t HRS57:1;
+                uint32_t HRS56:1;
+                uint32_t HRS55:1;
+                uint32_t HRS54:1;
+                uint32_t HRS53:1;
+                uint32_t HRS52:1;
+                uint32_t HRS51:1;
+                uint32_t HRS50:1;
+                uint32_t HRS49:1;
+                uint32_t HRS48:1;
+                uint32_t HRS47:1;
+                uint32_t HRS46:1;
+                uint32_t HRS45:1;
+                uint32_t HRS44:1;
+                uint32_t HRS43:1;
+                uint32_t HRS42:1;
+                uint32_t HRS41:1;
+                uint32_t HRS40:1;
+                uint32_t HRS39:1;
+                uint32_t HRS38:1;
+                uint32_t HRS37:1;
+                uint32_t HRS36:1;
+                uint32_t HRS35:1;
+                uint32_t HRS34:1;
+                uint32_t HRS33:1;
+                uint32_t HRS32:1;
+            } B;
+        } HRSH;
+        union {                  /* hardware request status low */
+            uint32_t R;
+            struct {
+                uint32_t HRS31:1;
+                uint32_t HRS30:1;
+                uint32_t HRS29:1;
+                uint32_t HRS28:1;
+                uint32_t HRS27:1;
+                uint32_t HRS26:1;
+                uint32_t HRS25:1;
+                uint32_t HRS24:1;
+                uint32_t HRS23:1;
+                uint32_t HRS22:1;
+                uint32_t HRS21:1;
+                uint32_t HRS20:1;
+                uint32_t HRS19:1;
+                uint32_t HRS18:1;
+                uint32_t HRS17:1;
+                uint32_t HRS16:1;
+                uint32_t HRS15:1;
+                uint32_t HRS14:1;
+                uint32_t HRS13:1;
+                uint32_t HRS12:1;
+                uint32_t HRS11:1;
+                uint32_t HRS10:1;
+                uint32_t HRS09:1;
+                uint32_t HRS08:1;
+                uint32_t HRS07:1;
+                uint32_t HRS06:1;
+                uint32_t HRS05:1;
+                uint32_t HRS04:1;
+                uint32_t HRS03:1;
+                uint32_t HRS02:1;
+                uint32_t HRS01:1;
+                uint32_t HRS00:1;
+            } B;
+        } HRSL;
+        uint32_t eDMA_reserved0038[50];  /* 0x0038-0x00FF */
+#else
+        uint32_t edma_reserved1[52];
+#endif
+        union {
+            uint8_t R;
+            struct {
+                uint8_t ECP:1;
+                uint8_t DPA:1;
+#else
+                  uint8_t:1;
+#endif
+                uint8_t GRPPRI:2;
+                uint8_t CHPRI:4;
+            } B;
+        } CPR[64];
+        uint32_t edma_reserved2[944];
+/*       DMA2 Transfer Control Descriptor                                   */
+        struct tcd_t {
+            uint32_t SADDR;    /* source address */
+            /* Source and destination fields */
+            union tcd_SDF_tag {
+                uint32_t R;
+                struct {
+                    uint16_t SMOD:5;   /* source address modulo */
+                    uint16_t SSIZE:3;  /* source transfer size */
+                    uint16_t DMOD:5;   /* destination address modulo */
+                    uint16_t DSIZE:3;  /* destination transfer size */
+                    int16_t SOFF;      /* signed source address offset */
+                } B;
+            } SDF;
