[PATCH v3 1/1] tester: Add yaml format to the supported report formats
Cláudio Maia
clrrm at isep.ipp.pt
Tue Dec 15 23:36:14 UTC 2020
Hello Chris,
Did you have a chance to look at the updated version of this patch?
Regards,
Cláudio
On 08/12/20 15:40, clrrm at isep.ipp.pt wrote:
> From: Cláudio Maia <clrrm at isep.ipp.pt>
> tester/rt/test.py | 116 +++++++++++++++++++++++++++++++++++++++++++++-
> 1 file changed, 114 insertions(+), 2 deletions(-)
> diff --git a/tester/rt/test.py b/tester/rt/test.py
> index 9b157e9..66f1756 100644
> --- a/tester/rt/test.py
> +++ b/tester/rt/test.py
> @@ -339,9 +339,115 @@ def generate_junit_report(args, reports, start_time, end_time,
> with open(junit_file, 'w') as f:
> TestSuite.to_file(f, [ts], prettyprint = True)
> +def generate_yaml_report(args, reports, start_time, end_time,
> + total, yaml_file):
> + """ Generates a YAML file containing information about the test run,
> + including all test outputs """
> + import yaml
> + def format_output(output_list):
> + return "\n".join(output_list).replace("] ", '').replace('=> ', '')
> + yaml_log = {}
> + yaml_log['command-line'] = args
> + yaml_log['host'] = host.label(mode='all')
> + yaml_log['python'] = sys.version.replace('\n', '')
> + yaml_log['summary'] = {}
> + yaml_log['summary']['passed-count'] = reports.passed
> + yaml_log['summary']['failed-count'] = reports.failed
> + yaml_log['summary']['user-input-count'] = reports.user_input
> + yaml_log['summary']['expected-fail-count'] = reports.expected_fail
> + yaml_log['summary']['indeterminate-count'] = reports.indeterminate
> + yaml_log['summary']['benchmark-count'] = reports.benchmark
> + yaml_log['summary']['timeout-count'] = reports.timeouts
> + yaml_log['summary']['test-too-long_count'] = reports.test_too_long
> + yaml_log['summary']['invalid-count'] = reports.invalids
> + yaml_log['summary']['wrong-version-count'] = reports.wrong_version
> + yaml_log['summary']['wrong-build-count'] = reports.wrong_build
> + yaml_log['summary']['wrong-tools-count'] = reports.wrong_tools
> + yaml_log['summary']['total-count'] = reports.total
> + time_delta = end_time - start_time
> + yaml_log['summary']['average-test-time'] = str(time_delta / total)
> + yaml_log['summary']['testing-time'] = str(time_delta)
> + result_types = [
> + 'failed', 'user-input', 'expected-fail', 'indeterminate',
> + 'benchmark', 'timeout', 'test-too-long', 'invalid', 'wrong-version',
> + 'wrong-build', 'wrong-tools'
> + for result_type in result_types:
> + yaml_log['summary'][result_type] = []
> + result_element = {}
> + yaml_log['outputs'] = []
> + # process output of each test
> + for exe_name in reports.results:
> + test_parts = exe_name.split("/")
> + test_name = test_parts[-1]
> + result_element['executable-name'] = test_name
> + result_element['executable-sha512'] = get_hash512(exe_name)
> + result_element['execution-start'] = reports.results[exe_name]['start'].isoformat()
> + result_element['execution-end'] = reports.results[exe_name]['end'].isoformat()
> + date_diff = reports.results[exe_name]['end'] - reports.results[exe_name]['start']
> + result_element['execution-duration'] = str(date_diff)
> + result_element['execution-result'] = reports.results[exe_name]['result']
> + result_element['bsp'] = reports.results[exe_name]['bsp']
> + result_element['bsp-arch'] = reports.results[exe_name]['bsp_arch']
> + result_output = reports.results[exe_name]['output']
> + dbg_output = []
> + test_output = []
> + idxs_output = [] # store indices of given substrings
> + for elem in result_output:
> + if '=> ' in elem:
> + idxs_output.append(result_output.index(elem))
> + if '*** END' in elem:
> + if len(idxs_output) == 3: # test executed and has result
> + dbg_output = result_output[idxs_output[0]:idxs_output[1]]
> + dbg_output.append("=== Executed Test ===")
> + dbg_output = dbg_output + result_output[idxs_output[2]+1:len(result_output)]
> + test_output = result_output[idxs_output[1]:idxs_output[2]+1]
> + else:
> + result_element['debugger-output'] = format_output(dbg_output)
> + result_element['console-output'] = format_output(test_output)
> + yaml_log['outputs'].append(result_element)
> + result_type = reports.results[exe_name]['result']
> + # map "fatal-error" on to "failed"
> + if result_type == "fatal-error":
> + result_type = "failed"
> + if result_type != 'passed':
> + yaml_log['summary'][result_type].append(test_name)
> + with open(yaml_file, 'w') as outfile:
> + yaml.dump(yaml_log, outfile, default_flow_style=False, allow_unicode=True)
> +def get_hash512(exe):
> + """ returns SHA512 hash string of a given binary file passed as argument """
> + import hashlib
> + hash = hashlib.sha512()
> + with open(exe, "rb") as f:
> + for byte_block in iter(lambda: f.read(4096), b""):
> + hash.update(byte_block)
> + return hash.hexdigest()
> report_formatters = {
> 'json': generate_json_report,
> - 'junit': generate_junit_report
> + 'junit': generate_junit_report,
> + 'yaml': generate_yaml_report
> @@ -352,6 +458,12 @@ def check_report_formats(report_formats, report_location):
> if report_format not in report_formatters:
> raise error.general('invalid RTEMS report formatter: %s'
> % report_format)
> + if report_format == 'yaml':
> + try:
> + import yaml
> + except ImportError:
> + raise error.general('Please install PyYAML module. HINT: You can '
> + 'use pip to install it!')
> def run(args):
> @@ -365,7 +477,7 @@ def run(args):
> '--rtems-bsp': 'The RTEMS BSP to run the test on',
> '--user-config': 'Path to your local user configuration INI file',
> '--report-path': 'Report output base path (file extension will be added)',
> - '--report-format': 'Formats in which to report test results in addition to txt: json',
> + '--report-format': 'Formats in which to report test results in addition to txt: json, yaml',
> '--log-mode': 'Reporting modes, failures (default),all,none',
> '--list-bsps': 'List the supported BSPs',
> '--debug-trace': 'Debug trace based on specific flags (console,gdb,output,cov)',