+            uint32_t NBYTES;   /* inner (“minor”) byte count */
+            int32_t SLAST;     /* last destination address adjustment, or
+                                   scatter/gather address (if e_sg = 1) */
+            uint32_t DADDR;    /* destination address */
+            /* CITER and destination fields */
+            union tcd_CDF_tag {
+                uint32_t R;
+                struct {
+                    uint16_t CITERE_LINK:1;
+                    uint16_t CITER:15;
+                    int16_t DOFF;      /* signed destination address offset */
+                } B;
+                struct {
+		    uint16_t CITERLINKCH:6;
+		    uint16_t CITER:9;
+                    int16_t DOFF;
+                } B_ALT;
+                struct {
+                    uint16_t CITER;
+                    int16_t DOFF;
+                } B_NOLINK;
+            } CDF;
+            int32_t DLAST_SGA;
+            /* BITER and misc fields */
+            union tcd_BMF_tag {
+                uint32_t R;
+                struct {
+                    uint32_t BITERE_LINK:1;    /* beginning ("major") iteration count */
+                    uint32_t BITER:15;
+                    uint32_t BWC:2;    /* bandwidth control */
+                    uint32_t MAJORLINKCH:6;    /* enable channel-to-channel link */
+                    uint32_t DONE:1;   /* channel done */
+                    uint32_t ACTIVE:1; /* channel active */
+                    uint32_t MAJORE_LINK:1;    /* enable channel-to-channel link */
+                    uint32_t E_SG:1;   /* enable scatter/gather descriptor */
+                    uint32_t D_REQ:1;  /* disable ipd_req when done */
+                    uint32_t INT_HALF:1;       /* interrupt on citer = (biter >> 1) */
+                    uint32_t INT_MAJ:1;        /* interrupt on major loop completion */
+                    uint32_t START:1;  /* explicit channel start */
+                } B;
+                struct {
+                    uint32_t BITERLINKCH:6;
+                    uint32_t BITER:9;
+                    uint32_t BWC:2;
+                    uint32_t DONE:1;
+                    uint32_t E_SG:1;
+                    uint32_t D_REQ:1;
+                    uint32_t START:1;
+                } B_ALT;
+                struct {
+                    uint16_t BITER;
+                    uint16_t BWC:2;
+                    uint16_t MAJORLINKCH:6;
+                    uint16_t DONE:1;
+                    uint16_t ACTIVE:1;
+                    uint16_t MAJORE_LINK:1;
+                    uint16_t E_SG:1;
+                    uint16_t D_REQ:1;
+                    uint16_t INT_HALF:1;
+                    uint16_t INT_MAJ:1;
+                    uint16_t START:1;
+                } B_NOLINK;
+            } BMF;
+        } TCD[64];              /* transfer_control_descriptor */
+#ifndef  __cplusplus
+    static const struct tcd_t EDMA_TCD_DEFAULT = {
+        .SADDR = 0,
+        .SDF = { .R = 0 },
+        .NBYTES = 0,
+        .SLAST = 0,
+        .DADDR = 0,
+        .CDF = { .R = 0 },
+        .DLAST_SGA = 0,
+        .BMF = { .R = 0 }
+#define EDMA_TCD_BITER_MASK 0x7fff
+#define EDMA_TCD_BITER_SIZE (EDMA_TCD_BITER_MASK + 1)
+#define EDMA_TCD_BITER_LINKED_MASK 0x1ff
+#define EDMA_TCD_BITER_LINKED_SIZE (EDMA_TCD_BITER_LINKED_MASK + 1)
+#define EDMA_TCD_LINK_AND_BITER(link, biter) \
+  (((link) << 9) + ((biter) & EDMA_TCD_BITER_LINKED_MASK))
+#ifdef  __cplusplus
+#endif /* LIBCPU_POWERPC_MPC55XX_REGS_EDMA_H */
diff --git a/bsps/shared/dev/dma/fsl-edma.c b/bsps/shared/dev/dma/fsl-edma.c
index 0000000000..c34624ed10
--- /dev/null
+++ b/bsps/shared/dev/dma/fsl-edma.c
@@ -0,0 +1,329 @@
+ * @file
+ *  Dornierstr. 4
+ *  82178 Puchheim
+ *  Germany
+#include <mpc55xx/edma.h>
+#include <mpc55xx/mpc55xx.h>
+#include <assert.h>
+#include <bsp.h>
+#include <bsp/fatal.h>
+#include <bsp/irq.h>
+#define EDMA_CHANNELS_PER_GROUP 32U
+#define EDMA_GROUP_COUNT ((EDMA_CHANNEL_COUNT + 31U) / 32U)
+#define EDMA_GROUP_INDEX(channel) ((channel) / EDMA_CHANNELS_PER_GROUP)
+#define EDMA_GROUP_BIT(channel) (1U << ((channel) % EDMA_CHANNELS_PER_GROUP))
+#define EDMA_MODULE_INDEX(channel) ((channel) / EDMA_CHANNELS_PER_MODULE)
+static uint32_t edma_channel_occupation [EDMA_GROUP_COUNT];
+static RTEMS_CHAIN_DEFINE_EMPTY(edma_channel_chain);
+static unsigned edma_channel_index_of_tcd(volatile struct tcd_t *edma_tcd)
+  return channel;
+  return channel + (&EDMA_A == edma ? 0 : EDMA_CHANNELS_PER_MODULE);
+#else
+#endif
+static volatile struct EDMA_tag *edma_get_regs_by_module(unsigned module)
+  return &EDMA;
+  return module == 0 ? &EDMA_A : &EDMA_B;
+#else
+#endif
+static uint32_t edma_bit_array_set(unsigned channel, uint32_t *bit_array)
+  unsigned array = channel / 32;
+  uint32_t bit = 1U << (channel % 32);
+  uint32_t previous = bit_array [array];
+  bit_array [array] = previous | bit;
+  return previous;
+static uint32_t edma_bit_array_clear(unsigned channel, uint32_t *bit_array)
+  bit_array [array] = previous & ~bit;
+  return previous;
+static void edma_interrupt_handler(void *arg)
+  edma_channel_context *ctx = arg;
+  mpc55xx_edma_clear_interrupts(ctx->edma_tcd);
+  (*ctx->done)(ctx, 0);
+static void edma_interrupt_error_handler(void *arg)
+  rtems_chain_control *chain = &edma_channel_chain;
+  rtems_chain_node *node = rtems_chain_first(chain);
+  uint32_t error_channels [] = {
+#if EDMA_GROUP_COUNT >= 1
+    EDMA.ERL.R
+#endif
+#if EDMA_GROUP_COUNT >= 2
+    , EDMA.ERH.R
+#endif
+#if EDMA_GROUP_COUNT >= 3
+    , EDMA_B.ERL.R
+#endif
+  uint32_t error_status [] = {
+    EDMA.ESR.R
+#endif
+    , EDMA_B.ESR.R
+#endif
+  EDMA.ERL.R = error_channels [0];
+#endif
+  EDMA.ERH.R = error_channels [1];
+#endif
+  EDMA_B.ERL.R = error_channels [2];
+#endif
+  while (!rtems_chain_is_tail(chain, node)) {
+    edma_channel_context *ctx = (edma_channel_context *) node;
+    unsigned channel_index = edma_channel_index_of_tcd(ctx->edma_tcd);
+    unsigned group_index = EDMA_GROUP_INDEX(channel_index);
+    unsigned group_bit = EDMA_GROUP_BIT(channel_index);
+    if ((error_channels [group_index] & group_bit) != 0) {
+      unsigned module_index = EDMA_MODULE_INDEX(channel_index);
+      (*ctx->done)(ctx, error_status [module_index]);
+    node = rtems_chain_next(node);
+  rtems_status_code sc = RTEMS_SUCCESSFUL;
+  unsigned channel_remaining = EDMA_CHANNEL_COUNT;
+  unsigned module = 0;
+  unsigned group = 0;
+  for (module = 0; module < EDMA_MODULE_COUNT; ++module) {
+    volatile struct EDMA_tag *edma = edma_get_regs_by_module(module);
+    unsigned channel_count = channel_remaining < EDMA_CHANNELS_PER_MODULE ?
+      channel_remaining : EDMA_CHANNELS_PER_MODULE;
+    unsigned channel = 0;
+    channel_remaining -= channel_count;
+    /* Disable requests */
+    edma->CERQR.B.CERQ = 0x40;
+    /* Arbitration mode: group round robin, channel fixed */
+    edma->CR.B.ERGA = 1;
+    edma->CR.B.ERCA = 0;
+    for (channel = 0; channel < channel_count; ++channel) {
+      volatile struct tcd_t *tcd = &edma->TCD [channel];
+      edma->CPR [channel].R = 0x80U | (channel & 0xfU);
+      /* Initialize TCD, stop channel first */
+      tcd->BMF.R = 0;
+      tcd->SADDR = 0;
+      tcd->SDF.R = 0;
+      tcd->NBYTES = 0;
+      tcd->SLAST = 0;
+      tcd->DADDR = 0;
+      tcd->CDF.R = 0;
+      tcd->DLAST_SGA = 0;
+    /* Clear interrupt requests */
+    edma->CIRQR.B.CINT = 0x40;
+    edma->CER.B.CERR = 0x40;
+  for (group = 0; group < EDMA_GROUP_COUNT; ++group) {
+    sc = mpc55xx_interrupt_handler_install(
+      MPC55XX_IRQ_EDMA_ERROR(group),
+      "eDMA Error",
+      RTEMS_INTERRUPT_UNIQUE,
+      MPC55XX_INTC_DEFAULT_PRIORITY,
+      edma_interrupt_error_handler,
+      NULL
+    if (sc != RTEMS_SUCCESSFUL) {
+      bsp_fatal(MPC55XX_FATAL_EDMA_IRQ_INSTALL);
+  unsigned channel_index = edma_channel_index_of_tcd(edma_tcd);
+  rtems_interrupt_level level;
+  uint32_t channel_occupation;
+  rtems_interrupt_disable(level);
+  channel_occupation = edma_bit_array_set(
+    channel_index,
+    &edma_channel_occupation [0]
+  rtems_interrupt_enable(level);
+  if ((channel_occupation & EDMA_GROUP_BIT(channel_index)) != 0) {
+    sc = RTEMS_RESOURCE_IN_USE;
+  return sc;
+  edma_bit_array_clear(channel_index, &edma_channel_occupation [0]);
+  mpc55xx_edma_disable_hardware_requests(edma_tcd);
+  mpc55xx_edma_disable_error_interrupts(edma_tcd);
+  rtems_status_code sc = mpc55xx_edma_obtain_channel_by_tcd(ctx->edma_tcd);
+  if (sc == RTEMS_SUCCESSFUL) {
+      MPC55XX_IRQ_EDMA(channel_index),
+      "eDMA Channel",
+      RTEMS_INTERRUPT_SHARED,
+      irq_priority,
+      edma_interrupt_handler,
+      ctx
+      rtems_chain_prepend(&edma_channel_chain, &ctx->node);
+      mpc55xx_edma_enable_error_interrupts(ctx->edma_tcd);
+    } else {
+      mpc55xx_edma_release_channel_by_tcd(ctx->edma_tcd);
+      sc = RTEMS_IO_ERROR;
+  return sc;
+  rtems_chain_extract(&ctx->node);
+  sc = rtems_interrupt_handler_remove(
+    ctx
+    bsp_fatal(MPC55XX_FATAL_EDMA_IRQ_REMOVE);
+  /* Clear DONE flag */
+  edma_tcd->BMF.R = 0;
+  edma_tcd->SADDR = source_tcd->SADDR;
+  edma_tcd->SDF.R = source_tcd->SDF.R;
+  edma_tcd->NBYTES = source_tcd->NBYTES;
+  edma_tcd->SLAST = source_tcd->SLAST;
+  edma_tcd->DADDR = source_tcd->DADDR;
+  edma_tcd->CDF.R = source_tcd->CDF.R;
+  edma_tcd->DLAST_SGA = source_tcd->DLAST_SGA;
+  edma_tcd->BMF.R = source_tcd->BMF.R;
+  mpc55xx_edma_copy(edma_tcd, source_tcd);
+  mpc55xx_edma_enable_hardware_requests(edma_tcd);
+  edma_tcd->DLAST_SGA = (int32_t) source_tcd;
+  edma_tcd->BMF.B.E_SG = 1;
+  if (!edma_tcd->BMF.B.E_SG) {
2.26.2
